Protomol core on old CPUs
Bob8421
Post by Bob8421 »
According to the news blog announcing the Protomol core...
"If you have a processor that doesn’t have the above mentioned optimizations (Pentium 3, Athlon XP, etc.), please report the behavior and the performance of this core on your machine."
I am running an Athlon MP 2800+ system (SSE only) with Windows 2000 and the v5.04 client. Overnight both CPUs finished their GROMACS work units and were assigned new Protomol units. One CPU started the work unit properly and is working as expected (slower than newer CPUs). It is currently at about 50%.
The second CPU received the same client-core communications error that I got on one of my XP clients. I was not there to respond to the Windows message that the core would be shut down, but the client continued running. It deleted the current work unit and downloaded another (actually the same one) and then downloaded the b4 core again. The process happened 5 times and then the client said that it was going to sleep for 1 day because of the unsuccessful work units.
This morning, when I saw what had happened, I closed the client, deleted the work directory and the queue.dat file, and then restarted the client. It downloaded the same work unit again. I tried this about 20 times and was never able to get a different work unit. Then I let it continue without responding. It did not stop at 5 attempts. After 10 unsuccessful attempts at running the same work unit, it proceeded to delete the work files for all 10 slots and then began downloading work units again. This time after 5 attempts it again went to sleep.
In some ways it seems that the Protomol core is better behaved with client v5.04 on Windows 2000 than it is with client v6.23 on Windows XP, but the end result is really the same -- good work units run and bad work units don't.
Tobit
Re: Protomol core on old CPUs
Post by Tobit »
Is this a dual processor system you are referring to? I assume it is based on how you wrote your message but one can never assume anything. Could you please copy and paste an excerpt from the FAHlog.txt file of the client you are having problems with. We don't need the entire log, just an excerpt that shows the client config, the core info, the project info, and the error message. Probably go to the end to get the information from the last project attempted. If you aren't comfortable with this, you can send me the entire log file via email and I can snip out the portions we need and add it to this thread. My email address is linked in my profile.
Thank you for your report. (I think you might be the first person to report this problem.)
Can you give a more detailed description of each machine (e.g.- RAM size, OS, etc.) and post the specific information from FAHlog surrounding each type of error message. (We don't need to see the error messages more than once or any other information that's just repeated over and over.)
Some of your machines seem to be processing p10000/10001 WUs just fine. Please post the first 8 characters of the UserID (it's longer than that) of the machines that are having troubles. (We don't recommend posting the full User ID.) You can find it at the top of FAHlog.txt just after your User Name and Team No.
Fahlog contents might help too.
Bob8421
Post by Bob8421 »
Tobit:
Yes, the old system has two processors. Athlon MPs are really just Athlon XPs that are capable of running multiple CPUs on the same mobo.
Bruce:
Older system: Athlon MP 2800+, 1GB RAM, Windows 2000 SP4, F@H client 5.04 x 2.
This is the end of the log from the overnight run on the older machine:
[11:15:56] + Attempting to get work packet
[11:15:56] - Will indicate memory of 1023 MB
[11:15:56] - Connecting to assignment server
[11:15:56] Connecting to http://assign.stanford.edu:8080/
[11:15:56] Posted data.
[11:15:56] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[11:15:56] + News From Folding@Home: Welcome to Folding@Home
[11:15:56] Loaded queue successfully.
[11:15:56] Connecting to http://129.74.85.48:8080/
[11:15:57] Posted data.
[11:15:57] Initial: 0000; - Receiving payload (expected size: 78044)
[11:15:57] Conversation time very short, giving reduced weight in bandwidth avg
[11:15:57] - Downloaded at ~152 kB/s
[11:15:57] - Averaged speed for that direction ~124 kB/s
[11:15:57] + Received work.
[11:15:57] + Closed connections
[11:16:02]
[11:16:02] + Processing work unit
[11:16:02] Core required: FahCore_b4.exe
[11:16:02] Core found.
[11:16:02] Working on Unit 09 [December 23 11:16:02]
[11:16:02] + Working ...
[11:16:02] - Calling 'FahCore_b4.exe -dir work/ -suffix 09 -checkpoint 30 -forceasm -verbose -lifeline 816 -version 504'
[11:16:03] *********************** Log Started 23/Dec/2009 11:16:03 ***********************
[11:16:03] ************************** ProtoMol Folding@Home Core **************************
[11:16:03]   Version: 19
[11:16:03]      Type: 180
[11:16:03]      Core: ProtoMol
[11:16:03]   Website: http://folding.stanford.edu/
[11:16:03] Copyright: (c) 2009 Stanford University
[11:16:03]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[11:16:03]      Args: -dir work/ -suffix 09 -checkpoint 30 -forceasm -verbose -lifeline 816
[11:16:03]            -version 504
[11:16:03]
[11:16:03] ************************************ Build *************************************
[11:16:03]      Date: Dec 16 2009
[11:16:03]      Time: 17:02:04
[11:16:03]  Revision: 1746
[11:16:03]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[11:16:03]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[11:16:03]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[11:16:03]  Platform: Windows XP
[11:16:03]      Bits: 32
[11:16:03] ************************************ System ************************************
[11:16:03]        OS: Microsoft Windows 2000 Service Pack 4
[11:16:03]       CPU: Unknown CPU Type
[11:16:03]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[11:16:03]      CPUs: 1 Logical, 1 Physical
[11:16:03]    Memory: 1023 MB
[11:16:03] ********************************************************************************
[11:16:03] Project: 10001 (Run 411, Clone 4, Gen 3)
[11:16:03] Reading tar file par_all27_prot_lipid.inp
[11:16:03] Reading tar file scpismQuartic.inp
[11:16:03] Reading tar file ww_exteq_nowater1.pdb
[11:16:03] Reading tar file ww_exteq_nowater1.psf
[11:16:03] Reading tar file checkpt
[11:16:03] Reading tar file ww_exteq_nowater1.317.pos
[11:16:03] Reading tar file ww_exteq_nowater1.317.vel
[11:16:03] Reading tar file protomol.conf
[11:16:03] Reading tar file core.xml
[11:16:03] Digital signatures verified
[11:16:03] GUI Server started
[11:16:03] Completed 0 out of 200000 steps (0)
[11:16:03] ERROR: Exception in thread 1: @ fah\net\Socket.cpp:139:<unknown> 0: Could not bind socket to 127.0.0.1: No error
[11:16:09] CoreStatus = C000001D (-1073741795)
[11:16:09] Client-core communications error: ERROR 0xc000001d
[11:16:09] Deleting current work unit & continuing...
[11:16:13] - Warning: Could not delete all work unit files (9): Core returned invalid code
[11:16:13] Trying to send all finished work units
[11:16:13] + No unsent completed units remaining.
[11:16:13] - Preparing to get new work unit...
[11:16:13] + Attempting to get work packet
[11:16:13] - Will indicate memory of 1023 MB
[11:16:13] - Connecting to assignment server
[11:16:13] Connecting to http://assign.stanford.edu:8080/
[11:16:13] Posted data.
[11:16:13] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[11:16:13] + News From Folding@Home: Welcome to Folding@Home
[11:16:13] Loaded queue successfully.
[11:16:13] Connecting to http://129.74.85.48:8080/
[11:16:14] Posted data.
[11:16:14] Initial: 0000; - Receiving payload (expected size: 78044)
[11:16:14] Conversation time very short, giving reduced weight in bandwidth avg
[11:16:14] - Downloaded at ~152 kB/s
[11:16:14] - Averaged speed for that direction ~127 kB/s
[11:16:14] + Received work.
[11:16:14] + Closed connections
[11:16:19]
[11:16:19] + Processing work unit
[11:16:19] Core required: FahCore_b4.exe
[11:16:19] Core found.
[11:16:19] Working on Unit 00 [December 23 11:16:19]
[11:16:19] + Working ...
[11:16:19] - Calling 'FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 30 -forceasm -verbose -lifeline 816 -version 504'
[11:16:20] *********************** Log Started 23/Dec/2009 11:16:20 ***********************
[11:16:20] ************************** ProtoMol Folding@Home Core **************************
[11:16:20]   Version: 19
[11:16:20]      Type: 180
[11:16:20]      Core: ProtoMol
[11:16:20]   Website: http://folding.stanford.edu/
[11:16:20] Copyright: (c) 2009 Stanford University
[11:16:20]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[11:16:20]      Args: -dir work/ -suffix 00 -checkpoint 30 -forceasm -verbose -lifeline 816
[11:16:20]            -version 504
[11:16:20]
[11:16:20] ************************************ Build *************************************
[11:16:20]      Date: Dec 16 2009
[11:16:20]      Time: 17:02:04
[11:16:20]  Revision: 1746
[11:16:20]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[11:16:20]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[11:16:20]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[11:16:20]  Platform: Windows XP
[11:16:20]      Bits: 32
[11:16:20] ************************************ System ************************************
[11:16:20]        OS: Microsoft Windows 2000 Service Pack 4
[11:16:20]       CPU: Unknown CPU Type
[11:16:20]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[11:16:20]      CPUs: 1 Logical, 1 Physical
[11:16:20]    Memory: 1023 MB
[11:16:20] ********************************************************************************
[11:16:20] Project: 10001 (Run 411, Clone 4, Gen 3)
[11:16:20] Reading tar file par_all27_prot_lipid.inp
[11:16:20] Reading tar file scpismQuartic.inp
[11:16:20] Reading tar file ww_exteq_nowater1.pdb
[11:16:20] Reading tar file ww_exteq_nowater1.psf
[11:16:20] Reading tar file checkpt
[11:16:20] Reading tar file ww_exteq_nowater1.317.pos
[11:16:20] Reading tar file ww_exteq_nowater1.317.vel
[11:16:20] Reading tar file protomol.conf
[11:16:20] Reading tar file core.xml
[11:16:20] Digital signatures verified
[11:16:20] GUI Server started
[11:16:20] ERROR: Exception in thread 1: @ fah\net\Socket.cpp:139:<unknown> 0: Could not bind socket to 127.0.0.1: No error
[11:16:20] Completed 0 out of 200000 steps (0)
[11:16:26] CoreStatus = C000001D (-1073741795)
[11:16:26] Client-core communications error: ERROR 0xc000001d
[11:16:26]
Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit.
[11:16:26] (To wake it up early, quit the application and restart it.)
[11:16:26] If problems persist, please visit our website at http://folding.stanford.edu for help.
[11:16:26] + Sleeping...
Newer systems (2): Core2Quad Q6600, 4GB RAM, Windows XP Home SP3, F@H client 6.23 x 8.
This is the log from a run on the newer machine:
[03:43:49] Work directory not found. Creating...
[03:43:49] Could not open work queue, generating new queue...
[03:43:49] - Preparing to get new work unit...
[03:43:49] - Autosending finished units... [December 23 03:43:49 UTC]
[03:43:49] + Attempting to get work packet
[03:43:49] Trying to send all finished work units
[03:43:49] - Will indicate memory of 800 MB
[03:43:49] + No unsent completed units remaining.
[03:43:49] - Detect CPU.[03:43:49] - Autosend completed
 Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[03:43:49] - Connecting to assignment server
[03:43:49] Connecting to http://assign.stanford.edu:8080/
[03:43:49] Posted data.
[03:43:49] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[03:43:49] + News From Folding@Home: Welcome to Folding@Home
[03:43:50] Loaded queue successfully.
[03:43:50] Connecting to http://129.74.85.48:8080/
[03:43:50] Posted data.
[03:43:50] Initial: 0000; - Receiving payload (expected size: 38736)
[03:43:50] Conversation time very short, giving reduced weight in bandwidth avg
[03:43:50] - Downloaded at ~75 kB/s
[03:43:50] - Averaged speed for that direction ~75 kB/s
[03:43:50] + Received work.
[03:43:50] + Closed connections
[03:43:50]
[03:43:50] + Processing work unit
[03:43:50] Core required: FahCore_b4.exe
[03:43:50] Core found.
[03:43:50] Working on queue slot 01 [December 23 03:43:50 UTC]
[03:43:50] + Working ...
