ProtoMol: Streaming 0x7B's
[Ars] For Caitlin
Hardware configuration: Two homebuilt rigs. Radeon 6900XT. Nvidia 2060 Super.
Post by [Ars] For Caitlin »
I have an old box that only folds that died last night. I replaced the power supply and took the opportunity to upgrade them memory. I checked the Folding logs for the first time in quite awhile and saw that it has been streaming 0x7B's after going to the new B4 core.
Partial log follows. The rest is more of the same. I can pull the wu's names if anybody needs them.
 Past main M.D. loop
[02:03:32]
[02:03:32] Finished Work Unit:
[02:03:32] - Reading up to 188448 from "work/wudata_01.arc": Read 188448
[02:03:32] - Reading up to 17540 from "work/wudata_01.xtc": Read 17540
[02:03:32] goefile size: 0
[02:03:32] logfile size: 17629
[02:03:32] Leaving Run
[02:03:33] - Writing 230621 bytes of core data to disk...
[02:03:34] Done: 230109 -> 206930 (compressed to 89.9 percent)
[02:03:34]   ... Done.
[02:03:34] - Shutting down core
[02:03:34]
[02:03:34] Folding@home Core Shutdown: FINISHED_UNIT
[02:03:37] CoreStatus = 64 (100)
[02:03:37] Unit 1 finished with 96 percent of time to deadline remaining.
[02:03:37] Updated performance fraction: 0.968050
[02:03:37] Sending work to server
[02:03:37] + Attempting to send results
[02:03:37] - Reading file work/wuresults_01.dat from core
[02:03:37]   (Read 207442 bytes from disk)
[02:03:40] - Uploaded at ~67 kB/s
[02:03:40] - Averaged speed for that direction ~71 kB/s
[02:03:40] + Results successfully sent
[02:03:40] Thank you for your contribution to Folding@Home.
[02:03:40] + Number of Units Completed: 873
[02:03:44] Trying to send all finished work units
[02:03:44] + No unsent completed units remaining.
[02:03:44] - Preparing to get new work unit...
[02:03:44] + Attempting to get work packet
[02:03:44] - Will indicate memory of 255 MB
[02:03:44] - Connecting to assignment server
[02:03:45] - Successful: assigned to (129.74.85.48).
[02:03:45] + News From Folding@Home: Welcome to Folding@Home
[02:03:45] Loaded queue successfully.
[02:03:47] - Receiving payload (expected size: 77612)
[02:03:47] Conversation time very short, giving reduced weight in bandwidth avg
[02:03:47] - Downloaded at ~151 kB/s
[02:03:47] - Averaged speed for that direction ~86 kB/s
[02:03:47] + Received work.
[02:03:47] Trying to send all finished work units
[02:03:47] + No unsent completed units remaining.
[02:03:47] + Closed connections
[02:03:47]
[02:03:47] + Processing work unit
[02:03:47] Core required: FahCore_b4.exe
[02:03:47] Core not found.
[02:03:47] - Core is not present or corrupted.
[02:03:47] - Attempting to download new core...
[02:03:47] + Downloading new core: FahCore_b4.exe
[02:03:47] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[02:03:48] + 10240 bytes downloaded
SNIP
[02:04:25] + 5043905 bytes downloaded
[02:04:25] Verifying core Core_b4.fah...
[02:04:25] Signature is VALID
[02:04:25]
[02:04:25] Trying to unzip core FahCore_b4.exe
[02:04:37] Decompressed FahCore_b4.exe (16226304 bytes) successfully
[02:04:37] + Core successfully engaged
[02:04:42]
[02:04:42] + Processing work unit
[02:04:42] Core required: FahCore_b4.exe
[02:04:42] Core found.
[02:04:42] Working on Unit 02 [December 26 02:04:42]
[02:04:42] + Working ...
[02:04:42] - Calling 'FahCore_b4.exe -dir work/ -suffix 02 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:04:49] *********************** Log Started 26/Dec/2009 02:04:49 ***********************
[02:04:49] ************************** ProtoMol Folding@Home Core **************************
[02:04:49]   Version: 21
[02:04:49]      Type: 180
[02:04:49]      Core: ProtoMol
[02:04:49]   Website: http://folding.stanford.edu/
[02:04:49] Copyright: (c) 2009 Stanford University
[02:04:49]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:04:49]      Args: -dir work/ -suffix 02 -checkpoint 15 -forceasm -verbose -lifeline
[02:04:49]            1588 -version 504
[02:04:49]
[02:04:49] ************************************ Build *************************************
[02:04:49]      Date: Dec 24 2009
[02:04:49]      Time: 14:36:31
[02:04:49]  Revision: 1748
[02:04:49]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:04:49]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:04:49]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:04:49]  Platform: Windows XP
[02:04:49]      Bits: 32
[02:04:49] ************************************ System ************************************
[02:04:49]        OS: Microsoft Windows 2000 Service Pack 4
[02:04:49]       CPU: AMD Athlon(tm) XP
[02:04:49]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:04:49]      CPUs: 1 Logical, 1 Physical
[02:04:49]    Memory: 255 MB
[02:04:49] ********************************************************************************
[02:04:49] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:04:50] Reading tar file par_all27_prot_lipid.inp
[02:04:50] Reading tar file scpismQuartic.inp
[02:04:50] Reading tar file ww_exteq_nowater1.pdb
[02:04:50] Reading tar file ww_exteq_nowater1.psf
[02:04:50] Reading tar file checkpt
[02:04:50] Reading tar file ww_exteq_nowater1.238.pos
[02:04:50] Reading tar file ww_exteq_nowater1.238.vel
[02:04:50] Reading tar file protomol.conf
[02:04:50] Reading tar file core.xml
[02:04:50] Digital signatures verified
[02:04:55] GUI Server started
[02:04:55] Completed 0 out of 200000 steps (0)
[02:04:56] WARNING: UnexpectedExitHandler triggered
[02:04:56] WARNING: Unexpected exit from science code
[02:04:56] Saving result file logfile_02.txt
[02:04:56] Saving result file checkpt
[02:04:56] Saving result file log.txt
[02:04:56] Saving result file protomol.conf
[02:04:56] Saving result file ww.dcd
[02:04:56] Saving result file ww_exteq_nowater1.238.pos
[02:04:56] Saving result file ww_exteq_nowater1.238.vel
[02:04:56] Folding@home Core Shutdown: UNKNOWN
[02:04:59] CoreStatus = 7B (123)
[02:04:59] Client-core communications error: ERROR 0x7b
[02:04:59] Deleting current work unit & continuing...
