how to run advmetholds
hootis
- Hardware configuration: AMD Phenom II 955 @ 3.8 +ATi HD 5870
AMD Athlon II 610e @ 2.5 + 2x Nvidia 560Ti @ 1ghz
AMD Athlon II 605e @ 2.4 +Nvidia 550Ti + Nvidia GT 240
AMD Athlon II 620 @ 3.3ghz
is it a simple as it sounds just add -advmetholds flag to your smp just making sure thanks
Things yet to materialize.
Re: how to run advmetholds
Same as every other flag.
http://fahwiki.net/index.php/How_do_I_a ... _client%3F
http://fahwiki.net/index.php/How_do_I_a ... ce_mode%3F
How_do_I_reconfigure_the_console_client to add flags to the Additional Parameters field?
http://fahwiki.net/index.php/How_do_I_k ... they_do%3F
chrisretusn
- Hardware configuration: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
AMD Athlon(tm) XP 2600+ - Location: Philippines
Here is quick rundown on setting -advmethods using the Linux 6.29 Client with the -configonly parameter. If this method is used you do not have to add the -advmethods parameter when starting fah6. In fact you start fah6 with no parameters using this method.
Note: This does not work with the Linux 6.02 client, I know it works with 6.24beta and 6.29.
folder@racermach:~/fah6$ fah6 -configonly
User name [chrisretusn]?
Team Number [2291]?
Passkey [XXXX]?
Ask before fetching/sending work (no/yes) [no]?
Use proxy (yes/no) [no]?
Acceptable size of work assignment and work result packets (bigger units
may have large memory demands) -- 'small' is <5MB, 'normal' is <10MB, and
'big' is >10MB (small/normal/big) [big]?
Change advanced options (yes/no) [no]? y <<<<< ------ y or yes
Core Priority (idle/low) [idle]?
Disable highly optimized assembly code (no/yes) [no]?
Interval, in minutes, between checkpoints (3-30) [15]?
Memory, in MB, to indicate (3816 available) [3816]?
Set -advmethods flag always, requesting new advanced
scientific cores and/or work units if available (no/yes) [yes]? <<<<<< ----- y or yes
Ignore any deadline information (mainly useful if
system clock frequently has errors) (no/yes) [no]?
Machine ID (1-16) [1]?
The following options require you to restart the client before they take effect
Disable CPU affinity lock (no/yes) [no]?
Additional client parameters. Use space to clear. [-verbosity 9 -smp -oneunit]?
IP address to bind core to (for viewer). Use space to clear []?
Team Number [2291]?
Passkey [XXXX]?