[03:43:50] - Calling '.\FahCore_b4.exe -dir work/ -suffix 01 -checkpoint 10 -verbose -lifeline 2340 -version 623'
[03:43:52] *********************** Log Started 23/Dec/2009 03:43:52 ***********************
[03:43:52] ************************** ProtoMol Folding@Home Core **************************
[03:43:52]   Version: 19
[03:43:52]      Type: 180
[03:43:52]      Core: ProtoMol
[03:43:52]   Website: http://folding.stanford.edu/
[03:43:52] Copyright: (c) 2009 Stanford University
[03:43:52]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[03:43:52]      Args: -dir work/ -suffix 01 -checkpoint 10 -verbose -lifeline 2340 -version
[03:43:52]            623
[03:43:52] ************************************ Build *************************************
[03:43:52]      Date: Dec 16 2009
[03:43:52]      Time: 17:02:04
[03:43:52]  Revision: 1746
[03:43:52]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[03:43:52]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[03:43:52]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[03:43:52]  Platform: Windows XP
[03:43:52]      Bits: 32
[03:43:52] ************************************ System ************************************
[03:43:52]        OS: Microsoft Windows XP Home Edition
[03:43:52]       CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
[03:43:52]    CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
[03:43:52]      CPUs: 4 Logical, 1 Physical
[03:43:52]    Memory: 3.50 GB
[03:43:52] ********************************************************************************
[03:43:52] Project: 10001 (Run 590, Clone 5, Gen 0)
[03:43:52] Reading tar file par_all27_prot_lipid.inp
[03:43:52] Reading tar file scpismQuartic.inp
[03:43:52] Reading tar file ww_exteq_nowater1.pdb
[03:43:52] Reading tar file ww_exteq_nowater1.psf
[03:43:52] Reading tar file protomol.conf
[03:43:52] Reading tar file core.xml
[03:43:52] Digital signatures verified
[03:43:58] CoreStatus = 3 (3)
[03:43:58] Client-core communications error: ERROR 0x3
[03:43:58] This is a sign of more serious problems, shutting down.
Bob8421
Post by Bob8421 »
Bruce:
No, I'm not the only one with this problem. There are others in the Error 0x3 thread.
Yes, all of the other clients that have received work units 10000/10001 are processing them properly.
Older system User ID: 46AD18E2...
Newer system User ID: 2991D43E...
Tobit
Post by Tobit »
Yeah, the 0x3 error seems to happen mostly with folks running multiple instances on the same box. This is likely something that will need to be addressed by the developers. I would disable -advmethods for now until this gets straightened out.
Bob8421
Post by Bob8421 »
In addition to the 0x3 error, I am frequently getting a similar error message with a different code at the start of a work unit:
Amaruk
Post by Amaruk »
Bob8421 wrote:In addition to the 0x3 error, I am frequently getting a similar error message with a different code at the start of a work unit:
I got the same error.
Athlon XP 2800+, 1 GB RAM, XP Pro 32, 6.23 Systray
[21:48:52] + Attempting to get work packet
[21:48:53] - Will indicate memory of 1023 MB
[21:48:53] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[21:48:53] - Connecting to assignment server
[21:48:53] Connecting to http://assign.stanford.edu:8080/
[21:48:53] Posted data.
[21:48:53] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[21:48:53] + News From Folding@Home: Welcome to Folding@Home
[21:48:53] Loaded queue successfully.
[21:48:53] Connecting to http://129.74.85.48:8080/
[21:48:53] Initial: 0000; - Receiving payload (expected size: 77463)
[21:48:54] - Downloaded at ~75 kB/s
[21:48:54] - Averaged speed for that direction ~245 kB/s
[21:48:54] + Received work.
[21:48:54] Trying to send all finished work units
[21:48:54] + No unsent completed units remaining.
[21:48:54] + Closed connections
[21:48:54]
[21:48:54] + Processing work unit
[21:48:54] Core required: FahCore_b4.exe
[21:48:54] Core not found.
[21:48:54] - Core is not present or corrupted.
[21:48:54] - Attempting to download new core...
[21:48:54] + Downloading new core: FahCore_b4.exe
[21:48:54] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[21:48:54] Initial: AFDE; + 10240 bytes downloaded
<SNIP>
[21:48:58] Initial: B7A3; + 5041701 bytes downloaded
[21:48:58] Verifying core Core_b4.fah...
[21:48:58] Signature is VALID
[21:48:58]
[21:48:58] Trying to unzip core FahCore_b4.exe
[21:49:05] Decompressed FahCore_b4.exe (16222720 bytes) successfully
[21:49:10] + Core successfully engaged
[21:49:16]
[21:49:16] + Processing work unit
[21:49:16] Core required: FahCore_b4.exe
[21:49:16] Core found.
[21:49:16] Working on queue slot 00 [December 23 21:49:16 UTC]
[21:49:16] + Working ...
[21:49:16] - Calling '.\FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 268212 -version 623'
[21:49:27] *********************** Log Started 23/Dec/2009 21:49:26 ***********************
[21:49:27] ************************** ProtoMol Folding@Home Core **************************
[21:49:27]   Version: 19
[21:49:27]      Type: 180
[21:49:27]      Core: ProtoMol
[21:49:27]   Website: http://folding.stanford.edu/
[21:49:27] Copyright: (c) 2009 Stanford University
[21:49:27]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[21:49:27]      Args: -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 268212
[21:49:27]            -version 623
[21:49:27] ************************************ Build *************************************
[21:49:27]      Date: Dec 16 2009
[21:49:27]      Time: 17:02:04
[21:49:27]  Revision: 1746
[21:49:27]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[21:49:27]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[21:49:27]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[21:49:27]  Platform: Windows XP
[21:49:27]      Bits: 32
[21:49:27] ************************************ System ************************************
[21:49:27]        OS: Microsoft Windows XP Professional
[21:49:27]       CPU: AMD Athlon(tm) XP 2800+
[21:49:27]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[21:49:27]      CPUs: 1 Logical, 1 Physical
[21:49:27]    Memory: 1023 MB
[21:49:27] ********************************************************************************
[21:49:27] Project: 10001 (Run 701, Clone 5, Gen 3)
[21:49:27] Reading tar file par_all27_prot_lipid.inp
[21:49:27] Reading tar file scpismQuartic.inp
[21:49:27] Reading tar file ww_exteq_nowater1.pdb
[21:49:27] Reading tar file ww_exteq_nowater1.psf
[21:49:27] Reading tar file checkpt
[21:49:27] Reading tar file ww_exteq_nowater1.130.pos
[21:49:27] Reading tar file ww_exteq_nowater1.130.vel
[21:49:27] Reading tar file protomol.conf
[21:49:27] Reading tar file core.xml
[21:49:27] Digital signatures verified
[21:49:30] GUI Server started
[21:49:30] Completed 0 out of 200000 steps (0%)
[21:49:50] CoreStatus = C000001D (-1073741795)
[21:49:50] Client-core communications error: ERROR 0xc000001d
[21:49:50] This is a sign of more serious problems, shutting down.
~~~RESTART~~~
--- Opening Log file [December 23 21:55:46 UTC]
# Windows CPU Systray Edition #################################################
Launch directory: C:\Documents and Settings\Chow\Application Data\Folding@home-x86
Arguments: -verbosity 9 -advmethods
[21:55:46] - Ask before connecting: No
[21:55:46] - User name: Amaruk (Team 50625)
[21:55:46] - User ID: 2D76848Cxxxxxxxx
[21:55:46] - Machine ID: 1
[21:55:46]
[21:55:46] Loaded queue successfully.
[21:55:46] Initialization complete
[21:55:46]
[21:55:46] + Processing work unit
[21:55:46] - Autosending finished units... [December 23 21:55:46 UTC]
[21:55:46] Trying to send all finished work units
[21:55:46] + No unsent completed units remaining.
[21:55:46] - Autosend completed
[21:55:46] Core required: FahCore_b4.exe
[21:55:46] Core found.
[21:55:46] Working on queue slot 00 [December 23 21:55:46 UTC]
[21:55:46] + Working ...
[21:55:46] - Calling '.\FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 267504 -version 623'
[21:55:53] CoreStatus = 63 (99)
[21:55:53] + Error starting Folding@Home core.
[21:55:58]
[21:55:58] + Processing work unit
[21:55:58] Core required: FahCore_b4.exe
[21:55:58] Core found.
[21:55:58] Working on queue slot 00 [December 23 21:55:58 UTC]
[21:55:58] + Working ...
[21:55:58] - Calling '.\FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 267504 -version 623'
[21:56:00] *********************** Log Started 23/Dec/2009 21:56:00 ***********************
[21:56:00] ************************** ProtoMol Folding@Home Core **************************
[21:56:00]   Version: 19
[21:56:00]      Type: 180
[21:56:00]      Core: ProtoMol
[21:56:00]   Website: http://folding.stanford.edu/
[21:56:00] Copyright: (c) 2009 Stanford University
[21:56:00]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[21:56:00]      Args: -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 267504
[21:56:00]            -version 623
[21:56:00] ************************************ Build *************************************
[21:56:00]      Date: Dec 16 2009
[21:56:00]      Time: 17:02:04
[21:56:00]  Revision: 1746
[21:56:00]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[21:56:00]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[21:56:00]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[21:56:00]  Platform: Windows XP
[21:56:00]      Bits: 32
[21:56:00] ************************************ System ************************************
[21:56:00]        OS: Microsoft Windows XP Professional
[21:56:00]       CPU: AMD Athlon(tm) XP 2800+
[21:56:00]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[21:56:00]      CPUs: 1 Logical, 1 Physical
[21:56:00]    Memory: 1023 MB
[21:56:00] ********************************************************************************
[21:56:00] Project: 10001 (Run 701, Clone 5, Gen 3)
[21:56:00] Reading tar file par_all27_prot_lipid.inp
[21:56:00] Reading tar file scpismQuartic.inp
[21:56:00] Reading tar file ww_exteq_nowater1.pdb
[21:56:00] Reading tar file ww_exteq_nowater1.psf
[21:56:00] Reading tar file checkpt
[21:56:01] Reading tar file ww_exteq_nowater1.130.pos
[21:56:01] Reading tar file ww_exteq_nowater1.130.vel
[21:56:01] Reading tar file protomol.conf
[21:56:01] Reading tar file core.xml
[21:56:01] Digital signatures verified
[21:56:01] GUI Server started
[21:56:01] Completed 0 out of 200000 steps (0%)
[21:57:22] CoreStatus = C000001D (-1073741795)
[21:57:22] Client-core communications error: ERROR 0xc000001d
[21:57:22] This is a sign of more serious problems, shutting down.
~~~RESTART~~~
--- Opening Log file [December 23 21:59:47 UTC]
[21:59:47] - Ask before connecting: No
[21:59:47] - User name: Amaruk (Team 50625)
[21:59:47] - User ID: 2D76848Cxxxxxxxx
[21:59:47] - Machine ID: 1
[21:59:47]
[21:59:47] Loaded queue successfully.
[21:59:47] Initialization complete
[21:59:47]
[21:59:47] + Processing work unit
[21:59:47] - Autosending finished units... [December 23 21:59:47 UTC]
[21:59:47] Trying to send all finished work units
[21:59:47] + No unsent completed units remaining.
[21:59:47] - Autosend completed
[21:59:47] Core required: FahCore_b4.exe
[21:59:47] Core found.
[21:59:47] Working on queue slot 00 [December 23 21:59:47 UTC]
[21:59:47] + Working ...
[21:59:47] - Calling '.\FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 265300 -version 623'
[21:59:53] CoreStatus = 63 (99)
[21:59:53] + Error starting Folding@Home core.
[21:59:58]
[21:59:58] + Processing work unit
[21:59:58] Core required: FahCore_b4.exe
[21:59:58] Core found.
[21:59:58] Working on queue slot 00 [December 23 21:59:58 UTC]
[21:59:58] + Working ...
[21:59:58] - Calling '.\FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 265300 -version 623'
[22:00:01] *********************** Log Started 23/Dec/2009 22:00:01 ***********************
[22:00:01] ************************** ProtoMol Folding@Home Core **************************
[22:00:01]   Version: 19
[22:00:01]      Type: 180
[22:00:01]      Core: ProtoMol
[22:00:01]   Website: http://folding.stanford.edu/
[22:00:01] Copyright: (c) 2009 Stanford University
[22:00:01]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[22:00:01]      Args: -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 265300
[22:00:01]            -version 623
[22:00:01] ************************************ Build *************************************
[22:00:01]      Date: Dec 16 2009
[22:00:01]      Time: 17:02:04
[22:00:01]  Revision: 1746
[22:00:01]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[22:00:01]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[22:00:01]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[22:00:01]  Platform: Windows XP
[22:00:01]      Bits: 32
[22:00:01] ************************************ System ************************************
[22:00:01]        OS: Microsoft Windows XP Professional
[22:00:01]       CPU: AMD Athlon(tm) XP 2800+
[22:00:01]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[22:00:01]      CPUs: 1 Logical, 1 Physical
[22:00:01]    Memory: 1023 MB
[22:00:01] ********************************************************************************
[22:00:01] Project: 10001 (Run 701, Clone 5, Gen 3)
[22:00:01] Reading tar file par_all27_prot_lipid.inp
[22:00:01] Reading tar file scpismQuartic.inp
[22:00:01] Reading tar file ww_exteq_nowater1.pdb
[22:00:01] Reading tar file ww_exteq_nowater1.psf
[22:00:01] Reading tar file checkpt
[22:00:01] Reading tar file ww_exteq_nowater1.130.pos
[22:00:01] Reading tar file ww_exteq_nowater1.130.vel
[22:00:01] Reading tar file protomol.conf
[22:00:01] Reading tar file core.xml
[22:00:01] Digital signatures verified
[22:00:01] GUI Server started
[22:00:02] Completed 0 out of 200000 steps (0%)
[22:04:41] CoreStatus = C000001D (-1073741795)
[22:04:41] Client-core communications error: ERROR 0xc000001d
[22:04:41] This is a sign of more serious problems, shutting down.
