Project: 10103 (Run 638, Clone 0, Gen 5)
[Inpact]Terminou
Post by [Inpact]Terminou »
[20:30:00] Project: 10103 (Run 638, Clone 0, Gen 5)
[20:30:00]
[20:30:00] Assembly optimizations on if available.
[20:30:00] Entering M.D.
[20:30:06] Tpr hash work/wudata_05.tpr: 3529118583 2452865290 339078037 2399004577 3437509336
[20:30:06]
[20:30:06] Calling fah_main args: 14 usage=100
[20:30:06]
[20:30:06] Working on p10103_lambda_370K
[20:30:09] Client config found, loading data.
[20:30:09] Starting GUI Server
[20:31:21] Completed 1%
[20:32:33] Completed 2%
[20:33:46] Completed 3%
[20:34:58] Completed 4%
[20:36:10] Completed 5%
[20:37:22] Completed 6%
[20:38:34] Completed 7%
[20:39:46] Completed 8%
[20:40:59] Completed 9%
[20:42:11] Completed 10%
[20:43:23] Completed 11%
[20:44:35] Completed 12%
[20:45:47] Completed 13%
[20:46:59] Completed 14%
[20:48:11] Completed 15%
[20:49:24] Completed 16%
[20:50:36] Completed 17%
[20:51:48] Completed 18%
[20:53:00] Completed 19%
[20:54:12] Completed 20%
[20:55:24] Completed 21%
[20:56:37] Completed 22%
[20:57:49] Completed 23%
[20:59:01] Completed 24%
[21:00:13] Completed 25%
[21:01:25] Completed 26%
[21:02:37] Completed 27%
[21:03:49] Completed 28%
[21:05:02] Completed 29%
[21:06:14] Completed 30%
[21:07:26] Completed 31%
[21:08:38] Completed 32%
[21:09:50] Completed 33%
[21:11:02] Completed 34%
[21:12:14] Completed 35%
[21:13:27] Completed 36%
[21:14:39] Completed 37%
[21:15:51] Completed 38%
[21:17:03] Completed 39%
[21:18:15] Completed 40%
[21:19:27] Completed 41%
[21:20:40] Completed 42%
[21:20:40] mdrun_gpu returned
[21:20:40] Nonzero force sum on GPU
[21:20:40]
[21:20:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:20:42] CoreStatus = 7A (122)
[21:20:42] Sending work to server
[21:20:42] Project: 10103 (Run 638, Clone 0, Gen 5)
[21:20:42] - Read packet limit of 540015616... Set to 524286976.
[21:20:42] - Error: Could not get length of results file work/wuresults_05.dat
[21:20:42] - Error: Could not read unit 05 file. Removing from queue.
[21:20:42] - Preparing to get new work unit...
[21:20:42] + Attempting to get work packet
[21:20:42] - Connecting to assignment server
[21:20:44] - Successful: assigned to (171.64.65.71).
[21:20:44] + News From Folding@Home: Welcome to Folding@Home
[21:20:44] Loaded queue successfully.
[21:20:47] + Closed connections
[21:20:52]
[21:20:52] Project: 10103 (Run 638, Clone 0, Gen 5)
[21:20:52]
[21:20:52] Assembly optimizations on if available.
[21:20:52] Entering M.D.
[21:20:58] Tpr hash work/wudata_06.tpr: 3529118583 2452865290 339078037 2399004577 3437509336
[21:20:58]
[21:20:58] Calling fah_main args: 14 usage=100
[21:20:58]
[21:20:59] Working on p10103_lambda_370K
[21:21:01] Client config found, loading data.
