Hallo,
I have tried to upload a ready unit Project: 6318 (Run 1949, Clone 58, Gen 0) since January 24th.
But there is always the same message and I think there are any other errors than I read after using the search-function.
--- Opening Log file [February 1 17:56:24 UTC]
http://folding.stanford.edu
Launch directory: D:\Programme\Folding@Home\sic
Executable: D:\Programme\Folding@Home\sic\Folding@home-Win32-x86.exe
[17:56:24] - Ask before connecting: No
[17:56:24] - User name: JeansOn (Team 70335)
[17:56:24] - User ID: xxxxxxxxxxxxx
[17:56:24] - Machine ID: 1
[17:56:24]
[17:56:25] Loaded queue successfully.
[17:56:25]
[17:56:25] + Processing work unit
[17:56:25] Project: 6318 (Run 1949, Clone 58, Gen 0)
[17:56:25] Core required: FahCore_78.exe
[17:56:25] - Read packet limit of 540015616... Set to 524286976.
[17:56:25] Core found.
[17:56:25] + Attempting to send results [February 1 17:56:25 UTC]
[17:56:25] Working on queue slot 06 [February 1 17:56:25 UTC]
[17:56:26] + Working ...
[17:56:28]
[17:56:28] *------------------------------*
[17:56:28] Folding@Home Gromacs Core
[17:56:28] Version 1.90 (March 8, 2006)
[17:56:28]
[17:56:28] Preparing to commence simulation
[17:56:28] - Looking at optimizations...
[17:56:28] - Files status OK
[17:56:31] - Expanded 2961857 -> 15082413 (decompressed 509.2 percent)
[17:56:32]
[17:56:32] Project: 2499 (Run 7071, Clone 317, Gen 15)
[17:56:32]
[17:56:34] Assembly optimizations on if available.
[17:56:34] Entering M.D.
[17:56:56] (Starting from checkpoint)
[17:56:56] Protein: Translocon_ALX2
[17:56:56]
[17:56:56] Writing local files
[17:56:56] Completed 13765 out of 250000 steps (6%)
[17:56:58] Extra SSE boost OK.
[17:59:11] - Server does not have record of this unit. Will try again later.
[17:59:11] - Error: Could not transmit unit 05 (completed January 24) to work server.
[17:59:11] - Read packet limit of 540015616... Set to 524286976.
[17:59:11] + Attempting to send results [February 1 17:59:11 UTC]
[18:01:46] - Server does not have record of this unit. Will try again later.
[18:01:46] Could not transmit unit 05 to Collection server; keeping in queue.
Next is ..\F@H\work\logfile_05:
- Files status OK
- Expanded 390808 -> 2244040 (decompressed 574.2 percent)
Entering M.D.
Protein: Great Red Oystrich Makes All Chemists Sane in water
Writing local files
Completed 465000 out of 500000 steps (93%)
Extra SSE boost OK.
Writing local files
Completed 470000 out of 500000 steps (94%)
Writing local files
Completed 475000 out of 500000 steps (95%)
Writing local files
Completed 480000 out of 500000 steps (96%)
Writing local files
Completed 485000 out of 500000 steps (97%)
Writing local files
Completed 490000 out of 500000 steps (98%)
Writing local files
Completed 495000 out of 500000 steps (99%)
Writing local files
Completed 500000 out of 500000 steps (100%)
Writing final coordinates.
Past main M.D. loop
Finished Work Unit:
- Reading up to 362448 from "work/wudata_05.arc": Read 362448
- Reading up to 5825716 from "work/wudata_05.xtc": Read 5825716
goefile size: 0
Leaving Run
- Writing 7787144 bytes of core data to disk...
Done: 7786632 -> 6917530 (compressed to 88.8 percent)
... Done.
- Shutting down core
Folding@home Core Shutdown: FINISHED_UNIT
What can I do? Have I to wait only?
Greets
JeansOn
Server does not take a ready WU
Re: Server does not take a ready WU
See my response in the discussion here: viewtopic.php?f=18&t=12897&p=129325#p129325
Hello Bruce,
thank you for your reply.
I start my F@H Clients manually by desktop-icon.
I tried to upload without PC-Firewall / Antivirus (I'm working behind a router)
There are further downloads and uploads well done. But it might be interested, there are just two further clients running with a 6318 Project. I get them one after the other.
or :-/ I don't know in this moment. ^^
[21:03:51] Sending work to server
[21:03:51] Project: 6318 (Run 153, Clone 87, Gen 0)
[21:03:51] - Read packet limit of 540015616... Set to 524286976.
