My Stats are not going to the correct team?
scammer
Post by scammer »
I'm new to this whole thing and I set up my config to send my stats to a friends team as he requested.
I don't mind helping fold but my friend really wants the #s for his team.
This is the Team I am supposed to be on: hxxp://fah-web.stanford.edu/cgi-bin/mai ... num=178722
But my stats went here: hxxp://fah-web.stanford.edu/cgi-bin/mai ... mnum=78501
In my config I set it to 178722 for sure and it shows this in the log.
[06:30:52] - Ask before connecting: No
[06:30:52] - User name: Scammer (Team 178722)
[06:30:52] - User ID not found locally
[06:30:52] + Requesting User ID from server
[06:30:53] - Machine ID: 1
I'll skip to the bottom and see this:
[04:08:28] Project: 6318 (Run 1294, Clone 28, Gen 0)
[04:08:28]
[04:08:28] Assembly optimizations on if available.
[04:08:28] Entering M.D.
[04:08:34] Protein: Great Red Oystrich Makes All Chemists Sane in water
[04:08:34]
[04:08:34] Writing local files
[04:08:34] Extra SSE boost OK.
[04:08:34] Completed 0 out of 500000 steps (0%)
[04:16:23] Opening C:\Users\Scammer\AppData\Roaming\Folding@home-x86\MyFolding.html...
[04:16:41] Opening hxxp://fah-web.stanford.edu/cgi-bin/mai ... =Scammer...
[04:19:35] Opening hxxp://fah-web.stanford.edu/cgi-bin/mai ... m=178722...
[04:20:13] Writing local files
My friend is really bummed out because he says I got a nice score for his team.
Any help would be greatly appreciated.
Also is there anyone I can contact to have the score moved to the right team? I know it is all for a greater cause but he put the work in of recruiting me.
Re: My Stats are not going to the correct team?
Have you actually completed any WUs? The log that you posted indicates that the installation is new, and the last credit for anyone using the name Scammer was a long time ago. My guess is that somebody else already used that name and you're looking at the credits that they earned for another team. [There is no protection to keep you from using an existing name other than using a passkey.]
Where in FAHlog.txt do you see the "Thank you...." message indicating that you have uploaded a result, and did you allow a couple hours after that before you checked your status?
scammer
Post by scammer »
I think I figured it out.
I installed and it had run for about 24hrs.
Yes I did get a thank you as seen here:
[04:07:27] + Attempting to send results [January 17 04:07:27 UTC]
[04:08:19] + Results successfully sent
[04:08:19] Thank you for your contribution to Folding@Home.
[04:08:19] + Starting local stats count at 1
[04:08:24] - Preparing to get new work unit...
[04:08:24] + Attempting to get work packet
[04:08:24] - Connecting to assignment server
[04:08:24] - Successful: assigned to (171.64.65.60).
[04:08:24] + News From Folding@Home: Welcome to Folding@Home
[04:08:24] Loaded queue successfully.
[04:08:27] + Closed connections
What I think happened is I should have restarted after the install, I think it just gave away my first run because I did not restart the app and the config did not go through.
Now that I have restarted everything is going to the right team.
I will post the full log that I have it shows the restart I believe.
--- Opening Log file [January 16 06:27:48 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Users\Scammer\AppData\Roaming\Folding@home-x86
[06:30:53]
[06:30:53] Work directory not found. Creating...
[06:30:53] Could not open work queue, generating new queue...
[06:30:53] Initialization complete
[06:30:53] - Preparing to get new work unit...
[06:30:53] + Attempting to get work packet
[06:30:53] - Connecting to assignment server
[06:30:53] - Successful: assigned to (171.64.65.111).
[06:30:53] + News From Folding@Home: Welcome to Folding@Home
[06:30:53] Loaded queue successfully.
[06:30:57] + Closed connections
[06:30:57]
[06:30:57] + Processing work unit
[06:30:57] Core required: FahCore_78.exe
[06:30:57] Core not found.
