Project: 5765 (Run 2, Clone 347, Gen 1012) - mdrun_gpu retur
Tobit
Post by Tobit »
Stock GTX275 on Linux via WINE. I don't generally have problems with this setup, this is probably my first problem unit in the past 100 or so. I don't believe I have a system problem. This successfully uploaded partial results and received a different project as designed. Just reporting this in case it is a bad WU.
[02:02:10] + Processing work unit
[02:02:10] Core required: FahCore_11.exe
[02:02:10] Core found.
[02:02:10] Working on queue slot 07 [February 11 02:02:10 UTC]
[02:02:10] + Working ...
[02:02:10] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 708 -version 623'
[02:02:10]
[02:02:10] *------------------------------*
[02:02:10] Folding@Home GPU Core
[02:02:10] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[02:02:10]
[02:02:10] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:02:10] Build host: amoeba
[02:02:10] Board Type: Nvidia
[02:02:10] Core      :
[02:02:10] Preparing to commence simulation
[02:02:10] - Looking at optimizations...
[02:02:10] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[02:02:10] - Created dyn
[02:02:10] - Files status OK
[02:02:10] - Expanded 46684 -> 252912 (decompressed 541.7 percent)
[02:02:10] Called DecompressByteArray: compressed_data_size=46684 data_size=252912, decompressed_data_size=252912 diff=0
[02:02:10] - Digital signature verified
[02:02:10]
[02:02:10] Project: 5765 (Run 2, Clone 347, Gen 1012)
[02:02:10]
[02:02:10] Assembly optimizations on if available.
[02:02:10] Entering M.D.
[02:02:16] Tpr hash work/wudata_07.tpr:  2490235126 495319702 3254161713 4194136250 2476249807
[02:02:16]
[02:02:16] Calling fah_main args: 14 usage=100
[02:02:16]
[02:02:17] Working on Protein
[02:02:17] Client config found, loading data.
[02:02:17] Starting GUI Server
[02:02:52] Completed 1%
[02:03:26] Completed 2%
[02:04:00] Completed 3%
[02:04:34] Completed 4%
[02:05:08] Completed 5%
[02:05:42] Completed 6%
[02:06:16] Completed 7%
[02:06:50] Completed 8%
[02:07:24] Completed 9%
[02:07:58] Completed 10%
[02:08:32] Completed 11%
[02:09:07] Completed 12%
[02:09:41] Completed 13%
[02:10:15] Completed 14%
[02:10:48] Completed 15%
[02:11:23] Completed 16%
[02:11:57] Completed 17%
[02:12:31] Completed 18%
[02:13:04] Completed 19%
[02:13:39] Completed 20%
[02:14:13] Completed 21%
[02:14:47] Completed 22%
[02:15:21] Completed 23%
[02:15:55] Completed 24%
[02:16:29] Completed 25%
[02:17:03] Completed 26%
[02:17:37] Completed 27%
[02:18:11] Completed 28%
[02:18:45] Completed 29%
[02:18:45] mdrun_gpu returned
[02:18:45] Going to send back what have done -- stepsTotalG=15000000
[02:18:45] Work fraction=0.2900 steps=15000000.
[02:18:49] logfile size=15776 infoLength=15776 edr=0 trr=25
[02:18:49] + Opened results file
[02:18:49] - Writing 16314 bytes of core data to disk...
[02:18:49] Done: 15802 -> 4691 (compressed to 29.6 percent)
[02:18:49]   ... Done.
[02:18:49] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[02:18:49]
[02:18:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:18:54] CoreStatus = 7A (122)
[02:18:54] Sending work to server
[02:18:54] Project: 5765 (Run 2, Clone 347, Gen 1012)
[02:18:54] - Read packet limit of 540015616... Set to 524286976.
[02:18:54] + Attempting to send results [February 11 02:18:54 UTC]
[02:18:54] - Reading file work/wuresults_07.dat from core
[02:18:54]   (Read 5203 bytes from disk)
[02:18:54] Connecting to http://171.67.108.11:8080/
[02:18:54] Posted data.
[02:18:54] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[02:18:54] - Uploaded at ~12 kB/s
[02:18:54] - Averaged speed for that direction ~73 kB/s
[02:18:54] + Results successfully sent
[02:18:54] Thank you for your contribution to Folding@Home.
[02:18:58] Trying to send all finished work units
[02:18:58] + No unsent completed units remaining.
[02:18:58] - Preparing to get new work unit...
Re: Project: 5765 (Run 2, Clone 347, Gen 1012) - mdrun_gpu retur
I see your UM report, but also two other people that completed it successfully ...