[02:05:03] Trying to send all finished work units
[02:05:03] + No unsent completed units remaining.
[02:05:03] - Preparing to get new work unit...
[02:05:03] + Attempting to get work packet
[02:05:03] - Will indicate memory of 255 MB
[02:05:03] - Connecting to assignment server
[02:05:04] - Successful: assigned to (129.74.85.48).
[02:05:04] + News From Folding@Home: Welcome to Folding@Home
[02:05:04] Loaded queue successfully.
[02:05:04] - Receiving payload (expected size: 77612)
[02:05:04] Conversation time very short, giving reduced weight in bandwidth avg
[02:05:04] - Downloaded at ~151 kB/s
[02:05:04] - Averaged speed for that direction ~93 kB/s
[02:05:04] + Received work.
[02:05:05] + Closed connections
[02:05:10]
[02:05:10] + Processing work unit
[02:05:10] Core required: FahCore_b4.exe
[02:05:10] Core found.
[02:05:10] Working on Unit 03 [December 26 02:05:10]
[02:05:10] + Working ...
[02:05:10] - Calling 'FahCore_b4.exe -dir work/ -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:05:10] *********************** Log Started 26/Dec/2009 02:05:10 ***********************
[02:05:10] ************************** ProtoMol Folding@Home Core **************************
[02:05:10]   Version: 21
[02:05:10]      Type: 180
[02:05:10]      Core: ProtoMol
[02:05:10]   Website: http://folding.stanford.edu/
[02:05:10] Copyright: (c) 2009 Stanford University
[02:05:10]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:05:10]      Args: -dir work/ -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline
[02:05:10]            1588 -version 504
[02:05:10]
[02:05:10] ************************************ Build *************************************
[02:05:10]      Date: Dec 24 2009
[02:05:10]      Time: 14:36:31
[02:05:10]  Revision: 1748
[02:05:10]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:05:10]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:05:10]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:05:10]  Platform: Windows XP
[02:05:10]      Bits: 32
[02:05:10] ************************************ System ************************************
[02:05:10]        OS: Microsoft Windows 2000 Service Pack 4
[02:05:10]       CPU: AMD Athlon(tm) XP
[02:05:10]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:05:10]      CPUs: 1 Logical, 1 Physical
[02:05:10]    Memory: 255 MB
[02:05:10] ********************************************************************************
[02:05:10] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:05:10] Reading tar file par_all27_prot_lipid.inp
[02:05:10] Reading tar file scpismQuartic.inp
[02:05:10] Reading tar file ww_exteq_nowater1.pdb
[02:05:10] Reading tar file ww_exteq_nowater1.psf
[02:05:10] Reading tar file checkpt
[02:05:10] Reading tar file ww_exteq_nowater1.238.pos
[02:05:10] Reading tar file ww_exteq_nowater1.238.vel
[02:05:10] Reading tar file protomol.conf
[02:05:10] Reading tar file core.xml
[02:05:10] Digital signatures verified
[02:05:11] Completed 0 out of 200000 steps (0)
[02:05:11] GUI Server started
[02:05:11] WARNING: UnexpectedExitHandler triggered
[02:05:11] WARNING: Unexpected exit from science code
[02:05:11] Saving result file logfile_03.txt
[02:05:11] Saving result file checkpt
[02:05:11] Saving result file log.txt
[02:05:11] Saving result file protomol.conf
[02:05:11] Saving result file ww.dcd
[02:05:11] Saving result file ww_exteq_nowater1.238.pos
[02:05:11] Saving result file ww_exteq_nowater1.238.vel
[02:05:11] Folding@home Core Shutdown: UNKNOWN
[02:05:14] CoreStatus = 7B (123)
[02:05:14] Client-core communications error: ERROR 0x7b
[02:05:14] Deleting current work unit & continuing...
[02:05:18] Trying to send all finished work units
[02:05:18] + No unsent completed units remaining.
[02:05:18] - Preparing to get new work unit...
[02:05:18] + Attempting to get work packet
[02:05:18] - Will indicate memory of 255 MB
[02:05:18] - Connecting to assignment server
[02:06:14] - Successful: assigned to (129.74.85.48).
[02:06:14] + News From Folding@Home: Welcome to Folding@Home
[02:06:14] Loaded queue successfully.
[02:06:14] - Receiving payload (expected size: 77612)
[02:06:14] Conversation time very short, giving reduced weight in bandwidth avg
[02:06:14] - Downloaded at ~151 kB/s
[02:06:14] - Averaged speed for that direction ~100 kB/s
[02:06:14] + Received work.
[02:06:14] + Closed connections
[02:06:19]
[02:06:19] + Processing work unit
[02:06:19] Core required: FahCore_b4.exe
[02:06:19] Core found.
[02:06:19] Working on Unit 04 [December 26 02:06:19]
[02:06:19] + Working ...
[02:06:19] - Calling 'FahCore_b4.exe -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:06:20] *********************** Log Started 26/Dec/2009 02:06:20 ***********************
[02:06:20] ************************** ProtoMol Folding@Home Core **************************
[02:06:20]   Version: 21
[02:06:20]      Type: 180
[02:06:20]      Core: ProtoMol
[02:06:20]   Website: http://folding.stanford.edu/
[02:06:20] Copyright: (c) 2009 Stanford University
[02:06:20]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:06:20]      Args: -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline
[02:06:20]            1588 -version 504
[02:06:20]
[02:06:20] ************************************ Build *************************************
[02:06:20]      Date: Dec 24 2009
[02:06:20]      Time: 14:36:31
[02:06:20]  Revision: 1748
[02:06:20]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:06:20]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:06:20]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:06:20]  Platform: Windows XP
[02:06:20]      Bits: 32
[02:06:20] ************************************ System ************************************
[02:06:20]        OS: Microsoft Windows 2000 Service Pack 4
[02:06:20]       CPU: AMD Athlon(tm) XP
[02:06:20]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:06:20]      CPUs: 1 Logical, 1 Physical
[02:06:20]    Memory: 255 MB
[02:06:20] ********************************************************************************
[02:06:20] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:06:20] Reading tar file par_all27_prot_lipid.inp
[02:06:20] Reading tar file scpismQuartic.inp
[02:06:20] Reading tar file ww_exteq_nowater1.pdb
[02:06:20] Reading tar file ww_exteq_nowater1.psf
[02:06:20] Reading tar file checkpt
[02:06:20] Reading tar file ww_exteq_nowater1.238.pos
[02:06:20] Reading tar file ww_exteq_nowater1.238.vel
[02:06:20] Reading tar file protomol.conf
[02:06:20] Reading tar file core.xml
[02:06:20] Digital signatures verified
[02:06:21] Completed 0 out of 200000 steps (0)
[02:06:21] GUI Server started
[02:06:21] WARNING: UnexpectedExitHandler triggered
[02:06:21] WARNING: Unexpected exit from science code
[02:06:21] Saving result file logfile_04.txt
[02:06:21] Saving result file checkpt
[02:06:21] Saving result file log.txt
[02:06:21] Saving result file protomol.conf
[02:06:21] Saving result file ww.dcd
[02:06:21] Saving result file ww_exteq_nowater1.238.pos
[02:06:21] Saving result file ww_exteq_nowater1.238.vel
[02:06:21] Folding@home Core Shutdown: UNKNOWN
[02:06:24] CoreStatus = 7B (123)
[02:06:24] Client-core communications error: ERROR 0x7b
[02:06:24] - Attempting to download new core...
