[16:08:12] - Preparing to get new work unit...
[16:08:12] + Attempting to get work packet
[16:08:12] - Connecting to assignment server
[16:08:13] - Successful: assigned to (129.74.85.48).
[16:08:13] + News From Folding@Home: Welcome to Folding@Home
[16:08:13] Loaded queue successfully.
[16:08:13] + Closed connections
[16:08:13]
[16:08:13] + Processing work unit
[16:08:13] Core required: FahCore_b4.exe
[16:08:13] Core found.
[16:08:13] Working on queue slot 05 [December 31 16:08:13 UTC]
[16:08:13] + Working ...
[16:08:18] *********************** Log Started 31/Dec/2009 16:08:18 ***********************
[16:08:18] ************************** ProtoMol Folding@Home Core **************************
[16:08:18] Version: 21
[16:08:18] Type: 180
[16:08:18] Core: ProtoMol
[16:08:18] Website: http://folding.stanford.edu/
[16:08:18] Copyright: (c) 2009 Stanford University
[16:08:18] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:08:18] Args: -dir work/ -suffix 05 -checkpoint 30 -lifeline 652 -version 623
[16:08:18] ************************************ Build *************************************
[16:08:18] Date: Dec 24 2009
[16:08:18] Time: 14:36:31
[16:08:18] Revision: 1748
[16:08:18] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:08:18] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:08:18] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:08:18] Platform: Windows XP
[16:08:18] Bits: 32
[16:08:18] ************************************ System ************************************
[16:08:18] OS: Microsoft(R) Windows(R) Server 2003, Enterprise Edition
[16:08:18] CPU: Intel(R) Pentium(R) 4 CPU 3.20GHz
[16:08:18] CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[16:08:18] CPUs: 2 Logical, 1 Physical
[16:08:18] Memory: 2.00 GB
[16:08:18] ********************************************************************************
[16:08:18] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:08:18] Reading tar file par_all27_prot_lipid.inp
[16:08:18] Reading tar file scpismQuartic.inp
[16:08:18] Reading tar file ww_exteq_nowater1.pdb
[16:08:18] Reading tar file ww_exteq_nowater1.psf
[16:08:18] Reading tar file protomol.conf
[16:08:18] Reading tar file core.xml
[16:08:18] Digital signatures verified
[16:08:18] WARNING: UnexpectedExitHandler triggered
[16:08:18] WARNING: Unexpected exit from science code
[16:08:18] Saving result file logfile_05.txt
[16:08:18] Saving result file log.txt
[16:08:18] Saving result file protomol.conf
[16:08:18] Folding@home Core Shutdown: UNKNOWN
[16:08:22] CoreStatus = 7B (123)
[16:08:25] Sending work to server
[16:08:25] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:08:25] - Read packet limit of 540015616... Set to 524286976.
[16:08:25] + Attempting to send results [December 31 16:08:25 UTC]
[16:08:25] + Results successfully sent
[16:08:25] Thank you for your contribution to Folding@Home.
[16:08:33] - Preparing to get new work unit...
[16:08:33] + Attempting to get work packet
[16:08:33] - Connecting to assignment server
[16:08:34] - Successful: assigned to (129.74.85.48).
[16:08:34] + News From Folding@Home: Welcome to Folding@Home
[16:08:34] Loaded queue successfully.
[16:08:34] + Closed connections
[16:08:39]
[16:08:39] + Processing work unit
[16:08:39] Core required: FahCore_b4.exe
[16:08:39] Core found.
[16:08:39] Working on queue slot 06 [December 31 16:08:39 UTC]
[16:08:39] + Working ...
