5910 (Run 14, Clone 84, Gen 4)
After returning to an EUE'd folding farm I pulled 3 out of 4 of the exact same WU.
Already verified that the GPUs have different machine IDs, but they would have been pulled to the same IP all within the same minute. Is this normal, or is there something wrong with the WU server?
5910 (Run 14, Clone 84, Gen 4) Multiple instances
sswilson
- Hardware configuration: ASUS Crosshair IV Formula / AMD 1090T / 4X2 Gig GSkill Pi PC3-12800 / Corsair TX750W PSU / Sparkle GTX275 Plus / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Enzotech Luna WB / Dell Ultrasharp 2209WA
Gigabyte P35-DQ6 / Q6600 / 2X 1G 1066 Firestix / "Baked" XFX GTX 280 (RIP again :( ) / MSI GTS 450 Cyclone OC /PC P&C 750W Silencer / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Highspeed PC Tech Station / Samsung 931BF / BenQ Q9T4 - Location: Moncton, New Brunswick, Canada
Re: 5910 (Run 14, Clone 84, Gen 4) Multiple instances
Don't worry about it in the case of core 14 projects. The PRCG coding doesn't work quite the same way as for other projects; they're still doing useful work.
sswilson
Shutdown two of the clients, deleted both the queue dat file and the Work folder (checked for old files first), restarted the clients, and they both pulled exactly the same WU again!!!!
What gives? Didn't look like the WU was downloaded again, is the work file no longer saved in the work folder?
sswilson
Will I still get points for the individual projects? These are mediocre PPD in the first place.ihaque wrote:Don't worry about it in the case of core 14 projects. The PRCG coding doesn't work quite the same way as for other projects; they're still doing useful work.
Yes, you'll get points for them. the server knows what files it assigned and which ones are actually assigned.
If you move files from one computer to another or you try to get points that you didn't earn (such as restoring a backup and then uploading the same result a second time) it won't give credit. Just let the clients run and you'll be fine.