[02:06:24] + Downloading new core: FahCore_b4.exe
[02:06:24] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[02:06:24] + 10240 bytes downloaded
SNIP
[02:06:24] + 5043905 bytes downloaded
[02:06:24] Verifying core Core_b4.fah...
[02:06:24] Signature is VALID
[02:06:24]
[02:06:24] Trying to unzip core FahCore_b4.exe
[02:06:37] Decompressed FahCore_b4.exe (16226304 bytes) successfully
[02:06:37] + Core successfully engaged
[02:06:37] Deleting current work unit & continuing...
[02:06:43] Trying to send all finished work units
[02:06:43] + No unsent completed units remaining.
[02:06:43] - Preparing to get new work unit...
[02:06:43] + Attempting to get work packet
[02:06:43] - Will indicate memory of 255 MB
[02:06:43] - Connecting to assignment server
[02:06:44] - Successful: assigned to (129.74.85.48).
[02:06:44] + News From Folding@Home: Welcome to Folding@Home
[02:06:44] Loaded queue successfully.
[02:06:45] - Receiving payload (expected size: 77612)
[02:06:45] Conversation time very short, giving reduced weight in bandwidth avg
[02:06:45] - Downloaded at ~151 kB/s
[02:06:45] - Averaged speed for that direction ~105 kB/s
[02:06:45] + Received work.
[02:06:45] + Closed connections
[02:06:50]
[02:06:50] + Processing work unit
[02:06:50] Core required: FahCore_b4.exe
[02:06:50] Core found.
[02:06:50] Working on Unit 05 [December 26 02:06:50]
[02:06:50] + Working ...
[02:06:50] - Calling 'FahCore_b4.exe -dir work/ -suffix 05 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:06:51] *********************** Log Started 26/Dec/2009 02:06:51 ***********************
[02:06:51] ************************** ProtoMol Folding@Home Core **************************
[02:06:51]   Version: 21
[02:06:51]      Type: 180
[02:06:51]      Core: ProtoMol
[02:06:51]   Website: http://folding.stanford.edu/
[02:06:51] Copyright: (c) 2009 Stanford University
[02:06:51]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:06:51]      Args: -dir work/ -suffix 05 -checkpoint 15 -forceasm -verbose -lifeline
[02:06:51]            1588 -version 504
[02:06:51]
[02:06:51] ************************************ Build *************************************
[02:06:51]      Date: Dec 24 2009
[02:06:51]      Time: 14:36:31
[02:06:51]  Revision: 1748
[02:06:51]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:06:51]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:06:51]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:06:51]  Platform: Windows XP
[02:06:51]      Bits: 32
[02:06:51] ************************************ System ************************************
[02:06:51]        OS: Microsoft Windows 2000 Service Pack 4
[02:06:51]       CPU: AMD Athlon(tm) XP
[02:06:51]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:06:51]      CPUs: 1 Logical, 1 Physical
[02:06:51]    Memory: 255 MB
[02:06:51] ********************************************************************************
[02:06:51] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:06:51] Reading tar file par_all27_prot_lipid.inp
[02:06:51] Reading tar file scpismQuartic.inp
[02:06:51] Reading tar file ww_exteq_nowater1.pdb
[02:06:51] Reading tar file ww_exteq_nowater1.psf
[02:06:51] Reading tar file checkpt
[02:06:51] Reading tar file ww_exteq_nowater1.238.pos
[02:06:51] Reading tar file ww_exteq_nowater1.238.vel
[02:06:51] Reading tar file protomol.conf
[02:06:51] Reading tar file core.xml
[02:06:51] Digital signatures verified
[02:06:53] GUI Server started
[02:06:53] Completed 0 out of 200000 steps (0)
[02:06:53] WARNING: UnexpectedExitHandler triggered
[02:06:53] WARNING: Unexpected exit from science code
[02:06:53] Saving result file logfile_05.txt
[02:06:53] Saving result file checkpt
[02:06:53] Saving result file log.txt
[02:06:53] Saving result file protomol.conf
[02:06:53] Saving result file ww.dcd
[02:06:53] Saving result file ww_exteq_nowater1.238.pos
[02:06:53] Saving result file ww_exteq_nowater1.238.vel
[02:06:53] Folding@home Core Shutdown: UNKNOWN
[02:06:57] CoreStatus = 7B (123)
[02:06:57] Client-core communications error: ERROR 0x7b
[02:06:57] Deleting current work unit & continuing...
[02:07:01] Trying to send all finished work units
[02:07:01] + No unsent completed units remaining.
[02:07:01] - Preparing to get new work unit...
[02:07:01] + Attempting to get work packet
[02:07:01] - Will indicate memory of 255 MB
[02:07:01] - Connecting to assignment server
[02:07:01] - Successful: assigned to (129.74.85.48).
[02:07:01] + News From Folding@Home: Welcome to Folding@Home
[02:07:01] Loaded queue successfully.
[02:07:01] - Receiving payload (expected size: 77612)
[02:07:02] - Downloaded at ~75 kB/s
[02:07:02] - Averaged speed for that direction ~99 kB/s
[02:07:02] + Received work.
