Project Probs 5767&5765
Mr. Scary
Hardware configuration: The Rock-XPS630i/QX6850@3.67ghz/OCZ Plat 1066 2x2gb/(2)8800GT AlphaDogs/(2)10krpm Raptors Raid0&(2)WD HDD 500gb
Nekid-CoolerMaster CM690/MSI-P6N Diamond/Q6600@3.0ghz/Samsung 2x2gb 800mhz/(2)9800GT's/TX2 HSF/Corsair TX850W PSU/(2)WD 160gb HDD's Raid 0, (1)500gb WD & (1)1.5tb WD HDD
Bare Nekid-MSI-P6N Diamond/E7200@3.2ghz/OCZ ReaperX1000mhz 2x2gb/(2)8800GT's/Corsair TX750W PSU/160gb WD HDD
Buck Nekid-Xion XON-303/Dell'd 650iMobo/Q6600@3.15ghz/Naya 4x1gb 667mhz/(2)8800GT's SLI/750W PSU/320gb WD HDD
Post by Mr. Scary »
I'm not running the cpu or the gpu's OC'd.
I get this after every work unit is done.
I go in to my folding folder(LOL that's funny sounding) and delete all the usual stuff, i.e. work folder, log, unit info, etc.
Then i start the client. i've started it from the shortcut as well as directly from the folder.
It trys to start 2-3 times. i do the delete thing and then finally, it grabs another wu and starts.
it runs the wu fine with no probs and no temp issues, then after it's done it Unstable_Machine's to the point of eue pausing 24hrs...
one of the logs is listed below(if i can figure out how to post it:)! any help would be greatly appreciate as i'm losing science and ppd,,,,both of which are important!!!! :lol: BUT i can't be here in front of the machine all the time and it's starting to drive me nutz!
I'm using 182.50 drivers like the other 3 rigs. they are the most stable drivers i've found. the gpu's are gtx 260's NOT oc'd. one's an msi and the other is an evga. is it possible i need different drivers for the 260's? the other rigs are running a mix of gpu's 8800GT's and 9800GX2's. all with the same driver all having no problems. the cpu is an e8200, NOT oc'd on a MSI p6n diamond mobo with 2x2gb's of NOT OC'd memory at stock specs. OS is vista ult 64bit, 1 320gb hdd and a dell 750W psu.
i've also checked the client config file and it looks to be normal/good/the usual :)
thanks much all for any help you can give me, i'm really at the end of my rope.
M$
[12:53:16] Completed 92%
[12:54:30] Completed 93%
[12:55:45] Completed 94%
[12:56:59] Completed 95%
[12:58:13] Completed 96%
[12:59:28] Completed 97%
[13:00:42] Completed 98%
[13:01:57] Completed 99%
[13:03:11] Completed 100%
[13:03:11] Successful run
[13:03:11] DynamicWrapper: Finished Work Unit: sleep=10000
[13:03:21] Reserved 101340 bytes for xtc file; Cosm status=0
[13:03:21] Allocated 101340 bytes for xtc file
[13:03:21] - Reading up to 101340 from "work/wudata_02.xtc": Read 101340
[13:03:21] Read 101340 bytes from xtc file; available packet space=786329124
[13:03:21] xtc file hash check passed.
[13:03:21] Reserved 30216 30216 786329124 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[13:03:21] Allocated 30216 bytes for arc file
[13:03:21] - Reading up to 30216 from "work/wudata_02.trr": Read 30216
[13:03:21] Read 30216 bytes from arc file; available packet space=786298908
[13:03:21] trr file hash check passed.
[13:03:21] Allocated 560 bytes for edr file
[13:03:21] Read bedfile
[13:03:21] edr file hash check passed.
[13:03:21] Logfile not read.
[13:03:21] GuardedRun: success in DynamicWrapper
[13:03:21] GuardedRun: done
[13:03:21] Run: GuardedRun completed.
[13:03:23] + Opened results file
[13:03:23] - Writing 132628 bytes of core data to disk...
