171.67.108.11 outta work
statesidecoma
Can you check this server and see if it is out of work? Or is my client just all the sudden causing the issue. Checked server page, it says accepting. With 80,000 WU's left. So is the problem on my end?
Re: 171.67.108.11 outta work
That server has a lot of WUs and is assigning them at a rapid pace. Note the value in the "% Ass G" column.
