171.67.108.21 is Reject;
oivisao
Post by oivisao »
can not send results==> servet has no record of the unit.
log
[07:30:04] Completed 94%
[07:32:32] Completed 95%
[07:34:52] Completed 96%
[07:37:11] Completed 97%
[07:39:32] Completed 98%
[07:41:54] Completed 99%
[07:44:16] Completed 100%
[07:44:16] Successful run
[07:44:16] DynamicWrapper: Finished Work Unit: sleep=10000
[07:44:26] Reserved 144884 bytes for xtc file; Cosm status=0
[07:44:26] Allocated 144884 bytes for xtc file
[07:44:26] - Reading up to 144884 from "work/wudata_08.xtc": Read 144884
[07:44:26] Read 144884 bytes from xtc file; available packet space=786285580
[07:44:26] xtc file hash check passed.
[07:44:26] Reserved 22056 22056 786285580 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[07:44:26] Allocated 22056 bytes for arc file
[07:44:26] - Reading up to 22056 from "work/wudata_08.trr": Read 22056
[07:44:26] Read 22056 bytes from arc file; available packet space=786263524
[07:44:26] trr file hash check passed.
[07:44:26] Allocated 560 bytes for edr file
[07:44:26] Read bedfile
[07:44:26] edr file hash check passed.
[07:44:26] Logfile not read.
[07:44:26] GuardedRun: success in DynamicWrapper
[07:44:26] GuardedRun: done
[07:44:26] Run: GuardedRun completed.
[07:44:27] + Opened results file
[07:44:27] - Writing 168012 bytes of core data to disk...
[07:44:27] Done: 167500 -> 165998 (compressed to 99.1 percent)
[07:44:27]   ... Done.
[07:44:27] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[07:44:27] Shutting down core
[07:44:27]
[07:44:27] Folding@home Core Shutdown: FINISHED_UNIT
[07:44:31] CoreStatus = 64 (100)
[07:44:31] Sending work to server
[07:44:31] Project: 5786 (Run 0, Clone 35, Gen 5)
[07:44:31] + Attempting to send results [January 17 07:44:31 UTC]
[07:44:43] - Couldn't send HTTP request to server
[07:44:43] + Could not connect to Work Server (results)
[07:44:43]     (171.67.108.21:8080)
[07:44:43] + Retrying using alternative port
[07:45:04] - Couldn't send HTTP request to server
[07:45:04] + Could not connect to Work Server (results)
[07:45:04]     (171.67.108.21:80)
[07:45:04] - Error: Could not transmit unit 08 (completed January 17) to work server.
[07:45:04]   Keeping unit 08 in queue.
[07:45:04] Project: 5784 (Run 5, Clone 39, Gen 1)
[07:45:04] + Attempting to send results [January 17 07:45:04 UTC]
[07:45:11] - Couldn't send HTTP request to server
[07:45:11] + Could not connect to Work Server (results)
[07:45:11]     (171.67.108.21:8080)
[07:45:11] + Retrying using alternative port
[07:45:32] - Couldn't send HTTP request to server
[07:45:32] + Could not connect to Work Server (results)
[07:45:32]     (171.67.108.21:80)
[07:45:32] - Error: Could not transmit unit 03 (completed January 15) to work server.
[07:45:32] + Attempting to send results [January 17 07:45:32 UTC]
[07:45:51] - Server does not have record of this unit. Will try again later.
[07:45:51]   Could not transmit unit 03 to Collection server; keeping in queue.
[07:45:51] Project: 5786 (Run 0, Clone 35, Gen 5)
[07:45:51] + Attempting to send results [January 17 07:45:51 UTC]
[07:46:03] - Couldn't send HTTP request to server
[07:46:03] + Could not connect to Work Server (results)
[07:46:03]     (171.67.108.21:8080)
[07:46:03] + Retrying using alternative port
[07:46:24] - Couldn't send HTTP request to server
[07:46:24] + Could not connect to Work Server (results)
[07:46:24]     (171.67.108.21:80)
[07:46:24] - Error: Could not transmit unit 08 (completed January 17) to work server.
[07:46:24] + Attempting to send results [January 17 07:46:24 UTC]
[07:46:34] - Server does not have record of this unit. Will try again later.
[07:46:34]   Could not transmit unit 08 to Collection server; keeping in queue.
[07:46:34] - Preparing to get new work unit...
[07:46:34] + Attempting to get work packet
[07:46:34] - Connecting to assignment server
[07:46:36] - Successful: assigned to (171.67.108.11).
[07:46:36] + News From Folding@Home: Welcome to Folding@Home
[07:46:37] Loaded queue successfully.
[07:46:40] Project: 5784 (Run 5, Clone 39, Gen 1)
[07:46:40] + Attempting to send results [January 17 07:46:40 UTC]
[07:46:51] - Couldn't send HTTP request to server
[07:46:51] + Could not connect to Work Server (results)
[07:46:51]     (171.67.108.21:8080)
[07:46:51] + Retrying using alternative port
[07:47:12] - Couldn't send HTTP request to server
[07:47:12] + Could not connect to Work Server (results)
[07:47:12]     (171.67.108.21:80)
[07:47:12] - Error: Could not transmit unit 03 (completed January 15) to work server.