~~~Delete work folder, queue.dat, unitinfo.txt, MyFolding.html and FahCore_B4.exe - RESTART~~~
--- Opening Log file [December 23 22:13:30 UTC]
[22:13:30] - Ask before connecting: No
[22:13:30] - User name: Amaruk (Team 50625)
[22:13:30] - User ID: 2D76848Cxxxxxxxx
[22:13:30] - Machine ID: 1
[22:13:30]
[22:13:31] Work directory not found. Creating...
[22:13:31] Could not open work queue, generating new queue...
[22:13:31] Initialization complete
[22:13:31] - Preparing to get new work unit...
[22:13:31] + Attempting to get work packet
[22:13:31] - Autosending finished units... [December 23 22:13:31 UTC]
[22:13:31] Trying to send all finished work units
[22:13:31] + No unsent completed units remaining.
[22:13:31] - Autosend completed
[22:13:31] - Will indicate memory of 1023 MB
[22:13:31] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[22:13:31] - Connecting to assignment server
[22:13:31] Connecting to http://assign.stanford.edu:8080/
[22:13:31] Posted data.
[22:13:31] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[22:13:31] + News From Folding@Home: Welcome to Folding@Home
[22:13:31] Loaded queue successfully.
[22:13:31] Connecting to http://129.74.85.48:8080/
[22:13:31] Initial: 0000; - Receiving payload (expected size: 77463)
[22:13:32] - Downloaded at ~75 kB/s
[22:13:32] - Averaged speed for that direction ~75 kB/s
[22:13:32] + Received work.
[22:13:32] + Closed connections
[22:13:32]
[22:13:32] + Processing work unit
[22:13:32] Core required: FahCore_b4.exe
[22:13:32] Core not found.
[22:13:32] - Core is not present or corrupted.
[22:13:32] - Attempting to download new core...
[22:13:32] + Downloading new core: FahCore_b4.exe
[22:13:32] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[22:13:32] Initial: AFDE; + 10240 bytes downloaded
<SNIP>
[22:13:36] Initial: B7A3; + 5041701 bytes downloaded
[22:13:36] Verifying core Core_b4.fah...
[22:13:36] Signature is VALID
[22:13:36]
[22:13:36] Trying to unzip core FahCore_b4.exe
[22:13:44] Decompressed FahCore_b4.exe (16222720 bytes) successfully
[22:13:49] + Core successfully engaged
[22:13:55]
[22:13:55] + Processing work unit
[22:13:55] Core required: FahCore_b4.exe
[22:13:55] Core found.
[22:13:55] Working on queue slot 01 [December 23 22:13:55 UTC]
[22:13:55] + Working ...
[22:13:55] - Calling '.\FahCore_b4.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 267368 -version 623'
[22:14:00] *********************** Log Started 23/Dec/2009 22:13:59 ***********************
[22:14:00] ************************** ProtoMol Folding@Home Core **************************
[22:14:00]   Version: 19
[22:14:00]      Type: 180
[22:14:00]      Core: ProtoMol
[22:14:00]   Website: http://folding.stanford.edu/
[22:14:00] Copyright: (c) 2009 Stanford University
[22:14:00]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[22:14:00]      Args: -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 267368
[22:14:00]            -version 623
[22:14:00] ************************************ Build *************************************
[22:14:00]      Date: Dec 16 2009
[22:14:00]      Time: 17:02:04
[22:14:00]  Revision: 1746
[22:14:00]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[22:14:00]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[22:14:00]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[22:14:00]  Platform: Windows XP
[22:14:00]      Bits: 32
[22:14:00] ************************************ System ************************************
[22:14:00]        OS: Microsoft Windows XP Professional
[22:14:00]       CPU: AMD Athlon(tm) XP 2800+
[22:14:00]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[22:14:00]      CPUs: 1 Logical, 1 Physical
[22:14:00]    Memory: 1023 MB
[22:14:00] ********************************************************************************
[22:14:00] Project: 10001 (Run 701, Clone 5, Gen 3)
[22:14:00] Reading tar file par_all27_prot_lipid.inp
[22:14:00] Reading tar file scpismQuartic.inp
[22:14:00] Reading tar file ww_exteq_nowater1.pdb
[22:14:00] Reading tar file ww_exteq_nowater1.psf
[22:14:00] Reading tar file checkpt
[22:14:00] Reading tar file ww_exteq_nowater1.130.pos
[22:14:00] Reading tar file ww_exteq_nowater1.130.vel
[22:14:00] Reading tar file protomol.conf
[22:14:00] Reading tar file core.xml
[22:14:00] Digital signatures verified
[22:14:03] GUI Server started
[22:14:03] Completed 0 out of 200000 steps (0%)
[22:23:32] CoreStatus = C000001D (-1073741795)
[22:23:32] Client-core communications error: ERROR 0xc000001d
[22:23:32] This is a sign of more serious problems, shutting down.
~~~ONE LAST RETRY, removed -advmethods flag before core died~~~
--- Opening Log file [December 23 22:35:44 UTC]
[22:35:44] - Ask before connecting: No
[22:35:44] - User name: Amaruk (Team 50625)
[22:35:44] - User ID: 2D76848Cxxxxxxxx
[22:35:44] - Machine ID: 1
[22:35:44]
[22:35:44] Loaded queue successfully.
[22:35:44] Initialization complete
[22:35:44]
[22:35:44] + Processing work unit
[22:35:44] - Autosending finished units... [December 23 22:35:44 UTC]
[22:35:44] Trying to send all finished work units
[22:35:44] + No unsent completed units remaining.
[22:35:44] - Autosend completed
[22:35:44] Core required: FahCore_b4.exe
[22:35:44] Core found.
[22:35:44] Working on queue slot 01 [December 23 22:35:44 UTC]
[22:35:44] + Working ...
[22:35:44] - Calling '.\FahCore_b4.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 264448 -version 623'
[22:35:50] CoreStatus = 63 (99)
[22:35:50] + Error starting Folding@Home core.
[22:35:55]
[22:35:55] + Processing work unit
[22:35:55] Core required: FahCore_b4.exe
[22:35:55] Core found.
[22:35:55] Working on queue slot 01 [December 23 22:35:55 UTC]
[22:35:55] + Working ...
[22:35:55] - Calling '.\FahCore_b4.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 264448 -version 623'
[22:35:58] *********************** Log Started 23/Dec/2009 22:35:58 ***********************
[22:35:58] ************************** ProtoMol Folding@Home Core **************************
[22:35:58]   Version: 19
[22:35:58]      Type: 180
[22:35:58]      Core: ProtoMol
[22:35:58]   Website: http://folding.stanford.edu/
[22:35:58] Copyright: (c) 2009 Stanford University
[22:35:58]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[22:35:58]      Args: -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 264448
[22:35:58]            -version 623
[22:35:58] ************************************ Build *************************************
[22:35:58]      Date: Dec 16 2009
[22:35:58]      Time: 17:02:04
[22:35:58]  Revision: 1746
[22:35:58]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[22:35:58]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[22:35:58]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[22:35:58]  Platform: Windows XP
[22:35:58]      Bits: 32
[22:35:58] ************************************ System ************************************
[22:35:58]        OS: Microsoft Windows XP Professional
[22:35:58]       CPU: AMD Athlon(tm) XP 2800+
[22:35:58]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[22:35:58]      CPUs: 1 Logical, 1 Physical
[22:35:58]    Memory: 1023 MB
[22:35:58] ********************************************************************************
[22:35:58] Project: 10001 (Run 701, Clone 5, Gen 3)
[22:35:58] Reading tar file par_all27_prot_lipid.inp
[22:35:58] Reading tar file scpismQuartic.inp
[22:35:58] Reading tar file ww_exteq_nowater1.pdb
[22:35:58] Reading tar file ww_exteq_nowater1.psf
[22:35:58] Reading tar file checkpt
[22:35:58] Reading tar file ww_exteq_nowater1.130.pos
[22:35:58] Reading tar file ww_exteq_nowater1.130.vel
[22:35:58] Reading tar file protomol.conf
[22:35:58] Reading tar file core.xml
[22:35:58] Digital signatures verified
[22:35:59] GUI Server started
[22:35:59] Completed 0 out of 200000 steps (0%)
[22:36:06] CoreStatus = C000001D (-1073741795)
[22:36:06] Client-core communications error: ERROR 0xc000001d
[22:36:06] This is a sign of more serious problems, shutting down.
--- Opening Log file [December 23 22:39:56 UTC]
[22:39:56] - Ask before connecting: No
[22:39:56] - User name: Amaruk (Team 50625)
[22:39:56] - User ID: 2D76848Cxxxxxxxx
[22:39:56] - Machine ID: 1
[22:39:56]
[22:39:56] Work directory not found. Creating...
[22:39:56] Could not open work queue, generating new queue...
[22:39:56] Initialization complete
[22:39:56] - Preparing to get new work unit...
[22:39:56] + Attempting to get work packet
[22:39:56] - Autosending finished units... [December 23 22:39:56 UTC]
[22:39:56] Trying to send all finished work units
[22:39:56] + No unsent completed units remaining.
[22:39:56] - Autosend completed
[22:39:56] - Will indicate memory of 1023 MB
[22:39:56] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[22:39:56] - Connecting to assignment server
[22:39:56] Connecting to http://assign.stanford.edu:8080/
[22:39:57] Posted data.
[22:39:57] Initial: 40AB; - Successful: assigned to (171.64.65.111).
[22:39:57] + News From Folding@Home: Welcome to Folding@Home
[22:39:57] Loaded queue successfully.
[22:39:57] Connecting to http://171.64.65.111:8080/
[22:39:57] Initial: 0000; - Receiving payload (expected size: 464357)
[22:39:58] - Downloaded at ~453 kB/s
[22:39:58] - Averaged speed for that direction ~453 kB/s
[22:39:58] + Received work.
[22:39:58] + Closed connections
[22:39:58]
[22:39:58] + Processing work unit
[22:39:58] Core required: FahCore_78.exe
[22:39:58] Core found.
[22:39:58] Working on queue slot 01 [December 23 22:39:58 UTC]
[22:39:58] + Working ...
[22:39:58] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 266092 -version 623'
[22:39:58]
[22:39:58] *------------------------------*
[22:39:58] Folding@Home Gromacs Core
[22:39:58] Version 1.90 (March 8, 2006)
[22:39:58]
[22:39:58] Preparing to commence simulation
[22:39:58] - Looking at optimizations...
[22:39:58] - Created dyn
[22:39:58] - Files status OK
[22:39:59] - Expanded 463845 -> 2244013 (decompressed 483.7 percent)
[22:39:59] - Starting from initial work packet
[22:39:59]
[22:39:59] Project: 6316 (Run 347, Clone 10, Gen 21)
[22:39:59]
[22:39:59] Assembly optimizations on if available.
[22:39:59] Entering M.D.
[22:40:05] Protein: p6316_sh3_with_ALA_frags
[22:40:05]
[22:40:05] Writing local files
[22:40:05] Extra SSE boost OK.
[22:40:06] Writing local files
[22:40:06] Completed 0 out of 500000 steps  (0%)
If the client is restarted with the FahCore_b4.exe already downloaded it generates two errors. This is the first:
The second is generated just before it dies.
Bob8421
Post by Bob8421 »
My last two clients that finished and got a new ProtoMol work unit downloaded a new b4 core (version 20). Maybe the problem has been fixed. At least we can hope!
Amaruk
Post by Amaruk »
Bob8421 wrote:My last two clients that finished and got a new ProtoMol work unit downloaded a new b4 core (version 20). Maybe the problem has been fixed. At least we can hope!
I was curious to see if the newer core made any difference, so I put the -advmethods flag back into my Athlon XP folder several days ago. Just got assigned to the ProtoMol server, and this was the resulting trainwreck. Machine is an HP a230n with additional ram and graphics card, running XP Pro 32
[07:03:23] Completed 250000 out of 250000 steps  (100%)
[07:03:23] Writing final coordinates.
[07:03:29] Past main M.D. loop
[07:04:31]
[07:04:31] Finished Work Unit:
[07:04:31] - Reading up to 2296008 from "work/wudata_02.arc": Read 2296008
[07:04:31] - Reading up to 97124 from "work/wudata_02.xtc": Read 97124
[07:04:31] goefile size: 0
[07:04:31] logfile size: 33634
[07:04:31] Leaving Run
[07:04:35] - Writing 2444942 bytes of core data to disk...
[07:04:35]   ... Done.
[07:04:35] - Shutting down core
[07:04:35]
[07:04:35] Folding@home Core Shutdown: FINISHED_UNIT
[07:04:40] CoreStatus = 64 (100)
[07:04:40] Unit 2 finished with 95 percent of time to deadline remaining.
[07:04:40] Updated performance fraction: 0.959535
[07:04:40] Sending work to server
[07:04:40] Project: 2483 (Run 148, Clone 12, Gen 12)
[07:04:40] - Read packet limit of 540015616... Set to 524286976.