[21:03:51] + Attempting to send results [February 2 21:03:51 UTC]
[21:06:40] + Results successfully sent
[21:06:40] Thank you for your contribution to Folding@Home.
[21:06:40] + Number of Units Completed: 32
[21:06:45] - Preparing to get new work unit...
[21:06:45] + Attempting to get work packet
[21:06:45] - Connecting to assignment server
[21:06:46] - Successful: assigned to (171.64.65.60).
[21:06:46] + News From Folding@Home: Welcome to Folding@Home
[21:06:46] Loaded queue successfully.
[21:06:49] + Closed connections
[21:06:49]
[21:06:49] + Processing work unit
[21:06:49] Core required: FahCore_78.exe
[21:06:49] Core found.
[21:06:49] Working on queue slot 03 [February 2 21:06:49 UTC]
[21:06:49] + Working ...
[21:06:49]
[21:06:49] *------------------------------*
[21:06:49] Folding@Home Gromacs Core
[21:06:49] Version 1.90 (March 8, 2006)
[21:06:49]
[21:06:49] Preparing to commence simulation
[21:06:49] - Looking at optimizations...
[21:06:49] - Created dyn
[21:06:49] - Files status OK
[21:06:49] - Expanded 464406 -> 2244040 (decompressed 483.2 percent)
[21:06:49] - Starting from initial work packet
[21:06:49]
[21:06:49] Project: 6318 (Run 1846, Clone 16, Gen 1)
[21:06:49]
[21:06:49] Assembly optimizations on if available.
[21:06:49] Entering M.D.
[21:06:55] Protein: Great Red Oystrich Makes All Chemists Sane in water
[21:06:55]
[21:06:55] Writing local files
[21:06:55] Extra SSE boost OK.
[21:06:55] Completed 0 out of 500000 steps (0%)
I think there is a problem between the server and the WU -> Project: 6318 (Run 1949, Clone 58, Gen 0)
Perhaps a missing record in db?
[21:06:49]
[21:06:49]
[21:06:49]
[21:06:49]
[21:06:49]
[21:06:55]
Re: Server does not take two ready WU - PRJ 6318
Hello,
and here is the next WU, I can send, but server can not receive :-////
Sending stops after ~2 minutes
--- Opening Log file [February 5 19:30:32 UTC]
Launch directory: D:\Programme\F@H
Executable: D:\Programme\F@H\Folding@home-Win32-x86-client2.exe
[19:30:32] - Ask before connecting: No
[19:30:32] - User name: JeansOn (Team 70335)
[19:30:32] - User ID: 76477FD04111093B
[19:30:32] - Machine ID: 2
[19:30:32]
[19:30:32] Loaded queue successfully.
[19:30:32]
[19:30:32] + Processing work unit
[19:30:32] Project: 6318 (Run 1846, Clone 16, Gen 1)
[19:30:32] Core required: FahCore_78.exe
[19:30:32] - Read packet limit of 540015616... Set to 524286976.
[19:30:32] Core found.
[19:30:32] + Attempting to send results [February 5 19:30:32 UTC]
[19:30:32] Working on queue slot 04 [February 5 19:30:32 UTC]
[19:30:32] + Working ...
[19:30:32]
[19:30:32] *------------------------------*
[19:30:32] Folding@Home Gromacs Core
[19:30:32] Version 1.90 (March 8, 2006)
[19:30:32]
[19:30:32] Preparing to commence simulation
[19:30:32] - Looking at optimizations...
[19:30:32] - Files status OK
[19:30:51] - Expanded 9257057 -> 47924691 (decompressed 53.7 percent)
[19:30:51]
[19:30:51] Project: 2613 (Run 33, Clone 17, Gen 72)
[19:30:51]
[19:30:51] Assembly optimizations on if available.
[19:30:51] Entering M.D.
[19:31:13] (Starting from checkpoint)
[19:31:14] Protein: p2613_TETHERED VESICLES
[19:31:14]
[19:31:14] Writing local files
[19:31:27] Extra SSE boost OK.