[06:30:57] - Core is not present or corrupted.
[06:30:57] - Attempting to download new core...
[06:30:57] + Downloading new core: FahCore_78.exe
[06:30:57] + 10240 bytes downloaded
[06:30:58] + 20480 bytes downloaded
[06:30:58] + 30720 bytes downloaded
[06:30:58] + 40960 bytes downloaded
[06:30:58] + 51200 bytes downloaded
[06:30:58] + 61440 bytes downloaded
[06:30:58] + 71680 bytes downloaded
[06:30:58] + 81920 bytes downloaded
[06:30:58] + 92160 bytes downloaded
[06:30:58] + 102400 bytes downloaded
[06:30:58] + 112640 bytes downloaded
[06:30:58] + 122880 bytes downloaded
[06:30:58] + 133120 bytes downloaded
[06:30:58] + 143360 bytes downloaded
[06:30:58] + 153600 bytes downloaded
[06:30:58] + 163840 bytes downloaded
[06:30:58] + 174080 bytes downloaded
[06:30:58] + 184320 bytes downloaded
[06:30:58] + 194560 bytes downloaded
[06:30:58] + 204800 bytes downloaded
[06:30:58] + 215040 bytes downloaded
[06:30:58] + 225280 bytes downloaded
[06:30:58] + 235520 bytes downloaded
[06:30:58] + 245760 bytes downloaded
[06:30:58] + 256000 bytes downloaded
[06:30:58] + 266240 bytes downloaded
[06:30:58] + 276480 bytes downloaded
[06:30:58] + 286720 bytes downloaded
[06:30:59] + 296960 bytes downloaded
[06:30:59] + 307200 bytes downloaded
[06:30:59] + 317440 bytes downloaded
[06:30:59] + 327680 bytes downloaded
[06:30:59] + 337920 bytes downloaded
[06:30:59] + 348160 bytes downloaded
[06:30:59] + 358400 bytes downloaded
[06:30:59] + 368640 bytes downloaded
[06:30:59] + 378880 bytes downloaded
[06:30:59] + 389120 bytes downloaded
[06:30:59] + 399360 bytes downloaded
[06:30:59] + 409600 bytes downloaded
[06:30:59] + 419840 bytes downloaded
[06:30:59] + 430080 bytes downloaded
[06:30:59] + 440320 bytes downloaded
[06:30:59] + 450560 bytes downloaded
[06:30:59] + 460800 bytes downloaded
[06:30:59] + 471040 bytes downloaded
[06:30:59] + 481280 bytes downloaded
[06:30:59] + 491520 bytes downloaded
[06:30:59] + 501760 bytes downloaded
[06:30:59] + 512000 bytes downloaded
[06:30:59] + 522240 bytes downloaded
[06:30:59] + 532480 bytes downloaded
[06:30:59] + 542720 bytes downloaded
[06:30:59] + 552960 bytes downloaded
[06:30:59] + 563200 bytes downloaded
[06:30:59] + 573440 bytes downloaded
[06:30:59] + 583680 bytes downloaded
[06:30:59] + 593920 bytes downloaded
[06:30:59] + 604160 bytes downloaded
[06:30:59] + 614400 bytes downloaded
[06:30:59] + 624640 bytes downloaded
[06:30:59] + 634880 bytes downloaded
[06:30:59] + 645120 bytes downloaded
[06:30:59] + 655360 bytes downloaded
[06:30:59] + 665600 bytes downloaded
[06:30:59] + 675840 bytes downloaded
[06:30:59] + 686080 bytes downloaded
[06:31:00] + 696320 bytes downloaded
[06:31:00] + 706560 bytes downloaded
[06:31:00] + 716800 bytes downloaded
[06:31:00] + 727040 bytes downloaded
[06:31:00] + 737280 bytes downloaded
[06:31:00] + 747520 bytes downloaded
[06:31:00] + 757760 bytes downloaded
[06:31:00] + 768000 bytes downloaded
[06:31:00] + 778240 bytes downloaded
[06:31:00] + 788480 bytes downloaded
[06:31:00] + 798720 bytes downloaded
[06:31:00] + 808960 bytes downloaded
[06:31:00] + 819200 bytes downloaded
[06:31:00] + 825633 bytes downloaded
[06:31:00] Verifying core Core_78.fah...