[16:08:43] *********************** Log Started 31/Dec/2009 16:08:43 ***********************
[16:08:43] ************************** ProtoMol Folding@Home Core **************************
[16:08:43] Version: 21
[16:08:43] Type: 180
[16:08:43] Core: ProtoMol
[16:08:43] Website: http://folding.stanford.edu/
[16:08:43] Copyright: (c) 2009 Stanford University
[16:08:43] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:08:43] Args: -dir work/ -suffix 06 -checkpoint 30 -lifeline 652 -version 623
[16:08:43] ************************************ Build *************************************
[16:08:43] Date: Dec 24 2009
[16:08:43] Time: 14:36:31
[16:08:43] Revision: 1748
[16:08:43] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:08:43] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:08:43] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:08:43] Platform: Windows XP
[16:08:43] Bits: 32
[16:08:43] ************************************ System ************************************
[16:08:43] OS: Microsoft(R) Windows(R) Server 2003, Enterprise Edition
[16:08:43] CPU: Intel(R) Pentium(R) 4 CPU 3.20GHz
[16:08:43] CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[16:08:43] CPUs: 2 Logical, 1 Physical
[16:08:43] Memory: 2.00 GB
[16:08:43] ********************************************************************************
[16:08:43] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:08:43] Reading tar file par_all27_prot_lipid.inp
[16:08:43] Reading tar file scpismQuartic.inp
[16:08:43] Reading tar file ww_exteq_nowater1.pdb
[16:08:43] Reading tar file ww_exteq_nowater1.psf
[16:08:43] Reading tar file protomol.conf
[16:08:43] Reading tar file core.xml
[16:08:43] Digital signatures verified
[16:08:43] WARNING: UnexpectedExitHandler triggered
[16:08:43] WARNING: Unexpected exit from science code
[16:08:43] Saving result file logfile_06.txt
[16:08:43] Saving result file log.txt
[16:08:43] Saving result file protomol.conf
[16:08:43] Folding@home Core Shutdown: UNKNOWN
[16:08:47] CoreStatus = 7B (123)
[16:08:47] Sending work to server
[16:08:47] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:08:47] - Read packet limit of 540015616... Set to 524286976.
[16:08:47] + Attempting to send results [December 31 16:08:47 UTC]
[16:08:48] + Results successfully sent
[16:08:48] Thank you for your contribution to Folding@Home.
[16:08:56] - Preparing to get new work unit...
[16:08:56] + Attempting to get work packet
[16:08:56] - Connecting to assignment server
[16:08:56] - Successful: assigned to (129.74.85.48).
[16:08:56] + News From Folding@Home: Welcome to Folding@Home
[16:08:56] Loaded queue successfully.
[16:08:57] + Closed connections
[16:09:02]
[16:09:02] + Processing work unit
[16:09:02] Core required: FahCore_b4.exe
[16:09:02] Core found.
[16:09:02] Working on queue slot 07 [December 31 16:09:02 UTC]
[16:09:02] + Working ...
[16:09:06] *********************** Log Started 31/Dec/2009 16:09:06 ***********************
[16:09:06] ************************** ProtoMol Folding@Home Core **************************
[16:09:06] Version: 21
[16:09:06] Type: 180
[16:09:06] Core: ProtoMol
[16:09:06] Website: http://folding.stanford.edu/
[16:09:06] Copyright: (c) 2009 Stanford University
[16:09:06] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:09:06] Args: -dir work/ -suffix 07 -checkpoint 30 -lifeline 652 -version 623
[16:09:06] ************************************ Build *************************************
[16:09:06] Date: Dec 24 2009
[16:09:06] Time: 14:36:31
[16:09:06] Revision: 1748
[16:09:06] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:09:06] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:09:06] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:09:06] Platform: Windows XP
[16:09:06] Bits: 32
[16:09:06] ************************************ System ************************************
[16:09:06] OS: Microsoft(R) Windows(R) Server 2003, Enterprise Edition
[16:09:06] CPU: Intel(R) Pentium(R) 4 CPU 3.20GHz
[16:09:06] CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[16:09:06] CPUs: 2 Logical, 1 Physical
[16:09:06] Memory: 2.00 GB
[16:09:06] ********************************************************************************
[16:09:06] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:09:06] Reading tar file par_all27_prot_lipid.inp
[16:09:06] Reading tar file scpismQuartic.inp
[16:09:06] Reading tar file ww_exteq_nowater1.pdb
[16:09:06] Reading tar file ww_exteq_nowater1.psf
[16:09:06] Reading tar file protomol.conf
[16:09:06] Reading tar file core.xml
[16:09:06] Digital signatures verified
[16:09:06] WARNING: UnexpectedExitHandler triggered
[16:09:06] WARNING: Unexpected exit from science code
[16:09:06] Saving result file logfile_07.txt
[16:09:06] Saving result file log.txt
[16:09:06] Saving result file protomol.conf
[16:09:06] Folding@home Core Shutdown: UNKNOWN
[16:09:10] CoreStatus = 7B (123)
[16:09:10] Sending work to server
[16:09:10] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:09:10] - Read packet limit of 540015616... Set to 524286976.
