Cheers
Consolidating Points
I do not have an issue with a specific server, my problem is with how the my stats are being shown. Is it possible to consolidate all my points under my username/passkey? I finally got my passkey, but ever since I updated my clients configuration with it, my points seem to be separated into before the passkey and after the passkey. When I search for my username without the passkey I get one points total returned, and another total when use the passkey. At the same time I was updating the passkey I realized I had input the wrong team id (dooh) so I did a little work for another team
Is it possible to also have those point consolidated too (and assigned to the proper team)
Cheers
Cheers
Re: Consolidating Points
When you requested your passkey, you used a unique combination of fah user name and email address combination. Because that is unique, fah can use that to distinguish you from any other wkhudsons that are currently folding.
How would you suppose they seperate the points for the 37 JohnSmiths that are folding right now? And less than half of them are using passkeys...
Unfortunately there is no unique identifier to seperate out the points before and after the passkey, let alone people with similar names. And without that ability, it would be unfair to try.
Thanks 7im, I thought that might be the case, I thought that because I was the only wkhudson out there when I did a donor stats search, it might be possible. Thanks anyways.