[07:47:12] + Attempting to send results [January 17 07:47:12 UTC]
[07:47:24] - Server does not have record of this unit. Will try again later.
[07:47:24]   Could not transmit unit 03 to Collection server; keeping in queue.
[07:47:24] Project: 5786 (Run 0, Clone 35, Gen 5)
[07:47:24] + Attempting to send results [January 17 07:47:24 UTC]
[07:47:33] - Couldn't send HTTP request to server
[07:47:33] + Could not connect to Work Server (results)
[07:47:33]     (171.67.108.21:8080)
[07:47:33] + Retrying using alternative port
[07:47:54] - Couldn't send HTTP request to server
[07:47:54] + Could not connect to Work Server (results)
[07:47:54]     (171.67.108.21:80)
[07:47:54] - Error: Could not transmit unit 08 (completed January 17) to work server.
[07:47:54] + Attempting to send results [January 17 07:47:54 UTC]
[07:48:12] - Server does not have record of this unit. Will try again later.
[07:48:12]   Could not transmit unit 08 to Collection server; keeping in queue.
[07:48:12] + Closed connections
Re: Project: 5786 (R0, C35, G5) and 5784 ( R5, C39, G1)
Eventually, the server that is responsible for these project is the Work Server and you were not able to contact that sever. I didn't check, but if it was down, your client will hold the WUs and retry them later.
When a Work Server is down, the client also tries to upload to a Collection Server. Sometimes this is successful, but one possible error is that the Collection server has no record of the WU. This happens when the Works server is down and will be fixed when the Work Server is back on-line.
Please be patient.
RGene
Post by RGene »
i've got the same problem with units 5786 (11-32-3), 5785 (10-85-3), 5786 (1-55-14).
--- Opening Log file [January 23 13:46:16 UTC]
                          http://folding.stanford.edu
Launch directory: D:\Program Files\FAH-GPU1
Arguments: -send all -gpu 1
[13:46:16] - Ask before connecting: No
[13:46:16] - User name: RGene (Team 47191)
[13:46:16] - User ID: 72AC19F01BACF7A2
[13:46:16] - Machine ID: 1
[13:46:16]
[13:46:16] Loaded queue successfully.
[13:46:16] Initialization complete
[13:46:16] Attempting to return result(s) to server...
[13:46:16] Project: 5786 (Run 11, Clone 32, Gen 3)
[13:46:16] - Read packet limit of 540015616... Set to 524286976.
[13:46:16] + Attempting to send results [January 23 13:46:16 UTC]
[13:46:18] - Couldn't send HTTP request to server
[13:46:18] + Could not connect to Work Server (results)
[13:46:18]     (171.67.108.21:8080)
[13:46:18] + Retrying using alternative port
[13:46:39] - Couldn't send HTTP request to server
[13:46:39] + Could not connect to Work Server (results)
[13:46:39]     (171.67.108.21:80)
[13:46:39] - Error: Could not transmit unit 02 (completed January 17) to work server.
[13:46:39] - Read packet limit of 540015616... Set to 524286976.
[13:46:39] + Attempting to send results [January 23 13:46:39 UTC]
[13:46:41] - Server does not have record of this unit. Will try again later.
[13:46:41]   Could not transmit unit 02 to Collection server; keeping in queue.
[13:46:41] - Failed to send all units to server
Folding@Home Client Shutdown.
--- Opening Log file [January 23 13:43:00 UTC]
Launch directory: D:\Program Files\FAH-GPU2
Arguments: -send all -gpu 0
[13:43:00] - Ask before connecting: No
[13:43:00] - User name: RGene (Team 47191)
[13:43:00] - User ID: 72AC19F01BACF7A2
[13:43:00] - Machine ID: 2
[13:43:00]
[13:43:00] Loaded queue successfully.
[13:43:00] Initialization complete
[13:43:00] Attempting to return result(s) to server...
[13:43:00] Project: 5785 (Run 10, Clone 85, Gen 3)
[13:43:00] - Read packet limit of 540015616... Set to 524286976.
[13:43:00] + Attempting to send results [January 23 13:43:00 UTC]
[13:43:02] - Couldn't send HTTP request to server
[13:43:02] + Could not connect to Work Server (results)
[13:43:02]     (171.67.108.21:8080)
[13:43:02] + Retrying using alternative port
[13:43:23] - Couldn't send HTTP request to server
[13:43:23] + Could not connect to Work Server (results)
[13:43:23]     (171.67.108.21:80)
[13:43:23] - Error: Could not transmit unit 06 (completed January 17) to work server.
[13:43:23] - Read packet limit of 540015616... Set to 524286976.
[13:43:23] + Attempting to send results [January 23 13:43:23 UTC]
[13:43:25] - Server does not have record of this unit. Will try again later.
[13:43:25]   Could not transmit unit 06 to Collection server; keeping in queue.
