When I go to my page it tells me my score, but I'm apparently not a member of any workgroup. If I go to the certificate link, it tells me I have 0 points. I was going to post a link but I'm too new.
It's a little disconcerting to have NO score when I leave my PC folding every second I'm not playing a game. I don't expect an award or anything, but I'd just like to know my efforts are being recorded. Is this just a server error or something?
One other thing... Any time I try to run the viewer my PC crashes with a BSOD... I run the FAH GPU client, Hardware is as follows:
CPU: Intel i5-750
GPU: eVGA GTX-260 Core 216
Mobo: ASUS P7P55D Pro
RAM: Corsair XMS3-1600, 2 GB
I'm running XP Pro 32 bit
What's with the stats?
Zagen30
Re: What's with the stats?
The stats weirdness probably has to do with this: http://foldingforum.org/viewtopic.php?f=24&t=13306
The viewer is known to be buggy and doesn't usually work properly. Don't use it. If you want to keep track of your clients' progress, use a third-party monitoring program like FahMon or HFM.net
They have the active clients list back up... must be them new servers of theirs.
The certificates seem to work for me
http://fah-web.stanford.edu/awards/cert ... t=wus&bg=3
http://fah-web.stanford.edu/awards/cert ... pts=142920
