Empie
Posts: 17 Joined: Sat Dec 27, 2008 3:56 pm
Post
by Empie » Sat Feb 06, 2010 4:01 pm
Project: 5746 (Run 4, Clone 50, Gen 602) gives me UNSTABLE_MACHINE and my GPU client stopped for 24h
[06:02:19]
[06:02:19] + Processing work unit
[06:02:19] Core required: FahCore_11.exe
[06:02:19] Core found.
[06:02:19] Working on queue slot 07 [February 6 06:02:19 UTC]
[06:02:19] + Working ...
[06:02:19] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 15 -verbose -lifeline 4864 -version 623'
[06:02:19]
[06:02:19] *------------------------------*
[06:02:19] Folding@Home GPU Core - Beta
[06:02:19] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:02:19]
[06:02:19] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:02:19] Build host: amoeba
[06:02:19] Board Type: AMD
[06:02:19] Core :
[06:02:19] Preparing to commence simulation
[06:02:19] - Looking at optimizations...
[06:02:19] - Created dyn
[06:02:19] - Files status OK
[06:02:19] - Expanded 68542 -> 357580 (decompressed 521.6 percent)
[06:02:19] Called DecompressByteArray: compressed_data_size=68542 data_size=357580, decompressed_data_size=357580 diff=0
[06:02:19] - Digital signature verified
[06:02:19]
[06:02:19] Project: 5746 (Run 4, Clone 50, Gen 602)
[06:02:19]
[06:02:19] Assembly optimizations on if available.
[06:02:19] Entering M.D.
[06:02:25] Tpr hash work/wudata_07.tpr: 2869176403 4131998202 3991812177 3618754043 2832518370
[06:02:26] Working on Protein
[06:02:26] Client config found, loading data.
[06:02:26] Starting GUI Server
[06:02:28] mdrun_gpu returned
[06:02:28] Nonzero force sum on GPU
[06:02:28]
[06:02:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:02:31] CoreStatus = 7A (122)
[06:02:31] Sending work to server
[06:02:31] Project: 5746 (Run 4, Clone 50, Gen 602)
[06:02:31] - Error: Could not get length of results file work/wuresults_07.dat
[06:02:31] - Error: Could not read unit 07 file. Removing from queue.
[06:02:31] Trying to send all finished work units
[06:02:31] + No unsent completed units remaining.
[06:02:31] - Preparing to get new work unit...
[06:02:31] + Attempting to get work packet
[06:02:31] - Will indicate memory of 4094 MB
[06:02:31] - Connecting to assignment server
[06:02:31] Connecting to http://assign-GPU.stanford.edu:8080/
[06:02:32] Posted data.
[06:02:32] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[06:02:32] + News From Folding@Home: Welcome to Folding@Home
[06:02:32] Loaded queue successfully.
[06:02:32] Connecting to http://171.64.65.102:8080/
[06:02:33] Posted data.
[06:02:33] Initial: 0000; - Receiving payload (expected size: 69054)
[06:02:35] - Downloaded at ~33 kB/s
[06:02:35] - Averaged speed for that direction ~55 kB/s
[06:02:35] + Received work.
[06:02:35] Trying to send all finished work units
[06:02:35] + No unsent completed units remaining.
[06:02:35] + Closed connections
[06:02:40]
[06:02:40] + Processing work unit
[06:02:40] Core required: FahCore_11.exe
[06:02:40] Core found.
[06:02:40] Working on queue slot 08 [February 6 06:02:40 UTC]
[06:02:40] + Working ...
[06:02:40] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 4864 -version 623'
[06:02:40]
[06:02:40] *------------------------------*
[06:02:40] Folding@Home GPU Core - Beta
[06:02:40] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:02:40]
[06:02:40] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:02:40] Build host: amoeba
[06:02:40] Board Type: AMD
[06:02:40] Core :
[06:02:40] Preparing to commence simulation
[06:02:40] - Looking at optimizations...
[06:02:40] - Created dyn
[06:02:40] - Files status OK
[06:02:40] - Expanded 68542 -> 357580 (decompressed 521.6 percent)
[06:02:40] Called DecompressByteArray: compressed_data_size=68542 data_size=357580, decompressed_data_size=357580 diff=0
[06:02:40] - Digital signature verified
[06:02:40]
[06:02:40] Project: 5746 (Run 4, Clone 50, Gen 602)
[06:02:40]
[06:02:40] Assembly optimizations on if available.