[13:43:25] - Failed to send all units to server
--- Opening Log file [January 23 13:46:23 UTC]
Launch directory: D:\Program Files\FAH-GPU3
[13:46:23] - Ask before connecting: No
[13:46:23] - User name: RGene (Team 47191)
[13:46:23] - User ID: 72AC19F01BACF7A2
[13:46:23] - Machine ID: 3
[13:46:23]
[13:46:23] Loaded queue successfully.
[13:46:23] Initialization complete
[13:46:23] Attempting to return result(s) to server...
[13:46:23] Project: 5786 (Run 1, Clone 55, Gen 14)
[13:46:23] - Read packet limit of 540015616... Set to 524286976.
[13:46:23] + Attempting to send results [January 23 13:46:23 UTC]
[13:46:25] - Couldn't send HTTP request to server
[13:46:25] + Could not connect to Work Server (results)
[13:46:25]     (171.67.108.21:8080)
[13:46:25] + Retrying using alternative port
[13:46:46] - Couldn't send HTTP request to server
[13:46:46] + Could not connect to Work Server (results)
[13:46:46]     (171.67.108.21:80)
[13:46:46] - Error: Could not transmit unit 09 (completed January 21) to work server.
[13:46:46] - Read packet limit of 540015616... Set to 524286976.
[13:46:46] + Attempting to send results [January 23 13:46:46 UTC]
[13:46:48] - Server does not have record of this unit. Will try again later.
[13:46:48]   Could not transmit unit 09 to Collection server; keeping in queue.
[13:46:48] - Failed to send all units to server
as we see here, gpu-client could not connect to Work Server 171.67.108.21 for sending competed unit. but this is not the problem with network, and server is not down because i can receive and upload any other 783 point units (projects 5781, 5785, 5786, etc) from this server. i did it many times and everything works fine except these three units.
my team mates have also encountered the problem. we have 5781 (19-395-0), 5784 (5-50-14) and some more units that we can't upload to server.
thanks for your attention.
RGene
Post by RGene »
another problem units:
5786(8-98-18)
5782(1-26-3)
5781(9-912-0)
5784 (11-86-17)
Mr. Scary
Hardware configuration: The Rock-XPS630i/QX6850@3.67ghz/OCZ Plat 1066 2x2gb/(2)8800GT AlphaDogs/(2)10krpm Raptors Raid0&(2)WD HDD 500gb
Nekid-CoolerMaster CM690/MSI-P6N Diamond/Q6600@3.0ghz/Samsung 2x2gb 800mhz/(2)9800GT's/TX2 HSF/Corsair TX850W PSU/(2)WD 160gb HDD's Raid 0, (1)500gb WD & (1)1.5tb WD HDD
Bare Nekid-MSI-P6N Diamond/E7200@3.2ghz/OCZ ReaperX1000mhz 2x2gb/(2)8800GT's/Corsair TX750W PSU/160gb WD HDD
Buck Nekid-Xion XON-303/Dell'd 650iMobo/Q6600@3.15ghz/Naya 4x1gb 667mhz/(2)8800GT's SLI/750W PSU/320gb WD HDD
Post by Mr. Scary »
all these new 578x WU's are doin' the same thing for me as well.
Also, on my GX2, they eue after each one is finished. i can't babysit all day clearing the pausing 24hrs. And lastly, they still aren't appearing in FahMon.
Is anyone on this or making any headway? is it in a different thread i missed?
thanks much.
M$
Fatal1st
Post by Fatal1st »
[19:57:01] + Attempting to send results [January 29 19:57:01 UTC]
[19:57:03] - Couldn't send HTTP request to server
[19:57:03] + Could not connect to Work Server (results)
[19:57:03]     (171.67.108.11:8080)
[19:57:03] + Retrying using alternative port
[19:57:04] - Couldn't send HTTP request to server
[19:57:04] + Could not connect to Work Server (results)
[19:57:04]     (171.67.108.11:80)
[19:57:04] - Error: Could not transmit unit 03 (completed January 29) to work server.
[19:57:04]   Keeping unit 03 in queue.
[19:57:04] Project: 5768 (Run 12, Clone 221, Gen 833)
Server is in Reject mode :(
But this kind of issues have to be reported in the Issues with a specific server forum.
EDIT: Topic renamed and moved.
(The server is up now.)
Ragnar Dan
Re: 171.67.108.21 is Reject;
Post by Ragnar Dan »
All 3 of my GPU2 clients are failing to download new WU's from this server. As you can see, there seems to be a bigger problem than just failing to get a WU. The client appears to get all the returns it needs to think a new WU is coming, but then it's never sent.
Edit: Well, as I was entering this, my other 2 GPU's, which had been waiting over 30 and over 23 minutes, respectively, got new WU's. But my fastest GPU is still waiting after over an hour. Maybe it's just backed up at this point.
Edit #2: Yep. My main GPU finally got its WU, too. 8-)
[00:02:09] CoreStatus = 64 (100)
[00:02:09] Unit 2 finished with 98 percent of time to deadline remaining.
[00:02:09] Updated performance fraction: 0.980278
[00:02:09] Sending work to server
[00:02:09] Project: 5766 (Run 1, Clone 391, Gen 1779)
[00:02:09] - Read packet limit of 540015616... Set to 524286976.
