00:09:59] + Could not connect to Work Server (results)
[00:09:59] (171.67.108.26:8080)
[00:09:59] + Retrying using alternative port
[00:09:59] Connecting to http://171.67.108.26:80/
[00:09:59] - Couldn't send HTTP request to server
[00:09:59] + Could not connect to Work Server (results)
[00:09:59] (171.67.108.26:80)
[00:09:59] Could not transmit unit 00 to Collection server; keeping in queue.
[00:09:59] Project: 10103 (Run 277, Clone 1, Gen 2)
[00:09:59] - Read packet limit of 540015616... Set to 524286976.
[00:09:59] + Attempting to send results [February 9 00:09:59 UTC]
[00:09:59] - Reading file work/wuresults_00.dat from core
[00:09:59] (Read 132426 bytes from disk)
[00:09:59] Connecting to http://171.64.65.71:8080/
[00:10:01] - Couldn't send HTTP request to server
[00:10:01] + Could not connect to Work Server (results)
[00:10:01] (171.64.65.71:8080)
[00:10:01] + Retrying using alternative port
[00:10:01] Connecting to http://171.64.65.71:80/
[00:10:04] - Couldn't send HTTP request to server
[00:10:04] + Could not connect to Work Server (results)
[00:10:04] (171.64.65.71:80)
[00:10:04] - Error: Could not transmit unit 00 (completed February 8) to work server.
[00:10:04] - 3 failed uploads of this unit.
[00:10:04] - Read packet limit of 540015616... Set to 524286976.
[00:10:04] + Attempting to send results [February 9 00:10:04 UTC]
[00:10:04] - Reading file work/wuresults_00.dat from core
[00:10:04] (Read 132426 bytes from disk)
[00:10:04] Connecting to http://171.67.108.26:8080/
[00:15:20] Posted data.
[00:15:20] Initial: 0000; - Uploaded at ~0 kB/s
[00:15:20] - Averaged speed for that direction ~25 kB/s
[00:15:20] - Server does not have record of this unit. Will try again later.
[00:15:20] Could not transmit unit 00 to Collection server; keeping in queue.
[00:15:20] + Sent 0 of 2 completed units to the server
[00:15:20] - Autosend completed
Been watching that thread but got a WU that cannot go to that server for 24 hours now , getting a status 503 , and the server is indeed busy. maybe someone needs to sort the loading out as prof pande alluded to in the other thread.
A problem with a collection server is never the only problem you're having. Your WU may be getting a 503 error from 171.67.108.26 but before you got that error there would have also been another server involved. I won't be able to tell whether or not your WU is trying to go back to one of the servers with the problem that has been identified but not yet fixed until you post FAHlog.txt.
