Project: 10101 (Run 664, Clone 8, Gen 5)WU will not send
alberts1414
Post by alberts1414 »
This WU has been stuck for over 24 hrs now. Have repeatedly restarted client but same message every time "server has no record of this WU". What else can be done? Otherwise it is working fine. Have included latest attempt after finishing latest WU.
[[12:06:04] Completed 99%
[12:07:55] Completed 100%
[12:07:57] Successful run
[12:07:57] DynamicWrapper: Finished Work Unit: sleep=10000
[12:08:07] Reserved 101044 bytes for xtc file; Cosm status=0
[12:08:07] Allocated 101044 bytes for xtc file
[12:08:07] - Reading up to 101044 from "work/wudata_06.xtc": Read 101044
[12:08:07] Read 101044 bytes from xtc file; available packet space=786329420
[12:08:07] xtc file hash check passed.
[12:08:07] Reserved 30216 30216 786329420 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[12:08:07] Allocated 30216 bytes for arc file
[12:08:07] - Reading up to 30216 from "work/wudata_06.trr": Read 30216
[12:08:07] Read 30216 bytes from arc file; available packet space=786299204
[12:08:07] trr file hash check passed.
[12:08:07] Allocated 560 bytes for edr file
[12:08:07] Read bedfile
[12:08:07] edr file hash check passed.
[12:08:07] Logfile not read.
[12:08:07] GuardedRun: success in DynamicWrapper
[12:08:07] GuardedRun: done
[12:08:07] Run: GuardedRun completed.
[12:08:09] + Opened results file
[12:08:09] - Writing 132332 bytes of core data to disk...
[12:08:09] Done: 131820 -> 131364 (compressed to 99.6 percent)
[12:08:09]   ... Done.
[12:08:09] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[12:08:09] Shutting down core
[12:08:09]
[12:08:09] Folding@home Core Shutdown: FINISHED_UNIT
[12:08:11] CoreStatus = 64 (100)
[12:08:11] Sending work to server
[12:08:11] Project: 10101 (Run 453, Clone 1, Gen 12)
[12:08:11] - Read packet limit of 540015616... Set to 524286976.
[12:08:11] + Attempting to send results [January 1 12:08:11 UTC]
[12:08:16] + Results successfully sent
[12:08:16] Thank you for your contribution to Folding@Home.
[12:08:16] + Number of Units Completed: 54
[12:08:20] Project: 10101 (Run 664, Clone 8, Gen 5)
[12:08:20] - Read packet limit of 540015616... Set to 524286976.
[12:08:20] + Attempting to send results [January 1 12:08:20 UTC]
[12:08:24] - Couldn't send HTTP request to server
[12:08:24] + Could not connect to Work Server (results)
[12:08:24]     (171.64.65.71:8080)
[12:08:24] + Retrying using alternative port
[12:08:26] - Couldn't send HTTP request to server
[12:08:26] + Could not connect to Work Server (results)
[12:08:26]     (171.64.65.71:80)
[12:08:26] - Error: Could not transmit unit 08 (completed December 31) to work server.
[12:08:26] - Read packet limit of 540015616... Set to 524286976.
[12:08:26] + Attempting to send results [January 1 12:08:26 UTC]
[12:08:30] - Server does not have record of this unit. Will try again later.
[12:08:30]   Could not transmit unit 08 to Collection server; keeping in queue.
[12:08:30] - Preparing to get new work unit...
[12:08:30] + Attempting to get work packet
[12:08:30] - Connecting to assignment server
[12:08:31] - Successful: assigned to (171.64.65.71).
[12:08:31] + News From Folding@Home: Welcome to Folding@Home
[12:08:32] Loaded queue successfully.
[12:08:34] Project: 10101 (Run 664, Clone 8, Gen 5)
[12:08:34] - Read packet limit of 540015616... Set to 524286976.