[00:02:09] + Attempting to send results [February 4 00:02:09 UTC]
[00:02:09] - Reading file work/wuresults_02.dat from core
[00:02:09]   (Read 99669 bytes from disk)
[00:02:09] Connecting to http://171.67.108.11:8080/
[00:02:09] - Couldn't send HTTP request to server
[00:02:09]   (Got status 503)
[00:02:09] + Could not connect to Work Server (results)
[00:02:09]     (171.67.108.11:8080)
[00:02:09] + Retrying using alternative port
[00:02:09] Connecting to http://171.67.108.11:80/
[00:02:10] Posted data.
[00:02:10] Initial: 0000; + Results successfully sent
[00:02:11] Thank you for your contribution to Folding@Home.
[00:02:11] + Number of Units Completed: 4723
[00:02:15] Trying to send all finished work units
[00:02:15] + No unsent completed units remaining.
[00:02:15] - Preparing to get new work unit...
[00:02:15] + Attempting to get work packet
[00:02:15] - Will indicate memory of 896 MB
[00:02:15] - Connecting to assignment server
[00:02:15] Connecting to http://assign-GPU.stanford.edu:8080/
[00:02:15] Posted data.
[00:02:15] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[00:02:15] + News From Folding@Home: Welcome to Folding@Home
[00:02:15] Loaded queue successfully.
[00:02:15] Connecting to http://171.67.108.11:8080/
[00:02:16] Posted data.
[00:02:16] Initial: 5448; + Could not connect to Work Server
[00:02:16] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[00:02:26] + Attempting to get work packet
[00:02:26] - Will indicate memory of 896 MB
[00:02:26] - Connecting to assignment server
[00:02:26] Connecting to http://assign-GPU.stanford.edu:8080/
[00:02:27] Posted data.
[00:02:27] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[00:02:27] + News From Folding@Home: Welcome to Folding@Home
[00:02:27] Loaded queue successfully.
[00:02:27] Connecting to http://171.67.108.11:8080/
[00:02:27] - Couldn't send HTTP request to server
[00:02:27] + Could not connect to Work Server
[00:02:27] - Attempt #2  to get work failed, and no other work to do.
[00:02:47] + Attempting to get work packet
[00:02:47] - Will indicate memory of 896 MB
[00:02:47] - Connecting to assignment server
[00:02:47] Connecting to http://assign-GPU.stanford.edu:8080/
[00:02:48] Posted data.
[00:02:48] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[00:02:48] + News From Folding@Home: Welcome to Folding@Home
[00:02:48] Loaded queue successfully.
[00:02:48] Connecting to http://171.67.108.11:8080/
[00:02:48] - Couldn't send HTTP request to server
[00:02:48]   (Got status 503)
[00:02:48] + Could not connect to Work Server
[00:02:48] - Attempt #3  to get work failed, and no other work to do.
[00:03:19] + Attempting to get work packet
[00:03:19] - Will indicate memory of 896 MB
[00:03:19] - Connecting to assignment server
[00:03:19] Connecting to http://assign-GPU.stanford.edu:8080/
[00:03:20] Posted data.
[00:03:20] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[00:03:20] + News From Folding@Home: Welcome to Folding@Home
[00:03:20] Loaded queue successfully.
[00:03:20] Connecting to http://171.67.108.11:8080/
[00:03:21] Posted data.
[00:03:21] Initial: 5448; + Could not connect to Work Server
[00:03:21] - Attempt #4  to get work failed, and no other work to do.
[00:04:02] + Attempting to get work packet
[00:04:02] - Will indicate memory of 896 MB
[00:04:02] - Connecting to assignment server
[00:04:02] Connecting to http://assign-GPU.stanford.edu:8080/
[00:04:03] Posted data.
[00:04:03] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[00:04:03] + News From Folding@Home: Welcome to Folding@Home
[00:04:03] Loaded queue successfully.
[00:04:03] Connecting to http://171.67.108.21:8080/
[00:04:04] Posted data.
[00:04:04] Initial: 0000; - Receiving payload (expected size: 65151)
[00:24:04] + Could not get Work unit data from Work Server
[00:24:04] - Attempt #5  to get work failed, and no other work to do.
[00:25:29] + Attempting to get work packet
[00:25:29] - Will indicate memory of 896 MB
[00:25:29] - Connecting to assignment server
[00:25:29] Connecting to http://assign-GPU.stanford.edu:8080/
[00:25:31] Posted data.
[00:25:31] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[00:25:31] + News From Folding@Home: Welcome to Folding@Home
[00:25:31] Loaded queue successfully.
[00:25:31] Connecting to http://171.67.108.21:8080/
[00:25:32] Posted data.
[00:25:32] Initial: 0000; - Receiving payload (expected size: 65939)
[00:28:01] Service stop request received.
[00:28:01] ***** Got a SIGTERM signal (2)
[00:28:01] Killing all core threads
--- Opening Log file [February 4 00:28:11 UTC]
Launch directory: D:\Program Files\Folding@Home\Folding@home-gpu
Service: D:\Program Files\Folding@Home\Folding@home-gpu\Folding@home-Win32-GPU.exe
Arguments: -svcstart -d D:\Program Files\Folding@Home\Folding@home-gpu -local -forceasm -verbosity 9
Launched as a service.
