Project: 5733 (Run 1, Clone 4, Gen 666)
zananzelm
Hardware configuration: cpu: AMD ATHLON 64 X2 5200+
vga: ATI HD2900PRO 1GB
ram: 2GB DDR 800MHZ GEIL
mb: ASUS M2R32-MVP
os: WIN XP PRO
1 CPU client
1 GPU ATI client
Post by zananzelm »
this one is giving me UNSTABLE MACHINE as soon as it is started.
[19:11:46] Project: 5733 (Run 1, Clone 4, Gen 666)
[19:11:46]
[19:11:46] Assembly optimizations on if available.
[19:11:46] Entering M.D.
[19:11:52] Tpr hash work/wudata_07.tpr:  1948574494 3811376024 3119906033 3891475998 3034729314
[19:11:52] Working on Protein
[19:11:52] Client config found, loading data.
[19:11:53] Starting GUI Server
[19:11:56] mdrun_gpu returned
[19:11:56] NANs detected on GPU
[19:11:56]
[19:11:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:11:58] CoreStatus = 7A (122)
[19:11:58] Sending work to server
[19:11:58] Project: 5733 (Run 1, Clone 4, Gen 666)
[19:11:58] - Read packet limit of 540015616... Set to 524286976.
[19:11:58] - Error: Could not get length of results file work/wuresults_07.dat
[19:11:58] - Error: Could not read unit 07 file. Removing from queue.
[19:11:58] Trying to send all finished work units
[19:11:58] + No unsent completed units remaining.
[19:11:58] - Preparing to get new work unit...
[19:11:58] + Attempting to get work packet
[19:11:58] - Will indicate memory of 8182 MB
[19:11:58] - Connecting to assignment server
[19:11:58] Connecting to http://assign-GPU.stanford.edu:8080/
[19:12:00] Posted data.
[19:12:00] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[19:12:00] + News From Folding@Home: Welcome to Folding@Home
[19:12:00] Loaded queue successfully.
[19:12:00] Connecting to http://171.64.65.102:8080/
[19:12:00] Initial: 0000; - Receiving payload (expected size: 64040)
[19:12:02] - Downloaded at ~31 kB/s
[19:12:02] - Averaged speed for that direction ~34 kB/s
[19:12:02] + Received work.
[19:12:02] Trying to send all finished work units
[19:12:02] + No unsent completed units remaining.
[19:12:02] + Closed connections
[19:12:07]
[19:12:07] + Processing work unit
[19:12:07] Core required: FahCore_11.exe
[19:12:07] Core found.
[19:12:07] Working on queue slot 08 [February 8 19:12:07 UTC]
[19:12:07] + Working ...
[19:12:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 3 -forceasm -verbose -lifeline 456 -version 623'
[19:12:07]
[19:12:07] *------------------------------*
[19:12:07] Folding@Home GPU Core - Beta
[19:12:07] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[19:12:07]
[19:12:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:12:07] Build host: amoeba
[19:12:07] Board Type: AMD
[19:12:07] Core      :
[19:12:07] Preparing to commence simulation
[19:12:07] - Assembly optimizations manually forced on.
[19:12:07] - Not checking prior termination.
[19:12:07] - Expanded 63528 -> 492188 (decompressed 774.7 percent)
[19:12:07] Called DecompressByteArray: compressed_data_size=63528 data_size=492188, decompressed_data_size=492188 diff=0
[19:12:07] - Digital signature verified
[19:12:07]
[19:12:07] Project: 5733 (Run 1, Clone 4, Gen 666)
[19:12:07]
[19:12:07] Assembly optimizations on if available.
[19:12:07] Entering M.D.
[19:12:13] Tpr hash work/wudata_08.tpr:  1948574494 3811376024 3119906033 3891475998 3034729314
[19:12:13] Working on Protein
[19:12:13] Client config found, loading data.
[19:12:14] Starting GUI Server
[19:12:17] mdrun_gpu returned
[19:12:17] NANs detected on GPU
[19:12:17]
[19:12:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:12:20] CoreStatus = 7A (122)
[19:12:20] Sending work to server
[19:12:20] Project: 5733 (Run 1, Clone 4, Gen 666)
[19:12:20] - Read packet limit of 540015616... Set to 524286976.
[19:12:20] - Error: Could not get length of results file work/wuresults_08.dat
[19:12:20] - Error: Could not read unit 08 file. Removing from queue.
[19:12:20] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5733 (Run 1, Clone 4, Gen 666)
Woooot our database is back ... mods and admins can check WUs again ! :)
So, this WU ise a bad one (are you superstitious about the Gen number ? :roll: )
Two people attempted to fold it, and both failed with immediate unstable_machine.
AtwaterFS
Post by AtwaterFS »
Project: 5733 (Run 1, Clone 4, Gen 666) - Me too - this keeps coming up while I'm away at work and its annoying - every other WU I porcess is fine - this EUE's me and in general ruins my day - Thank You!
I've marked it as bad.