[02:07:02] + Closed connections
[02:07:07]
[02:07:07] + Processing work unit
[02:07:07] Core required: FahCore_b4.exe
[02:07:07] Core found.
[02:07:07] Working on Unit 06 [December 26 02:07:07]
[02:07:07] + Working ...
[02:07:07] - Calling 'FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:07:07] *********************** Log Started 26/Dec/2009 02:07:07 ***********************
[02:07:07] ************************** ProtoMol Folding@Home Core **************************
[02:07:07]   Version: 21
[02:07:07]      Type: 180
[02:07:07]      Core: ProtoMol
[02:07:07]   Website: http://folding.stanford.edu/
[02:07:07] Copyright: (c) 2009 Stanford University
[02:07:07]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:07:07]      Args: -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline
[02:07:07]            1588 -version 504
[02:07:07]
[02:07:07] ************************************ Build *************************************
[02:07:07]      Date: Dec 24 2009
[02:07:07]      Time: 14:36:31
[02:07:07]  Revision: 1748
[02:07:07]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:07:07]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:07:07]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:07:07]  Platform: Windows XP
[02:07:07]      Bits: 32
[02:07:07] ************************************ System ************************************
[02:07:07]        OS: Microsoft Windows 2000 Service Pack 4
[02:07:07]       CPU: AMD Athlon(tm) XP
[02:07:07]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:07:07]      CPUs: 1 Logical, 1 Physical
[02:07:07]    Memory: 255 MB
[02:07:07] ********************************************************************************
[02:07:07] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:07:07] Reading tar file par_all27_prot_lipid.inp
[02:07:07] Reading tar file scpismQuartic.inp
[02:07:07] Reading tar file ww_exteq_nowater1.pdb
[02:07:07] Reading tar file ww_exteq_nowater1.psf
[02:07:07] Reading tar file checkpt
[02:07:08] Reading tar file ww_exteq_nowater1.238.pos
[02:07:08] Reading tar file ww_exteq_nowater1.238.vel
[02:07:08] Reading tar file protomol.conf
[02:07:08] Reading tar file core.xml
[02:07:08] Digital signatures verified
[02:07:08] Completed 0 out of 200000 steps (0)
[02:07:08] GUI Server started
[02:07:08] WARNING: UnexpectedExitHandler triggered
[02:07:08] WARNING: Unexpected exit from science code
[02:07:08] Saving result file logfile_06.txt
[02:07:08] Saving result file checkpt
[02:07:08] Saving result file log.txt
[02:07:08] Saving result file protomol.conf
[02:07:08] Saving result file ww.dcd
[02:07:08] Saving result file ww_exteq_nowater1.238.pos
[02:07:08] Saving result file ww_exteq_nowater1.238.vel
[02:07:08] Folding@home Core Shutdown: UNKNOWN
[02:07:12] CoreStatus = 7B (123)
[02:07:12] Client-core communications error: ERROR 0x7b
[02:07:12] Deleting current work unit & continuing...
[02:07:16] Trying to send all finished work units
[02:07:16] + No unsent completed units remaining.
[02:07:16] - Preparing to get new work unit...
[02:07:16] + Attempting to get work packet
[02:07:16] - Will indicate memory of 255 MB
[02:07:16] - Connecting to assignment server
[02:07:16] - Successful: assigned to (129.74.85.48).
[02:07:16] + News From Folding@Home: Welcome to Folding@Home
[02:07:16] Loaded queue successfully.
[02:07:16] - Receiving payload (expected size: 77612)
[02:07:17] - Downloaded at ~75 kB/s
[02:07:17] - Averaged speed for that direction ~95 kB/s
[02:07:17] + Received work.
[02:07:17] + Closed connections
[02:07:22]
[02:07:22] + Processing work unit
[02:07:22] Core required: FahCore_b4.exe
[02:07:22] Core found.
[02:07:22] Working on Unit 07 [December 26 02:07:22]
[02:07:22] + Working ...
[02:07:22] - Calling 'FahCore_b4.exe -dir work/ -suffix 07 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:07:22] *********************** Log Started 26/Dec/2009 02:07:22 ***********************
[02:07:22] ************************** ProtoMol Folding@Home Core **************************
[02:07:22]   Version: 21
[02:07:22]      Type: 180
[02:07:22]      Core: ProtoMol
[02:07:22]   Website: http://folding.stanford.edu/
[02:07:22] Copyright: (c) 2009 Stanford University
[02:07:22]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:07:22]      Args: -dir work/ -suffix 07 -checkpoint 15 -forceasm -verbose -lifeline
[02:07:22]            1588 -version 504
[02:07:22]
[02:07:22] ************************************ Build *************************************
[02:07:22]      Date: Dec 24 2009
[02:07:22]      Time: 14:36:31
[02:07:22]  Revision: 1748
[02:07:22]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:07:22]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:07:22]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:07:22]  Platform: Windows XP
[02:07:22]      Bits: 32
[02:07:22] ************************************ System ************************************
[02:07:22]        OS: Microsoft Windows 2000 Service Pack 4
[02:07:22]       CPU: AMD Athlon(tm) XP
[02:07:22]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:07:22]      CPUs: 1 Logical, 1 Physical
[02:07:22]    Memory: 255 MB
[02:07:22] ********************************************************************************
[02:07:22] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:07:22] Reading tar file par_all27_prot_lipid.inp
[02:07:22] Reading tar file scpismQuartic.inp
[02:07:22] Reading tar file ww_exteq_nowater1.pdb
[02:07:22] Reading tar file ww_exteq_nowater1.psf
[02:07:23] Reading tar file checkpt
[02:07:23] Reading tar file ww_exteq_nowater1.238.pos
[02:07:23] Reading tar file ww_exteq_nowater1.238.vel
[02:07:23] Reading tar file protomol.conf
[02:07:23] Reading tar file core.xml
[02:07:23] Digital signatures verified
[02:07:23] Completed 0 out of 200000 steps (0)
[02:07:23] GUI Server started
[02:07:23] WARNING: UnexpectedExitHandler triggered
[02:07:23] WARNING: Unexpected exit from science code
[02:07:23] Saving result file logfile_07.txt
[02:07:23] Saving result file checkpt
[02:07:23] Saving result file log.txt
[02:07:23] Saving result file protomol.conf
[02:07:23] Saving result file ww.dcd
[02:07:23] Saving result file ww_exteq_nowater1.238.pos
[02:07:23] Saving result file ww_exteq_nowater1.238.vel
[02:07:23] Folding@home Core Shutdown: UNKNOWN
[02:07:26] CoreStatus = 7B (123)
[02:07:26] Client-core communications error: ERROR 0x7b
[02:07:26] - Attempting to download new core...