Entered D:\Program Files\Folding@Home\Folding@home-gpu to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[00:28:11] - Ask before connecting: No
[00:28:11] - User name: Ragnar_Dan (Team 2630)
[00:28:11] - User ID: 1B443E90173906C4
[00:28:11] - Machine ID: 3
[00:28:11]
[00:28:11] Loaded queue successfully.
[00:28:11] - Preparing to get new work unit...
[00:28:11] + Attempting to get work packet
[00:28:11] - Will indicate memory of 896 MB
[00:28:11] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 3, Stepping: 2
[00:28:11] - Connecting to assignment server
[00:28:11] Connecting to http://assign-GPU.stanford.edu:8080/
[00:28:11] - Autosending finished units... [February 4 00:28:11 UTC]
[00:28:11] Trying to send all finished work units
[00:28:11] + No unsent completed units remaining.
[00:28:11] - Autosend completed
[00:28:14] Posted data.
[00:28:14] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[00:28:14] + News From Folding@Home: Welcome to Folding@Home
[00:28:14] Loaded queue successfully.
[00:28:14] Connecting to http://171.67.108.21:8080/
[00:28:16] Posted data.
[00:28:16] Initial: 0000; - Receiving payload (expected size: 65150)
[00:33:33] Service stop request received.
[00:33:33] ***** Got a SIGTERM signal (2)
[00:33:33] Killing all core threads
caintry_boy
Post by caintry_boy »
Yup!! Been rejecting me for some time now.....
Launch directory: C:\Documents and Settings\Administrator\Application Data\Folding@home-gpu
Arguments: -advmethods
[21:35:23] - Ask before connecting: No
[21:35:23] - User name: caintry_boy (Team 32035)
[21:35:23] - User ID: 5849CD517E4EE06F
[21:35:23] - Machine ID: 2
[21:35:23]
[21:35:23] Loaded queue successfully.
[21:35:23] Initialization complete
[21:35:23] - Preparing to get new work unit...
[21:35:23] + Attempting to get work packet
[21:35:23] - Connecting to assignment server
[21:35:24] - Successful: assigned to (171.67.108.21).
[21:35:24] + News From Folding@Home: Welcome to Folding@Home
[21:35:24] Loaded queue successfully.
[21:35:24] - Couldn't send HTTP request to server
[21:35:24] + Could not connect to Work Server
[21:35:24] - Attempt #1  to get work failed, and no other work to do.
[21:35:35] + Attempting to get work packet
[21:35:35] - Connecting to assignment server
[21:35:56] - Couldn't send HTTP request to server
[21:35:56] + Could not connect to Assignment Server
[21:36:17] - Couldn't send HTTP request to server
[21:36:17] + Could not connect to Assignment Server 2
[21:36:17] + Couldn't get work instructions.
[21:36:17] - Attempt #2  to get work failed, and no other work to do.
[21:36:28] + Attempting to get work packet
[21:36:28] - Connecting to assignment server
[21:36:29] - Successful: assigned to (171.67.108.21).
[21:36:29] + News From Folding@Home: Welcome to Folding@Home
[21:36:29] Loaded queue successfully.
[21:36:29] - Couldn't send HTTP request to server
[21:36:29] + Could not connect to Work Server
[21:36:29] - Attempt #3  to get work failed, and no other work to do.
[21:36:50] + Attempting to get work packet
[21:36:50] - Connecting to assignment server
[21:36:50] - Successful: assigned to (171.67.108.21).
[21:36:50] + News From Folding@Home: Welcome to Folding@Home
[21:36:50] Loaded queue successfully.
[21:36:50] - Couldn't send HTTP request to server
[21:36:50] + Could not connect to Work Server
[21:36:50] - Attempt #4  to get work failed, and no other work to do.
[21:37:45] + Attempting to get work packet
[21:37:45] - Connecting to assignment server
[21:37:45] - Successful: assigned to (171.67.108.21).
[21:37:45] + News From Folding@Home: Welcome to Folding@Home
[21:37:45] Loaded queue successfully.
[21:37:46] - Couldn't send HTTP request to server
[21:37:46] + Could not connect to Work Server
[21:37:46] - Attempt #5  to get work failed, and no other work to do.
[21:39:19] + Attempting to get work packet
[21:39:19] - Connecting to assignment server
[21:39:19] - Successful: assigned to (171.67.108.21).
[21:39:19] + News From Folding@Home: Welcome to Folding@Home
[21:39:19] Loaded queue successfully.
[21:39:20] - Couldn't send HTTP request to server
[21:39:20] + Could not connect to Work Server
[21:39:20] - Attempt #6  to get work failed, and no other work to do.
[21:42:02] + Attempting to get work packet
[21:42:02] - Connecting to assignment server
[21:42:02] - Successful: assigned to (171.67.108.21).
[21:42:02] + News From Folding@Home: Welcome to Folding@Home
[21:42:02] Loaded queue successfully.