[06:02:40] Entering M.D.
[06:02:46] Tpr hash work/wudata_08.tpr: 2869176403 4131998202 3991812177 3618754043 2832518370
[06:02:46] Working on Protein
[06:02:46] Client config found, loading data.
[06:02:46] Starting GUI Server
[06:02:49] mdrun_gpu returned
[06:02:49] Nonzero force sum on GPU
[06:02:49]
[06:02:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:02:52] CoreStatus = 7A (122)
[06:02:52] Sending work to server
[06:02:52] Project: 5746 (Run 4, Clone 50, Gen 602)
[06:02:52] - Error: Could not get length of results file work/wuresults_08.dat
[06:02:52] - Error: Could not read unit 08 file. Removing from queue.
[06:02:52] EUE limit exceeded. Pausing 24 hours.
Renamed 'work' directory and made new one, restarted the client and now it busy crunching again.
Edit: my gfx card is a Sapphire Radeon 4870 512 MB DDR5
GreenPuffle92
Posts: 2 Joined: Sun Sep 06, 2009 12:01 am
Hardware configuration: Windows Vista™ Home Premium Intel(R) Core(TM)2 Duo CPU T8100 @ 2.10GHz 3.00 GB RAM NVIDIA GeForce 8400M GT Windows Vista 32-bit
Post
by GreenPuffle92 » Sat Feb 06, 2010 7:55 pm
I get the same problem
Windows Vista™ Home Premium SP2
3.00 GB RAM
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Sat Feb 06, 2010 8:24 pm
GreenPuffle92 wrote: I get the same problem
Please post FAHlog.
Do you mean you've had the same error with a different WU or do you mean you processed the same WU with the same result?
GreenPuffle92
Post
by GreenPuffle92 » Sat Feb 06, 2010 8:29 pm
Read this Post: viewtopic.php?f=50&t=13301
I have the same error with a different WU(I think)
Here FAHlog:
--- Opening Log file [February 6 19:44:12 UTC]
http://folding.stanford.edu
Launch directory: C:\Users\Kaplan\AppData\Roaming\Folding@home-gpu
[19:44:12] - Ask before connecting: No
[19:44:12] - User name: Missymouse97 (Team 143016)
[19:44:12] - User ID: 52F84A8B4C363F13
[19:44:12] - Machine ID: 2
[19:44:12]
[19:44:12] Work directory not found. Creating...
[19:44:12] Loaded queue successfully.
[19:44:12] Initialization complete
[19:44:12] - Preparing to get new work unit...
[19:44:12] + Attempting to get work packet
[19:44:12] - Connecting to assignment server
[19:44:18] - Successful: assigned to (171.67.108.21).
[19:44:18] + News From Folding@Home: Welcome to Folding@Home
[19:44:18] Loaded queue successfully.
[19:44:20] + Closed connections
[19:44:20]
[19:44:20] + Processing work unit
[19:44:20] Core required: FahCore_11.exe
[19:44:20] Core not found.
[19:44:20] - Core is not present or corrupted.
[19:44:20] - Attempting to download new core...
[19:44:20] + Downloading new core: FahCore_11.exe
[19:44:24] + 10240 bytes downloaded
[19:44:24] + 20480 bytes downloaded
[19:44:24] + 30720 bytes downloaded
[19:44:24] + 40960 bytes downloaded
[19:44:24] + 51200 bytes downloaded
[19:44:24] + 61440 bytes downloaded
[19:44:24] + 71680 bytes downloaded
[19:44:24] + 81920 bytes downloaded
[19:44:24] + 92160 bytes downloaded
[19:44:24] + 102400 bytes downloaded
[19:44:24] + 112640 bytes downloaded
[19:44:24] + 122880 bytes downloaded
[19:44:24] + 133120 bytes downloaded
[19:44:24] + 143360 bytes downloaded
[19:44:24] + 153600 bytes downloaded
[19:44:24] + 163840 bytes downloaded
[19:44:24] + 174080 bytes downloaded
[19:44:24] + 184320 bytes downloaded
[19:44:24] + 194560 bytes downloaded
[19:44:24] + 204800 bytes downloaded
[19:44:24] + 215040 bytes downloaded
[19:44:24] + 225280 bytes downloaded
[19:44:24] + 235520 bytes downloaded
[19:44:24] + 245760 bytes downloaded