[06:31:00] Signature is VALID
[06:31:00]
[06:31:00] Trying to unzip core FahCore_78.exe
[06:31:00] Decompressed FahCore_78.exe (2338816 bytes) successfully
[06:31:05] + Core successfully engaged
[06:31:10]
[06:31:10] + Processing work unit
[06:31:10] Core required: FahCore_78.exe
[06:31:10] Core found.
[06:31:10] Working on queue slot 01 [January 16 06:31:10 UTC]
[06:31:10] + Working ...
[06:31:10]
[06:31:10] *------------------------------*
[06:31:10] Folding@Home Gromacs Core
[06:31:10] Version 1.90 (March 8, 2006)
[06:31:10]
[06:31:10] Preparing to commence simulation
[06:31:10] - Looking at optimizations...
[06:31:10] - Created dyn
[06:31:10] - Files status OK
[06:31:11] - Expanded 465338 -> 2244013 (decompressed 482.2 percent)
[06:31:11] - Starting from initial work packet
[06:31:11]
[06:31:11] Project: 6316 (Run 709, Clone 5, Gen 33)
[06:31:11]
[06:31:11] Assembly optimizations on if available.
[06:31:11] Entering M.D.
[06:31:13] Opening C:\Users\Scammer\AppData\Roaming\Folding@home-x86\MyFolding.html...
[06:31:17] Protein: p6316_sh3_with_ALA_frags
[06:31:17]
[06:31:17] Writing local files
[06:31:17] Extra SSE boost OK.
[06:31:17] Completed 0 out of 500000 steps  (0%)
[06:44:29] Writing local files
[06:44:29] Completed 5000 out of 500000 steps  (1%)
[06:57:45] Writing local files
[06:57:45] Completed 10000 out of 500000 steps  (2%)
[07:10:54] Writing local files
[07:10:54] Completed 15000 out of 500000 steps  (3%)
[07:24:17] Writing local files
[07:24:17] Completed 20000 out of 500000 steps  (4%)
[07:37:19] Writing local files
[07:37:19] Completed 25000 out of 500000 steps  (5%)
[07:50:15] Writing local files
[07:50:15] Completed 30000 out of 500000 steps  (6%)
[08:03:25] Writing local files
[08:03:25] Completed 35000 out of 500000 steps  (7%)
[08:17:05] Writing local files
[08:17:05] Completed 40000 out of 500000 steps  (8%)
[08:30:49] Writing local files
[08:30:49] Completed 45000 out of 500000 steps  (9%)
[08:44:10] Writing local files
[08:44:10] Completed 50000 out of 500000 steps  (10%)
[08:57:06] Writing local files
[08:57:06] Completed 55000 out of 500000 steps  (11%)
[09:10:08] Writing local files
[09:10:08] Completed 60000 out of 500000 steps  (12%)
[09:22:53] Writing local files
[09:22:54] Completed 65000 out of 500000 steps  (13%)
[09:35:39] Writing local files
[09:35:39] Completed 70000 out of 500000 steps  (14%)
[09:48:25] Writing local files
[09:48:25] Completed 75000 out of 500000 steps  (15%)
[10:01:10] Writing local files
[10:01:10] Completed 80000 out of 500000 steps  (16%)
[10:13:56] Writing local files
[10:13:56] Completed 85000 out of 500000 steps  (17%)
[10:26:41] Writing local files
[10:26:41] Completed 90000 out of 500000 steps  (18%)
[10:39:27] Writing local files
[10:39:27] Completed 95000 out of 500000 steps  (19%)
[10:52:12] Writing local files
[10:52:12] Completed 100000 out of 500000 steps  (20%)
[11:04:58] Writing local files
[11:04:58] Completed 105000 out of 500000 steps  (21%)
[11:17:44] Writing local files
[11:17:44] Completed 110000 out of 500000 steps  (22%)
[11:30:29] Writing local files
[11:30:30] Completed 115000 out of 500000 steps  (23%)
[11:43:15] Writing local files
[11:43:15] Completed 120000 out of 500000 steps  (24%)
[11:56:01] Writing local files
[11:56:01] Completed 125000 out of 500000 steps  (25%)
[12:08:47] Writing local files
[12:08:47] Completed 130000 out of 500000 steps  (26%)
[12:21:33] Writing local files
[12:21:33] Completed 135000 out of 500000 steps  (27%)
[12:30:53] + Working...
