171.67.108.11 and 25
theo343
Hardware configuration: Home Network:
ADSL 12Mbps - 807 / 14.439
USRobotics 8port 10/100/1000
All computers connected with TP CAT5
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
removed - (8800GTS-512MB@724/1810/972)
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xGPU2 v6.20 R1 Core 1.18/1.19
1xSMP v6.23 Beta R1
HC2:
AM2+ x4 Phenom 9950@3GHz
2GB Crucial Ballistix PC2-5300
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
3xGPU2 v6.20 R1 Core 1.18
1xSMP v6.23 Beta R1
HC3: (not folding atm and outdated)
X2 6000+@Stock
HD3850OC-512MB@783MHz
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*GPU2 v6.12 Beta8 Core 1.04
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
8800GT-256MB@702/1755/900
4GB PC6400
Tagan 480W
Vista Ultimate 32bit SP1
FW 178.24
1xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
OC2:
E8400@stock
2x8800GT-512MB@stock
8GB PC3-8500
Corsair HX520
Vista Business 64bit
FW178.24
2xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
Post by theo343 »
[14:43:16] + Attempting to send results [December 23 14:43:16 UTC]
[14:43:17] - Couldn't send HTTP request to server
[14:43:17] + Could not connect to Work Server (results)
[14:43:17] (171.67.108.11:8080)
[14:43:17] + Retrying using alternative port
[14:43:19] - Couldn't send HTTP request to server
[14:43:19] + Could not connect to Work Server (results)
[14:43:19] (171.67.108.11:80)
[14:43:19] - Error: Could not transmit unit 08 (completed December 23) to work server.
[14:43:19] - Read packet limit of 540015616... Set to 524286976.
[14:43:19] + Attempting to send results [December 23 14:43:19 UTC]
[14:43:21] - Couldn't send HTTP request to server
[14:43:21] + Could not connect to Work Server (results)
[14:43:21] (171.67.108.25:8080)
[14:43:21] + Retrying using alternative port
[14:43:23] - Couldn't send HTTP request to server
[14:43:23] + Could not connect to Work Server (results)
[14:43:23] (171.67.108.25:80)
[14:43:23] Could not transmit unit 08 to Collection server; keeping in queue.
Re: 171.67.108.11 and 25
I can open all four of http://171.67.108.11 and http://171.67.108.11:8080 and http://171.67.108.25:8080/ and http://171.67.108.25/from here.
171.67.108.11 is rather busy, but it seems to be working normally. Go on to running the next WU and the client will keep trying until it gets through.
theo343
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xSMP v6.23 Beta R1
HC2:
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
1xSMP v6.23 Beta R1
X2 6000+@Stock
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
4GB PC6400
Tagan 480W
FW 178.24
1xSMP v6.23 Beta R1
OC2:
E8400@stock
8GB PC3-8500
Corsair HX520
FW178.24
1xSMP v6.23 Beta R1
Post by theo343 »
Cajun_Don
Post by Cajun_Don »
I have been having the same problem with the last 5 or more wu's uploading, since yesterday, but they do eventually upload in time before the preferred deadline.
Happy Holidays everyone
Have a great day.
tobor
Hardware configuration: ASUS M3N-HT deluxe,AMD6400 duel 3.2gig, GeForce9800 GTX C-760 M-1140 S-1900,4 gig OCZ ddr
Post by tobor »
I've got 5 clients not sending.... 171.67.108.25-11
171.67.108.25 is indeed not accepting connections, but it's a collection server which is only called into service when the primary work server has problems. I will report it, of course, but it's a secondary consideration.
The primary consideration is server 171.67.108.11. That server was down from about 11:00 to about 13:45 PST and you posted at 13:48 PST so I'll assume that the problem was fixed about the same time you posted unless I hear from you again. It seems to have been accepting a lot of results since then, as well as distributing a lot of new WUs.
bollix47
Post by bollix47 »
171.67.108.11 in REJECT
