171.64.122.70 - Missing credits
Darken1
Post by Darken1 »
Hello friends :)
I had finish about 10 1888 point WU's, but i didnt get credit for them.
Log file looks good they all finish, and were sent successfully.
Any ideas, help would be appreciated.
Thanks.
[21:43:05] Project: 5913 (Run 7, Clone 940, Gen 34)
[21:43:05]
[21:43:05] Assembly optimizations on if available.
[21:43:05] Entering M.D.
[21:43:11] Tpr hash work/wudata_05.tpr:  2300254034 1004834272 987482302 123117004 3427921789
[21:43:12] Working on Protein
[21:43:12] Client config found, loading data.
[21:43:12] Starting GUI Server
[21:46:09] Completed 1%
[21:49:21] Completed 2%
[21:52:47] Completed 3%
[21:56:05] Completed 4%
[21:59:33] Completed 5%
[22:02:47] Completed 6%
[22:06:07] Completed 7%
[22:09:35] Completed 8%
[22:13:08] Completed 9%
[22:16:29] Completed 10%
Snip
[03:03:46] Completed 94%
[03:07:01] Completed 95%
[03:10:19] Completed 96%
[03:13:32] Completed 97%
[03:16:37] Completed 98%
[03:20:02] Completed 99%
[03:23:26] Completed 100%
[03:23:26]run
[03:23:26] DynamicWrapper: Finished Work Unit: sleep=10000
[03:23:36] Reserved 34452 bytes for xtc file; Cosm status=0
[03:23:36] Allocated 34452 bytes for xtc file
[03:23:36] - Reading up to 34452 from "work/wudata_05.xtc": Read 34452
[03:23:36] Read 34452 bytes from xtc file; available packet space=786396012
[03:23:36] xtc file hash check passed.
[03:23:36] Reserved 23472 23472 786396012 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[03:23:36] Allocated 23472 bytes for arc file
[03:23:36] - Reading up to 23472 from "work/wudata_05.trr": Read 23472
[03:23:36] Read 23472 bytes from arc file; available packet space=786372540
[03:23:36] trr file hash check passed.
[03:23:36] Allocated 560 bytes for edr file
[03:23:36] Read bedfile
[03:23:36] edr file hash check passed.
[03:23:36] Allocated 10432 bytes for logfile
[03:23:36] Read logfile
[03:23:36] GuardedRun: success in DynamicWrapper
[03:23:36] GuardedRun: done
[03:23:36] Run: GuardedRun completed.
[03:23:41] - Writing 69428 bytes of core data to disk...
[03:23:41] Done: 68916 -> 63228 (compressed to 91.7 percent)
[03:23:41]   ... Done.
[03:23:41] - Shutting down core
[03:23:41]
[03:23:41] Folding@home Core Shutdown: FINISHED_UNIT
[03:23:44] CoreStatus = 64 (100)
[03:23:44] Sending work to server
[03:23:44] Project: 5913 (Run 7, Clone 940, Gen 34)
[03:23:44] - Read packet limit of 540015616... Set to 524286976.
[03:23:44] + Attempting to send results [March 4 03:23:44 UTC]
[03:23:47] + Results successfully sent
[03:23:47] Thank you for your contribution to Folding@Home.
[03:23:47] + Number of Units Completed: 857
ChelseaOilman
Re: No credit for 1888 point WU's
Post by ChelseaOilman »
Welcome to the forum Darken1.
You got credit for the WU you posted about.
Hi Darken1 (team 171785),
Your WU (P5913 R7 C940 G34) was added to the stats database on 2010-03-03 19:02:47 for 1888 points of credit.
And looking at your stats at Kakao Stats it looks like you got credit for others.
http://kakaostats.com/up.php?u=1575361
JayxG
Post by JayxG »
Hi :) ,
have here a similar problem. The WU has been successfully uploaded, but does not appear in the statistics. The server (171.64.122.70) seems to be ok ...
[07:59:32] Project: 5907 (Run 2, Clone 12, Gen 19)
[07:59:32]
[07:59:34] Assembly optimizations on if available.
[07:59:35] Entering M.D.
[07:59:41] Tpr hash work/wudata_08.tpr:  4091981036 848281750 2259385697 1901766003 4078660998
[08:00:31] Working on Protein
[08:00:33] Client config found, loading data.
