Project: 6020 (Run 0, Clone 182, Gen 9) ERROR 0x3
DavidMudkips
Post by DavidMudkips »
I've been running SMP 6.29 fine for two weeks or so, with both a1 and a3 units. Then I get this error which accompanies a popup from Microsoft Visual C++ Runtime Library that "This application has requested the Runtime to terminate it in an unusual way", referring to the FAH a3 core exe.
Here's FAHLog. This error persists upon restarting the client, even after it downloaded the new a3 core (2.15, I had 2.14 before). Is this just a bad WU?
[06:34:04] Project: 6020 (Run 0, Clone 182, Gen 9)
[06:34:04]
[06:34:04] Assembly optimizations on if available.
[06:34:04] Entering M.D.
[06:34:10] Completed 0 out of 500000 steps  (0%)
[06:34:22] CoreStatus = 3 (3)
[06:34:22] Client-core communications error: ERROR 0x3
[06:34:22] Deleting current work unit & continuing...
Re: Project: 6020 (Run 0, Clone 182, Gen 9) ERROR 0x3
This one might be bad ... no body has been able to return it yet :(
DavidMudkips
Just had the same problem again (after some nonproblematic runs), with the same WU (same R/C/G). Except this time, I wasn't around to see the error when it occurred, so the ERROR 0x3 only got written to FAHLog when I came back and hit OK on the Microsoft Runtime error popup. That explains the 3-hour gap, and based on my temperature readings the core was running the entire time, which I would rather it not do if it's not doing anything productive...
Is there a way to prevent problematic WUs like this one from being reassigned to a machine it's failed on already?
[18:00:09] Project: 6020 (Run 0, Clone 182, Gen 9)
[18:00:09]
[18:00:09] Assembly optimizations on if available.
[18:00:09] Entering M.D.
[18:00:15] Completed 0 out of 500000 steps  (0%)
[18:09:53] - Autosending finished units... [February 12 18:09:53 UTC]
[18:09:53] Trying to send all finished work units
[18:09:53] + No unsent completed units remaining.
[18:09:53] - Autosend completed
[21:23:21] CoreStatus = 3 (3)
[21:23:21] Client-core communications error: ERROR 0x3
[21:23:21] Deleting current work unit & continuing...
I reported this WU as bad.
