vmware issues
hootis
Hardware configuration: AMD Phenom II 955 @ 3.8 +ATi HD 5870
AMD Athlon II 610e @ 2.5 + 2x Nvidia 560Ti @ 1ghz
AMD Athlon II 605e @ 2.4 +Nvidia 550Ti + Nvidia GT 240
AMD Athlon II 620 @ 3.3ghz
vmware issues
Post by hootis »
The problem = when i run the linux smp it only starts with 1 core, however i have enabled the vmware player to use 4 cores, the first time i started the client it ran fine(with 4 cores). when i tried to restart it only 1 core is used.(also not sure if this is an issue but when i was useing the normal windows smp my gpu did't use more than 1%cpu but in the vm it uses 4-10% could this be fixed as well)
[FIXED]
Things yet to materialize.
Re: vmware issues
I guess you forget the -smp switch when starting your Linux client ...
hootis
Re: vmware issues
Post by hootis »
ifail gpu is still useing 10% but cpu is working fine again