[07:04:40] + Attempting to send results [December 30 07:04:40 UTC]
[07:04:40] - Reading file work/wuresults_02.dat from core
[07:04:40]   (Read 2444942 bytes from disk)
[07:04:40] Connecting to http://171.65.103.162:8080/
[07:04:46] Posted data.
[07:04:46] Initial: 0000; - Uploaded at ~298 kB/s
[07:04:48] - Averaged speed for that direction ~327 kB/s
[07:04:48] + Results successfully sent
[07:04:48] Thank you for your contribution to Folding@Home.
[07:04:48] + Number of Units Completed: 57
[07:04:52] Trying to send all finished work units
[07:04:52] + No unsent completed units remaining.
[07:04:52] - Preparing to get new work unit...
[07:04:52] + Attempting to get work packet
[07:04:52] - Will indicate memory of 1023 MB
[07:04:52] - Connecting to assignment server
[07:04:52] Connecting to http://assign.stanford.edu:8080/
[07:04:53] Posted data.
[07:04:53] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:04:53] + News From Folding@Home: Welcome to Folding@Home
[07:04:53] Loaded queue successfully.
[07:04:53] Connecting to http://129.74.85.48:8080/
[07:04:53] Initial: 0000; - Receiving payload (expected size: 77903)
[07:04:54] - Downloaded at ~76 kB/s
[07:04:54] - Averaged speed for that direction ~659 kB/s
[07:04:54] + Received work.
[07:04:54] Trying to send all finished work units
[07:04:54] + No unsent completed units remaining.
[07:04:54] + Closed connections
[07:04:54]
[07:04:54] + Processing work unit
[07:04:54] Core required: FahCore_b4.exe
[07:04:54] Core not found.
[07:04:54] - Core is not present or corrupted.
[07:04:54] - Attempting to download new core...
[07:04:54] + Downloading new core: FahCore_b4.exe
[07:04:54] Downloading core (/~pande/Win32/x86/Core_b4.fah from www.stanford.edu)
[07:04:54] Initial: AFDE; + 10240 bytes downloaded
[07:04:54] Initial: 3AC3; + 20480 bytes downloaded
<SNIP>
[07:04:58] Initial: 951F; + 5038080 bytes downloaded
[07:04:58] Initial: 5B18; + 5043905 bytes downloaded
[07:04:58] Verifying core Core_b4.fah...
[07:04:58] Signature is VALID
[07:04:58]
[07:04:58] Trying to unzip core FahCore_b4.exe
[07:05:05] Decompressed FahCore_b4.exe (16226304 bytes) successfully
[07:05:10] + Core successfully engaged
[07:05:16]
[07:05:16] + Processing work unit
[07:05:16] Core required: FahCore_b4.exe
[07:05:16] Core found.
[07:05:16] Working on queue slot 03 [December 30 07:05:16 UTC]
[07:05:16] + Working ...
[07:05:16] - Calling '.\FahCore_b4.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:05:25] *********************** Log Started 30/Dec/2009 07:05:24 ***********************
[07:05:25] ************************** ProtoMol Folding@Home Core **************************
[07:05:25]   Version: 21
[07:05:25]      Type: 180
[07:05:25]      Core: ProtoMol
[07:05:25]   Website: http://folding.stanford.edu/
[07:05:25] Copyright: (c) 2009 Stanford University
[07:05:25]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:05:25]      Args: -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 267364
[07:05:25]            -version 623
[07:05:25] ************************************ Build *************************************
[07:05:25]      Date: Dec 24 2009
[07:05:25]      Time: 14:36:31
[07:05:25]  Revision: 1748
[07:05:25]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:05:25]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:05:25]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:05:25]  Platform: Windows XP
[07:05:25]      Bits: 32
[07:05:25] ************************************ System ************************************
[07:05:25]        OS: Microsoft Windows XP Professional
[07:05:25]       CPU: AMD Athlon(tm) XP 2800+
[07:05:25]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:05:25]      CPUs: 1 Logical, 1 Physical
[07:05:25]    Memory: 1023 MB
[07:05:25] ********************************************************************************
[07:05:25] Project: 10001 (Run 653, Clone 2, Gen 11)
[07:05:25] Reading tar file par_all27_prot_lipid.inp
[07:05:25] Reading tar file scpismQuartic.inp
[07:05:25] Reading tar file ww_exteq_nowater1.pdb
[07:05:25] Reading tar file ww_exteq_nowater1.psf
[07:05:25] Reading tar file checkpt
[07:05:25] Reading tar file ww_exteq_nowater1.484.pos
[07:05:25] Reading tar file ww_exteq_nowater1.484.vel
[07:05:25] Reading tar file protomol.conf
[07:05:25] Reading tar file core.xml
[07:05:25] Digital signatures verified
[07:05:28] GUI Server started
[07:05:28] Completed 0 out of 200000 steps (0%)
[07:05:28] WARNING: UnexpectedExitHandler triggered
[07:05:28] WARNING: Unexpected exit from science code
[07:05:28] Saving result file logfile_03.txt
[07:05:28] Saving result file checkpt
[07:05:28] Saving result file log.txt
[07:05:28] Saving result file protomol.conf
[07:05:28] Saving result file ww.dcd
[07:05:28] Saving result file ww_exteq_nowater1.484.pos
[07:05:28] Saving result file ww_exteq_nowater1.484.vel
[07:05:28] Folding@home Core Shutdown: UNKNOWN
[07:05:32] CoreStatus = 7B (123)
[07:05:32] Sending work to server
[07:05:32] Project: 10001 (Run 653, Clone 2, Gen 11)
[07:05:32] - Read packet limit of 540015616... Set to 524286976.
[07:05:32] + Attempting to send results [December 30 07:05:32 UTC]
[07:05:32] - Reading file work/wuresults_03.dat from core
[07:05:32]   (Read 49330 bytes from disk)
[07:05:32] Connecting to http://129.74.85.48:8080/
[07:05:42] Posted data.
[07:05:42] Initial: 0000; - Uploaded at ~4 kB/s
[07:05:42] - Averaged speed for that direction ~219 kB/s
[07:05:42] + Results successfully sent
[07:05:42] Thank you for your contribution to Folding@Home.
[07:05:48] Trying to send all finished work units
[07:05:48] + No unsent completed units remaining.
[07:05:48] - Preparing to get new work unit...
[07:05:48] + Attempting to get work packet
[07:05:48] - Will indicate memory of 1023 MB
[07:05:48] - Connecting to assignment server
[07:05:48] Connecting to http://assign.stanford.edu:8080/
[07:05:48] Posted data.
[07:05:48] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:05:48] + News From Folding@Home: Welcome to Folding@Home
[07:05:48] Loaded queue successfully.
[07:05:48] Connecting to http://129.74.85.48:8080/
[07:05:48] Initial: 0000; - Receiving payload (expected size: 77927)
[07:05:49] - Downloaded at ~76 kB/s
[07:05:49] - Averaged speed for that direction ~513 kB/s
[07:05:49] + Received work.
[07:05:49] Trying to send all finished work units
[07:05:49] + No unsent completed units remaining.
[07:05:49] + Closed connections
[07:05:54]
[07:05:54] + Processing work unit
[07:05:54] Core required: FahCore_b4.exe
[07:05:54] Core found.
[07:05:54] Working on queue slot 04 [December 30 07:05:54 UTC]
[07:05:54] + Working ...
[07:05:54] - Calling '.\FahCore_b4.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:05:57] *********************** Log Started 30/Dec/2009 07:05:57 ***********************
[07:05:57] ************************** ProtoMol Folding@Home Core **************************
[07:05:57]   Version: 21
[07:05:57]      Type: 180
[07:05:57]      Core: ProtoMol
[07:05:57]   Website: http://folding.stanford.edu/
[07:05:57] Copyright: (c) 2009 Stanford University
[07:05:57]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:05:57]      Args: -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 267364
[07:05:57]            -version 623
[07:05:57] ************************************ Build *************************************
[07:05:57]      Date: Dec 24 2009
[07:05:57]      Time: 14:36:31
[07:05:57]  Revision: 1748
[07:05:57]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:05:57]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:05:57]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:05:57]  Platform: Windows XP
[07:05:57]      Bits: 32
[07:05:57] ************************************ System ************************************
[07:05:57]        OS: Microsoft Windows XP Professional
[07:05:57]       CPU: AMD Athlon(tm) XP 2800+
[07:05:57]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:05:57]      CPUs: 1 Logical, 1 Physical
[07:05:57]    Memory: 1023 MB
[07:05:57] ********************************************************************************
[07:05:57] Project: 10001 (Run 653, Clone 2, Gen 11)
[07:05:57] Reading tar file par_all27_prot_lipid.inp
[07:05:57] Reading tar file scpismQuartic.inp
[07:05:57] Reading tar file ww_exteq_nowater1.pdb
[07:05:57] Reading tar file ww_exteq_nowater1.psf
[07:05:57] Reading tar file checkpt
[07:05:57] Reading tar file ww_exteq_nowater1.484.pos
[07:05:57] Reading tar file ww_exteq_nowater1.484.vel
[07:05:57] Reading tar file protomol.conf
[07:05:57] Reading tar file core.xml
[07:05:57] Digital signatures verified
[07:05:57] GUI Server started
[07:05:57] Completed 0 out of 200000 steps (0%)
[07:05:57] WARNING: UnexpectedExitHandler triggered
[07:05:57] WARNING: Unexpected exit from science code
[07:05:58] Saving result file logfile_04.txt
[07:05:58] Saving result file checkpt
[07:05:58] Saving result file log.txt
[07:05:58] Saving result file protomol.conf
[07:05:58] Saving result file ww.dcd
[07:05:58] Saving result file ww_exteq_nowater1.484.pos
[07:05:58] Saving result file ww_exteq_nowater1.484.vel
[07:05:58] Folding@home Core Shutdown: UNKNOWN
[07:06:01] CoreStatus = 7B (123)
[07:06:01] Sending work to server
[07:06:01] Project: 10001 (Run 653, Clone 2, Gen 11)
[07:06:01] - Read packet limit of 540015616... Set to 524286976.
[07:06:01] + Attempting to send results [December 30 07:06:01 UTC]
[07:06:01] - Reading file work/wuresults_04.dat from core
[07:06:01]   (Read 49284 bytes from disk)
[07:06:01] Connecting to http://129.74.85.48:8080/
[07:06:03] Posted data.
[07:06:03] Initial: 0000; - Uploaded at ~24 kB/s
[07:06:03] - Averaged speed for that direction ~170 kB/s
[07:06:03] + Results successfully sent
[07:06:03] Thank you for your contribution to Folding@Home.
[07:06:09] Trying to send all finished work units
[07:06:09] + No unsent completed units remaining.
[07:06:09] - Preparing to get new work unit...
[07:06:09] + Attempting to get work packet
[07:06:09] - Will indicate memory of 1023 MB
[07:06:09] - Connecting to assignment server
[07:06:09] Connecting to http://assign.stanford.edu:8080/
[07:06:09] Posted data.
[07:06:09] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:06:09] + News From Folding@Home: Welcome to Folding@Home
[07:06:09] Loaded queue successfully.
[07:06:09] Connecting to http://129.74.85.48:8080/
[07:06:09] Initial: 0000; - Receiving payload (expected size: 77784)
[07:06:11] - Downloaded at ~37 kB/s
[07:06:11] - Averaged speed for that direction ~418 kB/s
[07:06:11] + Received work.
[07:06:11] Trying to send all finished work units
[07:06:11] + No unsent completed units remaining.
[07:06:11] + Closed connections
[07:06:16]
[07:06:16] + Processing work unit
[07:06:16] Core required: FahCore_b4.exe
[07:06:16] Core found.
[07:06:16] Working on queue slot 05 [December 30 07:06:16 UTC]
[07:06:16] + Working ...