[12:34:19] Writing local files
[12:34:19] Completed 140000 out of 500000 steps  (28%)
[12:47:04] Writing local files
[12:47:04] Completed 145000 out of 500000 steps  (29%)
[12:59:50] Writing local files
[12:59:50] Completed 150000 out of 500000 steps  (30%)
[13:12:36] Writing local files
[13:12:36] Completed 155000 out of 500000 steps  (31%)
[13:25:21] Writing local files
[13:25:21] Completed 160000 out of 500000 steps  (32%)
[13:38:07] Writing local files
[13:38:07] Completed 165000 out of 500000 steps  (33%)
[13:50:52] Writing local files
[13:50:52] Completed 170000 out of 500000 steps  (34%)
[14:03:38] Writing local files
[14:03:38] Completed 175000 out of 500000 steps  (35%)
[14:16:24] Writing local files
[14:16:24] Completed 180000 out of 500000 steps  (36%)
[14:29:10] Writing local files
[14:29:10] Completed 185000 out of 500000 steps  (37%)
[14:41:56] Writing local files
[14:41:56] Completed 190000 out of 500000 steps  (38%)
[14:54:41] Writing local files
[14:54:41] Completed 195000 out of 500000 steps  (39%)
[15:07:28] Writing local files
[15:07:28] Completed 200000 out of 500000 steps  (40%)
[15:20:15] Writing local files
[15:20:15] Completed 205000 out of 500000 steps  (41%)
[15:33:01] Writing local files
[15:33:01] Completed 210000 out of 500000 steps  (42%)
[15:45:46] Writing local files
[15:45:46] Completed 215000 out of 500000 steps  (43%)
[15:58:34] Writing local files
[15:58:34] Completed 220000 out of 500000 steps  (44%)
[16:11:21] Writing local files
[16:11:21] Completed 225000 out of 500000 steps  (45%)
[16:24:07] Writing local files
[16:24:07] Completed 230000 out of 500000 steps  (46%)
[16:36:52] Writing local files
[16:36:52] Completed 235000 out of 500000 steps  (47%)
[16:49:38] Writing local files
[16:49:38] Completed 240000 out of 500000 steps  (48%)
[17:02:24] Writing local files
[17:02:24] Completed 245000 out of 500000 steps  (49%)
[17:15:10] Writing local files
[17:15:10] Completed 250000 out of 500000 steps  (50%)
[17:27:56] Writing local files
[17:27:56] Completed 255000 out of 500000 steps  (51%)
[17:40:42] Writing local files
[17:40:42] Completed 260000 out of 500000 steps  (52%)
[17:53:28] Writing local files
[17:53:28] Completed 265000 out of 500000 steps  (53%)
[18:06:14] Writing local files
[18:06:14] Completed 270000 out of 500000 steps  (54%)
[18:19:01] Writing local files
[18:19:01] Completed 275000 out of 500000 steps  (55%)
[18:30:53] + Working...