[21:21:01] Starting GUI Server
[21:22:13] Completed 1%
[21:23:26] Completed 2%
[21:24:38] Completed 3%
[21:25:50] Completed 4%
[21:27:02] Completed 5%
[21:28:14] Completed 6%
[21:29:26] Completed 7%
[21:30:38] Completed 8%
[21:31:51] Completed 9%
[21:33:03] Completed 10%
[21:34:15] Completed 11%
[21:35:27] Completed 12%
[21:36:39] Completed 13%
[21:37:51] Completed 14%
[21:39:03] Completed 15%
[21:40:16] Completed 16%
[21:41:28] Completed 17%
[21:42:40] Completed 18%
[21:42:40] mdrun_gpu returned
[21:42:40] Nonzero force sum on GPU
[21:42:40]
[21:42:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:42:44] CoreStatus = 7A (122)
[21:42:44] Sending work to server
[21:42:44] Project: 10103 (Run 638, Clone 0, Gen 5)
[21:42:44] - Read packet limit of 540015616... Set to 524286976.
[21:42:44] - Error: Could not get length of results file work/wuresults_06.dat
[21:42:44] - Error: Could not read unit 06 file. Removing from queue.
[21:42:44] - Preparing to get new work unit...
[21:42:44] + Attempting to get work packet
[21:42:44] - Connecting to assignment server
[21:42:46] - Successful: assigned to (171.64.65.71).
[21:42:53]
[21:42:53] Assembly optimizations on if available.
[21:42:53] Entering M.D.
[21:42:59] Tpr hash work/wudata_07.tpr: 3529118583 2452865290 339078037 2399004577 3437509336
[21:42:59]
[21:42:59] Calling fah_main args: 14 usage=100
[21:42:59]
[21:43:00] Working on p10103_lambda_370K
[21:43:02] Client config found, loading data.
[21:43:03] Starting GUI Server
[21:44:15] Completed 1%
[21:45:27] Completed 2%
[21:46:39] Completed 3%
[21:47:51] Completed 4%
[21:49:03] Completed 5%
[21:50:16] Completed 6%
[21:51:28] Completed 7%
[21:52:40] Completed 8%
[21:53:52] Completed 9%
[21:55:04] Completed 10%
[21:56:16] Completed 11%
[21:57:29] Completed 12%
[21:58:41] Completed 13%
[21:59:53] Completed 14%
[22:01:05] Completed 15%
[22:02:17] Completed 16%
[22:03:29] Completed 17%
[22:04:41] Completed 18%
[22:05:54] Completed 19%
[22:05:54] mdrun_gpu returned
[22:05:54] Nonzero force sum on GPU
[22:05:54]
[22:05:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:05:58] CoreStatus = 7A (122)
[22:05:58] Sending work to server
[22:05:58] Project: 10103 (Run 638, Clone 0, Gen 5)
[22:05:58] - Read packet limit of 540015616... Set to 524286976.
[22:05:58] - Error: Could not get length of results file work/wuresults_07.dat
[22:05:58] - Error: Could not read unit 07 file. Removing from queue.
[22:05:58] - Preparing to get new work unit...
[22:05:58] + Attempting to get work packet
[22:05:58] - Connecting to assignment server
[22:05:59] - Successful: assigned to (171.64.65.71).
[22:05:59] + News From Folding@Home: Welcome to Folding@Home
[22:05:59] Loaded queue successfully.
[22:06:01] + Closed connections
[22:06:06]
[22:06:06] + Processing work unit
[22:06:06] Core required: FahCore_11.exe
[22:06:06] Core found.
[22:06:06] Working on queue slot 08 [February 14 22:06:06 UTC]
[22:06:06] + Working ...
Between thoses WU and the Server 171.67.108.21 which says
[20:29:54] + Attempting to send results [February 14 20:29:54 UTC]
[20:29:56] - Server has already received unit.
for others WU, i won't have 1K pts today insteaf of 8-10k :(
EVGA SR2, 2* 5680,12 GO Corsair XMS3 Cas 9 2000MHz
MM Ext. Asc, Be Quiet 1200W P8
2 GWD GTX 260-896 GS 896 Mo (WC)
WD 600Go Sata III 10K, SSD Crucial C300 128Go (bigadv Kubuntu 10.10 + linux-ck + thekrakkhen)
All Watercooled
Re: Project: 10103 (Run 638, Clone 0, Gen 5)
Someone else has completed Project: 10103 (Run 638, Clone 0, Gen 5) successfully ...