[07:06:16] - Calling '.\FahCore_b4.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:06:18] *********************** Log Started 30/Dec/2009 07:06:18 ***********************
[07:06:18] ************************** ProtoMol Folding@Home Core **************************
[07:06:18]   Version: 21
[07:06:18]      Type: 180
[07:06:18]      Core: ProtoMol
[07:06:18]   Website: http://folding.stanford.edu/
[07:06:18] Copyright: (c) 2009 Stanford University
[07:06:18]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:06:18]      Args: -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 267364
[07:06:18]            -version 623
[07:06:18] ************************************ Build *************************************
[07:06:18]      Date: Dec 24 2009
[07:06:18]      Time: 14:36:31
[07:06:18]  Revision: 1748
[07:06:18]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:06:18]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:06:18]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:06:18]  Platform: Windows XP
[07:06:18]      Bits: 32
[07:06:18] ************************************ System ************************************
[07:06:18]        OS: Microsoft Windows XP Professional
[07:06:18]       CPU: AMD Athlon(tm) XP 2800+
[07:06:18]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:06:18]      CPUs: 1 Logical, 1 Physical
[07:06:18]    Memory: 1023 MB
[07:06:18] ********************************************************************************
[07:06:18] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:06:18] Reading tar file par_all27_prot_lipid.inp
[07:06:18] Reading tar file scpismQuartic.inp
[07:06:18] Reading tar file ww_exteq_nowater1.pdb
[07:06:18] Reading tar file ww_exteq_nowater1.psf
[07:06:18] Reading tar file checkpt
[07:06:18] Reading tar file ww_exteq_nowater1.33.pos
[07:06:19] Reading tar file ww_exteq_nowater1.33.vel
[07:06:19] Reading tar file protomol.conf
[07:06:19] Reading tar file core.xml
[07:06:19] Digital signatures verified
[07:06:19] GUI Server started
[07:06:19] Completed 0 out of 200000 steps (0%)
[07:06:19] WARNING: UnexpectedExitHandler triggered
[07:06:19] WARNING: Unexpected exit from science code
[07:06:19] Saving result file logfile_05.txt
[07:06:19] Saving result file checkpt
[07:06:19] Saving result file log.txt
[07:06:19] Saving result file protomol.conf
[07:06:19] Saving result file ww.dcd
[07:06:19] Saving result file ww_exteq_nowater1.33.pos
[07:06:19] Saving result file ww_exteq_nowater1.33.vel
[07:06:19] Folding@home Core Shutdown: UNKNOWN
[07:06:22] CoreStatus = 7B (123)
[07:06:22] Sending work to server
[07:06:22] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:06:22] - Read packet limit of 540015616... Set to 524286976.
[07:06:22] + Attempting to send results [December 30 07:06:22 UTC]
[07:06:22] - Reading file work/wuresults_05.dat from core
[07:06:22]   (Read 49312 bytes from disk)
[07:06:22] Connecting to http://129.74.85.48:8080/
[07:06:24] Posted data.
[07:06:24] Initial: 0000; - Uploaded at ~24 kB/s
[07:06:24] - Averaged speed for that direction ~141 kB/s
[07:06:24] + Results successfully sent
[07:06:24] Thank you for your contribution to Folding@Home.
[07:06:30] Trying to send all finished work units
[07:06:30] + No unsent completed units remaining.
[07:06:30] - Preparing to get new work unit...
[07:06:30] + Attempting to get work packet
[07:06:30] - Will indicate memory of 1023 MB
[07:06:30] - Connecting to assignment server
[07:06:30] Connecting to http://assign.stanford.edu:8080/
[07:06:30] Posted data.
[07:06:30] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:06:30] + News From Folding@Home: Welcome to Folding@Home
[07:06:31] Loaded queue successfully.
[07:06:31] Connecting to http://129.74.85.48:8080/
[07:06:33] Posted data.
[07:06:33] Initial: 0000; - Receiving payload (expected size: 77829)
[07:06:34] - Downloaded at ~76 kB/s
[07:06:34] - Averaged speed for that direction ~350 kB/s
[07:06:34] + Received work.
[07:06:34] Trying to send all finished work units
[07:06:34] + No unsent completed units remaining.
[07:06:34] + Closed connections
[07:06:39]
[07:06:39] + Processing work unit
[07:06:39] Core required: FahCore_b4.exe
[07:06:39] Core found.
[07:06:39] Working on queue slot 06 [December 30 07:06:39 UTC]
[07:06:39] + Working ...
[07:06:39] - Calling '.\FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:06:41] *********************** Log Started 30/Dec/2009 07:06:41 ***********************
[07:06:41] ************************** ProtoMol Folding@Home Core **************************
[07:06:41]   Version: 21
[07:06:41]      Type: 180
[07:06:41]      Core: ProtoMol
[07:06:41]   Website: http://folding.stanford.edu/
[07:06:41] Copyright: (c) 2009 Stanford University
[07:06:41]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:06:41]      Args: -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 267364
[07:06:41]            -version 623
[07:06:41] ************************************ Build *************************************
[07:06:41]      Date: Dec 24 2009
[07:06:41]      Time: 14:36:31
[07:06:41]  Revision: 1748
[07:06:41]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:06:41]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:06:41]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:06:41]  Platform: Windows XP
[07:06:41]      Bits: 32
[07:06:41] ************************************ System ************************************
[07:06:41]        OS: Microsoft Windows XP Professional
[07:06:41]       CPU: AMD Athlon(tm) XP 2800+
[07:06:41]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:06:41]      CPUs: 1 Logical, 1 Physical
[07:06:41]    Memory: 1023 MB
[07:06:41] ********************************************************************************
[07:06:41] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:06:41] Reading tar file par_all27_prot_lipid.inp
[07:06:41] Reading tar file scpismQuartic.inp
[07:06:41] Reading tar file ww_exteq_nowater1.pdb
[07:06:41] Reading tar file ww_exteq_nowater1.psf
[07:06:42] Reading tar file checkpt
[07:06:42] Reading tar file ww_exteq_nowater1.33.pos
[07:06:42] Reading tar file ww_exteq_nowater1.33.vel
[07:06:42] Reading tar file protomol.conf
[07:06:42] Reading tar file core.xml
[07:06:42] Digital signatures verified
[07:06:42] GUI Server started
[07:06:42] Completed 0 out of 200000 steps (0%)
[07:06:42] WARNING: UnexpectedExitHandler triggered
[07:06:42] WARNING: Unexpected exit from science code
[07:06:42] Saving result file logfile_06.txt
[07:06:42] Saving result file checkpt
[07:06:42] Saving result file log.txt
[07:06:42] Saving result file protomol.conf
[07:06:42] Saving result file ww.dcd
[07:06:42] Saving result file ww_exteq_nowater1.33.pos
[07:06:42] Saving result file ww_exteq_nowater1.33.vel
[07:06:42] Folding@home Core Shutdown: UNKNOWN
[07:06:45] CoreStatus = 7B (123)
[07:06:45] Sending work to server
[07:06:45] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:06:45] - Read packet limit of 540015616... Set to 524286976.
[07:06:45] + Attempting to send results [December 30 07:06:45 UTC]
[07:06:45] - Reading file work/wuresults_06.dat from core
[07:06:45]   (Read 49293 bytes from disk)
[07:06:45] Connecting to http://129.74.85.48:8080/
[07:06:50] Posted data.
[07:06:50] Initial: 0000; - Uploaded at ~9 kB/s
[07:06:50] - Averaged speed for that direction ~115 kB/s
[07:06:50] + Results successfully sent
[07:06:50] Thank you for your contribution to Folding@Home.
[07:06:56] Trying to send all finished work units
[07:06:56] + No unsent completed units remaining.
[07:06:56] - Preparing to get new work unit...
[07:06:56] + Attempting to get work packet
[07:06:56] - Will indicate memory of 1023 MB
[07:06:56] - Connecting to assignment server
[07:06:56] Connecting to http://assign.stanford.edu:8080/
[07:06:56] Posted data.
[07:06:56] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:06:56] + News From Folding@Home: Welcome to Folding@Home
[07:06:56] Loaded queue successfully.
[07:06:56] Connecting to http://129.74.85.48:8080/
[07:06:57] Posted data.
[07:06:57] Initial: 0000; - Receiving payload (expected size: 77826)
[07:06:57] Conversation time very short, giving reduced weight in bandwidth avg
[07:06:57] - Downloaded at ~152 kB/s
[07:06:57] - Averaged speed for that direction ~328 kB/s
[07:06:57] + Received work.
[07:06:57] Trying to send all finished work units
[07:06:57] + No unsent completed units remaining.
[07:06:57] + Closed connections
[07:07:02]
[07:07:02] + Processing work unit
[07:07:02] Core required: FahCore_b4.exe
[07:07:02] Core found.
[07:07:02] Working on queue slot 07 [December 30 07:07:02 UTC]
[07:07:02] + Working ...
[07:07:02] - Calling '.\FahCore_b4.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:07:05] *********************** Log Started 30/Dec/2009 07:07:05 ***********************
[07:07:05] ************************** ProtoMol Folding@Home Core **************************
[07:07:05]   Version: 21
[07:07:05]      Type: 180
[07:07:05]      Core: ProtoMol
[07:07:05]   Website: http://folding.stanford.edu/
[07:07:05] Copyright: (c) 2009 Stanford University
[07:07:05]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:07:05]      Args: -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 267364
[07:07:05]            -version 623
[07:07:05] ************************************ Build *************************************
[07:07:05]      Date: Dec 24 2009
[07:07:05]      Time: 14:36:31
[07:07:05]  Revision: 1748
[07:07:05]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:07:05]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:07:05]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:07:05]  Platform: Windows XP
[07:07:05]      Bits: 32
[07:07:05] ************************************ System ************************************
[07:07:05]        OS: Microsoft Windows XP Professional
[07:07:05]       CPU: AMD Athlon(tm) XP 2800+
[07:07:05]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:07:05]      CPUs: 1 Logical, 1 Physical
[07:07:05]    Memory: 1023 MB
[07:07:05] ********************************************************************************
[07:07:05] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:07:05] Reading tar file par_all27_prot_lipid.inp
[07:07:05] Reading tar file scpismQuartic.inp
[07:;07:05] Reading tar file ww_exteq_nowater1.pdb
[07:07:05] Reading tar file ww_exteq_nowater1.psf
[07:07:05] Reading tar file checkpt
[07:07:05] Reading tar file ww_exteq_nowater1.33.pos
[07:07:05] Reading tar file ww_exteq_nowater1.33.vel
[07:07:05] Reading tar file protomol.conf
[07:07:05] Reading tar file core.xml
[07:07:05] Digital signatures verified
[07:07:05] GUI Server started
[07:07:06] Completed 0 out of 200000 steps (0%)
[07:07:06] WARNING: UnexpectedExitHandler triggered
[07:07:06] WARNING: Unexpected exit from science code
[07:07:06] Saving result file logfile_07.txt
[07:07:06] Saving result file checkpt
[07:07:06] Saving result file log.txt
[07:07:06] Saving result file protomol.conf
[07:07:06] Saving result file ww.dcd
[07:07:06] Saving result file ww_exteq_nowater1.33.pos
[07:07:06] Saving result file ww_exteq_nowater1.33.vel
[07:07:06] Folding@home Core Shutdown: UNKNOWN
[07:07:09] CoreStatus = 7B (123)
[07:07:09] Sending work to server
[07:07:09] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:07:09] - Read packet limit of 540015616... Set to 524286976.
[07:07:09] + Attempting to send results [December 30 07:07:09 UTC]
[07:07:09] - Reading file work/wuresults_07.dat from core
[07:07:09]   (Read 49265 bytes from disk)
[07:07:09] Connecting to http://129.74.85.48:8080/
[07:07:12] Posted data.
[07:07:12] Initial: 0000; - Uploaded at ~16 kB/s
[07:07:12] - Averaged speed for that direction ~95 kB/s
[07:07:12] + Results successfully sent
[07:07:12] Thank you for your contribution to Folding@Home.
[07:07:18] Trying to send all finished work units
[07:07:18] + No unsent completed units remaining.
[07:07:18] - Preparing to get new work unit...
[07:07:18] + Attempting to get work packet
[07:07:18] - Will indicate memory of 1023 MB
[07:07:18] - Connecting to assignment server
[07:07:18] Connecting to http://assign.stanford.edu:8080/
[07:07:18] Posted data.
[07:07:18] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:07:18] + News From Folding@Home: Welcome to Folding@Home
[07:07:18] Loaded queue successfully.
[07:07:18] Connecting to http://129.74.85.48:8080/
[07:07:19] Posted data.
[07:07:19] Initial: 0000; - Receiving payload (expected size: 77815)
[07:07:20] - Downloaded at ~75 kB/s
[07:07:20] - Averaged speed for that direction ~277 kB/s
[07:07:20] + Received work.
[07:07:20] Trying to send all finished work units
[07:07:20] + No unsent completed units remaining.
[07:07:20] + Closed connections
[07:07:25]
[07:07:25] + Processing work unit
[07:07:25] Core required: FahCore_b4.exe
[07:07:25] Core found.
[07:07:25] Working on queue slot 08 [December 30 07:07:25 UTC]
[07:07:25] + Working ...