[02:07:26] + Downloading new core: FahCore_b4.exe
[02:07:26] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[02:07:26] + 10240 bytes downloaded
SNIP
[02:07:27] + 5043905 bytes downloaded
[02:07:27] Verifying core Core_b4.fah...
[02:07:27] Signature is VALID
[02:07:27]
[02:07:27] Trying to unzip core FahCore_b4.exe
[02:07:40] Decompressed FahCore_b4.exe (16226304 bytes) successfully
[02:07:40] + Core successfully engaged
[02:07:40] Deleting current work unit & continuing...
[02:07:44] Trying to send all finished work units
[02:07:44] + No unsent completed units remaining.
[02:07:44] - Preparing to get new work unit...
[02:07:44] + Attempting to get work packet
[02:07:44] - Will indicate memory of 255 MB
[02:07:44] - Connecting to assignment server
[02:07:45] - Successful: assigned to (129.74.85.48).
[02:07:45] + News From Folding@Home: Welcome to Folding@Home
[02:07:45] Loaded queue successfully.
[02:07:45] - Receiving payload (expected size: 77612)
[02:07:45] Conversation time very short, giving reduced weight in bandwidth avg
[02:07:45] - Downloaded at ~151 kB/s
[02:07:45] - Averaged speed for that direction ~101 kB/s
[02:07:45] + Received work.
[02:07:45] + Closed connections
[02:07:50]
[02:07:50] + Processing work unit
[02:07:50] Core required: FahCore_b4.exe
[02:07:50] Core found.
[02:07:50] Working on Unit 08 [December 26 02:07:50]
[02:07:50] + Working ...
[02:07:50] - Calling 'FahCore_b4.exe -dir work/ -suffix 08 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:07:51] *********************** Log Started 26/Dec/2009 02:07:51 ***********************
[02:07:51] ************************** ProtoMol Folding@Home Core **************************
[02:07:51]   Version: 21
[02:07:51]      Type: 180
[02:07:51]      Core: ProtoMol
[02:07:51]   Website: http://folding.stanford.edu/
[02:07:51] Copyright: (c) 2009 Stanford University
[02:07:51]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:07:51]      Args: -dir work/ -suffix 08 -checkpoint 15 -forceasm -verbose -lifeline
[02:07:51]            1588 -version 504
[02:07:51]
[02:07:51] ************************************ Build *************************************
[02:07:51]      Date: Dec 24 2009
[02:07:51]      Time: 14:36:31
[02:07:51]  Revision: 1748
[02:07:51]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:07:51]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:07:51]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:07:51]  Platform: Windows XP
[02:07:51]      Bits: 32
[02:07:51] ************************************ System ************************************
[02:07:51]        OS: Microsoft Windows 2000 Service Pack 4
[02:07:51]       CPU: AMD Athlon(tm) XP
[02:07:51]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:07:51]      CPUs: 1 Logical, 1 Physical
[02:07:51]    Memory: 255 MB
[02:07:51] ********************************************************************************
[02:07:51] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:07:51] Reading tar file par_all27_prot_lipid.inp
[02:07:51] Reading tar file scpismQuartic.inp
[02:07:51] Reading tar file ww_exteq_nowater1.pdb
[02:07:51] Reading tar file ww_exteq_nowater1.psf
[02:07:51] Reading tar file checkpt
[02:07:51] Reading tar file ww_exteq_nowater1.238.pos
[02:07:51] Reading tar file ww_exteq_nowater1.238.vel
[02:07:51] Reading tar file protomol.conf
[02:07:51] Reading tar file core.xml
[02:07:51] Digital signatures verified
[02:07:53] GUI Server started
[02:07:53] Completed 0 out of 200000 steps (0)
[02:07:53] WARNING: UnexpectedExitHandler triggered
[02:07:53] WARNING: Unexpected exit from science code
[02:07:53] Saving result file logfile_08.txt
[02:07:53] Saving result file checkpt
[02:07:53] Saving result file log.txt
[02:07:53] Saving result file protomol.conf
[02:07:53] Saving result file ww.dcd
[02:07:53] Saving result file ww_exteq_nowater1.238.pos
[02:07:53] Saving result file ww_exteq_nowater1.238.vel
[02:07:53] Folding@home Core Shutdown: UNKNOWN
[02:07:57] CoreStatus = 7B (123)
[02:07:57] Client-core communications error: ERROR 0x7b
[02:07:57] Deleting current work unit & continuing...
[02:08:01] Trying to send all finished work units
[02:08:01] + No unsent completed units remaining.
[02:08:01] - Preparing to get new work unit...
[02:08:01] + Attempting to get work packet
[02:08:01] - Will indicate memory of 255 MB
[02:08:01] - Connecting to assignment server
[02:08:01] - Successful: assigned to (129.74.85.48).
[02:08:01] + News From Folding@Home: Welcome to Folding@Home
[02:08:02] Loaded queue successfully.
[02:08:02] - Receiving payload (expected size: 77612)
[02:08:02] Conversation time very short, giving reduced weight in bandwidth avg
[02:08:02] - Downloaded at ~151 kB/s
[02:08:02] - Averaged speed for that direction ~106 kB/s
[02:08:02] + Received work.
[02:08:02] + Closed connections
[02:08:07]
[02:08:07] + Processing work unit
[02:08:07] Core required: FahCore_b4.exe
[02:08:07] Core found.
[02:08:07] Working on Unit 09 [December 26 02:08:07]
[02:08:07] + Working ...