[08:00:34] Starting GUI Server
[08:06:46] Completed 1%
[08:13:30] Completed 2%
[08:20:11] Completed 3%
[08:26:53] Completed 4%
[08:33:44] Completed 5%
[08:40:28] Completed 6%
[08:47:13] Completed 7%
[08:53:57] Completed 8%
[09:00:40] Completed 9%
[09:07:31] Completed 10%
[09:14:16] Completed 11%
[09:20:54] Completed 12%
[09:27:32] Completed 13%
[09:34:12] Completed 14%
[09:41:03] Completed 15%
[09:47:43] Completed 16%
[09:54:28] Completed 17%
[10:01:10] Completed 18%
[10:07:54] Completed 19%
[10:14:44] Completed 20%
[17:45:43] Completed 87%
[17:52:28] Completed 88%
[17:59:10] Completed 89%
[18:05:59] Completed 90%
[18:12:42] Completed 91%
[18:19:26] Completed 92%
[18:26:08] Completed 93%
[18:32:52] Completed 94%
[18:39:44] Completed 95%
[18:46:28] Completed 96%
[18:53:12] Completed 97%
[18:59:55] Completed 98%
[19:06:35] Completed 99%
[19:13:27] Completed 100%
[19:13:27] Successful run
[19:13:27] DynamicWrapper: Finished Work Unit: sleep=10000
[19:13:37] Reserved 33892 bytes for xtc file; Cosm status=0
[19:13:37] Allocated 33892 bytes for xtc file
[19:13:37] - Reading up to 33892 from "work/wudata_08.xtc": Read 33892
[19:13:37] Read 33892 bytes from xtc file; available packet space=786396572
[19:13:37] xtc file hash check passed.
[19:13:37] Reserved 23472 23472 786396572 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[19:13:37] Allocated 23472 bytes for arc file
[19:13:37] - Reading up to 23472 from "work/wudata_08.trr": Read 23472
[19:13:37] Read 23472 bytes from arc file; available packet space=786373100
[19:13:37] trr file hash check passed.
[19:13:37] Allocated 560 bytes for edr file
[19:13:37] Read bedfile
[19:13:37] edr file hash check passed.
[19:13:37] Allocated 430794 bytes for logfile
[19:13:37] Read logfile
[19:13:37] GuardedRun: success in DynamicWrapper
[19:13:37] GuardedRun: done
[19:13:37] Run: GuardedRun completed.
[19:13:40] - Writing 489230 bytes of core data to disk...
[19:13:41] Done: 488718 -> 67556 (compressed to 13.8 percent)
[19:13:41]   ... Done.
[19:13:41] - Shutting down core
[19:13:41]
[19:13:41] Folding@home Core Shutdown: FINISHED_UNIT
[19:13:43] CoreStatus = 64 (100)
[19:13:43] Unit 8 finished with 92 percent of time to deadline remaining.
[19:13:43] Updated performance fraction: 0.952602
[19:13:43] Sending work to server
[19:13:43] Project: 5907 (Run 2, Clone 12, Gen 19)
[19:13:43] - Read packet limit of 540015616... Set to 524286976.
[19:13:43] + Attempting to send results [March 3 19:13:43 UTC]
[19:13:43] - Reading file work/wuresults_08.dat from core
[19:13:43]   (Read 68068 bytes from disk)
[19:13:43] Connecting to http://171.64.122.70:8080/
[19:13:45] Posted data.
[19:13:45] Initial: 0000; - Uploaded at ~33 kB/s
[19:13:45] - Averaged speed for that direction ~28 kB/s
[19:13:45] + Results successfully sent
[19:13:45] Thank you for your contribution to Folding@Home.
[19:13:45] + Number of Units Completed: 471
[19:13:50] Trying to send all finished work units
[19:13:50] + No unsent completed units remaining.
[19:13:50] - Preparing to get new work unit...
[19:13:50] + Attempting to get work packet
For the following WU´s (P5910), there were no problems, these have already been credited.
Any ideas where could be the problem?
Thanks, JayX
shunter
Post by shunter »
I am having the same problem - 3 out of 7 1,888 point 59xx units completed in last 18 hours have been uploaded successfully but no points credited. The other 4 have been credited and an eighth one is just about to complete. Can someone investigate and explain please?
Rgds
Shunter
Units are 3 of:-
5907 R14 C9 G6; 5909 R7 C73 G4; 5912 R2 C896 G86; 5913 R13 C958 G44;
5907 R14 C43 G7; 5912 R6 C907 G74; 5915 R0 C999 G21
Darken1
Post by Darken1 »
I am missing 16K PPD for the day, I see the Stanford stat page and EOC shows the same amount of points,and kakaostats shows a total of 79,395 for the dayfor 3/3/10 thats not correct.