[21:42:02] - Couldn't send HTTP request to server
[21:42:02] + Could not connect to Work Server
[21:42:02] - Attempt #7  to get work failed, and no other work to do.
--- Opening Log file [February 14 21:45:00 UTC]
[21:45:00] - Ask before connecting: No
[21:45:00] - User name: caintry_boy (Team 32035)
[21:45:00] - User ID: 5849CD517E4EE06F
[21:45:00] - Machine ID: 2
[21:45:00]
[21:45:00] Loaded queue successfully.
[21:45:00] Initialization complete
[21:45:00] - Preparing to get new work unit...
[21:45:00] + Attempting to get work packet
[21:45:00] - Connecting to assignment server
[21:45:01] - Successful: assigned to (171.67.108.21).
[21:45:01] + News From Folding@Home: Welcome to Folding@Home
[21:45:01] Loaded queue successfully.
[21:45:01] - Couldn't send HTTP request to server
[21:45:01] + Could not connect to Work Server
[21:45:01] - Attempt #1  to get work failed, and no other work to do.
[21:45:18] + Attempting to get work packet
[21:45:18] - Connecting to assignment server
[21:45:18] - Successful: assigned to (171.67.108.21).
[21:45:18] + News From Folding@Home: Welcome to Folding@Home
[21:45:18] Loaded queue successfully.
[21:45:18] - Couldn't send HTTP request to server
[21:45:18] + Could not connect to Work Server
[21:45:18] - Attempt #2  to get work failed, and no other work to do.
[21:45:43] + Attempting to get work packet
[21:45:43] - Connecting to assignment server
[21:45:44] - Successful: assigned to (171.67.108.21).
[21:45:44] + News From Folding@Home: Welcome to Folding@Home
[21:45:44] Loaded queue successfully.
[21:45:44] - Couldn't send HTTP request to server
[21:45:44] + Could not connect to Work Server
[21:45:44] - Attempt #3  to get work failed, and no other work to do.
[21:46:07] + Attempting to get work packet
[21:46:07] - Connecting to assignment server
[21:46:07] - Successful: assigned to (171.67.108.21).
[21:46:07] + News From Folding@Home: Welcome to Folding@Home
[21:46:07] Loaded queue successfully.
[21:46:08] - Couldn't send HTTP request to server
[21:46:08] + Could not connect to Work Server
[21:46:08] - Attempt #4  to get work failed, and no other work to do.
[21:46:54] + Attempting to get work packet
[21:46:54] - Connecting to assignment server
[21:46:54] - Successful: assigned to (171.67.108.21).
[21:46:54] + News From Folding@Home: Welcome to Folding@Home
[21:46:54] Loaded queue successfully.
[21:46:55] - Couldn't send HTTP request to server
[21:46:55] + Could not connect to Work Server
[21:46:55] - Attempt #5  to get work failed, and no other work to do.
[21:48:29] + Attempting to get work packet
[21:48:29] - Connecting to assignment server
[21:48:29] - Successful: assigned to (171.67.108.21).
[21:48:29] + News From Folding@Home: Welcome to Folding@Home
[21:48:30] Loaded queue successfully.
[21:48:30] - Couldn't send HTTP request to server
[21:48:30] + Could not connect to Work Server
[21:48:30] - Attempt #6  to get work failed, and no other work to do.
And this is after shutting down the client and restarting....... :(
Cajun_Don
Post by Cajun_Don »
171.67.108.21 Has been restarted, but has been having other problems, with high cpu and net loads and other problems, since Feb 13 07:55:10 PST 2010 171.67.108.21 GPU vsp07b vvoelz full Accepting.
Have a great day.
Ravage7779
Hardware configuration: .
6x Intel i3-4130 (4) @ 3.400GHz
Apple M1 (8) @ 3.2 GHz
AMD Ryzen 5 5500U (12) @ 4.06 GHz
Intel Core i7-9700 (8) @ 4.70 GHz
AMD Ryzen 7 5700G (16) @ 4.67 GHz
Post by Ravage7779 »
It's either completely swamped, or down again...doesn't respond at all...
subego
Post by subego »
Throw me on the pile.
3 cards are on their 14th try.
noorman
Hardware configuration: Folders: Intel C2D E6550 @ 3.150 GHz + GPU XFX 9800GTX+ @ 765 MHZ w. WinXP-GPU
AMD A2X64 3800+ @ stock + GPU XFX 9800GTX+ @ 775 MHZ w. WinXP-GPU
Main rig: an old Athlon Barton 2500+ @2.25 GHz & 2* 512 MB RAM Apacer, Radeon 9800Pro, WinXP SP3+
Location: Belgium, near the International Sea-Port of Antwerp
Post by noorman »
Still no work coming through after 12 hrs ...
- stopped Linux SMP w. HT on i7-860@3.5 GHz
Folded since 10-06-04 till 09-2010
caintry_boy
Seems to be a recurring problem that isn't being fixed...... :(
Gave a few WU's last night and now this again....