[02:08:07] - Calling 'FahCore_b4.exe -dir work/ -suffix 09 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:08:08] *********************** Log Started 26/Dec/2009 02:08:07 ***********************
[02:08:08] ************************** ProtoMol Folding@Home Core **************************
[02:08:08]   Version: 21
[02:08:08]      Type: 180
[02:08:08]      Core: ProtoMol
[02:08:08]   Website: http://folding.stanford.edu/
[02:08:08] Copyright: (c) 2009 Stanford University
[02:08:08]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:08:08]      Args: -dir work/ -suffix 09 -checkpoint 15 -forceasm -verbose -lifeline
[02:08:08]            1588 -version 504
[02:08:08]
[02:08:08] ************************************ Build *************************************
[02:08:08]      Date: Dec 24 2009
[02:08:08]      Time: 14:36:31
[02:08:08]  Revision: 1748
[02:08:08]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:08:08]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:08:08]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:08:08]  Platform: Windows XP
[02:08:08]      Bits: 32
[02:08:08] ************************************ System ************************************
[02:08:08]        OS: Microsoft Windows 2000 Service Pack 4
[02:08:08]       CPU: AMD Athlon(tm) XP
[02:08:08]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:08:08]      CPUs: 1 Logical, 1 Physical
[02:08:08]    Memory: 255 MB
[02:08:08] ********************************************************************************
[02:08:08] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:08:08] Reading tar file par_all27_prot_lipid.inp
[02:08:08] Reading tar file scpismQuartic.inp
[02:08:08] Reading tar file ww_exteq_nowater1.pdb
[02:08:08] Reading tar file ww_exteq_nowater1.psf
[02:08:08] Reading tar file checkpt
[02:08:08] Reading tar file ww_exteq_nowater1.238.pos
[02:08:08] Reading tar file ww_exteq_nowater1.238.vel
[02:08:08] Reading tar file protomol.conf
[02:08:08] Reading tar file core.xml
[02:08:08] Digital signatures verified
[02:08:09] Completed 0 out of 200000 steps (0)
[02:08:09] WARNING: UnexpectedExitHandler triggered
[02:08:09] GUI Server started
[02:08:09] WARNING: Unexpected exit from science code
[02:08:09] Saving result file logfile_09.txt
[02:08:09] Saving result file checkpt
[02:08:09] Saving result file log.txt
[02:08:09] Saving result file protomol.conf
[02:08:09] Saving result file ww.dcd
[02:08:09] Saving result file ww_exteq_nowater1.238.pos
[02:08:09] Saving result file ww_exteq_nowater1.238.vel
[02:08:09] Folding@home Core Shutdown: UNKNOWN
[02:08:12] CoreStatus = 7B (123)
[02:08:12] Client-core communications error: ERROR 0x7b
[02:08:12] Deleting current work unit & continuing...
[02:08:16] Trying to send all finished work units
[02:08:16] + No unsent completed units remaining.
[02:08:16] - Preparing to get new work unit...
[02:08:16] + Attempting to get work packet
[02:08:16] - Will indicate memory of 255 MB
[02:08:16] - Connecting to assignment server
[02:08:16] - Successful: assigned to (129.74.85.48).
[02:08:16] + News From Folding@Home: Welcome to Folding@Home
[02:08:16] Loaded queue successfully.
[02:08:17] - Receiving payload (expected size: 77612)
[02:08:17] Conversation time very short, giving reduced weight in bandwidth avg
[02:08:17] - Downloaded at ~151 kB/s
[02:08:17] - Averaged speed for that direction ~111 kB/s
[02:08:17] + Received work.
[02:08:17] + Closed connections
[02:08:22]
[02:08:22] + Processing work unit
[02:08:22] Core required: FahCore_b4.exe
[02:08:22] Core found.
[02:08:22] Working on Unit 00 [December 26 02:08:22]
[02:08:22] + Working ...
[02:08:22] - Calling 'FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[02:08:22] *********************** Log Started 26/Dec/2009 02:08:22 ***********************
[02:08:22] ************************** ProtoMol Folding@Home Core **************************
[02:08:22]   Version: 21
[02:08:22]      Type: 180
[02:08:22]      Core: ProtoMol
[02:08:22]   Website: http://folding.stanford.edu/
[02:08:22] Copyright: (c) 2009 Stanford University
[02:08:22]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:08:22]      Args: -dir work/ -suffix 00 -checkpoint 15 -forceasm -verbose -lifeline
[02:08:22]            1588 -version 504
[02:08:22]
[02:08:22] ************************************ Build *************************************
[02:08:22]      Date: Dec 24 2009
[02:08:22]      Time: 14:36:31
[02:08:22]  Revision: 1748
[02:08:22]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:08:22]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:08:22]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:08:22]  Platform: Windows XP
[02:08:22]      Bits: 32
[02:08:22] ************************************ System ************************************
[02:08:22]        OS: Microsoft Windows 2000 Service Pack 4
[02:08:22]       CPU: AMD Athlon(tm) XP
[02:08:22]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[02:08:22]      CPUs: 1 Logical, 1 Physical
[02:08:22]    Memory: 255 MB
[02:08:22] ********************************************************************************
[02:08:22] Project: 10001 (Run 278, Clone 0, Gen 8)
[02:08:22] Reading tar file par_all27_prot_lipid.inp
[02:08:22] Reading tar file scpismQuartic.inp
[02:08:22] Reading tar file ww_exteq_nowater1.pdb
[02:08:22] Reading tar file ww_exteq_nowater1.psf
[02:08:22] Reading tar file checkpt
[02:08:23] Reading tar file ww_exteq_nowater1.238.pos
[02:08:23] Reading tar file ww_exteq_nowater1.238.vel
[02:08:23] Reading tar file protomol.conf
[02:08:23] Reading tar file core.xml
[02:08:23] Digital signatures verified
[02:08:23] GUI Server started
[02:08:23] Completed 0 out of 200000 steps (0)
[02:08:23] WARNING: UnexpectedExitHandler triggered
[02:08:23] WARNING: Unexpected exit from science code
[02:08:23] Saving result file logfile_00.txt
[02:08:23] Saving result file checkpt
[02:08:23] Saving result file log.txt
[02:08:23] Saving result file protomol.conf
[02:08:23] Saving result file ww.dcd
[02:08:23] Saving result file ww_exteq_nowater1.238.pos
[02:08:23] Saving result file ww_exteq_nowater1.238.vel
[02:08:23] Folding@home Core Shutdown: UNKNOWN
[02:08:27] CoreStatus = 7B (123)
[02:08:27] Client-core communications error: ERROR 0x7b
[02:08:27] - Attempting to download new core...
[02:08:27] + Downloading new core: FahCore_b4.exe
[02:08:27] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[02:08:27] + 10240 bytes downloaded
BIG SNIP OF A LOT OF THE SAME
[20:35:29] + 5043905 bytes downloaded
[20:35:29] Verifying core Core_b4.fah...