[18:31:47] Writing local files
[18:31:47] Completed 280000 out of 500000 steps  (56%)
[18:39:01] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Scammer...
[18:44:44] Writing local files
[18:44:44] Completed 285000 out of 500000 steps  (57%)
[18:57:47] Writing local files
[18:57:47] Completed 290000 out of 500000 steps  (58%)
[19:10:50] Writing local files
[19:10:50] Completed 295000 out of 500000 steps  (59%)
[19:23:51] Writing local files
[19:23:51] Completed 300000 out of 500000 steps  (60%)
[19:36:48] Writing local files
[19:36:48] Completed 305000 out of 500000 steps  (61%)
[19:49:44] Writing local files
[19:49:44] Completed 310000 out of 500000 steps  (62%)
[20:02:40] Writing local files
[20:02:40] Completed 315000 out of 500000 steps  (63%)
[20:15:35] Writing local files
[20:15:35] Completed 320000 out of 500000 steps  (64%)
[20:28:31] Writing local files
[20:28:31] Completed 325000 out of 500000 steps  (65%)
[20:41:28] Writing local files
[20:41:28] Completed 330000 out of 500000 steps  (66%)
[20:54:48] Writing local files
[20:54:48] Completed 335000 out of 500000 steps  (67%)
[21:07:57] Writing local files
[21:07:57] Completed 340000 out of 500000 steps  (68%)
[21:21:02] Writing local files
[21:21:02] Completed 345000 out of 500000 steps  (69%)
[21:34:04] Writing local files
[21:34:04] Completed 350000 out of 500000 steps  (70%)
[21:46:54] Writing local files
[21:46:54] Completed 355000 out of 500000 steps  (71%)
[21:59:40] Writing local files
[21:59:40] Completed 360000 out of 500000 steps  (72%)
[22:12:26] Writing local files
[22:12:26] Completed 365000 out of 500000 steps  (73%)
[22:25:12] Writing local files
[22:25:12] Completed 370000 out of 500000 steps  (74%)
[22:37:58] Writing local files
[22:37:58] Completed 375000 out of 500000 steps  (75%)
[22:50:44] Writing local files
[22:50:44] Completed 380000 out of 500000 steps  (76%)
[23:03:29] Writing local files
[23:03:29] Completed 385000 out of 500000 steps  (77%)
[23:16:15] Writing local files
[23:16:15] Completed 390000 out of 500000 steps  (78%)
[23:29:20] Writing local files
[23:29:20] Completed 395000 out of 500000 steps  (79%)
[23:42:44] Writing local files
[23:42:44] Completed 400000 out of 500000 steps  (80%)
[23:55:54] Writing local files
[23:55:54] Completed 405000 out of 500000 steps  (81%)
[00:09:20] Writing local files
[00:09:20] Completed 410000 out of 500000 steps  (82%)
[00:22:44] Writing local files
[00:22:44] Completed 415000 out of 500000 steps  (83%)
[00:24:04] Opening C:\Users\Scammer\AppData\Roaming\Folding@home-x86\MyFolding.html...
[00:30:53] + Working...
