Project: 2653 (Run 1, Clone 99, Gen 141)
gizmo
Hardware configuration: Lenovo T61p laptop
Intel Core2Duo T7700 @ 2.2 Ghz
Fedora 12 64-bit
Post by gizmo »
And again with a 2653 that hangs at "Entering M.D.", same pattern as I noted with the 2665: http://foldingforum.org/viewtopic.php?f ... 01#p130401
# SMP Client ##################################################################
                       Folding@Home Client Version 6.02
                          http://folding.stanford.edu
Launch directory: /home/fah
Executable: ./fah6
Arguments: -smp -verbosity 9
[21:33:39] - Ask before connecting: No
[21:33:39] - User name: ChrisRichards (Team 45)
[21:33:39] - User ID: 1440AB7A28AA1143
[21:33:39] - Machine ID: 1
[21:33:39]
[21:33:39] Work directory not found. Creating...
[21:33:39] Could not open work queue, generating new queue...
[21:33:39] - Autosending finished units...
[21:33:39] Trying to send all finished work units
[21:33:39] + No unsent completed units remaining.
[21:33:39] - Autosend completed
[21:33:39] - Preparing to get new work unit...
[21:33:39] + Attempting to get work packet
[21:33:39] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 10
[21:33:39] - Connecting to assignment server
[21:33:39] Connecting to http://assign.stanford.edu:8080/
[21:33:39] Posted data.
[21:33:39] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[21:33:39] + News From Folding@Home: Welcome to Folding@Home
[21:33:40] Loaded queue successfully.
[21:33:40] Connecting to http://171.64.65.64:8080/
[21:33:41] Posted data.
[21:33:41] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[21:33:41] - Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[21:33:57] + Attempting to get work packet
[21:33:57] - Connecting to assignment server
[21:33:57] Connecting to http://assign.stanford.edu:8080/
[21:33:58] Posted data.
[21:33:58] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[21:33:58] + News From Folding@Home: Welcome to Folding@Home
[21:33:58] Loaded queue successfully.
[21:33:58] Connecting to http://171.64.65.64:8080/
[21:34:01] Posted data.
[21:34:01] Initial: 0000; - Receiving payload (expected size: 2427536)
[21:34:18] - Downloaded at ~139 kB/s
[21:34:18] - Averaged speed for that direction ~139 kB/s
[21:34:18] + Received work.
[21:34:18] + Closed connections
[21:34:18]
[21:34:18] + Processing work unit
[21:34:18] Core required: FahCore_a1.exe
[21:34:18] Core found.
[21:34:18] Working on Unit 01 [February 9 21:34:18]
[21:34:18] + Working ...
[21:34:18] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 27152 -version 602'
[21:34:18]
[21:34:18] *------------------------------*
[21:34:18] Folding@Home Gromacs SMP Core
[21:34:18] Version 1.74 (November 27, 2006)
[21:34:18]
[21:34:18] Preparing to commence simulation
[21:34:18] - Ensuring status. Please wait.
[21:34:35] - Looking at optimizations...
[21:34:35] - Working with standard loops on this execution.
[21:34:35] - Previous termination of core was improper.
[21:34:35] - Going to use standard loops.
[21:34:35] - Files status OK
[21:34:36] - Expanded 2427024 -> 12891997 (decompressed 531.1 percent)
[21:34:37] - Starting from initial work packet
[21:34:37]
[21:34:37] Project: 2653 (Run 1, Clone 99, Gen 141)
[21:34:37]
[21:34:37] Entering M.D.
Re: Project: 2653 (Run 1, Clone 99, Gen 141)
You definitely have a problem with you client setup ...
First, you're still using quite an old client, I guess you should upgrade.