[07:07:25] - Calling '.\FahCore_b4.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:07:27] *********************** Log Started 30/Dec/2009 07:07:27 ***********************
[07:07:27] ************************** ProtoMol Folding@Home Core **************************
[07:07:27]   Version: 21
[07:07:27]      Type: 180
[07:07:27]      Core: ProtoMol
[07:07:27]   Website: http://folding.stanford.edu/
[07:07:27] Copyright: (c) 2009 Stanford University
[07:07:27]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:07:27]      Args: -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 267364
[07:07:27]            -version 623
[07:07:27] ************************************ Build *************************************
[07:07:27]      Date: Dec 24 2009
[07:07:27]      Time: 14:36:31
[07:07:27]  Revision: 1748
[07:07:27]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:07:27]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:07:27]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:07:27]  Platform: Windows XP
[07:07:27]      Bits: 32
[07:07:27] ************************************ System ************************************
[07:07:27]        OS: Microsoft Windows XP Professional
[07:07:27]       CPU: AMD Athlon(tm) XP 2800+
[07:07:27]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:07:27]      CPUs: 1 Logical, 1 Physical
[07:07:27]    Memory: 1023 MB
[07:07:27] ********************************************************************************
[07:07:27] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:07:27] Reading tar file par_all27_prot_lipid.inp
[07:07:27] Reading tar file scpismQuartic.inp
[07:07:27] Reading tar file ww_exteq_nowater1.pdb
[07:07:27] Reading tar file ww_exteq_nowater1.psf
[07:07:27] Reading tar file checkpt
[07:07:28] Reading tar file ww_exteq_nowater1.33.pos
[07:07:28] Reading tar file ww_exteq_nowater1.33.vel
[07:07:28] Reading tar file protomol.conf
[07:07:28] Reading tar file core.xml
[07:07:28] Digital signatures verified
[07:07:28] GUI Server started
[07:07:28] Completed 0 out of 200000 steps (0%)
[07:07:28] WARNING: UnexpectedExitHandler triggered
[07:07:28] WARNING: Unexpected exit from science code
[07:07:28] Saving result file logfile_08.txt
[07:07:28] Saving result file checkpt
[07:07:28] Saving result file log.txt
[07:07:28] Saving result file protomol.conf
[07:07:28] Saving result file ww.dcd
[07:07:28] Saving result file ww_exteq_nowater1.33.pos
[07:07:28] Saving result file ww_exteq_nowater1.33.vel
[07:07:28] Folding@home Core Shutdown: UNKNOWN
[07:07:32] CoreStatus = 7B (123)
[07:07:32] Sending work to server
[07:07:32] Project: 10001 (Run 655, Clone 3, Gen 2)
[07:07:32] - Read packet limit of 540015616... Set to 524286976.
[07:07:32] + Attempting to send results [December 30 07:07:32 UTC]
[07:07:32] - Reading file work/wuresults_08.dat from core
[07:07:32]   (Read 49253 bytes from disk)
[07:07:32] Connecting to http://129.74.85.48:8080/
[07:07:34] Posted data.
[07:07:34] Initial: 0000; - Uploaded at ~24 kB/s
[07:07:34] - Averaged speed for that direction ~81 kB/s
[07:07:34] + Results successfully sent
[07:07:34] Thank you for your contribution to Folding@Home.
[07:07:40] Trying to send all finished work units
[07:07:40] + No unsent completed units remaining.
[07:07:40] - Preparing to get new work unit...
[07:07:40] + Attempting to get work packet
[07:07:40] - Will indicate memory of 1023 MB
[07:07:40] - Connecting to assignment server
[07:07:40] Connecting to http://assign.stanford.edu:8080/
[07:07:40] Posted data.
[07:07:40] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:07:40] + News From Folding@Home: Welcome to Folding@Home
[07:07:40] Loaded queue successfully.
[07:07:40] Connecting to http://129.74.85.48:8080/
[07:07:41] Posted data.
[07:07:41] Initial: 0000; - Receiving payload (expected size: 78049)
[07:07:41] Conversation time very short, giving reduced weight in bandwidth avg
[07:07:41] - Downloaded at ~152 kB/s
[07:07:41] - Averaged speed for that direction ~263 kB/s
[07:07:41] + Received work.
[07:07:41] Trying to send all finished work units
[07:07:41] + No unsent completed units remaining.
[07:07:41] + Closed connections
[07:07:46]
[07:07:46] + Processing work unit
[07:07:46] Core required: FahCore_b4.exe
[07:07:46] Core found.
[07:07:46] Working on queue slot 09 [December 30 07:07:46 UTC]
[07:07:46] + Working ...
[07:07:46] - Calling '.\FahCore_b4.exe -dir work/ -suffix 09 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:07:49] *********************** Log Started 30/Dec/2009 07:07:49 ***********************
[07:07:49] ************************** ProtoMol Folding@Home Core **************************
[07:07:49]   Version: 21
[07:07:49]      Type: 180
[07:07:49]      Core: ProtoMol
[07:07:49]   Website: http://folding.stanford.edu/
[07:07:49] Copyright: (c) 2009 Stanford University
[07:07:49]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:07:49]      Args: -dir work/ -suffix 09 -checkpoint 15 -verbose -lifeline 267364
[07:07:49]            -version 623
[07:07:49] ************************************ Build *************************************
[07:07:49]      Date: Dec 24 2009
[07:07:49]      Time: 14:36:31
[07:07:49]  Revision: 1748
[07:07:49]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:07:49]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:07:49]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:07:49]  Platform: Windows XP
[07:07:49]      Bits: 32
[07:07:49] ************************************ System ************************************
[07:07:49]        OS: Microsoft Windows XP Professional
[07:07:49]       CPU: AMD Athlon(tm) XP 2800+
[07:07:49]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:07:49]      CPUs: 1 Logical, 1 Physical
[07:07:49]    Memory: 1023 MB
[07:07:49] ********************************************************************************
[07:07:49] Project: 10001 (Run 659, Clone 4, Gen 5)
[07:07:49] Reading tar file par_all27_prot_lipid.inp
[07:07:49] Reading tar file scpismQuartic.inp
[07:07:49] Reading tar file ww_exteq_nowater1.pdb
[07:07:49] Reading tar file ww_exteq_nowater1.psf
[07:07:49] Reading tar file checkpt
[07:07:49] Reading tar file ww_exteq_nowater1.182.pos
[07:07:49] Reading tar file ww_exteq_nowater1.182.vel
[07:07:49] Reading tar file protomol.conf
[07:07:49] Reading tar file core.xml
[07:07:49] Digital signatures verified
[07:07:50] GUI Server started
[07:07:50] Completed 0 out of 200000 steps (0%)
[07:07:50] WARNING: UnexpectedExitHandler triggered
[07:07:50] WARNING: Unexpected exit from science code
[07:07:50] Saving result file logfile_09.txt
[07:07:50] Saving result file checkpt
[07:07:50] Saving result file log.txt
[07:07:50] Saving result file protomol.conf
[07:07:50] Saving result file ww.dcd
[07:07:50] Saving result file ww_exteq_nowater1.182.pos
[07:07:50] Saving result file ww_exteq_nowater1.182.vel
[07:07:50] Folding@home Core Shutdown: UNKNOWN
[07:07:53] CoreStatus = 7B (123)
[07:07:53] Sending work to server
[07:07:53] Project: 10001 (Run 659, Clone 4, Gen 5)
[07:07:53] - Read packet limit of 540015616... Set to 524286976.
[07:07:53] + Attempting to send results [December 30 07:07:53 UTC]
[07:07:53] - Reading file work/wuresults_09.dat from core
[07:07:53]   (Read 49591 bytes from disk)
[07:07:53] Connecting to http://129.74.85.48:8080/
[07:07:57] Posted data.
[07:07:57] Initial: 0000; - Uploaded at ~12 kB/s
[07:07:57] - Averaged speed for that direction ~67 kB/s
[07:07:57] + Results successfully sent
[07:07:57] Thank you for your contribution to Folding@Home.
[07:08:03] Trying to send all finished work units
[07:08:03] + No unsent completed units remaining.
[07:08:03] - Preparing to get new work unit...
[07:08:03] + Attempting to get work packet
[07:08:03] - Will indicate memory of 1023 MB
[07:08:03] - Connecting to assignment server
[07:08:03] Connecting to http://assign.stanford.edu:8080/
[07:08:04] Posted data.
[07:08:04] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:08:04] + News From Folding@Home: Welcome to Folding@Home
[07:08:04] Loaded queue successfully.
[07:08:04] Connecting to http://129.74.85.48:8080/
[07:08:04] Initial: 0000; - Receiving payload (expected size: 77749)
[07:08:05] - Downloaded at ~75 kB/s
[07:08:05] - Averaged speed for that direction ~226 kB/s
[07:08:05] + Received work.
[07:08:05] Trying to send all finished work units
[07:08:05] + No unsent completed units remaining.
[07:08:05] + Closed connections
[07:08:10]
[07:08:10] + Processing work unit
[07:08:10] Core required: FahCore_b4.exe
[07:08:10] Core found.
[07:08:10] Working on queue slot 00 [December 30 07:08:10 UTC]
[07:08:10] + Working ...
[07:08:10] - Calling '.\FahCore_b4.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:08:12] *********************** Log Started 30/Dec/2009 07:08:12 ***********************
[07:08:12] ************************** ProtoMol Folding@Home Core **************************
[07:08:12]   Version: 21
[07:08:12]      Type: 180
[07:08:12]      Core: ProtoMol
[07:08:12]   Website: http://folding.stanford.edu/
[07:08:12] Copyright: (c) 2009 Stanford University
[07:08:12]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:08:12]      Args: -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 267364
[07:08:12]            -version 623
[07:08:12] ************************************ Build *************************************
[07:08:12]      Date: Dec 24 2009
[07:08:12]      Time: 14:36:31
[07:08:12]  Revision: 1748
[07:08:12]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:08:12]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:08:12]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:08:12]  Platform: Windows XP
[07:08:12]      Bits: 32
[07:08:12] ************************************ System ************************************
[07:08:12]        OS: Microsoft Windows XP Professional
[07:08:12]       CPU: AMD Athlon(tm) XP 2800+
[07:08:12]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:08:12]      CPUs: 1 Logical, 1 Physical
[07:08:12]    Memory: 1023 MB
[07:08:12] ********************************************************************************
[07:08:12] Project: 10001 (Run 410, Clone 5, Gen 9)
[07:08:12] Reading tar file par_all27_prot_lipid.inp
[07:08:12] Reading tar file scpismQuartic.inp
[07:08:12] Reading tar file ww_exteq_nowater1.pdb
[07:08:13] Reading tar file ww_exteq_nowater1.psf
[07:08:13] Reading tar file checkpt
[07:08:13] Reading tar file ww_exteq_nowater1.445.pos
[07:08:13] Reading tar file ww_exteq_nowater1.445.vel
[07:08:13] Reading tar file protomol.conf
[07:08:13] Reading tar file core.xml
[07:08:13] Digital signatures verified
[07:08:13] GUI Server started
[07:08:13] Completed 0 out of 200000 steps (0%)
[07:08:13] WARNING: UnexpectedExitHandler triggered
[07:08:13] WARNING: Unexpected exit from science code
[07:08:13] Saving result file logfile_00.txt
[07:08:13] Saving result file checkpt
[07:08:13] Saving result file log.txt
[07:08:13] Saving result file protomol.conf
[07:08:13] Saving result file ww.dcd
[07:08:13] Saving result file ww_exteq_nowater1.445.pos
[07:08:13] Saving result file ww_exteq_nowater1.445.vel
[07:08:13] Folding@home Core Shutdown: UNKNOWN
[07:08:16] CoreStatus = 7B (123)
[07:08:16] Sending work to server
[07:08:16] Project: 10001 (Run 410, Clone 5, Gen 9)
[07:08:16] - Read packet limit of 540015616... Set to 524286976.
[07:08:16] + Attempting to send results [December 30 07:08:16 UTC]
[07:08:16] - Reading file work/wuresults_00.dat from core
[07:08:16]   (Read 49151 bytes from disk)
[07:08:16] Connecting to http://129.74.85.48:8080/
[07:08:18] Posted data.
[07:08:18] Initial: 0000; - Uploaded at ~24 kB/s
[07:08:18] - Averaged speed for that direction ~58 kB/s
[07:08:18] + Results successfully sent
[07:08:18] Thank you for your contribution to Folding@Home.
[07:08:24] Trying to send all finished work units
[07:08:24] + No unsent completed units remaining.
[07:08:24] - Preparing to get new work unit...
[07:08:24] + Attempting to get work packet
[07:08:24] - Will indicate memory of 1023 MB
[07:08:24] - Connecting to assignment server
[07:08:24] Connecting to http://assign.stanford.edu:8080/
[07:08:24] Posted data.
[07:08:24] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:08:24] + News From Folding@Home: Welcome to Folding@Home
[07:08:25] Loaded queue successfully.
[07:08:25] Connecting to http://129.74.85.48:8080/
[07:08:25] Posted data.
[07:08:25] Initial: 0000; - Receiving payload (expected size: 77724)
[07:08:26] - Downloaded at ~75 kB/s
[07:08:26] - Averaged speed for that direction ~196 kB/s
[07:08:26] + Received work.
[07:08:26] Trying to send all finished work units
[07:08:26] + No unsent completed units remaining.
[07:08:26] + Closed connections
[07:08:31]
[07:08:31] + Processing work unit
[07:08:31] Core required: FahCore_b4.exe
[07:08:31] Core found.
[07:08:31] Working on queue slot 01 [December 30 07:08:31 UTC]
[07:08:31] + Working ...