[16:09:10] + Attempting to send results [December 31 16:09:10 UTC]
[16:09:10] + Results successfully sent
[16:09:10] Thank you for your contribution to Folding@Home.
[16:09:18] - Preparing to get new work unit...
[16:09:18] + Attempting to get work packet
[16:09:18] - Connecting to assignment server
[16:09:18] - Successful: assigned to (129.74.85.48).
[16:09:18] + News From Folding@Home: Welcome to Folding@Home
[16:09:19] Loaded queue successfully.
[16:09:19] + Closed connections
[16:09:24]
[16:09:24] + Processing work unit
[16:09:24] Core required: FahCore_b4.exe
[16:09:24] Core found.
[16:09:24] Working on queue slot 08 [December 31 16:09:24 UTC]
[16:09:24] + Working ...
[16:09:28] *********************** Log Started 31/Dec/2009 16:09:28 ***********************
[16:09:28] ************************** ProtoMol Folding@Home Core **************************
[16:09:28] Version: 21
[16:09:28] Type: 180
[16:09:28] Core: ProtoMol
[16:09:28] Website: http://folding.stanford.edu/
[16:09:28] Copyright: (c) 2009 Stanford University
[16:09:28] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:09:28] Args: -dir work/ -suffix 08 -checkpoint 30 -lifeline 652 -version 623
[16:09:28] ************************************ Build *************************************
[16:09:28] Date: Dec 24 2009
[16:09:28] Time: 14:36:31
[16:09:28] Revision: 1748
[16:09:28] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:09:28] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:09:28] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:09:28] Platform: Windows XP
[16:09:28] Bits: 32
[16:09:28] ************************************ System ************************************
[16:09:28] OS: Microsoft(R) Windows(R) Server 2003, Enterprise Edition
[16:09:28] CPU: Intel(R) Pentium(R) 4 CPU 3.20GHz
[16:09:28] CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[16:09:28] CPUs: 2 Logical, 1 Physical
[16:09:28] Memory: 2.00 GB
[16:09:28] ********************************************************************************
[16:09:28] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:09:28] Reading tar file par_all27_prot_lipid.inp
[16:09:28] Reading tar file scpismQuartic.inp
[16:09:28] Reading tar file ww_exteq_nowater1.pdb
[16:09:28] Reading tar file ww_exteq_nowater1.psf
[16:09:28] Reading tar file protomol.conf
[16:09:28] Reading tar file core.xml
[16:09:28] Digital signatures verified
[16:09:29] WARNING: UnexpectedExitHandler triggered
[16:09:29] WARNING: Unexpected exit from science code
[16:09:29] Saving result file logfile_08.txt
[16:09:29] Saving result file log.txt
[16:09:29] Saving result file protomol.conf
[16:09:29] Folding@home Core Shutdown: UNKNOWN
[16:09:32] CoreStatus = 7B (123)
[16:09:32] Sending work to server
[16:09:32] Project: 10001 (Run 123, Clone 5, Gen 0)
[16:09:32] - Read packet limit of 540015616... Set to 524286976.
[16:09:32] + Attempting to send results [December 31 16:09:32 UTC]
[16:09:32] + Results successfully sent
[16:09:32] Thank you for your contribution to Folding@Home.Code: Select all
tags.[/size]
