My two pence worth:
I use the WinDoze Client, so posted it here, suppose it should go in the Linux Section, but Hey-Ho, here goes.
--> Would like a way to install ( deploy ) the beast to headless Linux Clients.
--> Ability to Cache WU's locally and serve them out to nodes via Proxy or something similar.
--> Ability to Sart / Stop / Restart / administer headless nodes from a central server / workstation. A simple web-server application would do nicely.
--> An Error Report generation tool, similar to bugzilla would be good I think. Help automate capturing information that you need to fix things.
The biggest problems I face daily and particularly when new WU's / Clients / Cores are releasesd is administering remote nodes with issues. Anything to improve installation and sustaining maintenace from a central workstation would be ++ for me especially in the Linux world.
Suggestions
KE1HA
- Hardware configuration: Beta Rig - All Stock For Testing
| Q9770 3.2GHz | Rampage Formula | 4GB OCZ Reaper 8500
| BFG 8800 GTS | Raptor 73GB | G15 | Razer Copperhead |
| ASUS MK2401H HDMI @ 1920x1200 | - Location: San Jose, CA
Suggestions
2x - Q6600 1 with 2x 9800GT's / 1 with 2x 8800GTS G92 512's UB-8.04 CLI Only
2x - AMD 9850 1 with 3x 9800 GT's / 1 with 1x 9800 GT's UB-8.04 CLI Only
1x - QX9770 GTX-280 WinDoze Vista 64
