Project: 2665 (Run 3, Clone 959, Gen 156)
I'd like to report a bad wu, this wu has run 9 times to 64% and quit with, "gromacs can not continue further".
(1)X58a-UD3R . I7-970 (6/12core) @ 3.9 ghz (Windows 7) 12 gigs Mushkin 1333(V7)
(2)KGPE-D16 . 2 x 6274(32cores) @ 2.2 ghz (ubuntu 12.04.1) 16 gigs Kingston 1333(6.34)
(3)KGPE-D16 . 2 x 6274(32cores) @ 2.2 ghz (ubuntu 12.04.1) 32 gigs G Skill 1333(V7)
Re: Project: 2665 (Run 3, Clone 959, Gen 156)
Thank you for the report.
Even though you've described the error very well, it's helpful if you include a segment of FAHlog.txt containing the error so that we can see the surrounding messages.
11:32:09] Completed 157500 out of 250000 steps (63 percent)
[11:48:00] Writing local files
[11:48:00] Completed 160000 out of 250000 steps (64 percent)
[12:00:44] Gromacs cannot continue further.
[12:00:44] Going to send back what have done.
[12:00:44] logfile size: 128675
[12:00:44] - Writing 129211 bytes of core data to disk...
[12:00:44] ... Done.
[12:00:44] - Failed to delete work/wudata_04.sas
[12:00:44] - Failed to delete work/wudata_04.goe
[12:00:44] Warning: check for stray files
[12:00:44]
[12:00:44] Folding@home Core Shutdown: EARLY_UNIT_END
[12:00:44]
[12:00:52] CoreStatus = 63 (99)
[12:00:52] + Error starting Folding@Home core or unexpected system termination of core.
[12:00:52] - Attempting to download new core...
[12:00:52] + Downloading new core: FahCore_a1.exe
[12:00:52] + 10240 bytes downloaded