[20:35:29] Signature is VALID
[20:35:29]
[20:35:29] Trying to unzip core FahCore_b4.exe
[20:35:42] Decompressed FahCore_b4.exe (16226304 bytes) successfully
[20:35:42] + Core successfully engaged
[20:35:42] Deleting current work unit & continuing...
[20:35:46] Trying to send all finished work units
[20:35:46] + No unsent completed units remaining.
[20:35:46] - Preparing to get new work unit...
[20:35:46] + Attempting to get work packet
[20:35:46] - Will indicate memory of 255 MB
[20:35:46] - Connecting to assignment server
[20:35:47] - Successful: assigned to (129.74.85.48).
[20:35:47] + News From Folding@Home: Welcome to Folding@Home
[20:35:47] Loaded queue successfully.
[20:35:47] - Receiving payload (expected size: 78027)
[20:35:48] - Downloaded at ~76 kB/s
[20:35:48] - Averaged speed for that direction ~86 kB/s
[20:35:48] + Received work.
[20:35:48] + Closed connections
[20:35:53]
[20:35:53] + Processing work unit
[20:35:53] Core required: FahCore_b4.exe
[20:35:53] Core found.
[20:35:53] Working on Unit 06 [December 29 20:35:53]
[20:35:53] + Working ...
[20:35:53] - Calling 'FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[20:35:53] *********************** Log Started 29/Dec/2009 20:35:53 ***********************
[20:35:53] ************************** ProtoMol Folding@Home Core **************************
[20:35:53]   Version: 21
[20:35:53]      Type: 180
[20:35:53]      Core: ProtoMol
[20:35:53]   Website: http://folding.stanford.edu/
[20:35:53] Copyright: (c) 2009 Stanford University
[20:35:53]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[20:35:53]      Args: -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline
[20:35:53]            1588 -version 504
[20:35:53]
[20:35:53] ************************************ Build *************************************
[20:35:53]      Date: Dec 24 2009
[20:35:53]      Time: 14:36:31
[20:35:53]  Revision: 1748
[20:35:53]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[20:35:53]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[20:35:53]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[20:35:53]  Platform: Windows XP
[20:35:53]      Bits: 32
[20:35:53] ************************************ System ************************************
[20:35:53]        OS: Microsoft Windows 2000 Service Pack 4
[20:35:53]       CPU: AMD Athlon(tm) XP
[20:35:53]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[20:35:53]      CPUs: 1 Logical, 1 Physical
[20:35:53]    Memory: 255 MB
[20:35:53] ********************************************************************************
[20:35:53] Project: 10001 (Run 629, Clone 4, Gen 5)
[20:35:53] Reading tar file par_all27_prot_lipid.inp
[20:35:53] Reading tar file scpismQuartic.inp
[20:35:53] Reading tar file ww_exteq_nowater1.pdb
[20:35:53] Reading tar file ww_exteq_nowater1.psf
[20:35:53] Reading tar file checkpt
[20:35:53] Reading tar file ww_exteq_nowater1.165.pos
[20:35:53] Reading tar file ww_exteq_nowater1.165.vel
[20:35:53] Reading tar file protomol.conf
[20:35:53] Reading tar file core.xml
[20:35:53] Digital signatures verified
[20:35:55] GUI Server started
[20:35:55] Completed 0 out of 200000 steps (0)
[20:35:55] WARNING: UnexpectedExitHandler triggered
[20:35:55] WARNING: Unexpected exit from science code
[20:35:55] Saving result file logfile_06.txt
[20:35:55] Saving result file checkpt
[20:35:55] Saving result file log.txt
[20:35:55] Saving result file protomol.conf
[20:35:55] Saving result file ww.dcd
[20:35:55] Saving result file ww_exteq_nowater1.165.pos
[20:35:55] Saving result file ww_exteq_nowater1.165.vel
[20:35:55] Folding@home Core Shutdown: UNKNOWN
[20:35:59] CoreStatus = 7B (123)
[20:35:59] Client-core communications error: ERROR 0x7b
[20:35:59] Deleting current work unit & continuing...
[20:36:03] Trying to send all finished work units
[20:36:03] + No unsent completed units remaining.
[20:36:03] - Preparing to get new work unit...
[20:36:03] + Attempting to get work packet
[20:36:03] - Will indicate memory of 255 MB
[20:36:03] - Connecting to assignment server
[20:36:04] - Successful: assigned to (129.74.85.48).
[20:36:04] + News From Folding@Home: Welcome to Folding@Home
[20:36:04] Loaded queue successfully.
[20:36:05] - Receiving payload (expected size: 78027)
[20:36:06] - Downloaded at ~76 kB/s
[20:36:06] - Averaged speed for that direction ~84 kB/s
[20:36:06] + Received work.
[20:36:06] + Closed connections
[20:36:11]
[20:36:11] + Processing work unit
[20:36:11] Core required: FahCore_b4.exe
[20:36:11] Core found.
[20:36:11] Working on Unit 07 [December 29 20:36:11]
[20:36:11] + Working ...
[20:36:11] - Calling 'FahCore_b4.exe -dir work/ -suffix 07 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[20:36:11] *********************** Log Started 29/Dec/2009 20:36:11 ***********************
[20:36:11] ************************** ProtoMol Folding@Home Core **************************
[20:36:11]   Version: 21
[20:36:11]      Type: 180
[20:36:11]      Core: ProtoMol
[20:36:11]   Website: http://folding.stanford.edu/
[20:36:11] Copyright: (c) 2009 Stanford University
[20:36:11]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[20:36:11]      Args: -dir work/ -suffix 07 -checkpoint 15 -forceasm -verbose -lifeline
[20:36:11]            1588 -version 504
[20:36:11]
[20:36:11] ************************************ Build *************************************
[20:36:11]      Date: Dec 24 2009
[20:36:11]      Time: 14:36:31
[20:36:11]  Revision: 1748
[20:36:11]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[20:36:11]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[20:36:11]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[20:36:11]  Platform: Windows XP
[20:36:11]      Bits: 32
[20:36:11] ************************************ System ************************************
[20:36:11]        OS: Microsoft Windows 2000 Service Pack 4
[20:36:11]       CPU: AMD Athlon(tm) XP
[20:36:11]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[20:36:11]      CPUs: 1 Logical, 1 Physical
[20:36:11]    Memory: 255 MB
[20:36:11] ********************************************************************************
[20:36:11] Project: 10001 (Run 629, Clone 4, Gen 5)
[20:36:11] Reading tar file par_all27_prot_lipid.inp
[20:36:11] Reading tar file scpismQuartic.inp
[20:36:11] Reading tar file ww_exteq_nowater1.pdb
[20:36:11] Reading tar file ww_exteq_nowater1.psf
[20:36:12] Reading tar file checkpt
[20:36:12] Reading tar file ww_exteq_nowater1.165.pos
[20:36:12] Reading tar file ww_exteq_nowater1.165.vel
[20:36:12] Reading tar file protomol.conf
[20:36:12] Reading tar file core.xml
[20:36:12] Digital signatures verified
[20:36:12] Completed 0 out of 200000 steps (0)
[20:36:12] GUI Server started
[20:36:12] WARNING: UnexpectedExitHandler triggered
[20:36:12] WARNING: Unexpected exit from science code
[20:36:12] Saving result file logfile_07.txt
[20:36:12] Saving result file checkpt
[20:36:12] Saving result file log.txt
[20:36:12] Saving result file protomol.conf
[20:36:12] Saving result file ww.dcd
[20:36:12] Saving result file ww_exteq_nowater1.165.pos
[20:36:12] Saving result file ww_exteq_nowater1.165.vel
[20:36:12] Folding@home Core Shutdown: UNKNOWN
[20:36:15] CoreStatus = 7B (123)
[20:36:15] Client-core communications error: ERROR 0x7b
[20:36:15] Deleting current work unit & continuing...