[19:44:24] + 256000 bytes downloaded
[19:44:24] + 266240 bytes downloaded
[19:44:24] + 276480 bytes downloaded
[19:44:24] + 286720 bytes downloaded
[19:44:24] + 296960 bytes downloaded
[19:44:24] + 307200 bytes downloaded
[19:44:24] + 317440 bytes downloaded
[19:44:24] + 327680 bytes downloaded
[19:44:24] + 337920 bytes downloaded
[19:44:24] + 348160 bytes downloaded
[19:44:24] + 358400 bytes downloaded
[19:44:24] + 368640 bytes downloaded
[19:44:24] + 378880 bytes downloaded
[19:44:24] + 389120 bytes downloaded
[19:44:24] + 399360 bytes downloaded
[19:44:24] + 409600 bytes downloaded
[19:44:24] + 419840 bytes downloaded
[19:44:25] + 430080 bytes downloaded
[19:44:25] + 440320 bytes downloaded
[19:44:25] + 450560 bytes downloaded
[19:44:25] + 460800 bytes downloaded
[19:44:25] + 471040 bytes downloaded
[19:44:25] + 481280 bytes downloaded
[19:44:25] + 491520 bytes downloaded
[19:44:25] + 501760 bytes downloaded
[19:44:25] + 512000 bytes downloaded
[19:44:25] + 522240 bytes downloaded
[19:44:25] + 532480 bytes downloaded
[19:44:25] + 542720 bytes downloaded
[19:44:25] + 552960 bytes downloaded
[19:44:25] + 563200 bytes downloaded
[19:44:25] + 573440 bytes downloaded
[19:44:25] + 583680 bytes downloaded
[19:44:25] + 593920 bytes downloaded
[19:44:25] + 604160 bytes downloaded
[19:44:25] + 614400 bytes downloaded
[19:44:25] + 624640 bytes downloaded
[19:44:25] + 634880 bytes downloaded
[19:44:25] + 645120 bytes downloaded
[19:44:25] + 655360 bytes downloaded
[19:44:26] + 665067 bytes downloaded
[19:44:26] Verifying core Core_11.fah...
[19:44:26] Signature is VALID
[19:44:26]
[19:44:26] Trying to unzip core FahCore_11.exe
[19:44:26] Decompressed FahCore_11.exe (1908736 bytes) successfully
[19:44:31] + Core successfully engaged
[19:44:42]
[19:44:42] + Processing work unit
[19:44:42] Core required: FahCore_11.exe
[19:44:42] Core found.
[19:44:42] Working on queue slot 01 [February 6 19:44:42 UTC]
[19:44:42] + Working ...
[19:44:47]
[19:44:47] *------------------------------*
[19:44:47] Folding@Home GPU Core
[19:44:47] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[19:44:47]
[19:44:47] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:44:47] Build host: amoeba
[19:44:47] Board Type: Nvidia
[19:44:47] Core :
[19:44:47] Preparing to commence simulation
[19:44:47] - Looking at optimizations...
[19:44:47] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[19:44:47] - Created dyn
[19:44:47] - Files status OK
[19:44:47] - Expanded 65016 -> 344387 (decompressed 529.6 percent)
[19:44:47] Called DecompressByteArray: compressed_data_size=65016 data_size=344387, decompressed_data_size=344387 diff=0
[19:44:47] - Digital signature verified
[19:44:47]
[19:44:47] Project: 5781 (Run 34, Clone 99, Gen 2)
[19:44:47]
[19:44:47] Assembly optimizations on if available.
[19:44:47] Entering M.D.
[19:44:53] Tpr hash work/wudata_01.tpr: 2389673949 3639899887 4097273673 1427053214 999821619
[19:44:53]
[19:44:53] Calling fah_main args: 14 usage=100
[19:44:53]
[19:44:54] Working on Great Red Owns Many ACres of Sand
[19:44:54] Run: exception thrown during GuardedRun
[19:44:54] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[19:44:54] Going to send back what have done -- stepsTotalG=0
[19:44:54] Work fraction=0.0000 steps=0.
[19:44:58] logfile size=0 infoLength=0 edr=0 trr=23
[19:44:58] + Opened results file
[19:44:58] - Writing 635 bytes of core data to disk...
[19:44:58] Done: 123 -> 124 (compressed to 100.8 percent)
[19:44:58] ... Done.
