bruce wrote:I'm not sure about the bad packet type error. Have you gotten that on each of the 15 download attempts? Do you have a proxy?
Attempts 2, 9, & 15 have had the "bad packet type" message; all the others had ended akin to ...
[04:25:39] Posted data.
[04:25:39] Initial: 0000; - Receiving payload (expected size: 4300928)
[04:26:28] - Downloaded at ~85 kB/s
[04:26:28] - Averaged speed for that direction ~64 kB/s
[04:26:28] + Received work.
[04:26:28] - Attempt #16 to get work failed, and no other work to do.
Waiting before retry.
No proxy being used.
bruce wrote:In your client configuration, do you have Small/Normal/Big set to Big? The News Blog says that there's a shortage of small WUs and I'm not sure there are all that many WUs for classic clients of any size. When the servers have to deal with a lot of clients looking for a few WUs, the assignment servers have to work really hard to try to sort everything out.
Size is set for big (bigpackets=big). The only recent change to the config (have been folding on this VM for months) was to add a passkey after upgrading the folding client on Tuesday of last week, and I know it was still working OK then as it completed a few work packets during the 2nd half of the week. (I usually check each day to make sure things are still running OK, which I definitely did on Wednesday/Thursday/Friday last week as I wanted to make sure the new client was behaving OK prior to installing it on another VM and my main home PC. I upgraded the other VM on Thursday or Friday, and it is still working OK.)
