Project: 5906 (Run 0, Clone 745, Gen 3)
bollix47
Post by bollix47 »
[00:36:20] + Attempting to get work packet
[00:36:20] - Will indicate memory of 1870 MB
[00:36:20] - Connecting to assignment server
[00:36:20] Connecting to http://assign-GPU.stanford.edu:8080/
[00:36:20] Posted data.
[00:36:20] Initial: 40AB; - Successful: assigned to (171.64.122.70).
[00:36:20] + News From Folding@Home: Welcome to Folding@Home
[00:36:20] Loaded queue successfully.
[00:36:20] Connecting to http://171.64.122.70:8080/
[00:36:21] Posted data.
[00:36:21] Initial: 0000; - Receiving payload (expected size: 70759)
[00:36:21] Conversation time very short, giving reduced weight in bandwidth avg
[00:36:21] - Downloaded at ~138 kB/s
[00:36:21] - Averaged speed for that direction ~70 kB/s
[00:36:21] + Received work.
[00:36:21] Trying to send all finished work units
[00:36:21] + No unsent completed units remaining.
[00:36:21] + Closed connections
[00:36:21]
[00:36:21] + Processing work unit
[00:36:21] Core required: FahCore_14.exe
[00:36:21] Core found.
[00:36:21] Working on queue slot 01 [December 24 00:36:21 UTC]
[00:36:21] + Working ...
[00:36:21] - Calling '.\FahCore_14.exe -dir work/ -suffix 01 -priority 96 -checkpoint 30 -verbose -lifeline 1517 -version 623'
[00:36:21]
[00:36:21] *------------------------------*
[00:36:21] Folding@Home GPU Core - Beta
[00:36:21] Version 1.26 (Wed Oct 14 13:09:26 PDT 2009)
[00:36:21]
[00:36:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:36:21] Build host: vspm46
[00:36:21] Board Type: Nvidia
[00:36:21] Core      :
[00:36:21] Preparing to commence simulation
[00:36:21] - Looking at optimizations...
[00:36:21] - Created dyn
[00:36:21] - Files status OK
[00:36:21] - Expanded 70247 -> 360060 (decompressed 512.5 percent)
[00:36:21] Called DecompressByteArray: compressed_data_size=70247 data_size=360060, decompressed_data_size=360060 diff=0
[00:36:21] - Digital signature verified
[00:36:22]
[00:36:22] Project: 5906 (Run 0, Clone 745, Gen 3)
[00:36:22]
[00:36:22] Assembly optimizations on if available.
[00:36:22] Entering M.D.
[00:36:28] Tpr hash work/wudata_01.tpr:  3642192449 3414027571 1116172308 786354229 2118474874
[00:36:28] Working on Protein
[00:36:29] mdrun_gpu returned
[00:36:29] Going to send back what have done -- stepsTotalG=0
[00:36:29] Work fraction=0.0000 steps=0.
[00:36:33] logfile size=9192 infoLength=9192 edr=0 trr=25
[00:36:33] - Writing 9730 bytes of core data to disk...
[00:36:33] Done: 9218 -> 3341 (compressed to 36.2 percent)
[00:36:33]   ... Done.
[00:36:33]
[00:36:33] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:36:36] CoreStatus = 7A (122)
[00:36:36] Sending work to server
[00:36:36] Project: 5906 (Run 0, Clone 745, Gen 3)
[00:36:36] - Read packet limit of 540015616... Set to 524286976.
[00:36:36] + Attempting to send results [December 24 00:36:36 UTC]
[00:36:36] - Reading file work/wuresults_01.dat from core
[00:36:36]   (Read 3853 bytes from disk)
[00:36:36] Connecting to http://171.64.122.70:8080/
[00:36:36] Posted data.
[00:36:36] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[00:36:36] - Uploaded at ~9 kB/s
[00:36:36] - Averaged speed for that direction ~58 kB/s
[00:36:36] + Results successfully sent
[00:36:36] Thank you for your contribution to Folding@Home.
The client immediately moved on to different WU in the same project after one try and is running fine.
