Project: 3064 (Run 2, Clone 362, Gen 32) Segmentation fault
stanmc
Post by stanmc »
This is the second time I have received this exact project. It failed the second time just as it did the first time.
Obviously, if I receive it again, I will just eliminate it.
[01:49:51] Completed 4900000 out of 5000000 steps (98 percent)
[01:53:30] Warning: long 1-4 interactions
[01:53:30]
[01:53:30] Folding@home Core Shutdown: INTERRUPTED
[0]0:Return code = 0, signaled with Segmentation fault
[0]1:Return code = 0, signaled with Segmentation fault
[0]2:Return code = 0, signaled with Segmentation fault
[0]3:Return code = 0, signaled with Segmentation fault
[01:53:34] CoreStatus = 0 (0)
[01:53:34] Sending work to server
[01:53:34] Project: 3064 (Run 2, Clone 362, Gen 32)
[01:53:34] - Error: Could not get length of results file work/wuresults_07.dat
[01:53:34] - Error: Could not read unit 07 file. Removing from queue.
[01:53:34] Trying to send all finished work units
[01:53:34] + No unsent completed units remaining.
[01:53:34] + -oneunit flag given and have now finished a unit. Exiting.- Preparing to get new work unit...
[01:53:34] Cleaning up work directory
Re: Project: 3064 (Run 2, Clone 362, Gen 32) Segmentation fault
It looks like someone else has been able to complete it successfully.