[12:08:34] + Attempting to send results [January 1 12:08:34 UTC]
[12:08:37] - Couldn't send HTTP request to server
[12:08:37] + Could not connect to Work Server (results)
[12:08:37]     (171.64.65.71:8080)
[12:08:37] + Retrying using alternative port
[12:08:39] - Couldn't send HTTP request to server
[12:08:39] + Could not connect to Work Server (results)
[12:08:39]     (171.64.65.71:80)
[12:08:39] - Error: Could not transmit unit 08 (completed December 31) to work server.
[12:08:39] - Read packet limit of 540015616... Set to 524286976.
[12:08:39] + Attempting to send results [January 1 12:08:39 UTC]
[12:08:42] - Server does not have record of this unit. Will try again later.
[12:08:42]   Could not transmit unit 08 to Collection server; keeping in queue.
[12:08:42] + Closed connections
[12:08:42]
[12:08:42] + Processing work unit
[12:08:42] Core required: FahCore_11.exe
[12:08:42] Core found.
[12:08:42] Working on queue slot 07 [January 1 12:08:42 UTC]
[12:08:42] + Working ...
[12:08:42]
[12:08:42] *------------------------------*
[12:08:42] Folding@Home GPU Core
[12:08:42] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[12:08:42]
[12:08:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:08:42] Build host: amoeba
[12:08:42] Board Type: Nvidia
[12:08:42] Core      :
[12:08:42] Preparing to commence simulation
[12:08:42] - Looking at optimizations...
[12:08:42] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[12:08:42] - Created dyn
[12:08:42] - Files status OK
[12:08:43] - Expanded 88641 -> 447303 (decompressed 504.6 percent)
[12:08:43] Called DecompressByteArray: compressed_data_size=88641 data_size=447303, decompressed_data_size=447303 diff=0
[12:08:43] - Digital signature verified
[12:08:43]
[12:08:43] Project: 10101 (Run 417, Clone 9, Gen 15)
[12:08:43]
[12:08:43] Assembly optimizations on if available.
[12:08:43] Entering M.D.
[12:08:49] Tpr hash work/wudata_07.tpr:  32565632 1828589827 600027265 1279950743 2043495738
[12:08:49]
[12:08:49] Calling fah_main args: 14 usage=100
[12:08:49]
[12:08:49] Working on p4744_lam5w_300K
[12:08:51] Client config found, loading data.
[12:08:51] Starting GUI Server
[12:10:41] Completed 1%
[12:12:33] Completed 2%*]
Re: Project: 10101 (Run 664, Clone 8, Gen 5)WU will not send
Can you open http://171.64.65.71:8080/ and http://171.64.65.71/ in your browser ?
alberts1414
first one comes up as OK, second one has a problem opening page. Using Firefox
I know of several reasons why you might get a message "server has no record of this WU" (There may be others)
1) The WU was already credited (previously uploaded).
2) The primary Work Server is down and the Collection Server cannot accept it at this time. (Not true for your case.)
3) The WU has expired (Past the final deadline).
4) You moved the WU from one machine to another (sneakernetting).
alberts1414
Don't know how to check for points 1+2 but this was the 46th unit this client has processed on this machine. Have found the original log for when the unit was processed if it helps.
[00:42:39] - User ID not found locally
[00:42:39] + Requesting User ID from server
[00:42:40] - Machine ID: 2
[00:42:40]
[00:42:40] Loaded queue successfully.
[00:42:40]
[00:42:40] + Processing work unit
[00:42:40] Core required: FahCore_11.exe
[00:42:40] Core found.
[00:42:40] Working on queue slot 08 [December 31 00:42:40 UTC]
[00:42:40] + Working ...
[00:42:40]
[00:42:40] *------------------------------*
[00:42:40] Folding@Home GPU Core
[00:42:40] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[00:42:40]
[00:42:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:42:40] Build host: amoeba
[00:42:40] Board Type: Nvidia
[00:42:40] Core      :
[00:42:40] Preparing to commence simulation
[00:42:40] - Looking at optimizations...