[05:15:36] Completed 99%
[05:16:23] Completed 100%
[05:16:23] Successful run
[05:16:23] DynamicWrapper: Finished Work Unit: sleep=10000
[05:16:33] Reserved 75944 bytes for xtc file; Cosm status=0
[05:16:33] Allocated 75944 bytes for xtc file
[05:16:33] - Reading up to 75944 from "work/wudata_09.xtc": Read 75944
[05:16:33] Read 75944 bytes from xtc file; available packet space=786354520
[05:16:33] xtc file hash check passed.
[05:16:33] Reserved 15168 15168 786354520 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[05:16:33] Allocated 15168 bytes for arc file
[05:16:33] - Reading up to 15168 from "work/wudata_09.trr": Read 15168
[05:16:33] Read 15168 bytes from arc file; available packet space=786339352
[05:16:33] trr file hash check passed.
[05:16:33] Allocated 560 bytes for edr file
[05:16:33] Read bedfile
[05:16:33] edr file hash check passed.
[05:16:33] Allocated 33349 bytes for logfile
[05:16:33] Read logfile
[05:16:33] GuardedRun: success in DynamicWrapper
[05:16:33] GuardedRun: done
[05:16:33] Run: GuardedRun completed.
[05:16:33] + Opened results file
[05:16:33] - Writing 125533 bytes of core data to disk...
[05:16:33] Done: 125021 -> 99359 (compressed to 79.4 percent)
[05:16:33]   ... Done.
[05:16:33] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[05:16:33] Shutting down core
[05:16:33]
[05:16:33] Folding@home Core Shutdown: FINISHED_UNIT
[05:16:36] CoreStatus = 64 (100)
[05:16:36] Sending work to server
[05:16:36] Project: 5768 (Run 7, Clone 124, Gen 2232)
[05:16:36] - Read packet limit of 540015616... Set to 524286976.
[05:16:36] + Attempting to send results [February 15 05:16:36 UTC]
[05:16:38] + Results successfully sent
[05:16:38] Thank you for your contribution to Folding@Home.
[05:16:38] + Number of Units Completed: 2313
[05:16:42] - Preparing to get new work unit...
[05:16:42] + Attempting to get work packet
[05:16:42] - Connecting to assignment server
[05:16:43] - Successful: assigned to (171.67.108.21).
[05:16:43] + News From Folding@Home: Welcome to Folding@Home
[05:16:43] Loaded queue successfully.
[05:16:43] - Couldn't send HTTP request to server
[05:16:43] + Could not connect to Work Server
[05:16:43] - Attempt #1  to get work failed, and no other work to do.
[05:16:56] + Attempting to get work packet
[05:16:56] - Connecting to assignment server
[05:16:56] - Successful: assigned to (171.67.108.21).
[05:16:56] + News From Folding@Home: Welcome to Folding@Home
[05:16:56] Loaded queue successfully.
[05:16:56] - Couldn't send HTTP request to server
[05:16:56] + Could not connect to Work Server
[05:16:56] - Attempt #2  to get work failed, and no other work to do.
[05:17:15] + Attempting to get work packet
[05:17:15] - Connecting to assignment server
[05:17:15] - Successful: assigned to (171.67.108.21).
[05:17:15] + News From Folding@Home: Welcome to Folding@Home
[05:17:15] Loaded queue successfully.
[05:17:15] - Couldn't send HTTP request to server
[05:17:15] + Could not connect to Work Server
[05:17:15] - Attempt #3  to get work failed, and no other work to do.
[05:17:47] + Attempting to get work packet
[05:17:47] - Connecting to assignment server
[05:17:48] - Successful: assigned to (171.67.108.21).
[05:17:48] + News From Folding@Home: Welcome to Folding@Home
[05:17:48] Loaded queue successfully.
[05:17:48] - Couldn't send HTTP request to server
[05:17:48] + Could not connect to Work Server
[05:17:48] - Attempt #4  to get work failed, and no other work to do.
[05:18:39] + Attempting to get work packet
[05:18:39] - Connecting to assignment server
[05:18:40] - Successful: assigned to (171.67.108.21).
[05:18:40] + News From Folding@Home: Welcome to Folding@Home
[05:18:40] Loaded queue successfully.
[05:18:40] - Couldn't send HTTP request to server
[05:18:40] + Could not connect to Work Server
[05:18:40] - Attempt #5  to get work failed, and no other work to do.
[05:20:14] + Attempting to get work packet
[05:20:14] - Connecting to assignment server
[05:20:15] - Successful: assigned to (171.67.108.21).
[05:20:15] + News From Folding@Home: Welcome to Folding@Home
[05:20:15] Loaded queue successfully.
[05:20:15] - Couldn't send HTTP request to server
[05:20:15] + Could not connect to Work Server
[05:20:15] - Attempt #6  to get work failed, and no other work to do.
[05:23:02] + Attempting to get work packet
[05:23:02] - Connecting to assignment server
[05:23:03] - Successful: assigned to (171.67.108.21).
[05:23:03] + News From Folding@Home: Welcome to Folding@Home
[05:23:03] Loaded queue successfully.
[05:23:03] - Couldn't send HTTP request to server
[05:23:03] + Could not connect to Work Server
[05:23:03] - Attempt #7  to get work failed, and no other work to do.
