Project: 5787 (Run 13, Clone 635, Gen 0)
ei57
Post by ei57 »
17:32:17] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[17:32:17]
[17:32:17] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:32:17] Build host: amoeba
[17:32:17] Board Type: Nvidia
[17:32:17] Core      :
[17:32:17] Preparing to commence simulation
[17:32:17] - Looking at optimizations...
[17:32:17] - Created dyn
[17:32:17] - Files status OK
[17:32:17] - Expanded 49869 -> 346568 (decompressed 694.9 percent)
[17:32:17] Called DecompressByteArray: compressed_data_size=49869 data_size=346568, decompressed_data_size=346568 diff=0
[17:32:17] - Digital signature verified
[17:32:17]
[17:32:17] Project: 5787 (Run 13, Clone 635, Gen 0)
[17:32:17]
[17:32:17] Assembly optimizations on if available.
[17:32:17] Entering M.D.
[17:32:24] Working on Protein
[17:32:25] Client config found, loading data.
[17:32:25] Starting GUI Server
[17:32:25] Successful run
[17:32:25] DynamicWrapper: Finished Work Unit: sleep=10000
[17:32:35] Reserved 0 bytes for xtc file; Cosm status=-2
[17:32:35] Allocated 0 bytes for xtc file
[17:32:35] - Reading up to 0 from "work/wudata_01.xtc": Could not open file
[17:32:35] Error opening or reading xtcfile -- exiting.
[17:32:35] GuardedRun: run failure in DynamicWrapper
[17:32:35] Run: GuardedRun completed.
[17:32:37] y Shutting down core workthread not completede
[17:32:37] - Shutting down core
[17:32:37]
[17:32:37] Folding@home Core Shutdown: FILE_IO_ERROR
[17:32:42] CoreStatus = 75 (117)
[17:32:42] Error opening or reading from a file.
[17:32:42] Deleting current work unit & continuing...
uncle fuzzy
Re: Project: 5787 (Run 13, Clone 635, Gen 0)
Post by uncle fuzzy »
The same issue/different WU is reported here.
viewtopic.php?f=19&t=12621
ei57 wrote:Here's another one:
Project: 5790 (Run 7, Clone 974, Gen 0)
[21:55:23] Entering M.D.
[21:55:30] Working on Protein
[21:55:31] Client config found, loading data.
[21:55:31] Successful run
By coincidence, I was looking in the work directory as this WU was downloaded and noticed that the wudata_xx.tpr was 335KB. Usually these files are 337KB for 787 points WU's.
Topic split into one referencing 5790 (Run 7, Clone 974, Gen 0) explicitly