[07:08:31] - Calling '.\FahCore_b4.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:08:34] *********************** Log Started 30/Dec/2009 07:08:34 ***********************
[07:08:34] ************************** ProtoMol Folding@Home Core **************************
[07:08:34]   Version: 21
[07:08:34]      Type: 180
[07:08:34]      Core: ProtoMol
[07:08:34]   Website: http://folding.stanford.edu/
[07:08:34] Copyright: (c) 2009 Stanford University
[07:08:34]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:08:34]      Args: -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 267364
[07:08:34]            -version 623
[07:08:34] ************************************ Build *************************************
[07:08:34]      Date: Dec 24 2009
[07:08:34]      Time: 14:36:31
[07:08:34]  Revision: 1748
[07:08:34]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:08:34]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:08:34]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:08:34]  Platform: Windows XP
[07:08:34]      Bits: 32
[07:08:34] ************************************ System ************************************
[07:08:34]        OS: Microsoft Windows XP Professional
[07:08:34]       CPU: AMD Athlon(tm) XP 2800+
[07:08:34]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:08:34]      CPUs: 1 Logical, 1 Physical
[07:08:34]    Memory: 1023 MB
[07:08:34] ********************************************************************************
[07:08:34] Project: 10001 (Run 410, Clone 5, Gen 9)
[07:08:34] Reading tar file par_all27_prot_lipid.inp
[07:08:34] Reading tar file scpismQuartic.inp
[07:08:34] Reading tar file ww_exteq_nowater1.pdb
[07:08:34] Reading tar file ww_exteq_nowater1.psf
[07:08:34] Reading tar file checkpt
[07:08:34] Reading tar file ww_exteq_nowater1.445.pos
[07:08:34] Reading tar file ww_exteq_nowater1.445.vel
[07:08:34] Reading tar file protomol.conf
[07:08:34] Reading tar file core.xml
[07:08:34] Digital signatures verified
[07:08:34] GUI Server started
[07:08:35] Completed 0 out of 200000 steps (0%)
[07:08:35] WARNING: UnexpectedExitHandler triggered
[07:08:35] WARNING: Unexpected exit from science code
[07:08:35] Saving result file logfile_01.txt
[07:08:35] Saving result file checkpt
[07:08:35] Saving result file log.txt
[07:08:35] Saving result file protomol.conf
[07:08:35] Saving result file ww.dcd
[07:08:35] Saving result file ww_exteq_nowater1.445.pos
[07:08:35] Saving result file ww_exteq_nowater1.445.vel
[07:08:35] Folding@home Core Shutdown: UNKNOWN
[07:08:38] CoreStatus = 7B (123)
[07:08:38] Sending work to server
[07:08:38] Project: 10001 (Run 410, Clone 5, Gen 9)
[07:08:38] - Read packet limit of 540015616... Set to 524286976.
[07:08:38] + Attempting to send results [December 30 07:08:38 UTC]
[07:08:38] - Reading file work/wuresults_01.dat from core
[07:08:38]   (Read 49254 bytes from disk)
[07:08:38] Connecting to http://129.74.85.48:8080/
[07:08:40] Posted data.
[07:08:40] Initial: 0000; - Uploaded at ~24 kB/s
[07:08:40] - Averaged speed for that direction ~52 kB/s
[07:08:40] + Results successfully sent
[07:08:40] Thank you for your contribution to Folding@Home.
[07:08:46] Trying to send all finished work units
[07:08:46] + No unsent completed units remaining.
...to be continued...
Amaruk
Re: Protomol core on old CPUs
Post by Amaruk »
...part two...
[07:08:46] - Preparing to get new work unit...
[07:08:46] + Attempting to get work packet
[07:08:46] - Will indicate memory of 1023 MB
[07:08:46] - Connecting to assignment server
[07:08:46] Connecting to http://assign.stanford.edu:8080/
[07:08:46] Posted data.
[07:08:46] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:08:46] + News From Folding@Home: Welcome to Folding@Home
[07:08:46] Loaded queue successfully.
[07:08:46] Connecting to http://129.74.85.48:8080/
[07:08:47] Posted data.
[07:08:47] Initial: 0000; - Receiving payload (expected size: 77838)
[07:08:48] - Downloaded at ~76 kB/s
[07:08:48] - Averaged speed for that direction ~172 kB/s
[07:08:48] + Received work.
[07:08:48] Trying to send all finished work units
[07:08:48] + No unsent completed units remaining.
[07:08:48] + Closed connections
[07:08:53]
[07:08:53] + Processing work unit
[07:08:53] Core required: FahCore_b4.exe
[07:08:53] Core found.
[07:08:53] Working on queue slot 02 [December 30 07:08:53 UTC]
[07:08:53] + Working ...
[07:08:53] - Calling '.\FahCore_b4.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:08:55] *********************** Log Started 30/Dec/2009 07:08:55 ***********************
[07:08:55] ************************** ProtoMol Folding@Home Core **************************
[07:08:55]   Version: 21
[07:08:55]      Type: 180
[07:08:55]      Core: ProtoMol
[07:08:55]   Website: http://folding.stanford.edu/
[07:08:55] Copyright: (c) 2009 Stanford University
[07:08:55]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:08:55]      Args: -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 267364
[07:08:55]            -version 623
[07:08:55] ************************************ Build *************************************
[07:08:55]      Date: Dec 24 2009
[07:08:55]      Time: 14:36:31
[07:08:55]  Revision: 1748
[07:08:55]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:08:55]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:08:55]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:08:55]  Platform: Windows XP
[07:08:55]      Bits: 32
[07:08:55] ************************************ System ************************************
[07:08:55]        OS: Microsoft Windows XP Professional
[07:08:55]       CPU: AMD Athlon(tm) XP 2800+
[07:08:55]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:08:55]      CPUs: 1 Logical, 1 Physical
[07:08:55]    Memory: 1023 MB
[07:08:55] ********************************************************************************
[07:08:55] Project: 10001 (Run 666, Clone 5, Gen 4)
[07:08:55] Reading tar file par_all27_prot_lipid.inp
[07:08:55] Reading tar file scpismQuartic.inp
[07:08:55] Reading tar file ww_exteq_nowater1.pdb
[07:08:55] Reading tar file ww_exteq_nowater1.psf
[07:08:55] Reading tar file checkpt
[07:08:56] Reading tar file ww_exteq_nowater1.130.pos
[07:08:56] Reading tar file ww_exteq_nowater1.130.vel
[07:08:56] Reading tar file protomol.conf
[07:08:56] Reading tar file core.xml
[07:08:56] Digital signatures verified
[07:08:56] GUI Server started
[07:08:56] Completed 0 out of 200000 steps (0%)
[07:08:56] WARNING: UnexpectedExitHandler triggered
[07:08:56] WARNING: Unexpected exit from science code
[07:08:56] Saving result file logfile_02.txt
[07:08:56] Saving result file checkpt
[07:08:56] Saving result file log.txt
[07:08:56] Saving result file protomol.conf
[07:08:56] Saving result file ww.dcd
[07:08:56] Saving result file ww_exteq_nowater1.130.pos
[07:08:56] Saving result file ww_exteq_nowater1.130.vel
[07:08:56] Folding@home Core Shutdown: UNKNOWN
[07:08:59] CoreStatus = 7B (123)
[07:08:59] Sending work to server
[07:08:59] Project: 10001 (Run 666, Clone 5, Gen 4)
[07:08:59] - Read packet limit of 540015616... Set to 524286976.
[07:08:59] + Attempting to send results [December 30 07:08:59 UTC]
[07:08:59] - Reading file work/wuresults_02.dat from core
[07:08:59]   (Read 49347 bytes from disk)
[07:08:59] Connecting to http://129.74.85.48:8080/
[07:09:02] Posted data.
[07:09:02] Initial: 0000; - Uploaded at ~16 kB/s
[07:09:02] - Averaged speed for that direction ~44 kB/s
[07:09:02] + Results successfully sent
[07:09:02] Thank you for your contribution to Folding@Home.
[07:09:08] Trying to send all finished work units
[07:09:08] + No unsent completed units remaining.
[07:09:08] - Preparing to get new work unit...
[07:09:08] + Attempting to get work packet
[07:09:08] - Will indicate memory of 1023 MB
[07:09:08] - Connecting to assignment server
[07:09:08] Connecting to http://assign.stanford.edu:8080/
[07:09:08] Posted data.
[07:09:08] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:09:08] + News From Folding@Home: Welcome to Folding@Home
[07:09:08] Loaded queue successfully.
[07:09:08] Connecting to http://129.74.85.48:8080/
[07:09:09] Posted data.
[07:09:09] Initial: 0000; - Receiving payload (expected size: 77508)
[07:09:10] - Downloaded at ~75 kB/s
[07:09:10] - Averaged speed for that direction ~152 kB/s
[07:09:10] + Received work.
[07:09:10] Trying to send all finished work units
[07:09:10] + No unsent completed units remaining.
[07:09:10] + Closed connections
[07:09:15]
[07:09:15] + Processing work unit
[07:09:15] Core required: FahCore_b4.exe
[07:09:15] Core found.
[07:09:15] Working on queue slot 03 [December 30 07:09:15 UTC]
[07:09:15] + Working ...
[07:09:15] - Calling '.\FahCore_b4.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:09:17] *********************** Log Started 30/Dec/2009 07:09:17 ***********************
[07:09:17] ************************** ProtoMol Folding@Home Core **************************
[07:09:17]   Version: 21
[07:09:17]      Type: 180
[07:09:17]      Core: ProtoMol
[07:09:17]   Website: http://folding.stanford.edu/
[07:09:17] Copyright: (c) 2009 Stanford University
[07:09:17]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:09:17]      Args: -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 267364
[07:09:17]            -version 623
[07:09:17] ************************************ Build *************************************
[07:09:17]      Date: Dec 24 2009
[07:09:17]      Time: 14:36:31
[07:09:17]  Revision: 1748
[07:09:17]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:09:17]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:09:17]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:09:17]  Platform: Windows XP
[07:09:17]      Bits: 32
[07:09:17] ************************************ System ************************************
[07:09:17]        OS: Microsoft Windows XP Professional
[07:09:17]       CPU: AMD Athlon(tm) XP 2800+
[07:09:17]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:09:17]      CPUs: 1 Logical, 1 Physical
[07:09:17]    Memory: 1023 MB
[07:09:17] ********************************************************************************
[07:09:17] Project: 10001 (Run 462, Clone 2, Gen 10)
[07:09:17] Reading tar file par_all27_prot_lipid.inp
[07:09:17] Reading tar file scpismQuartic.inp
[07:09:17] Reading tar file ww_exteq_nowater1.pdb
[07:09:17] Reading tar file ww_exteq_nowater1.psf
[07:09:17] Reading tar file checkpt
[07:09:18] Reading tar file ww_exteq_nowater1.371.pos
[07:09:18] Reading tar file ww_exteq_nowater1.371.vel
[07:09:18] Reading tar file protomol.conf
[07:09:18] Reading tar file core.xml
[07:09:18] Digital signatures verified
[07:09:18] GUI Server started
[07:09:18] Completed 0 out of 200000 steps (0%)
[07:09:18] WARNING: UnexpectedExitHandler triggered
[07:09:18] WARNING: Unexpected exit from science code
[07:09:18] Saving result file logfile_03.txt
[07:09:18] Saving result file checkpt
[07:09:18] Saving result file log.txt
[07:09:18] Saving result file protomol.conf
[07:09:18] Saving result file ww.dcd
[07:09:18] Saving result file ww_exteq_nowater1.371.pos
[07:09:18] Saving result file ww_exteq_nowater1.371.vel
[07:09:18] Folding@home Core Shutdown: UNKNOWN
[07:09:21] CoreStatus = 7B (123)
[07:09:21] Sending work to server
[07:09:21] Project: 10001 (Run 462, Clone 2, Gen 10)
[07:09:21] - Read packet limit of 540015616... Set to 524286976.
[07:09:21] + Attempting to send results [December 30 07:09:21 UTC]
[07:09:21] - Reading file work/wuresults_03.dat from core
[07:09:21]   (Read 48956 bytes from disk)
[07:09:21] Connecting to http://129.74.85.48:8080/
[07:09:23] Posted data.
[07:09:23] Initial: 0000; - Uploaded at ~24 kB/s
[07:09:23] - Averaged speed for that direction ~40 kB/s
[07:09:23] + Results successfully sent
[07:09:23] Thank you for your contribution to Folding@Home.
[07:09:29] Trying to send all finished work units
[07:09:29] + No unsent completed units remaining.
[07:09:29] - Preparing to get new work unit...
[07:09:29] + Attempting to get work packet
[07:09:29] - Will indicate memory of 1023 MB
[07:09:29] - Connecting to assignment server
[07:09:29] Connecting to http://assign.stanford.edu:8080/
[07:09:29] Posted data.
[07:09:29] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:09:29] + News From Folding@Home: Welcome to Folding@Home
[07:09:30] Loaded queue successfully.
[07:09:30] Connecting to http://129.74.85.48:8080/
[07:09:30] Posted data.
[07:09:30] Initial: 0000; - Receiving payload (expected size: 77853)
[07:09:31] - Downloaded at ~76 kB/s
[07:09:31] - Averaged speed for that direction ~137 kB/s
[07:09:31] + Received work.
