Hi Guys, could anyone offer any idea of what I need to do here please
WU commenced [12:38:17] GMT on the 16/2/10
WU Completed [21:45:13] GMT on the 16/2/10
unfortunately its been stuck in the queue since
Time now 10:00 17/2/10 & after seeing my 24 Ave drop from 3,500 / 24 hrs to 2600 through numerous failed prior uploads, I’m now losing patience with F@H & fast.
Thank you, for any assistance
[12:38:17] Project: 5914 (Run 10, Clone 969, Gen 14)
[21:45:13] Folding@home Core Shutdown: FINISHED_UNIT
[21:45:16] + Attempting to send results [February 16 21:45:16 UTC]
[21:45:37] - Couldn't send HTTP request to server
[21:45:37] + Could not connect to Work Server (results)
[21:45:37] (171.64.65.20:8080)
[21:45:37] + Retrying using alternative port
[21:45:58] - Couldn't send HTTP request to server
[21:45:58] + Could not connect to Work Server (results)
[21:45:58] (171.64.65.20:80)
[21:45:58] - Error: Could not transmit unit 07 (completed February 16) to work server.
[21:45:58] Keeping unit 07 in queue.
171.64.65.20
Re: 171.64.65.20
This server is currently down :
171.64.65.20 GPU vspg1 - full DOWN-
*hondo*
- Hardware configuration: Geoforce 250 GTS Active for F@H
4 Core Intel not used at all for F@H - Location: England UK
Re: 171.64.65.20
Thank you for the reply toTOW but not only is the server down, I can't find a trace of 5914
in here
http://fah-web.stanford.edu/psummary.html
in here
Re: 171.64.65.20
If the server has been down for a long time, the psummary script may consider that the projects are no longer active, so it suppress them from the list. They will probably come back on the list as soon as the server comes back online.
VijayPande
- Pande Group Member
Re: 171.64.65.20
One of our boxes (vspg1) which supports 3 servers (vspg1, vsp1v, vspg1v2) went down some time last night (pacific time). It's 7am and so our admins are not in the office yet, but they will restart it once they get in. Luckily, this one looks to be a pretty standard restart issue.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Chair, Biophysics
Stanford University
*hondo*
Re: 171.64.65.20
Phew!! At last, it's gone.
Thank you both for the input
*hondo*
Re: 171.64.65.20
Hello again folks, do you know I've been folding now under a # of different aka's since I guess 2002 & also started my own small but useful team 51078. For whatever reason I seem to have managed to forget how F@H works
For more than 4.5 hours my PC has been attempting to send back to Stanford a finished WU = p5782 "apparently" to the below servers all so far have failed to accept the WU.
I can ping and get returns from each of these servers, I've even tried leaving the software firewall turned off, still with no success.
Will someone please advise before I pull my remaing bit of hair out.
171.67.108.26
171.67.108.21
171.67.108.28
171.67.108.26
171.67.108.21
171.67.108.28
*hondo*
Re: 171.64.65.20
[08:46:16] Assembly optimizations on if available.
[08:46:16] Entering M.D.
[08:46:19] + Results successfully sent
[08:46:19] Thank you for your contribution to Folding@Home.