[05:28:28] + Attempting to get work packet
[05:28:28] - Connecting to assignment server
[05:28:29] - Successful: assigned to (171.67.108.21).
[05:28:29] + News From Folding@Home: Welcome to Folding@Home
[05:28:29] Loaded queue successfully.
[05:28:29] - Couldn't send HTTP request to server
[05:28:29] + Could not connect to Work Server
[05:28:29] - Attempt #8  to get work failed, and no other work to do.
[05:39:14] + Attempting to get work packet
[05:39:14] - Connecting to assignment server
[05:39:15] - Successful: assigned to (171.67.108.21).
[05:39:15] + News From Folding@Home: Welcome to Folding@Home
[05:39:15] Loaded queue successfully.
[05:39:15] - Couldn't send HTTP request to server
[05:39:15] + Could not connect to Work Server
[05:39:15] - Attempt #9  to get work failed, and no other work to do.
[06:00:44] + Attempting to get work packet
[06:00:44] - Connecting to assignment server
[06:00:45] - Successful: assigned to (171.67.108.21).
[06:00:45] + News From Folding@Home: Welcome to Folding@Home
[06:00:45] Loaded queue successfully.
[06:00:45] - Couldn't send HTTP request to server
[06:00:45] + Could not connect to Work Server
[06:00:45] - Attempt #10  to get work failed, and no other work to do.
[06:43:28] + Attempting to get work packet
[06:43:28] - Connecting to assignment server
[06:43:29] - Successful: assigned to (171.67.108.21).
[06:43:29] + News From Folding@Home: Welcome to Folding@Home
[06:43:29] Loaded queue successfully.
[06:43:29] - Couldn't send HTTP request to server
[06:43:29] + Could not connect to Work Server
[06:43:29] - Attempt #11  to get work failed, and no other work to do.
[07:31:29] + Attempting to get work packet
[07:31:29] - Connecting to assignment server
[07:31:30] - Successful: assigned to (171.67.108.21).
[07:31:30] + News From Folding@Home: Welcome to Folding@Home
[07:31:30] Loaded queue successfully.
[07:31:30] - Couldn't send HTTP request to server
[07:31:30] + Could not connect to Work Server
[07:31:30] - Attempt #12  to get work failed, and no other work to do.
[08:19:43] + Attempting to get work packet
[08:19:43] - Connecting to assignment server
[08:19:43] - Successful: assigned to (171.67.108.21).
[08:19:43] + News From Folding@Home: Welcome to Folding@Home
[08:19:43] Loaded queue successfully.
[08:19:43] - Couldn't send HTTP request to server
[08:19:43] + Could not connect to Work Server
[08:19:43] - Attempt #13  to get work failed, and no other work to do.
[09:07:58] + Attempting to get work packet
[09:07:58] - Connecting to assignment server
[09:07:59] - Successful: assigned to (171.67.108.21).
[09:07:59] + News From Folding@Home: Welcome to Folding@Home
[09:07:59] Loaded queue successfully.
[09:07:59] - Couldn't send HTTP request to server
[09:07:59] + Could not connect to Work Server
[09:07:59] - Attempt #14  to get work failed, and no other work to do.
[09:56:02] + Attempting to get work packet
[09:56:02] - Connecting to assignment server
[09:56:02] - Successful: assigned to (171.67.108.21).
[09:56:02] + News From Folding@Home: Welcome to Folding@Home
[09:56:02] Loaded queue successfully.
[09:56:02] - Couldn't send HTTP request to server
[09:56:02] + Could not connect to Work Server
[09:56:02] - Attempt #15  to get work failed, and no other work to do.
[10:44:05] + Attempting to get work packet
[10:44:05] - Connecting to assignment server
[10:44:05] - Successful: assigned to (171.67.108.21).
[10:44:05] + News From Folding@Home: Welcome to Folding@Home
[10:44:05] Loaded queue successfully.
[10:44:05] - Couldn't send HTTP request to server
[10:44:05] + Could not connect to Work Server
[10:44:05] - Attempt #16  to get work failed, and no other work to do.
[11:32:13] + Attempting to get work packet
[11:32:13] - Connecting to assignment server
[11:32:13] - Successful: assigned to (171.67.108.21).
[11:32:13] + News From Folding@Home: Welcome to Folding@Home
[11:32:13] Loaded queue successfully.
[11:32:14] - Couldn't send HTTP request to server
[11:32:14] + Could not connect to Work Server
[11:32:14] - Attempt #17  to get work failed, and no other work to do.
[12:20:29] + Attempting to get work packet
[12:20:29] - Connecting to assignment server
[12:20:29] - Successful: assigned to (171.67.108.21).
[12:20:29] + News From Folding@Home: Welcome to Folding@Home
[12:20:29] Loaded queue successfully.
[12:20:29] - Couldn't send HTTP request to server
[12:20:29] + Could not connect to Work Server
[12:20:29] - Attempt #18  to get work failed, and no other work to do.
Not getting any science this way boys....... :idea:
noorman
Post by noorman »
by the way:
same error message here:
