171.64.65.64:8080
MoneyGuyBK
171.64.65.64:8080
Post by MoneyGuyBK »
I searched and all threads for this server seem to be locked; so I'm starting a new one.
@ Mods .... please do move this post where it belongs if you so see the need.
[17:42:48] Completed 247500 out of 250000 steps  (99 percent)
[18:05:01] Writing local files
[18:05:01] Completed 250000 out of 250000 steps  (100 percent)
[18:05:01] Writing final coordinates.
[18:05:02] Past main M.D. loop
[18:05:02] Will end MPI now
[18:06:02]
[18:06:02] Finished Work Unit:
[18:06:02] - Reading up to 21310704 from "work/wudata_01.arc": Read 21310704
[18:06:03] - Reading up to 561972 from "work/wudata_01.xtc": Read 561972
[18:06:03] goefile size: 0
[18:06:03] logfile size: 203288
[18:06:03] Leaving Run
[18:06:03] - Writing 22082336 bytes of core data to disk...
[18:06:03]   ... Done.
[18:06:03] - Failed to delete work/wudata_01.sas
[18:06:03] - Failed to delete work/wudata_01.goe
[18:06:03] Warning:  check for stray files
[18:06:03] - Shutting down core
[18:08:03]
[18:08:03] Folding@home Core Shutdown: FINISHED_UNIT
[18:08:03]
[18:08:07] CoreStatus = 7B (123)
[18:08:07] Sending work to server
[18:08:07] Project: 2665 (Run 3, Clone 140, Gen 152)
[18:08:07] + Attempting to send results [January 19 18:08:07 UTC]
[18:08:07] - Reading file work/wuresults_01.dat from core
[18:08:07]   (Read 22082336 bytes from disk)
[18:08:07] Connecting to http://171.64.65.64:8080/
[18:08:28] - Couldn't send HTTP request to server
[18:08:28] + Could not connect to Work Server (results)
[18:08:28]     (171.64.65.64:8080)
[18:08:28] + Retrying using alternative port
[18:08:28] Connecting to http://171.64.65.64:80/
[18:08:49] - Couldn't send HTTP request to server
[18:08:49] + Could not connect to Work Server (results)
[18:08:49]     (171.64.65.64:80)
[18:08:49] - Error: Could not transmit unit 01 (completed January 19) to work server.
[18:08:49] - 1 failed uploads of this unit.
[18:08:49]   Keeping unit 01 in queue.
[18:08:49] Trying to send all finished work units
[18:08:49] Project: 2665 (Run 3, Clone 140, Gen 152)
[18:08:49] + Attempting to send results [January 19 18:08:49 UTC]
[18:08:49] - Reading file work/wuresults_01.dat from core
[18:08:49]   (Read 22082336 bytes from disk)
[18:08:49] Connecting to http://171.64.65.64:8080/
[18:09:10] - Couldn't send HTTP request to server
[18:09:10] + Could not connect to Work Server (results)
[18:09:10]     (171.64.65.64:8080)
[18:09:10] + Retrying using alternative port
[18:09:10] Connecting to http://171.64.65.64:80/
[18:09:31] - Couldn't send HTTP request to server
[18:09:31] + Could not connect to Work Server (results)
[18:09:31]     (171.64.65.64:80)
[18:09:31] - Error: Could not transmit unit 01 (completed January 19) to work server.
[18:09:31] - 2 failed uploads of this unit.
[18:09:31] + Attempting to send results [January 19 18:09:31 UTC]
[18:09:31] - Reading file work/wuresults_01.dat from core
[18:09:31]   (Read 22082336 bytes from disk)
[18:09:31] Connecting to http://171.67.108.25:8080/
[18:09:31]   (Got status 503)
[18:09:31]     (171.67.108.25:8080)
[18:09:31] + Retrying using alternative port
[18:09:31] Connecting to http://171.67.108.25:80/
[18:09:31]     (171.67.108.25:80)
[18:09:31]   Could not transmit unit 01 to Collection server; keeping in queue.
[18:09:31] + Sent 0 of 1 completed units to the server
[18:09:31] - Preparing to get new work unit...
[18:09:31] Cleaning up work directory
[18:09:33] + Attempting to get work packet
[18:09:33] - Will indicate memory of 4047 MB
[18:09:33] - Connecting to assignment server
[18:09:33] Connecting to http://assign.stanford.edu:8080/
[18:09:33] Posted data.
[18:09:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:09:33] + Couldn't get work instructions.
[18:09:33] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[18:09:44] + Attempting to get work packet
[18:09:44] - Will indicate memory of 4047 MB
[18:09:44] - Connecting to assignment server
[18:09:44] Connecting to http://assign.stanford.edu:8080/
[18:09:44] Posted data.
[18:09:44] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:09:44] + Couldn't get work instructions.
[18:09:44] - Attempt #2  to get work failed, and no other work to do.
[18:10:00] + Attempting to get work packet
[18:10:00] - Will indicate memory of 4047 MB
[18:10:00] - Connecting to assignment server
[18:10:00] Connecting to http://assign.stanford.edu:8080/
[18:10:01] Posted data.
[18:10:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:10:01] + Couldn't get work instructions.
[18:10:01] - Attempt #3  to get work failed, and no other work to do.
[18:10:32] + Attempting to get work packet
[18:10:32] - Will indicate memory of 4047 MB
[18:10:32] - Connecting to assignment server
[18:10:32] Connecting to http://assign.stanford.edu:8080/
[18:10:32] Posted data.
[18:10:32] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:10:32] + Couldn't get work instructions.
[18:10:32] - Attempt #4  to get work failed, and no other work to do.
[18:11:12] + Attempting to get work packet
[18:11:12] - Will indicate memory of 4047 MB
[18:11:12] - Connecting to assignment server
[18:11:12] Connecting to http://assign.stanford.edu:8080/
[18:11:13] Posted data.
[18:11:13] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:11:13] + Couldn't get work instructions.
[18:11:13] - Attempt #5  to get work failed, and no other work to do.
[18:12:43] + Attempting to get work packet
[18:12:43] - Will indicate memory of 4047 MB
[18:12:43] - Connecting to assignment server
[18:12:43] Connecting to http://assign.stanford.edu:8080/
[18:12:44] Posted data.
[18:12:44] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:12:44] + Couldn't get work instructions.
[18:12:44] - Attempt #6  to get work failed, and no other work to do.
[18:15:31] + Attempting to get work packet
[18:15:31] - Will indicate memory of 4047 MB
[18:15:31] - Connecting to assignment server
[18:15:31] Connecting to http://assign.stanford.edu:8080/
[18:15:31] Posted data.
[18:15:31] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:15:31] + Couldn't get work instructions.
[18:15:31] - Attempt #7  to get work failed, and no other work to do.
[18:21:02] + Attempting to get work packet
[18:21:02] - Will indicate memory of 4047 MB
[18:21:02] - Connecting to assignment server
[18:21:02] Connecting to http://assign.stanford.edu:8080/
[18:21:02] Posted data.
[18:21:02] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:21:02] + Couldn't get work instructions.
[18:21:02] - Attempt #8  to get work failed, and no other work to do.
[18:31:54] + Attempting to get work packet
[18:31:54] - Will indicate memory of 4047 MB
[18:31:54] - Connecting to assignment server
[18:31:54] Connecting to http://assign.stanford.edu:8080/
[18:31:54] Posted data.
[18:31:54] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:31:54] + Couldn't get work instructions.
[18:31:54] - Attempt #9  to get work failed, and no other work to do.
[18:53:21] + Attempting to get work packet
[18:53:21] - Will indicate memory of 4047 MB
[18:53:21] - Connecting to assignment server
[18:53:21] Connecting to http://assign.stanford.edu:8080/
[18:53:26] Posted data.
[18:53:26] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:53:26] + Couldn't get work instructions.
[18:53:26] - Attempt #10  to get work failed, and no other work to do.
Peace
T.E.A.M. “Together Everyone Accomplishes Miracles!”
OC, S. California ... God Bless All
kasson
Pande Group Member
Re: 171.64.65.64:8080
Post by kasson »
Please see the thread about the power outage and Dr. Pande's blog post. This server is still down.
This server is still down because of the power outage : viewtopic.php?f=24&t=12962
edit : damn, too slow :shock:
MoneyGuyBK
Thanx guys
Peace
