Project: 10001 (Run 67, Clone 3, Gen 25)
Grendel
Hardware configuration: Q6600, Q9560 + GTX 660, i7-3770K + GTX 760
Post by Grendel »
Similar to the 10000 problem:
--- Opening Log file [January 9 23:24:08 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\All Users\Documents\Folding
Executable: C:\Documents and Settings\All Users\Documents\Folding\Folding@home-Win32-x86.exe
[23:24:08] - Ask before connecting: No
[23:24:08] - User name: Grendel (Team 39070)
[23:24:08] - User ID: XXXX
[23:24:08] - Machine ID: 1
[23:24:08]
[23:24:08] Work directory not found. Creating...
[23:24:08] Could not open work queue, generating new queue...
[23:24:08] - Preparing to get new work unit...
[23:24:08] + Attempting to get work packet
[23:24:08] - Connecting to assignment server
[23:24:09] - Successful: assigned to (129.74.85.48).
[23:24:09] + News From Folding@Home: Welcome to Folding@Home
[23:24:09] Loaded queue successfully.
[23:24:10] + Closed connections
[23:24:10]
[23:24:10] + Processing work unit
[23:24:10] Core required: FahCore_b4.exe
[23:24:10] Core not found.
[23:24:10] - Core is not present or corrupted.
[23:24:10] - Attempting to download new core...
[23:24:10] + Downloading new core: FahCore_b4.exe
[23:24:11] + 10240 bytes downloaded
[23:24:41] + 5043905 bytes downloaded
[23:24:41] Verifying core Core_b4.fah...
[23:24:41] Signature is VALID
[23:24:41]
[23:24:41] Trying to unzip core FahCore_b4.exe
[23:24:47] Decompressed FahCore_b4.exe (16226304 bytes) successfully
[23:24:52] + Core successfully engaged
[23:24:57]
[23:24:57] + Processing work unit
[23:24:57] Core required: FahCore_b4.exe
[23:24:57] Core found.
[23:24:57] Working on queue slot 01 [January 9 23:24:57 UTC]
[23:24:57] + Working ...
[23:25:00] *********************** Log Started 09/Jan/2010 23:25:00 ***********************
[23:25:00] ************************** ProtoMol Folding@Home Core **************************
[23:25:00]   Version: 21
[23:25:00]      Type: 180
[23:25:00]      Core: ProtoMol
[23:25:00]   Website: http://folding.stanford.edu/
[23:25:00] Copyright: (c) 2009 Stanford University
[23:25:00]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[23:25:00]      Args: -dir work/ -suffix 01 -checkpoint 15 -lifeline 3984 -version 623
[23:25:00] ************************************ Build *************************************
[23:25:00]      Date: Dec 24 2009
[23:25:00]      Time: 14:36:31
[23:25:00]  Revision: 1748
[23:25:00]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[23:25:00]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[23:25:00]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[23:25:00]  Platform: Windows XP
[23:25:00]      Bits: 32
[23:25:00] ************************************ System ************************************
[23:25:00]        OS: Microsoft Windows XP Professional
[23:25:00]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[23:25:00]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[23:25:00]      CPUs: 2 Logical, 1 Physical
[23:25:00]    Memory: 1023 MB
[23:25:00] ********************************************************************************
[23:25:00] Project: 10001 (Run 67, Clone 3, Gen 25)
[23:25:00] Reading tar file par_all27_prot_lipid.inp
[23:25:00] Reading tar file scpismQuartic.inp
[23:25:00] Reading tar file ww_exteq_nowater1.pdb
[23:25:00] Reading tar file ww_exteq_nowater1.psf
[23:25:00] Reading tar file checkpt
[23:25:00] ERROR: @ fah\tar\TarHeader.cpp:184:<unknown> 0: Error converting number '827609'
[23:25:00] Folding@home Core Shutdown: EARLY_UNIT_END
[23:25:04] CoreStatus = 79 (121)
[23:25:04] Client-core communications error: ERROR 0x79
[23:25:04] This is a sign of more serious problems, shutting down.
Re: Project: 10001 (Run 67, Clone 3, Gen 25)
I agree . . . it sure looks like the same problem, and it'll probably have the same answer:
jcoffland wrote:From your report I was able to track down the bug and fix it in the next release of the ProtoMol core.
There has been no new release of ProtoMol yet.