[19:44:58] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[19:44:58]
[19:44:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:45:02] CoreStatus = 7A (122)
[19:45:02] Sending work to server
[19:45:02] Project: 5781 (Run 34, Clone 99, Gen 2)
[19:45:02] + Attempting to send results [February 6 19:45:02 UTC]
[19:45:03] + Results successfully sent
[19:45:03] Thank you for your contribution to Folding@Home.
[19:45:07] - Preparing to get new work unit...
[19:45:07] + Attempting to get work packet
[19:45:07] - Connecting to assignment server
[19:45:08] - Successful: assigned to (171.67.108.21).
[19:45:08] + News From Folding@Home: Welcome to Folding@Home
[19:45:08] Loaded queue successfully.
[19:45:10] + Closed connections
[19:45:15]
[19:45:15] + Processing work unit
[19:45:15] Core required: FahCore_11.exe
[19:45:15] Core found.
[19:45:15] Working on queue slot 02 [February 6 19:45:15 UTC]
[19:45:15] + Working ...
[19:45:15]
[19:45:15] *------------------------------*
[19:45:15] Folding@Home GPU Core
[19:45:15] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[19:45:15]
[19:45:15] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:45:15] Build host: amoeba
[19:45:15] Board Type: Nvidia
[19:45:15] Core :
[19:45:15] Preparing to commence simulation
[19:45:15] - Looking at optimizations...
[19:45:15] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[19:45:15] - Created dyn
[19:45:15] - Files status OK
[19:45:15] - Expanded 65006 -> 344387 (decompressed 529.7 percent)
[19:45:15] Called DecompressByteArray: compressed_data_size=65006 data_size=344387, decompressed_data_size=344387 diff=0
[19:45:15] - Digital signature verified
[19:45:15]
[19:45:15] Project: 5781 (Run 29, Clone 919, Gen 1)
[19:45:15]
[19:45:15] Assembly optimizations on if available.
[19:45:15] Entering M.D.
[19:45:21] Tpr hash work/wudata_02.tpr: 1617096271 1935995296 1654276091 1661196672 4129551624
[19:45:21]
[19:45:21] Calling fah_main args: 14 usage=100
[19:45:21]
[19:45:22] Working on Great Red Owns Many ACres of Sand
[19:45:22] Run: exception thrown during GuardedRun
[19:45:22] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[19:45:22] Going to send back what have done -- stepsTotalG=0
[19:45:22] Work fraction=0.0000 steps=0.
[19:45:26] logfile size=0 infoLength=0 edr=0 trr=23
[19:45:26] + Opened results file
[19:45:26] - Writing 635 bytes of core data to disk...
[19:45:26] Done: 123 -> 124 (compressed to 100.8 percent)
[19:45:26] ... Done.
[19:45:26] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[19:45:26]
[19:45:26] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:45:29] CoreStatus = 7A (122)
[19:45:29] Sending work to server
[19:45:29] Project: 5781 (Run 29, Clone 919, Gen 1)
[19:45:29] + Attempting to send results [February 6 19:45:29 UTC]
[19:45:30] + Results successfully sent
[19:45:30] Thank you for your contribution to Folding@Home.
[19:45:34] - Preparing to get new work unit...
[19:45:34] + Attempting to get work packet
[19:45:34] - Connecting to assignment server
[19:45:35] - Successful: assigned to (171.67.108.21).
[19:45:35] + News From Folding@Home: Welcome to Folding@Home
[19:45:35] Loaded queue successfully.
[19:45:37] + Closed connections
[19:45:42]
[19:45:42] + Processing work unit
[19:45:42] Core required: FahCore_11.exe
[19:45:42] Core found.
[19:45:42] Working on queue slot 03 [February 6 19:45:42 UTC]
[19:45:42] + Working ...
[19:45:42]
[19:45:42] *------------------------------*
[19:45:42] Folding@Home GPU Core
[19:45:42] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[19:45:42]
[19:45:42] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:45:42] Build host: amoeba
[19:45:42] Board Type: Nvidia
[19:45:42] Core :
[19:45:42] Preparing to commence simulation
[19:45:42] - Looking at optimizations...
[19:45:42] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[19:45:42] - Created dyn
[19:45:42] - Files status OK
[19:45:42] - Expanded 64976 -> 344387 (decompressed 530.0 percent)
[19:45:42] Called DecompressByteArray: compressed_data_size=64976 data_size=344387, decompressed_data_size=344387 diff=0
[19:45:42] - Digital signature verified
[19:45:42]
[19:45:42] Project: 5781 (Run 34, Clone 105, Gen 2)
[19:45:42]
[19:45:42] Assembly optimizations on if available.