[00:42:40] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[00:42:40] - Created dyn
[00:42:40] - Files status OK
[00:42:40] - Expanded 88628 -> 447303 (decompressed 504.6 percent)
[00:42:40] Called DecompressByteArray: compressed_data_size=88628 data_size=447303, decompressed_data_size=447303 diff=0
[00:42:40] - Digital signature verified
[00:42:40]
[00:42:40] Project: 10101 (Run 664, Clone 8, Gen 5)
[00:42:40]
[00:42:40] Assembly optimizations on if available.
[00:42:40] Entering M.D.
[00:42:46] Tpr hash work/wudata_08.tpr:  3845384638 3460282096 3722740239 2623777337 2600458585
[00:42:46]
[00:42:46] Calling fah_main args: 14 usage=100
[00:42:46]
[00:42:47] Working on p4744_lam5w_300K
[00:42:49] Client config found, loading data.
[00:42:49] Starting GUI Server
[00:44:44] Completed 1%
[00:46:41] Completed 2%
[03:52:22] Completed 99%
[03:54:17] Completed 100%
[03:54:18] Successful run
[03:54:18] DynamicWrapper: Finished Work Unit: sleep=10000
[03:54:28] Reserved 101580 bytes for xtc file; Cosm status=0
[03:54:28] Allocated 101580 bytes for xtc file
[03:54:28] - Reading up to 101580 from "work/wudata_08.xtc": Read 101580
[03:54:28] Read 101580 bytes from xtc file; available packet space=786328884
[03:54:28] xtc file hash check passed.
[03:54:28] Reserved 30216 30216 786328884 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[03:54:28] Allocated 30216 bytes for arc file
[03:54:28] - Reading up to 30216 from "work/wudata_08.trr": Read 30216
[03:54:28] Read 30216 bytes from arc file; available packet space=786298668
[03:54:28] trr file hash check passed.
[03:54:28] Allocated 560 bytes for edr file
[03:54:28] Read bedfile
[03:54:28] edr file hash check passed.
[03:54:28] Logfile not read.
[03:54:28] GuardedRun: success in DynamicWrapper
[03:54:28] GuardedRun: done
[03:54:28] Run: GuardedRun completed.
[03:54:32] + Opened results file
[03:54:32] - Writing 132868 bytes of core data to disk...
[03:54:32] Done: 132356 -> 131889 (compressed to 99.6 percent)
[03:54:32]   ... Done.
[03:54:32] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[03:54:32] Shutting down core
[03:54:32]
[03:54:32] Folding@home Core Shutdown: FINISHED_UNIT
[03:54:35] CoreStatus = 64 (100)
[03:54:35] Sending work to server
[03:54:35] Project: 10101 (Run 664, Clone 8, Gen 5)
[03:54:35] - Read packet limit of 540015616... Set to 524286976.
[03:54:35] + Attempting to send results [December 31 03:54:35 UTC]
[03:54:39] - Couldn't send HTTP request to server
[03:54:39] + Could not connect to Work Server (results)
[03:54:39]     (171.64.65.71:8080)
[03:54:39] + Retrying using alternative port
[03:54:41] - Couldn't send HTTP request to server
[03:54:41] + Could not connect to Work Server (results)
[03:54:41]     (171.64.65.71:80)
[03:54:41] - Error: Could not transmit unit 08 (completed December 31) to work server.
[03:54:41]   Keeping unit 08 in queue.
[03:54:41] Project: 10101 (Run 664, Clone 8, Gen 5)
[03:54:41] - Read packet limit of 540015616... Set to 524286976.
[03:54:41] + Attempting to send results [December 31 03:54:41 UTC]
[03:54:45] - Couldn't send HTTP request to server
[03:54:45] + Could not connect to Work Server (results)
[03:54:45]     (171.64.65.71:8080)
[03:54:45] + Retrying using alternative port
[03:54:46] - Couldn't send HTTP request to server
[03:54:46] + Could not connect to Work Server (results)
[03:54:46]     (171.64.65.71:80)
[03:54:46] - Error: Could not transmit unit 08 (completed December 31) to work server.
[03:54:46] - Read packet limit of 540015616... Set to 524286976.