[00:36:30] Writing local files
[00:36:30] Completed 420000 out of 500000 steps  (84%)
[00:50:46] Writing local files
[00:50:46] Completed 425000 out of 500000 steps  (85%)
[01:03:52] Writing local files
[01:03:52] Completed 430000 out of 500000 steps  (86%)
[01:16:54] Writing local files
[01:16:54] Completed 435000 out of 500000 steps  (87%)
[01:29:49] Writing local files
[01:29:49] Completed 440000 out of 500000 steps  (88%)
[01:42:53] Writing local files
[01:42:53] Completed 445000 out of 500000 steps  (89%)
[01:55:51] Writing local files
[01:55:51] Completed 450000 out of 500000 steps  (90%)
[02:08:52] Writing local files
[02:08:52] Completed 455000 out of 500000 steps  (91%)
[02:21:58] Writing local files
[02:21:58] Completed 460000 out of 500000 steps  (92%)
[02:35:28] Writing local files
[02:35:28] Completed 465000 out of 500000 steps  (93%)
[02:48:28] Writing local files
[02:48:28] Completed 470000 out of 500000 steps  (94%)
[03:01:31] Writing local files
[03:01:31] Completed 475000 out of 500000 steps  (95%)
[03:14:33] Writing local files
[03:14:33] Completed 480000 out of 500000 steps  (96%)
[03:27:32] Writing local files
[03:27:32] Completed 485000 out of 500000 steps  (97%)
[03:40:32] Writing local files
[03:40:32] Completed 490000 out of 500000 steps  (98%)
[03:53:27] Writing local files
[03:53:27] Completed 495000 out of 500000 steps  (99%)
[04:06:22] Writing local files
[04:06:22] Completed 500000 out of 500000 steps  (100%)
[04:06:22] Writing final coordinates.
[04:06:22] Past main M.D. loop
[04:07:22]
[04:07:22] Finished Work Unit:
[04:07:22] - Reading up to 362448 from "work/wudata_01.arc": Read 362448
[04:07:22] - Reading up to 3517276 from "work/wudata_01.xtc": Read 3517276
[04:07:22] goefile size: 0
[04:07:22] logfile size: 930020
[04:07:22] Leaving Run
[04:07:23] - Writing 6574036 bytes of core data to disk...
[04:07:25] Done: 6573524 -> 4730780 (compressed to 71.9 percent)
[04:07:25]   ... Done.
[04:07:25] - Shutting down core
[04:07:25]
[04:07:25] Folding@home Core Shutdown: FINISHED_UNIT
[04:07:27] CoreStatus = 64 (100)
[04:07:27] Sending work to server
[04:07:27] Project: 6316 (Run 709, Clone 5, Gen 33)
[04:07:27] - Read packet limit of 540015616... Set to 524286976.
[04:08:27]
[04:08:27] + Processing work unit
[04:08:27] Core required: FahCore_78.exe
[04:08:27] Core found.
[04:08:27] Working on queue slot 02 [January 17 04:08:27 UTC]
[04:08:27] + Working ...
[04:08:27]
[04:08:27] *------------------------------*
[04:08:27] Folding@Home Gromacs Core
[04:08:27] Version 1.90 (March 8, 2006)
[04:08:27]
[04:08:27] Preparing to commence simulation
[04:08:27] - Looking at optimizations...
[04:08:27] - Created dyn
[04:08:27] - Files status OK
[04:08:28] - Expanded 390465 -> 2244040 (decompressed 574.7 percent)
[04:08:28] - Starting from initial work packet
[04:08:28]
[04:08:28]
[04:08:34]
[04:16:41] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Scammer...
[04:19:35] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=178722...
[04:20:13] Completed 5000 out of 500000 steps  (1%)
[04:31:56] Writing local files
[04:31:56] Completed 10000 out of 500000 steps  (2%)
Folding@Home Client Shutdown.
--- Opening Log file [January 17 04:34:55 UTC]
[04:34:55] - Ask before connecting: No
[04:34:55] - User name: Scammer (Team 178722)
[04:34:55] - User ID: 7F8735B96BF26BEE
[04:34:55] - Machine ID: 1
[04:34:55]
[04:34:55] Loaded queue successfully.
[04:34:56] Initialization complete
[04:34:56]
[04:34:56] + Processing work unit
[04:34:56] Core required: FahCore_78.exe
[04:34:56] Core found.
[04:34:56] Working on queue slot 02 [January 17 04:34:56 UTC]
[04:34:56] + Working ...
[04:34:56]
[04:34:56] *------------------------------*
[04:34:56] Folding@Home Gromacs Core
[04:34:56] Version 1.90 (March 8, 2006)
[04:34:56]
[04:34:56] Preparing to commence simulation
[04:34:56] - Looking at optimizations...