[19:31:27] Writing local files
[19:31:28] Completed 0 out of 125000 steps (0%)
[19:32:21] - Couldn't send HTTP request to server
[19:32:21] + Could not connect to Work Server (results) <-- Disconnect by provider it's NetCologne after 12h
[19:32:21] (171.64.65.60:8080)
[19:32:21] + Retrying using alternative port
[19:32:28] - Couldn't send HTTP request to server
[19:32:28] + Could not connect to Work Server (results)
[19:32:28] (171.64.65.60:80)
[19:32:28] - Error: Could not transmit unit 03 (completed February 5) to work server.
[19:32:28] - Read packet limit of 540015616... Set to 524286976.
[19:32:28] + Attempting to send results [February 5 19:32:28 UTC]
[19:36:12] - Server does not have record of this unit. Will try again later.
[19:36:12] Could not transmit unit 03 to Collection server; keeping in queue.
Folding@Home Client Shutdown.
[19:36:45]
--- Opening Log file [February 5 19:36:51 UTC]
[19:36:51] - Ask before connecting: No
[19:36:51] - User name: JeansOn (Team 70335)
[19:36:51] - User ID: 76477FD04111093B
[19:36:51] - Machine ID: 2
[19:36:51]
[19:36:51] Loaded queue successfully.
[19:36:51]
[19:36:51] Project: 6318 (Run 1846, Clone 16, Gen 1)
[19:36:51] + Processing work unit
[19:36:51] - Read packet limit of 540015616... [19:36:51] Core required: FahCore_78.exe
Set to 524286976.
[19:36:51] Core found.
[19:36:51] + Attempting to send results [February 5 19:36:51 UTC]
[19:36:51] Working on queue slot 04 [February 5 19:36:51 UTC]
[19:36:51] + Working ...
[19:36:51]
[19:36:51] *------------------------------*
[19:36:51] Folding@Home Gromacs Core
[19:36:51] Version 1.90 (March 8, 2006)
[19:36:51]
[19:36:51] Preparing to commence simulation
[19:36:51] - Looking at optimizations...
[19:36:52] - Files status OK
[19:37:09] - Expanded 9257057 -> 47924691 (decompressed 53.7 percent)
[19:37:10]
[19:37:10] Project: 2613 (Run 33, Clone 17, Gen 72)
[19:37:10]
[19:37:14] Assembly optimizations on if available.
[19:37:14] Entering M.D.
[19:37:36] (Starting from checkpoint)
[19:37:36] Protein: p2613_TETHERED VESICLES
[19:37:36]
[19:37:36] Writing local files
[19:37:36] Completed 158 out of 125000 steps (0%)
[19:37:49] Extra SSE boost OK.
[19:39:22] - Server does not have record of this unit. Will try again later.
[19:39:22] - Error: Could not transmit unit 03 (completed February 5) to work server.
[19:39:22] - Read packet limit of 540015616... Set to 524286976.
[19:39:22] + Attempting to send results [February 5 19:39:22 UTC]
[19:42:05] - Server does not have record of this unit. Will try again later.
[19:42:05] Could not transmit unit 03 to Collection server; keeping in queue.
and I have an other, 6318-WU 80% finished
I think, I'll better cancel new 6318-WUs in future.
Does anyone has an idea what I can do? mail-adress for problems? A secret mail-adress for such a problem?
[19:30:32]
[19:30:32]
[19:30:32]
[19:30:32]
[19:30:51]
[19:30:51]
[19:31:14]
[19:36:45]
[19:36:51]
[19:36:51]
Set to 524286976.
[19:36:51]
[19:36:51]
[19:37:10]
[19:37:10]
[19:37:36]
It's never better to cancel WUs. It'll hurt the project more than waiting for someone to fix the server (which is probably being worked on since it's going online and offline alternatively in the past two days).
There's nothing you can do but wait ...
I fear, you are right,toTOW.
But I remember I had read that it is better for the project I reach the prefered time. After that time there are only the points ...
My first WU I can not send became ready at January 24th. In several days I'll finish it by deleting. It is lost project power. I write about it - others don't.
Of course it's better for the project if you can meet the preferred deadline. I'm certain that the guys that are trying to fix the server know that, too, but until they complete whatever they're doing, there's nothing at all that any of us can do . . . except to be patient.
See Vijay's update --> viewtopic.php?f=19&t=13010&start=60#p129884
Thank you, bruce, AgrFan.
My new experience is, I'm not alone in this forum. I bookmarked the posted link, it's easier for me in future to find the right / better place. The error-message is an other now. I think the guys are working. I'll post the link in my team forum (it is PCGamesHardware). My sons are folding in that team too.