[03:54:46] + Attempting to send results [December 31 03:54:46 UTC]
[03:54:51] - Server does not have record of this unit. Will try again later.
[03:54:51]   Could not transmit unit 08 to Collection server; keeping in queue.
[03:54:51] - Preparing to get new work unit...
[03:54:51] + Attempting to get work packet
[03:54:51] - Connecting to assignment server
[03:54:52] - Successful: assigned to (171.64.65.71).
[03:54:52] + News From Folding@Home: Welcome to Folding@Home
[03:54:52] Loaded queue successfully.
[03:54:54] Project: 10101 (Run 664, Clone 8, Gen 5)
[03:54:54] - Read packet limit of 540015616... Set to 524286976.
[03:54:54] + Attempting to send results [December 31 03:54:54 UTC]
[03:54:58] - Couldn't send HTTP request to server
[03:54:58] + Could not connect to Work Server (results)
[03:54:58]     (171.64.65.71:8080)
[03:54:58] + Retrying using alternative port
[03:55:00] - Couldn't send HTTP request to server
[03:55:00] + Could not connect to Work Server (results)
[03:55:00]     (171.64.65.71:80)
[03:55:00] - Error: Could not transmit unit 08 (completed December 31) to work server.
[03:55:00] - Read packet limit of 540015616... Set to 524286976.
[03:55:00] + Attempting to send results [December 31 03:55:00 UTC]
[03:55:03] - Server does not have record of this unit. Will try again later.
[03:55:03]   Could not transmit unit 08 to Collection server; keeping in queue.
[03:55:03] + Closed connections
[03:55:03]
[03:55:03] + Processing work unit
[03:55:03] Core required: FahCore_11.exe
[03:55:03] Core found.
[03:55:03] Working on queue slot 09 [December 31 03:55:03 UTC]
[03:55:03] + Working ...
[03:55:03]
[03:55:03] *------------------------------*
[03:55:03] Folding@Home GPU Core
[03:55:03] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[03:55:03]
[03:55:03] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:55:03] Build host: amoeba
[03:55:03] Board Type: Nvidia
[03:55:03] Core      :
[03:55:03] Preparing to commence simulation
[03:55:03] - Looking at optimizations...
[03:55:03] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[03:55:03] - Created dyn
[03:55:03] - Files status OK
[03:55:03] - Expanded 88661 -> 447303 (decompressed 504.5 percent)
[03:55:03] Called DecompressByteArray: compressed_data_size=88661 data_size=447303, decompressed_data_size=447303 diff=0
[03:55:03] - Digital signature verified
[03:55:03]
[03:55:03] Project: 10101 (Run 836, Clone 6, Gen 5)
[03:55:03]
[03:55:03] Assembly optimizations on if available.
[03:55:03] Entering M.D.
[03:55:09] Tpr hash work/wudata_09.tpr:  2851038734 3148605848 3934715994 2694247530 3160581090
[03:55:09]
[03:55:09] Calling fah_main args: 14 usage=100
[03:55:09]
[03:55:12] Working on p4744_lam5w_300K
[03:55:14] Client config found, loading data.
[03:55:14] Starting GUI Server
[03:57:07] Completed 1%
[03:59:08] Completed 2%
[06:39:20] Completed 82%
[06:41:18] Completed 83%
[06:42:40] Project: 10101 (Run 664, Clone 8, Gen 5)
[06:42:40] - Read packet limit of 540015616... Set to 524286976.
[06:42:40] + Attempting to send results [December 31 06:42:40 UTC]
[06:42:45] - Couldn't send HTTP request to server
[06:42:45] + Could not connect to Work Server (results)
[06:42:45]     (171.64.65.71:8080)
[06:42:45] + Retrying using alternative port
[06:42:46] - Couldn't send HTTP request to server
[06:42:46] + Could not connect to Work Server (results)
[06:42:46]     (171.64.65.71:80)
[06:42:46] - Error: Could not transmit unit 08 (completed December 31) to work server.
[06:42:46] - Read packet limit of 540015616... Set to 524286976.
