Project: 6326 (Run 1, Clone 14, Gen 1) - LINCS WARNING
Tobit
Post by Tobit »
This might be the expected result as the log mentions. However, I am posting just in case it isn't.
[09:15:48] + Processing work unit
[09:15:48] Core required: FahCore_78.exe
[09:15:48] Core found.
[09:15:48] Working on queue slot 00 [February 10 09:15:48 UTC]
[09:15:48] + Working ...
[09:15:48] - Calling '.\FahCore_78.exe -dir work/ -suffix 00 -checkpoint 15 -service -verbose -lifeline 1012 -version 623'
[09:15:48]
[09:15:48] *------------------------------*
[09:15:48] Folding@Home Gromacs Core
[09:15:48] Version 1.90 (March 8, 2006)
[09:15:48]
[09:15:48] Preparing to commence simulation
[09:15:48] - Looking at optimizations...
[09:15:48] - Created dyn
[09:15:48] - Files status OK
[09:15:48] - Expanded 200317 -> 961460 (decompressed 479.9 percent)
[09:15:48] - Starting from initial work packet
[09:15:48]
[09:15:48] Project: 6326 (Run 1, Clone 14, Gen 1)
[09:15:48]
[09:15:48] Assembly optimizations on if available.
[09:15:48] Entering M.D.
[09:15:54] Protein: 6397 proG_coil_ff03
[09:15:54]
[09:15:54] Writing local files
[09:15:54] Extra SSE boost OK.
[09:15:54] Completed 0 out of 2500000 steps  (0%)
[09:28:16] Writing local files
[09:28:16] Completed 25000 out of 2500000 steps  (1%)
[09:40:37] Writing local files
[09:40:37] Completed 50000 out of 2500000 steps  (2%)
[09:53:00] Writing local files
[09:53:00] Completed 75000 out of 2500000 steps  (3%)
[10:05:22] Writing local files
[10:05:22] Completed 100000 out of 2500000 steps  (4%)
[10:17:44] Writing local files
[10:17:44] Completed 125000 out of 2500000 steps  (5%)
[10:30:07] Writing local files
[10:30:07] Completed 150000 out of 2500000 steps  (6%)
[10:42:28] Writing local files
[10:42:28] Completed 175000 out of 2500000 steps  (7%)
[10:54:49] Writing local files
[10:54:49] Completed 200000 out of 2500000 steps  (8%)
[11:03:15] Quit 101 - Fatal error:
[11:03:15] Step 217123, time 5434.25 (ps)  LINCS WARNING
[11:03:15] relative constraint deviation after LINCS:
[11:03:15] max 0.001917 (between atoms 148 and 149) rms 0.000239
[11:03:15]
[11:03:15] Simulation instability has been encountered. The run has entered a
[11:03:15]   state from which no further progress can be made.
[11:03:15] This may be the correct result of the simulation, however if you
[11:03:15]   often see other project units terminating early like this
[11:03:15]   too, you may wish to check the stability of your computer (issues
[11:03:15]   such as high temperature, overclocking, etc.).
[11:03:15] Going to send back what have done.
[11:03:15] logfile size: 15786
[11:03:15] - Writing 16468 bytes of core data to disk...
[11:03:15] Done: 15956 -> 3956 (compressed to 24.7 percent)
[11:03:15]   ... Done.
[11:03:15]
[11:03:15] Folding@home Core Shutdown: EARLY_UNIT_END
[11:03:18] CoreStatus = 72 (114)
[11:03:18] Sending work to server
[11:03:18] Project: 6326 (Run 1, Clone 14, Gen 1)
[11:03:18] - Read packet limit of 540015616... Set to 524286976.
[11:03:18] + Attempting to send results [February 10 11:03:18 UTC]
[11:03:18] - Reading file work/wuresults_00.dat from core
[11:03:18]   (Read 4468 bytes from disk)
[11:03:18] Connecting to http://171.64.65.60:8080/
[11:03:18] Posted data.
[11:03:18] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[11:03:18] - Uploaded at ~10 kB/s
[11:03:18] - Averaged speed for that direction ~195 kB/s
[11:03:18] + Results successfully sent
Re: Project: 6326 (Run 1, Clone 14, Gen 1) - LINCS WARNING
There are two reports of EUE, but someone finally completed it.
