no points awarded
bgd73
no points awarded
Post by bgd73 »
This is not updated on the folding stats page.
[15:16:52] Folding@home Core Shutdown: FINISHED_UNIT
[15:16:54] CoreStatus = 64 (100)
[15:16:54] Sending work to server
[15:16:54] Project: 4755 (Run 0, Clone 525, Gen 7)
[15:16:54] + Attempting to send results [February 17 15:16:54 UTC]
[15:16:59] + Results successfully sent
[15:16:59] Thank you for your contribution to Folding@Home.
[15:16:59] + Number of Units Completed: 3
No errors anywhere written. Is there something I should know?
Zagen30
Re: no points awarded
Post by Zagen30 »
How long ago was it uploaded? It can sometimes take some time between upload and the username being credited, but if it's been more than several hours then it's much more likely that something went wrong.
It's not in the stats DB ... but this project is not on psummary either ...
Can you tell us which server assigned this WU ?
Grandpa_01
Post by Grandpa_01 »
toTOW wrote:It's not in the stats DB ... but this project is not on psummary either ...
My guess is it is a ATI the # is close to some I have had. And the server (171.64.65.103) is not listed on the psumarry.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
bgd73
Post by bgd73 »
[15:16:41] DynamicWrapper: Finished Work Unit: sleep=10000
[15:16:51] Reserved 197756 bytes for xtc file; Cosm status=0
[15:16:51] Allocated 197756 bytes for xtc file
[15:16:51] - Reading up to 197756 from "work/wudata_08.xtc": Read 197756
[15:16:51] Read 197756 bytes from xtc file; available packet space=786232708
[15:16:51] xtc file hash check passed.
[15:16:51] Reserved 30216 30216 786232708 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[15:16:51] Allocated 30216 bytes for arc file
[15:16:51] - Reading up to 30216 from "work/wudata_08.trr": Read 30216
[15:16:51] Read 30216 bytes from arc file; available packet space=786202492
[15:16:51] trr file hash check passed.
[15:16:51] Allocated 560 bytes for edr file
[15:16:51] Read bedfile
[15:16:51] edr file hash check passed.
[15:16:51] Allocated 33310 bytes for logfile
[15:16:51] Read logfile
[15:16:51] GuardedRun: success in DynamicWrapper
[15:16:51] GuardedRun: done
[15:16:51] Run: GuardedRun completed.
[15:16:52] - Writing 262354 bytes of core data to disk...
[15:16:52] Done: 261842 -> 236598 (compressed to 90.3 percent)
[15:16:52]   ... Done.
[15:16:52] - Shutting down core
[15:16:52]
[15:17:03] - Preparing to get new work unit...
[15:17:03] + Attempting to get work packet
[15:17:03] - Connecting to assignment server
[15:17:04] - Successful: assigned to (171.64.65.102).
[15:17:04] + News From Folding@Home: Welcome to Folding@Home
[15:17:04] Loaded queue successfully.
[15:17:05] + Closed connections
[15:17:05]
here is a bigger chunk of log file. Still no points awarded.
There was a rather strange problem which has now been resolved.
Hi bgd73 (team 31574),
Your WU (P4755 R0 C525 G7) was added to the stats database on 2010-02-21 20:13:30 for 477 points of credit.