[20:36:19] Trying to send all finished work units
[20:36:19] + No unsent completed units remaining.
[20:36:19] - Preparing to get new work unit...
[20:36:19] + Attempting to get work packet
[20:36:19] - Will indicate memory of 255 MB
[20:36:19] - Connecting to assignment server
[20:36:20] - Successful: assigned to (129.74.85.48).
[20:36:20] + News From Folding@Home: Welcome to Folding@Home
[20:36:20] Loaded queue successfully.
[20:36:21] - Receiving payload (expected size: 78027)
[20:36:22] - Downloaded at ~76 kB/s
[20:36:22] - Averaged speed for that direction ~82 kB/s
[20:36:22] + Received work.
[20:36:22] + Closed connections
[20:36:27]
[20:36:27] + Processing work unit
[20:36:27] Core required: FahCore_b4.exe
[20:36:27] Core found.
[20:36:27] Working on Unit 08 [December 29 20:36:27]
[20:36:27] + Working ...
[20:36:27] - Calling 'FahCore_b4.exe -dir work/ -suffix 08 -checkpoint 15 -forceasm -verbose -lifeline 1588 -version 504'
[20:36:27] *********************** Log Started 29/Dec/2009 20:36:27 ***********************
[20:36:27] ************************** ProtoMol Folding@Home Core **************************
[20:36:27]   Version: 21
[20:36:27]      Type: 180
[20:36:27]      Core: ProtoMol
[20:36:27]   Website: http://folding.stanford.edu/
[20:36:27] Copyright: (c) 2009 Stanford University
[20:36:27]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[20:36:27]      Args: -dir work/ -suffix 08 -checkpoint 15 -forceasm -verbose -lifeline
[20:36:27]            1588 -version 504
[20:36:27]
[20:36:27] ************************************ Build *************************************
[20:36:27]      Date: Dec 24 2009
[20:36:27]      Time: 14:36:31
[20:36:27]  Revision: 1748
[20:36:27]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[20:36:27]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[20:36:27]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[20:36:27]  Platform: Windows XP
[20:36:27]      Bits: 32
[20:36:27] ************************************ System ************************************
[20:36:27]        OS: Microsoft Windows 2000 Service Pack 4
[20:36:27]       CPU: AMD Athlon(tm) XP
[20:36:27]    CPU ID: AuthenticAMD Family 6 Model 8 Stepping 1
[20:36:27]      CPUs: 1 Logical, 1 Physical
[20:36:27]    Memory: 255 MB
[20:36:27] ********************************************************************************
[20:36:27] Project: 10001 (Run 629, Clone 4, Gen 5)
[20:36:27] Reading tar file par_all27_prot_lipid.inp
[20:36:27] Reading tar file scpismQuartic.inp
[20:36:27] Reading tar file ww_exteq_nowater1.pdb
[20:36:27] Reading tar file ww_exteq_nowater1.psf
[20:36:27] Reading tar file checkpt
[20:36:27] Reading tar file ww_exteq_nowater1.165.pos
[20:36:27] Reading tar file ww_exteq_nowater1.165.vel
[20:36:27] Reading tar file protomol.conf
[20:36:27] Reading tar file core.xml
[20:36:27] Digital signatures verified
[20:36:28] Completed 0 out of 200000 steps (0)
[20:36:28] GUI Server started
[20:36:28] WARNING: UnexpectedExitHandler triggered
[20:36:28] WARNING: Unexpected exit from science code
[20:36:28] Saving result file logfile_08.txt
[20:36:28] Saving result file checkpt
[20:36:28] Saving result file log.txt
[20:36:28] Saving result file protomol.conf
[20:36:28] Saving result file ww.dcd
[20:36:28] Saving result file ww_exteq_nowater1.165.pos
[20:36:28] Saving result file ww_exteq_nowater1.165.vel
[20:36:28] Folding@home Core Shutdown: UNKNOWN
[20:36:31] CoreStatus = 7B (123)
[20:36:31] Client-core communications error: ERROR 0x7b
[20:36:31]
Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit.
[20:36:31] (To wake it up early, quit the application and restart it.)
[20:36:31] If problems persist, please visit our website at http://folding.stanford.edu for help.
[20:36:31] + Sleeping...
[01:13:17] - Autosending finished units...
[01:13:17] Trying to send all finished work units
[01:13:17] + No unsent completed units remaining.
[01:13:17] - Autosend completed
Box then died sometime after this.
Re: Streaming 0x7B's
Remove -advmethods flag (or advanced option) to avoid these WUs on this machine ...
VijayPande
Pande Group Member
Re: ProtoMol: Streaming 0x7B's
Post by VijayPande »
Thanks for the feedback. To fix this, we've done some AS-level rerouting to avoid the older machines for now, so removing the -adv flag should not be needed (hopefully).
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
I see a value for min ver has been added to the server status page recently (v6.119). Hopefully that helps also, or maybe that is part of what Dr. Pande mentioned aboue. ;)
[Ars] For Caitlin
Restarted just now and got a PMD. Thank you all.