This is the total from kakao 2,097,356, total from EOC 2,097,356 and Stanford 2097356, all three match but im still about 16K below on my points for 3/3/10.
I average 30K to 32K without the bigadv, here are my EOC numbers for the last six days.
03.03.10 16,493 29
03.02.10 90,723 53
03.01.10 30,208 55
02.28.10 88,029 52
02.27.10 32,568 48
02.26.10 85,805 42
shunter
Post by shunter »
5908 R8 C83 G3 has now completed, uploaded, units completed incremented but no credit given - what's going on please
Rgds
Shunter
Darken1
Post by Darken1 »
Ok i just checked my logs for the 1888's for 3/3/10, is there any way i can check if they were credited?.
Project: 5907 (Run 13, Clone 48, Gen 2)
Project: 5909 (Run 7, Clone 58, Gen 5)
Project: 5909 (Run 3, Clone 74, Gen 5)
Project: 5908 (Run 0, Clone 47, Gen 6)
Project: 5908 (Run 0, Clone 29, Gen 9)
Project: 5908 (Run 1, Clone 21, Gen 7)
Project: 5912 (Run 5, Clone 992, Gen 40)
Project: 5914 (Run 11, Clone 995, Gen 30)
Project: 5915 (Run 5, Clone 981, Gen 30)
Project: 5915 (Run 7, Clone 958, Gen 32)
uncle_fungus
Post by uncle_fungus »
Not credited to you
Not credited to you
Not credited to you
Not credited to you
Not credited to you
Not credited to you
Your WU (P5912 R5 C992 G40) was added to the stats database on 2010-03-03 08:03:06 for 1888 points of credit.
Your WU (P5914 R11 C995 G30) was added to the stats database on 2010-03-02 19:03:09 for 1888 points of credit.
Your WU (P5915 R5 C981 G30) was added to the stats database on 2010-03-02 20:03:10 for 1888 points of credit.
Your WU (P5915 R7 C958 G32) was added to the stats database on 2010-03-02 21:03:01 for 1888 points of credit.
I see a pattern here.
uncle_fungus wrote: 5907 - 5908 Not credited to you
5912 - 5915 was added to the stats database . . .
5907- 5909 are on 171.64.122.70
5910-5915 are on 171.64.65.20
Topic moved to "Issues with a specific server" and title changed.
jkefalas
Re: 171.64.65.20 - Missing credits
Post by jkefalas »
folding name: jkefalas
Unfortunately, I am at work, so I am unable to get to my log, but I am certain that I have folded many 59xx WU's and am currently running ~10k+ points short for my 24hr average.
Fold on!
bollix47
Post by bollix47 »
Isn't 171.64.122.70 the server that's missing credits? If so, then the new title is incorrect.
uncle_fungus
Re: 171.64.122.70 - Missing credits
Indeed. Corrected.
lambdapro
Post by lambdapro »
For computer 1632015, i had a pair of the large WUs completed and results sent, but no credit either. One was to 171.64.122.70 and one was to 171.67.108.11.
19:52:29] Folding@home Core Shutdown: FINISHED_UNIT
[19:52:32] CoreStatus = 64 (100)
[19:52:32] Sending work to server
[19:52:32] Project: 5907 (Run 0, Clone 53, Gen 9)
[19:52:32] - Read packet limit of 540015616... Set to 524286976.
[19:52:32] + Attempting to send results [March 3 19:52:32 UTC]
[19:52:34] + Results successfully sent
[19:52:34] Thank you for your contribution to Folding@Home.
[19:52:34] + Number of Units Completed: 253
[02:41:40] Folding@home Core Shutdown: FINISHED_UNIT
[02:41:42] CoreStatus = 64 (100)
[02:41:42] Sending work to server
[02:41:42] Project: 5908 (Run 14, Clone 62, Gen 5)
[02:41:42] - Read packet limit of 540015616... Set to 524286976.
[02:41:42] + Attempting to send results [March 4 02:41:42 UTC]
[02:41:44] + Results successfully sent
[02:41:44] Thank you for your contribution to Folding@Home.
[02:41:44] + Number of Units Completed: 254
I noticed these because there was a 21 hour gap between points on kakaostats for this computer. Checked the logs and saw that the two large WUs must have been missed.
David
The Pande Group is aware of the problem. There's no ETA for a fix.
lambdapro
Post by lambdapro »
Are the 1888 WUs working right now? Should I stop deleting the 1888s out of the queue when they are assigned?