[13:03:23] Done: 132116 -> 131661 (compressed to 99.6 percent)
[13:03:23]   ... Done.
[13:03:24] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[13:03:24] Shutting down core
[13:03:24]
[13:03:24] Folding@home Core Shutdown: FINISHED_UNIT
[13:03:26] CoreStatus = 64 (100)
[13:03:26] Sending work to server
[13:03:26] Project: 10102 (Run 891, Clone 4, Gen 1)
[13:03:26] - Read packet limit of 540015616... Set to 524286976.
[13:03:26] + Attempting to send results [February 4 13:03:26 UTC]
[13:03:27] + Results successfully sent
[13:03:27] Thank you for your contribution to Folding@Home.
[13:03:27] + Number of Units Completed: 384
[13:03:31] - Preparing to get new work unit...
[13:03:31] + Attempting to get work packet
[13:03:31] - Connecting to assignment server
[13:03:31] - Successful: assigned to (171.67.108.11).
[13:03:31] + News From Folding@Home: Welcome to Folding@Home
[13:03:32] Loaded queue successfully.
[13:03:33] + Closed connections
[13:03:33]
[13:03:33] + Processing work unit
[13:03:33] Core required: FahCore_11.exe
[13:03:33] Core found.
[13:03:33] Working on queue slot 03 [February 4 13:03:33 UTC]
[13:03:33] + Working ...
[13:03:33]
[13:03:33] *------------------------------*
[13:03:33] Folding@Home GPU Core
[13:03:33] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[13:03:33]
[13:03:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:03:33] Build host: amoeba
[13:03:33] Board Type: Nvidia
[13:03:33] Core      :
[13:03:33] Preparing to commence simulation
[13:03:33] - Looking at optimizations...
[13:03:33] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[13:03:33] - Created dyn
[13:03:33] - Files status OK
[13:03:33] - Expanded 46686 -> 252912 (decompressed 541.7 percent)
[13:03:33] Called DecompressByteArray: compressed_data_size=46686 data_size=252912, decompressed_data_size=252912 diff=0
[13:03:33] - Digital signature verified
[13:03:33]
[13:03:33] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:03:33]
[13:03:33] Assembly optimizations on if available.
[13:03:33] Entering M.D.
[13:03:39] Tpr hash work/wudata_03.tpr:  233222033 3990997042 1681933075 513394795 4004266800
[13:03:39]
[13:03:39] Calling fah_main args: 14 usage=100
[13:03:39]
[13:03:40] Working on Protein
[13:03:41] mdrun_gpu returned
[13:03:41] Self-test failure
[13:03:41]
[13:03:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:03:43] CoreStatus = 7A (122)
[13:03:43] Sending work to server
[13:03:43] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:03:43] - Read packet limit of 540015616... Set to 524286976.
[13:03:43] - Error: Could not get length of results file work/wuresults_03.dat
[13:03:43] - Error: Could not read unit 03 file. Removing from queue.
[13:03:43] - Preparing to get new work unit...
[13:03:43] + Attempting to get work packet
[13:03:43] - Connecting to assignment server
[13:03:44] - Successful: assigned to (171.67.108.11).
[13:03:44] + News From Folding@Home: Welcome to Folding@Home
[13:03:44] Loaded queue successfully.
[13:03:44] + Closed connections
[13:03:49]
[13:03:49] + Processing work unit
[13:03:49] Core required: FahCore_11.exe
[13:03:49] Core found.
[13:03:49] Working on queue slot 04 [February 4 13:03:49 UTC]
[13:03:49] + Working ...
[13:03:49]
[13:03:49] *------------------------------*
[13:03:49] Folding@Home GPU Core
[13:03:49] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[13:03:49]
[13:03:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:03:49] Build host: amoeba
[13:03:49] Board Type: Nvidia
[13:03:49] Core      :
[13:03:49] Preparing to commence simulation
[13:03:49] - Looking at optimizations...
