What is project that refered to small WU
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
i only know that 'small' is <5MB, 'normal' is <10MB, and 'big' is >10MB from setting for acceptable size of work assignment and work result packets. but what is spesific project refered to that?
Folding@Home user since Feb 2009
Re: What is project that refered to small WU
This size apply to the memory requirements and data transfers sizes (both upload and download). If any of these parameter exceed 5 MB, it's a normal WU, and if it exceed 10 MB, it's a big WU.
shiryunaga
so there are not spesific project A is small, project B is normal or project C is Big, if the parameter is data transfers size there are chance that same project will be small/normal/big?
If my memories are correct, p46xx are small projects, p44xx are either small or normal (I don't remember exactly), p24xx are big ...
By definition, all SMP projects are big.
I don't remember the details of all projects ...
shiryunaga
how about "number of atom" project from psummary, can i tell that WU is small/normal/big?
Not precisely ... but if there's a lot of atoms in the WU, there are high chances that it will use more memory.