[19:45:42] Entering M.D.
[19:45:48] Tpr hash work/wudata_03.tpr: 3019195714 1001837746 821882063 3381366160 3226410519
[19:45:48]
[19:45:48] Calling fah_main args: 14 usage=100
[19:45:48]
[19:45:49] Working on Great Red Owns Many ACres of Sand
[19:45:49] Run: exception thrown during GuardedRun
[19:45:49] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[19:45:49] Going to send back what have done -- stepsTotalG=0
[19:45:49] Work fraction=0.0000 steps=0.
[19:45:53] logfile size=0 infoLength=0 edr=0 trr=23
[19:45:53] + Opened results file
[19:45:53] - Writing 635 bytes of core data to disk...
[19:45:53] Done: 123 -> 124 (compressed to 100.8 percent)
[19:45:53] ... Done.
[19:45:53] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[19:45:53]
[19:45:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:45:56] CoreStatus = 7A (122)
[19:45:56] Sending work to server
[19:45:56] Project: 5781 (Run 34, Clone 105, Gen 2)
[19:45:56] + Attempting to send results [February 6 19:45:56 UTC]
[19:45:57] + Results successfully sent
[19:45:57] Thank you for your contribution to Folding@Home.
[19:46:01] - Preparing to get new work unit...
[19:46:01] + Attempting to get work packet
[19:46:01] - Connecting to assignment server
[19:46:02] - Successful: assigned to (171.67.108.21).
[19:46:02] + News From Folding@Home: Welcome to Folding@Home
[19:46:02] Loaded queue successfully.
[19:46:04] + Closed connections
[19:46:09]
[19:46:09] + Processing work unit
[19:46:09] Core required: FahCore_11.exe
[19:46:09] Core found.
[19:46:09] Working on queue slot 04 [February 6 19:46:09 UTC]
[19:46:09] + Working ...
[19:46:09]
[19:46:09] *------------------------------*
[19:46:09] Folding@Home GPU Core
[19:46:09] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[19:46:09]
[19:46:09] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:46:09] Build host: amoeba
[19:46:09] Board Type: Nvidia
[19:46:09] Core :
[19:46:09] Preparing to commence simulation
[19:46:09] - Looking at optimizations...
[19:46:09] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[19:46:09] - Created dyn
[19:46:09] - Files status OK
[19:46:09] - Expanded 64955 -> 344387 (decompressed 530.1 percent)
[19:46:09] Called DecompressByteArray: compressed_data_size=64955 data_size=344387, decompressed_data_size=344387 diff=0
[19:46:09] - Digital signature verified
[19:46:09]
[19:46:09] Project: 5781 (Run 34, Clone 103, Gen 2)
[19:46:09]
[19:46:09] Assembly optimizations on if available.
[19:46:09] Entering M.D.
[19:46:15] Tpr hash work/wudata_04.tpr: 1363118240 2348632586 1832682366 392986546 1193168000
[19:46:15]
[19:46:15] Calling fah_main args: 14 usage=100
[19:46:15]
[19:46:15] Working on Great Red Owns Many ACres of Sand
[19:46:16] Run: exception thrown during GuardedRun
[19:46:16] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[19:46:16] Going to send back what have done -- stepsTotalG=0
[19:46:16] Work fraction=0.0000 steps=0.
[19:46:20] logfile size=0 infoLength=0 edr=0 trr=23
[19:46:20] + Opened results file
[19:46:20] - Writing 635 bytes of core data to disk...
[19:46:20] Done: 123 -> 124 (compressed to 100.8 percent)
[19:46:20] ... Done.
[19:46:20] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[19:46:20]
[19:46:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:46:23] CoreStatus = 7A (122)
[19:46:23] Sending work to server
[19:46:23] Project: 5781 (Run 34, Clone 103, Gen 2)
[19:46:23] + Attempting to send results [February 6 19:46:23 UTC]
[19:46:24] + Results successfully sent
[19:46:24] Thank you for your contribution to Folding@Home.
[19:46:28] - Preparing to get new work unit...
[19:46:28] + Attempting to get work packet
[19:46:28] - Connecting to assignment server
[19:46:29] - Successful: assigned to (171.67.108.21).
[19:46:29] + News From Folding@Home: Welcome to Folding@Home
[19:46:29] Loaded queue successfully.