[13:03:49] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[13:03:49] - Created dyn
[13:03:49] - Files status OK
[13:03:49] - Expanded 46686 -> 252912 (decompressed 541.7 percent)
[13:03:49] Called DecompressByteArray: compressed_data_size=46686 data_size=252912, decompressed_data_size=252912 diff=0
[13:03:49] - Digital signature verified
[13:03:49]
[13:03:49] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:03:49]
[13:03:49] Assembly optimizations on if available.
[13:03:49] Entering M.D.
[13:03:55] Tpr hash work/wudata_04.tpr:  233222033 3990997042 1681933075 513394795 4004266800
[13:03:55]
[13:03:55] Calling fah_main args: 14 usage=100
[13:03:55]
[13:03:56] Working on Protein
[13:03:56] mdrun_gpu returned
[13:03:56] Self-test failure
[13:03:56]
[13:03:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:03:59] CoreStatus = 7A (122)
[13:03:59] Sending work to server
[13:03:59] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:03:59] - Read packet limit of 540015616... Set to 524286976.
[13:03:59] - Error: Could not get length of results file work/wuresults_04.dat
[13:03:59] - Error: Could not read unit 04 file. Removing from queue.
[13:03:59] - Preparing to get new work unit...
[13:03:59] + Attempting to get work packet
[13:03:59] - Connecting to assignment server
[13:04:00] - Successful: assigned to (171.67.108.11).
[13:04:00] + News From Folding@Home: Welcome to Folding@Home
[13:04:00] Loaded queue successfully.
[13:04:00] + Closed connections
[13:04:05]
[13:04:05] + Processing work unit
[13:04:05] Core required: FahCore_11.exe
[13:04:05] Core found.
[13:04:05] Working on queue slot 05 [February 4 13:04:05 UTC]
[13:04:05] + Working ...
[13:04:05]
[13:04:05] *------------------------------*
[13:04:05] Folding@Home GPU Core
[13:04:05] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[13:04:05]
[13:04:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:04:05] Build host: amoeba
[13:04:05] Board Type: Nvidia
[13:04:05] Core      :
[13:04:05] Preparing to commence simulation
[13:04:05] - Looking at optimizations...
[13:04:05] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[13:04:05] - Created dyn
[13:04:05] - Files status OK
[13:04:05] - Expanded 46686 -> 252912 (decompressed 541.7 percent)
[13:04:05] Called DecompressByteArray: compressed_data_size=46686 data_size=252912, decompressed_data_size=252912 diff=0
[13:04:05] - Digital signature verified
[13:04:05]
[13:04:05] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:04:05]
[13:04:05] Assembly optimizations on if available.
[13:04:05] Entering M.D.
[13:04:11] Tpr hash work/wudata_05.tpr:  233222033 3990997042 1681933075 513394795 4004266800
[13:04:11]
[13:04:11] Calling fah_main args: 14 usage=100
[13:04:11]
[13:04:12] Working on Protein
[13:04:12] mdrun_gpu returned
[13:04:12] Self-test failure
[13:04:12]
[13:04:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:04:15] CoreStatus = 7A (122)
[13:04:15] Sending work to server
[13:04:15] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:04:15] - Read packet limit of 540015616... Set to 524286976.
[13:04:15] - Error: Could not get length of results file work/wuresults_05.dat
[13:04:15] - Error: Could not read unit 05 file. Removing from queue.
[13:04:15] - Preparing to get new work unit...
[13:04:15] + Attempting to get work packet
[13:04:15] - Connecting to assignment server
[13:04:16] - Successful: assigned to (171.67.108.11).
[13:04:16] + News From Folding@Home: Welcome to Folding@Home
[13:04:16] Loaded queue successfully.
[13:04:16] + Closed connections
[13:04:21]
[13:04:21] + Processing work unit
[13:04:21] Core required: FahCore_11.exe
[13:04:21] Core found.
[13:04:21] Working on queue slot 06 [February 4 13:04:21 UTC]
[13:04:21] + Working ...