[06:42:46] + Attempting to send results [December 31 06:42:46 UTC]
[06:42:51] - Server does not have record of this unit. Will try again later.
[06:42:51]   Could not transmit unit 08 to Collection server; keeping in queue.
[06:43:14] Completed 84%
[06:45:09] Completed 85%
The log will probably help, but you didn't tell us your folding name. Please post the first page of FAHlog.
alberts1414
Here is the first page of the log as requested
[22:00:44] - Ask before connecting: No
[22:00:44] - User name: Gummibear (Team 46590)
[22:00:44] - User ID: 6B837C52xxxxxxxx
[22:00:44] - Machine ID: 2
[22:00:44]
[22:00:44] Loaded queue successfully.
[22:00:44]
[22:00:44] Project: 10101 (Run 664, Clone 8, Gen 5)
[22:00:44] + Processing work unit
[22:00:44] - Read packet limit of 540015616... [22:00:44] Core required: FahCore_11.exe
Set to 524286976.
[22:00:44] Core found.
[22:00:44] + Attempting to send results [December 31 22:00:44 UTC]
[22:00:44] Working on queue slot 04 [December 31 22:00:44 UTC]
[22:00:44] + Working ...
[22:00:44]
[22:00:44] *------------------------------*
[22:00:44] Folding@Home GPU Core
[22:00:44] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[22:00:44]
[22:00:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:00:44] Build host: amoeba
[22:00:44] Board Type: Nvidia
[22:00:44] Core      :
[22:00:44] Preparing to commence simulation
[22:00:44] - Looking at optimizations...
[22:00:44] - Files status OK
[22:00:45] - Expanded 88712 -> 447303 (decompressed 504.2 percent)
[22:00:45] Called DecompressByteArray: compressed_data_size=88712 data_size=447303, decompressed_data_size=447303 diff=0
[22:00:45] - Digital signature verified
[22:00:45]
[22:00:45] Project: 10101 (Run 533, Clone 5, Gen 8)
[22:00:45]
[22:00:45] Assembly optimizations on if available.
[22:00:45] Entering M.D.
[22:00:49] - Couldn't send HTTP request to server
[22:00:49] + Could not connect to Work Server (results)
[22:00:49]     (171.64.65.71:8080)
[22:00:49] + Retrying using alternative port
[22:00:50] - Couldn't send HTTP request to server
[22:00:50] + Could not connect to Work Server (results)
[22:00:50]     (171.64.65.71:80)
[22:00:50] - Error: Could not transmit unit 08 (completed December 31) to work server.
[22:00:50] - Read packet limit of 540015616... Set to 524286976.
[22:00:50] + Attempting to send results [December 31 22:00:50 UTC]
[22:00:50] Will resume from checkpoint file
[22:00:50] Tpr hash work/wudata_04.tpr:  27358091 2767676179 3101976723 160218026 3295436275
[22:00:50]
[22:00:50] Calling fah_main args: 14 usage=100
[22:00:50]
[22:00:51] Working on p4744_lam5w_300K
[22:00:53] Client config found, loading data.
[22:00:53] Starting GUI Server
[22:00:53] Resuming from checkpoint
[22:00:53] fcCheckPointResume: retreived and current tpr file hash:
[22:00:53]    0     27358091     27358091
[22:00:53]    1   2767676179   2767676179
[22:00:53]    2   3101976723   3101976723
[22:00:53]    3    160218026    160218026
[22:00:53]    4   3295436275   3295436275
[22:00:53] fcCheckPointResume: file hashes same.
[22:00:53] fcCheckPointResume: state restored.
[22:00:53] Verified work/wudata_04.log
[22:00:53] Verified work/wudata_04.edr
[22:00:53] Verified work/wudata_04.xtc
[22:00:53] Completed 61%
[22:00:55] - Server does not have record of this unit. Will try again later.
[22:00:55]   Could not transmit unit 08 to Collection server; keeping in queue.
[22:02:46] Completed 62%
[22:04:39] Completed 63%