[04:34:56] - Files status OK
[04:34:56] - Expanded 390465 -> 2244040 (decompressed 574.7 percent)
[04:34:56]
[04:34:56] Project: 6318 (Run 1294, Clone 28, Gen 0)
[04:34:56]
[04:34:56] Assembly optimizations on if available.
[04:34:56] Entering M.D.
[04:35:16] (Starting from checkpoint)
[04:35:16] Protein: Great Red Oystrich Makes All Chemists Sane in water
[04:35:16]
[04:35:16] Writing local files
[04:35:16] Completed 10000 out of 500000 steps  (2%)
[04:35:16] Extra SSE boost OK.
[04:38:34] Opening C:\Users\Scammer\AppData\Roaming\Folding@home-x86\MyFolding.html...
[04:39:04] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Scammer...
[04:47:03] Writing local files
[04:47:03] Completed 15000 out of 500000 steps  (3%)
[04:48:07] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=178722...
[04:58:50] Writing local files
[04:58:50] Completed 20000 out of 500000 steps  (4%)
[05:11:02] Writing local files
[05:11:02] Completed 25000 out of 500000 steps  (5%)
[05:22:47] Writing local files
[05:22:47] Completed 30000 out of 500000 steps  (6%)
[05:34:56] Writing local files
[05:34:56] Completed 35000 out of 500000 steps  (7%)
[05:46:40] Writing local files
[05:46:40] Completed 40000 out of 500000 steps  (8%)
[05:58:30] Writing local files
[05:58:30] Completed 45000 out of 500000 steps  (9%)
[06:10:19] Writing local files
[06:10:19] Completed 50000 out of 500000 steps  (10%)
[06:21:53] Writing local files
[06:21:53] Completed 55000 out of 500000 steps  (11%)
[06:33:28] Writing local files
[06:33:28] Completed 60000 out of 500000 steps  (12%)
[06:45:08] Writing local files
[06:45:08] Completed 65000 out of 500000 steps  (13%)
[06:56:47] Writing local files
[06:56:47] Completed 70000 out of 500000 steps  (14%)
[07:08:39] Writing local files
[07:08:39] Completed 75000 out of 500000 steps  (15%)
[07:20:33] Writing local files
[07:20:33] Completed 80000 out of 500000 steps  (16%)
[07:32:40] Writing local files
[07:32:40] Completed 85000 out of 500000 steps  (17%)
[07:44:27] Writing local files
[07:44:27] Completed 90000 out of 500000 steps  (18%)
[07:56:11] Writing local files
[07:56:11] Completed 95000 out of 500000 steps  (19%)
[08:07:46] Writing local files
[08:07:46] Completed 100000 out of 500000 steps  (20%)
[08:19:22] Writing local files
[08:19:22] Completed 105000 out of 500000 steps  (21%)
[08:30:57] Writing local files
[08:30:57] Completed 110000 out of 500000 steps  (22%)
[08:42:54] Writing local files
[08:42:54] Completed 115000 out of 500000 steps  (23%)
[08:54:48] Writing local files
[08:54:48] Completed 120000 out of 500000 steps  (24%)
scammer
Post by scammer »
bruce wrote:Have you actually completed any WUs? The log that you posted indicates that the installation is new, and the last credit for anyone using the name Scammer was a long time ago. My guess is that somebody else already used that name and you're looking at the credits that they earned for another team. [There is no protection to keep you from using an existing name other than using a passkey.]
This issue is now resolved.
I'd just like to thank you for your reply as you were 100% correct.
As I mentioned I am new to this and after looking through everything It is as you stated that another user has the same name. I know I get grief from the username for what it is but it is an old videogame tag I got in the arcades back in the 1980s for scamming the owners time by playing so long on one quarter.
But yes the answer was that the over 10,000 score seems to belong to someone else.
Thank-you for the reply.