[13:04:21]
[13:04:21] *------------------------------*
[13:04:21] Folding@Home GPU Core
[13:04:21] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[13:04:21]
[13:04:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:04:21] Build host: amoeba
[13:04:21] Board Type: Nvidia
[13:04:21] Core      :
[13:04:21] Preparing to commence simulation
[13:04:21] - Looking at optimizations...
[13:04:21] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[13:04:21] - Created dyn
[13:04:21] - Files status OK
[13:04:21] - Expanded 46686 -> 252912 (decompressed 541.7 percent)
[13:04:21] Called DecompressByteArray: compressed_data_size=46686 data_size=252912, decompressed_data_size=252912 diff=0
[13:04:21] - Digital signature verified
[13:04:21]
[13:04:21] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:04:21]
[13:04:21] Assembly optimizations on if available.
[13:04:21] Entering M.D.
[13:04:27] Tpr hash work/wudata_06.tpr:  233222033 3990997042 1681933075 513394795 4004266800
[13:04:27]
[13:04:27] Calling fah_main args: 14 usage=100
[13:04:27]
[13:04:28] Working on Protein
[13:04:28] mdrun_gpu returned
[13:04:28] Self-test failure
[13:04:28]
[13:04:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:04:31] CoreStatus = 7A (122)
[13:04:31] Sending work to server
[13:04:31] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:04:31] - Read packet limit of 540015616... Set to 524286976.
[13:04:31] - Error: Could not get length of results file work/wuresults_06.dat
[13:04:31] - Error: Could not read unit 06 file. Removing from queue.
[13:04:31] - Preparing to get new work unit...
[13:04:31] + Attempting to get work packet
[13:04:31] - Connecting to assignment server
[13:04:32] - Successful: assigned to (171.67.108.11).
[13:04:32] + News From Folding@Home: Welcome to Folding@Home
[13:04:32] Loaded queue successfully.
[13:04:33] + Closed connections
[13:04:38]
[13:04:38] + Processing work unit
[13:04:38] Core required: FahCore_11.exe
[13:04:38] Core found.
[13:04:38] Working on queue slot 07 [February 4 13:04:38 UTC]
[13:04:38] + Working ...
[13:04:38]
[13:04:38] *------------------------------*
[13:04:38] Folding@Home GPU Core
[13:04:38] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[13:04:38]
[13:04:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:04:38] Build host: amoeba
[13:04:38] Board Type: Nvidia
[13:04:38] Core      :
[13:04:38] Preparing to commence simulation
[13:04:38] - Looking at optimizations...
[13:04:38] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[13:04:38] - Created dyn
[13:04:38] - Files status OK
[13:04:38] - Expanded 46686 -> 252912 (decompressed 541.7 percent)
[13:04:38] Called DecompressByteArray: compressed_data_size=46686 data_size=252912, decompressed_data_size=252912 diff=0
[13:04:38] - Digital signature verified
[13:04:38]
[13:04:38] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:04:38]
[13:04:38] Assembly optimizations on if available.
[13:04:38] Entering M.D.
[13:04:44] Tpr hash work/wudata_07.tpr:  233222033 3990997042 1681933075 513394795 4004266800
[13:04:44]
[13:04:44] Calling fah_main args: 14 usage=100
[13:04:44]
[13:04:44] Working on Protein
[13:04:45] mdrun_gpu returned
[13:04:45] Self-test failure
[13:04:45]
[13:04:45] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:04:48] CoreStatus = 7A (122)
[13:04:48] Sending work to server
[13:04:48] Project: 5765 (Run 7, Clone 137, Gen 1672)
[13:04:48] - Read packet limit of 540015616... Set to 524286976.
[13:04:48] - Error: Could not get length of results file work/wuresults_07.dat
[13:04:48] - Error: Could not read unit 07 file. Removing from queue.
[13:04:48] EUE limit exceeded. Pausing 24 hours.
Mr. Scary
Re: Project Probs 5767&5765
Post by Mr. Scary »
sure enough, just like i posted.
did the start and stop thing 3 times,,,,starting it both ways.
got the same unstable_machine dealio
deleted all the 'stuff' over and over, then finally it give an unstable machine and retrys to start and then fire's up!
here's the log of it starting and running now.
help..??..??...
--- Opening Log file [February 4 15:16:20 UTC]
                          http://folding.stanford.edu
Launch directory: C:\F@H GPU 1
Executable: C:\F@H GPU 1\Folding@home-Win32-GPU.exe
Arguments: -gpu 0
[15:16:20] - Ask before connecting: No
[15:16:20] - User name: The_Garbage_Can_Club (Team 80856)
[15:16:20] - User ID: 71464A505D99F653
[15:16:20] - Machine ID: 1
[15:16:20]
[15:16:20] Work directory not found. Creating...
[15:16:20] Could not open work queue, generating new queue...
[15:16:20] - Preparing to get new work unit...
[15:16:20] + Attempting to get work packet
[15:16:20] - Connecting to assignment server
[15:16:21] - Successful: assigned to (171.67.108.11).
[15:16:21] + News From Folding@Home: Welcome to Folding@Home
[15:16:21] Loaded queue successfully.
[15:16:21] + Closed connections
[15:16:21]
[15:16:21] + Processing work unit
[15:16:21] Core required: FahCore_11.exe
[15:16:21] Core found.
[15:16:21] Working on queue slot 01 [February 4 15:16:21 UTC]
[15:16:21] + Working ...
[15:16:21]
[15:16:21] *------------------------------*
[15:16:21] Folding@Home GPU Core
[15:16:21] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[15:16:21]
[15:16:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:16:21] Build host: amoeba
[15:16:21] Board Type: Nvidia
[15:16:21] Core      :
[15:16:21] Preparing to commence simulation
[15:16:21] - Looking at optimizations...
[15:16:21] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[15:16:21] - Created dyn
[15:16:21] - Files status OK
[15:16:21] - Expanded 46704 -> 252912 (decompressed 541.5 percent)
[15:16:21] Called DecompressByteArray: compressed_data_size=46704 data_size=252912, decompressed_data_size=252912 diff=0
[15:16:21] - Digital signature verified
[15:16:21]
[15:16:21] Project: 5768 (Run 14, Clone 172, Gen 961)
[15:16:21]
[15:16:21] Assembly optimizations on if available.
[15:16:21] Entering M.D.
[15:16:27] Tpr hash work/wudata_01.tpr:  1659632032 1332496123 1405130735 3106253318 3682774152
[15:16:27]
[15:16:27] Calling fah_main args: 14 usage=100
[15:16:27]
[15:16:28] Working on Protein
[15:16:28] mdrun_gpu returned
[15:16:28] Self-test failure
[15:16:28]
[15:16:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:16:31] CoreStatus = 7A (122)
[15:16:31] Sending work to server
[15:16:31] Project: 5768 (Run 14, Clone 172, Gen 961)
[15:16:31] - Read packet limit of 540015616... Set to 524286976.
[15:16:31] - Error: Could not get length of results file work/wuresults_01.dat
[15:16:31] - Error: Could not read unit 01 file. Removing from queue.
[15:16:31] - Preparing to get new work unit...
[15:16:31] + Attempting to get work packet
[15:16:31] - Connecting to assignment server
[15:16:32] - Successful: assigned to (171.67.108.11).
[15:16:32] + News From Folding@Home: Welcome to Folding@Home
[15:16:32] Loaded queue successfully.
[15:16:32] + Closed connections
[15:16:37]
[15:16:37] + Processing work unit
[15:16:37] Core required: FahCore_11.exe
[15:16:37] Core found.
[15:16:37] Working on queue slot 02 [February 4 15:16:37 UTC]
[15:16:37] + Working ...
[15:16:37]
[15:16:37] *------------------------------*
[15:16:37] Folding@Home GPU Core
[15:16:37] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[15:16:37]
[15:16:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:16:37] Build host: amoeba
[15:16:37] Board Type: Nvidia
[15:16:37] Core      :
[15:16:37] Preparing to commence simulation
[15:16:37] - Looking at optimizations...