[19:46:31] + Closed connections
[19:46:36]
[19:46:36] + Processing work unit
[19:46:36] Core required: FahCore_11.exe
[19:46:36] Core found.
[19:46:36] Working on queue slot 05 [February 6 19:46:36 UTC]
[19:46:36] + Working ...
[19:46:36]
[19:46:36] *------------------------------*
[19:46:36] Folding@Home GPU Core
[19:46:36] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[19:46:36]
[19:46:36] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:46:36] Build host: amoeba
[19:46:36] Board Type: Nvidia
[19:46:36] Core :
[19:46:36] Preparing to commence simulation
[19:46:36] - Looking at optimizations...
[19:46:36] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[19:46:36] - Created dyn
[19:46:36] - Files status OK
[19:46:36] - Expanded 65048 -> 344387 (decompressed 529.4 percent)
[19:46:36] Called DecompressByteArray: compressed_data_size=65048 data_size=344387, decompressed_data_size=344387 diff=0
[19:46:36] - Digital signature verified
[19:46:36]
[19:46:36] Project: 5781 (Run 34, Clone 109, Gen 2)
[19:46:36]
[19:46:37] Assembly optimizations on if available.
[19:46:37] Entering M.D.
[19:46:43] Tpr hash work/wudata_05.tpr: 3380788378 1191634125 1471268911 863853252 1913901845
[19:46:43]
[19:46:43] Calling fah_main args: 14 usage=100
[19:46:43]
[19:46:43] Working on Great Red Owns Many ACres of Sand
[19:46:44] Run: exception thrown during GuardedRun
[19:46:44] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[19:46:44] Going to send back what have done -- stepsTotalG=0
[19:46:44] Work fraction=0.0000 steps=0.
[19:46:47] logfile size=0 infoLength=0 edr=0 trr=23
[19:46:47] + Opened results file
[19:46:47] - Writing 635 bytes of core data to disk...
[19:46:47] Done: 123 -> 124 (compressed to 100.8 percent)
[19:46:47] ... Done.
[19:46:47] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[19:46:47]
[19:46:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:46:50] CoreStatus = 7A (122)
[19:46:50] Sending work to server
[19:46:50] Project: 5781 (Run 34, Clone 109, Gen 2)
[19:46:50] + Attempting to send results [February 6 19:46:50 UTC]
[19:46:51] + Results successfully sent
[19:46:51] Thank you for your contribution to Folding@Home.
[19:46:55] EUE limit exceeded. Pausing 24 hours.
[19:47:57] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Missymouse97...
[20:21:17] Opening C:\Users\Kaplan\AppData\Roaming\Folding@home-gpu\MyFolding.html...
3.00 GB RAM
Post
by bruce » Sat Feb 06, 2010 8:38 pm
GreenPuffle92 wrote: Read this Post: viewtopic.php?f=50&t=13301
See my answer in the referenced topic.
mathwhiz
Posts: 16 Joined: Sun Jul 27, 2008 10:17 pm
Post
by mathwhiz » Tue Feb 09, 2010 9:27 pm
I received the same error on this work unit. (see log below). I process other work units just fine. May be a bad unit.
[21:17:39] Project: 5746 (Run 4, Clone 50, Gen 602)
[21:17:39]
[21:17:39] Assembly optimizations on if available.
[21:17:39] Entering M.D.
[21:17:45] Tpr hash work/wudata_03.tpr: 2869176403 4131998202
[21:17:45] Working on Protein
[21:17:46] Client config found, loading data.
[21:17:46] Starting GUI Server
[21:17:48] mdrun_gpu returned
[21:17:48] Nonzero force sum on GPU
[21:17:48]
[21:17:48] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:17:51] CoreStatus = 7A (122)
[21:17:51] Sending work to server
[21:17:51] Project: 5746 (Run 4, Clone 50, Gen 602)
[21:17:51] - Read packet limit of 540015616... Set to 524286976.
[21:17:51] - Error: Could not get length of results file
work/wuresults_03.dat
[21:17:51] - Error: Could not read unit 03 file. Removing from queue.
[21:17:51] - Preparing to get new work unit...
Post
by bruce » Tue Feb 09, 2010 11:36 pm
I've reported Project: 5746 (Run 4, Clone 50, Gen 602) as a bad WU.
mathwhiz
Post
by mathwhiz » Wed Feb 10, 2010 1:09 am
Thanks bruce!