[15:16:37] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[15:16:37] - Created dyn
[15:16:37] - Files status OK
[15:16:37] - Expanded 46704 -> 252912 (decompressed 541.5 percent)
[15:16:37] Called DecompressByteArray: compressed_data_size=46704 data_size=252912, decompressed_data_size=252912 diff=0
[15:16:37] - Digital signature verified
[15:16:37]
[15:16:37] Project: 5768 (Run 14, Clone 172, Gen 961)
[15:16:37]
[15:16:37] Assembly optimizations on if available.
[15:16:37] Entering M.D.
[15:16:43] Tpr hash work/wudata_02.tpr:  1659632032 1332496123 1405130735 3106253318 3682774152
[15:16:43]
[15:16:43] Calling fah_main args: 14 usage=100
[15:16:43]
[15:16:44] Working on Protein
[15:16:44] mdrun_gpu returned
[15:16:44] Self-test failure
[15:16:44]
[15:16:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:16:47] CoreStatus = 7A (122)
[15:16:47] Sending work to server
[15:16:47] Project: 5768 (Run 14, Clone 172, Gen 961)
[15:16:47] - Read packet limit of 540015616... Set to 524286976.
[15:16:47] - Error: Could not get length of results file work/wuresults_02.dat
[15:16:47] - Error: Could not read unit 02 file. Removing from queue.
[15:16:47] - Preparing to get new work unit...
[15:16:47] + Attempting to get work packet
[15:16:47] - Connecting to assignment server
[15:16:48] - Successful: assigned to (171.67.108.11).
[15:16:48] + News From Folding@Home: Welcome to Folding@Home
[15:16:48] Loaded queue successfully.
[15:16:48] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[15:16:58] + Attempting to get work packet
[15:16:58] - Connecting to assignment server
[15:16:58] - Successful: assigned to (171.67.108.11).
[15:16:58] + News From Folding@Home: Welcome to Folding@Home
[15:16:58] Loaded queue successfully.
[15:16:59] + Closed connections
[15:17:04]
[15:17:04] + Processing work unit
[15:17:04] Core required: FahCore_11.exe
[15:17:04] Core found.
[15:17:04] Working on queue slot 03 [February 4 15:17:04 UTC]
[15:17:04] + Working ...
[15:17:04]
[15:17:04] *------------------------------*
[15:17:04] Folding@Home GPU Core
[15:17:04] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[15:17:04]
[15:17:04] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:17:04] Build host: amoeba
[15:17:04] Board Type: Nvidia
[15:17:04] Core      :
[15:17:04] Preparing to commence simulation
[15:17:04] - Looking at optimizations...
[15:17:04] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[15:17:04] - Created dyn
[15:17:04] - Files status OK
[15:17:04] - Expanded 45464 -> 251112 (decompressed 552.3 percent)
[15:17:04] Called DecompressByteArray: compressed_data_size=45464 data_size=251112, decompressed_data_size=251112 diff=0
[15:17:04] - Digital signature verified
[15:17:04]
[15:17:04] Project: 5770 (Run 9, Clone 137, Gen 2286)
[15:17:04]
[15:17:04] Assembly optimizations on if available.
[15:17:04] Entering M.D.
[15:17:10] Tpr hash work/wudata_03.tpr:  2519070134 3774527321 1695851231 3960642257 3863268089
[15:17:10]
[15:17:10] Calling fah_main args: 14 usage=100
[15:17:10]
[15:17:10] Working on Protein
[15:17:11] Client config found, loading data.
[15:17:11] Starting GUI Server
Something is wrong with either the hardware or the drivers.
Self-test failure
Have you tried MemtestG80?
This is how my 9800 GTX+ started to leave this world progressively ...
If you start getting this Self test failure along with NaNs detected on GPU at various and random progresses, that might be the same thing happening to your board.
Try to run a MemtestG80 to check your board ... and it might be wise to update these very old drivers.