[07:09:31] Trying to send all finished work units
[07:09:31] + No unsent completed units remaining.
[07:09:31] + Closed connections
[07:09:36]
[07:09:36] + Processing work unit
[07:09:36] Core required: FahCore_b4.exe
[07:09:36] Core found.
[07:09:36] Working on queue slot 04 [December 30 07:09:36 UTC]
[07:09:36] + Working ...
[07:09:36] - Calling '.\FahCore_b4.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:09:38] *********************** Log Started 30/Dec/2009 07:09:38 ***********************
[07:09:38] ************************** ProtoMol Folding@Home Core **************************
[07:09:38]   Version: 21
[07:09:38]      Type: 180
[07:09:38]      Core: ProtoMol
[07:09:38]   Website: http://folding.stanford.edu/
[07:09:38] Copyright: (c) 2009 Stanford University
[07:09:38]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:09:38]      Args: -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 267364
[07:09:38]            -version 623
[07:09:38] ************************************ Build *************************************
[07:09:38]      Date: Dec 24 2009
[07:09:38]      Time: 14:36:31
[07:09:38]  Revision: 1748
[07:09:38]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:09:38]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:09:38]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:09:38]  Platform: Windows XP
[07:09:38]      Bits: 32
[07:09:38] ************************************ System ************************************
[07:09:38]        OS: Microsoft Windows XP Professional
[07:09:38]       CPU: AMD Athlon(tm) XP 2800+
[07:09:38]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:09:38]      CPUs: 1 Logical, 1 Physical
[07:09:38]    Memory: 1023 MB
[07:09:38] ********************************************************************************
[07:09:38] Project: 10001 (Run 493, Clone 5, Gen 6)
[07:09:38] Reading tar file par_all27_prot_lipid.inp
[07:09:38] Reading tar file scpismQuartic.inp
[07:09:38] Reading tar file ww_exteq_nowater1.pdb
[07:09:39] Reading tar file ww_exteq_nowater1.psf
[07:09:39] Reading tar file checkpt
[07:09:39] Reading tar file ww_exteq_nowater1.506.pos
[07:09:39] Reading tar file ww_exteq_nowater1.506.vel
[07:09:39] Reading tar file protomol.conf
[07:09:39] Reading tar file core.xml
[07:09:39] Digital signatures verified
[07:09:39] GUI Server started
[07:09:39] Completed 0 out of 200000 steps (0%)
[07:09:39] WARNING: UnexpectedExitHandler triggered
[07:09:39] WARNING: Unexpected exit from science code
[07:09:39] Saving result file logfile_04.txt
[07:09:39] Saving result file checkpt
[07:09:39] Saving result file log.txt
[07:09:39] Saving result file protomol.conf
[07:09:39] Saving result file ww.dcd
[07:09:39] Saving result file ww_exteq_nowater1.506.pos
[07:09:39] Saving result file ww_exteq_nowater1.506.vel
[07:09:39] Folding@home Core Shutdown: UNKNOWN
[07:09:42] CoreStatus = 7B (123)
[07:09:42] Sending work to server
[07:09:42] Project: 10001 (Run 493, Clone 5, Gen 6)
[07:09:42] - Read packet limit of 540015616... Set to 524286976.
[07:09:42] + Attempting to send results [December 30 07:09:42 UTC]
[07:09:42] - Reading file work/wuresults_04.dat from core
[07:09:42]   (Read 49309 bytes from disk)
[07:09:42] Connecting to http://129.74.85.48:8080/
[07:09:47] Posted data.
[07:09:47] Initial: 0000; - Uploaded at ~9 kB/s
[07:09:47] - Averaged speed for that direction ~34 kB/s
[07:09:47] + Results successfully sent
[07:09:47] Thank you for your contribution to Folding@Home.
[07:09:53] Trying to send all finished work units
[07:09:53] + No unsent completed units remaining.
[07:09:53] - Preparing to get new work unit...
[07:09:53] + Attempting to get work packet
[07:09:53] - Will indicate memory of 1023 MB
[07:09:53] - Connecting to assignment server
[07:09:53] Connecting to http://assign.stanford.edu:8080/
[07:09:54] Posted data.
[07:09:54] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:09:54] + News From Folding@Home: Welcome to Folding@Home
[07:09:54] Loaded queue successfully.
[07:09:54] Connecting to http://129.74.85.48:8080/
[07:09:55] Posted data.
[07:09:55] Initial: 0000; - Receiving payload (expected size: 77835)
[07:09:56] - Downloaded at ~76 kB/s
[07:09:56] - Averaged speed for that direction ~125 kB/s
[07:09:56] + Received work.
[07:09:56] Trying to send all finished work units
[07:09:56] + No unsent completed units remaining.
[07:09:56] + Closed connections
[07:10:01]
[07:10:01] + Processing work unit
[07:10:01] Core required: FahCore_b4.exe
[07:10:01] Core found.
[07:10:01] Working on queue slot 05 [December 30 07:10:01 UTC]
[07:10:01] + Working ...
[07:10:01] - Calling '.\FahCore_b4.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:10:04] *********************** Log Started 30/Dec/2009 07:10:04 ***********************
[07:10:04] ************************** ProtoMol Folding@Home Core **************************
[07:10:04]   Version: 21
[07:10:04]      Type: 180
[07:10:04]      Core: ProtoMol
[07:10:04]   Website: http://folding.stanford.edu/
[07:10:04] Copyright: (c) 2009 Stanford University
[07:10:04]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:10:04]      Args: -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 267364
[07:10:04]            -version 623
[07:10:04] ************************************ Build *************************************
[07:10:04]      Date: Dec 24 2009
[07:10:04]      Time: 14:36:31
[07:10:04]  Revision: 1748
[07:10:04]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:10:04]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:10:04]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:10:04]  Platform: Windows XP
[07:10:04]      Bits: 32
[07:10:04] ************************************ System ************************************
[07:10:04]        OS: Microsoft Windows XP Professional
[07:10:04]       CPU: AMD Athlon(tm) XP 2800+
[07:10:04]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:10:04]      CPUs: 1 Logical, 1 Physical
[07:10:04]    Memory: 1023 MB
[07:10:04] ********************************************************************************
[07:10:04] Project: 10001 (Run 534, Clone 3, Gen 14)
[07:10:04] Reading tar file par_all27_prot_lipid.inp
[07:10:04] Reading tar file scpismQuartic.inp
[07:10:04] Reading tar file ww_exteq_nowater1.pdb
[07:10:04] Reading tar file ww_exteq_nowater1.psf
[07:10:04] Reading tar file checkpt
[07:10:04] Reading tar file ww_exteq_nowater1.626.pos
[07:10:04] Reading tar file ww_exteq_nowater1.626.vel
[07:10:04] Reading tar file protomol.conf
[07:10:04] Reading tar file core.xml
[07:10:04] Digital signatures verified
[07:10:05] GUI Server started
[07:10:05] Completed 0 out of 200000 steps (0%)
[07:10:05] WARNING: UnexpectedExitHandler triggered
[07:10:05] WARNING: Unexpected exit from science code
[07:10:05] Saving result file logfile_05.txt
[07:10:05] Saving result file checkpt
[07:10:05] Saving result file log.txt
[07:10:05] Saving result file protomol.conf
[07:10:05] Saving result file ww.dcd
[07:10:05] Saving result file ww_exteq_nowater1.626.pos
[07:10:05] Saving result file ww_exteq_nowater1.626.vel
[07:10:05] Folding@home Core Shutdown: UNKNOWN
[07:10:08] CoreStatus = 7B (123)
[07:10:08] Sending work to server
[07:10:08] Project: 10001 (Run 534, Clone 3, Gen 14)
[07:10:08] - Read packet limit of 540015616... Set to 524286976.
[07:10:08] + Attempting to send results [December 30 07:10:08 UTC]
[07:10:08] - Reading file work/wuresults_05.dat from core
[07:10:08]   (Read 49154 bytes from disk)
[07:10:08] Connecting to http://129.74.85.48:8080/
[07:10:11] Posted data.
[07:10:11] Initial: 0000; - Uploaded at ~16 kB/s
[07:10:11] - Averaged speed for that direction ~30 kB/s
[07:10:11] + Results successfully sent
[07:10:11] Thank you for your contribution to Folding@Home.
[07:10:17] Trying to send all finished work units
[07:10:17] + No unsent completed units remaining.
[07:10:17] - Preparing to get new work unit...
[07:10:17] + Attempting to get work packet
[07:10:17] - Will indicate memory of 1023 MB
[07:10:17] - Connecting to assignment server
[07:10:17] Connecting to http://assign.stanford.edu:8080/
[07:10:18] Posted data.
[07:10:18] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:10:18] + News From Folding@Home: Welcome to Folding@Home
[07:10:18] Loaded queue successfully.
[07:10:18] Connecting to http://129.74.85.48:8080/
[07:10:21] Posted data.
[07:10:21] Initial: 0000; - Receiving payload (expected size: 77718)
[07:10:22] - Downloaded at ~75 kB/s
[07:10:22] - Averaged speed for that direction ~115 kB/s
[07:10:22] + Received work.
[07:10:22] Trying to send all finished work units
[07:10:22] + No unsent completed units remaining.
[07:10:22] + Closed connections
[07:10:27]
[07:10:27] + Processing work unit
[07:10:27] Core required: FahCore_b4.exe
[07:10:27] Core found.
[07:10:27] Working on queue slot 06 [December 30 07:10:27 UTC]
[07:10:27] + Working ...
[07:10:27] - Calling '.\FahCore_b4.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:10:29] *********************** Log Started 30/Dec/2009 07:10:29 ***********************
[07:10:29] ************************** ProtoMol Folding@Home Core **************************
[07:10:29]   Version: 21
[07:10:29]      Type: 180
[07:10:29]      Core: ProtoMol
[07:10:29]   Website: http://folding.stanford.edu/
[07:10:29] Copyright: (c) 2009 Stanford University
[07:10:29]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:10:29]      Args: -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 267364
[07:10:29]            -version 623
[07:10:29] ************************************ Build *************************************
[07:10:29]      Date: Dec 24 2009
[07:10:29]      Time: 14:36:31
[07:10:29]  Revision: 1748
[07:10:29]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:10:29]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:10:29]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:10:29]  Platform: Windows XP
[07:10:29]      Bits: 32
[07:10:29] ************************************ System ************************************
[07:10:29]        OS: Microsoft Windows XP Professional
[07:10:29]       CPU: AMD Athlon(tm) XP 2800+
[07:10:29]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:10:29]      CPUs: 1 Logical, 1 Physical
[07:10:29]    Memory: 1023 MB
[07:10:29] ********************************************************************************
[07:10:29] Project: 10001 (Run 849, Clone 2, Gen 11)
[07:10:29] Reading tar file par_all27_prot_lipid.inp
[07:10:29] Reading tar file scpismQuartic.inp
[07:10:29] Reading tar file ww_exteq_nowater1.pdb
[07:10:29] Reading tar file ww_exteq_nowater1.psf
[07:10:29] Reading tar file checkpt
[07:10:29] Reading tar file ww_exteq_nowater1.350.pos
[07:10:29] Reading tar file ww_exteq_nowater1.350.vel
[07:10:29] Reading tar file protomol.conf
[07:10:29] Reading tar file core.xml
[07:10:29] Digital signatures verified
[07:10:30] GUI Server started
[07:10:30] Completed 0 out of 200000 steps (0%)
[07:10:30] WARNING: UnexpectedExitHandler triggered
[07:10:30] WARNING: Unexpected exit from science code
[07:10:30] Saving result file logfile_06.txt
[07:10:30] Saving result file checkpt
[07:10:30] Saving result file log.txt
[07:10:30] Saving result file protomol.conf
[07:10:30] Saving result file ww.dcd
[07:10:30] Saving result file ww_exteq_nowater1.350.pos
[07:10:30] Saving result file ww_exteq_nowater1.350.vel
[07:10:30] Folding@home Core Shutdown: UNKNOWN
[07:10:33] CoreStatus = 7B (123)
[07:10:33] Sending work to server
[07:10:33] Project: 10001 (Run 849, Clone 2, Gen 11)
[07:10:33] - Read packet limit of 540015616... Set to 524286976.
[07:10:33] + Attempting to send results [December 30 07:10:33 UTC]
[07:10:33] - Reading file work/wuresults_06.dat from core
[07:10:33]   (Read 49183 bytes from disk)
[07:10:33] Connecting to http://129.74.85.48:8080/
[07:10:35] Posted data.
[07:10:35] Initial: 0000; - Uploaded at ~24 kB/s
[07:10:35] - Averaged speed for that direction ~29 kB/s
[07:10:35] + Results successfully sent
[07:10:35] Thank you for your contribution to Folding@Home.
[07:10:41] Trying to send all finished work units
[07:10:41] + No unsent completed units remaining.
[07:10:41] - Preparing to get new work unit...
[07:10:41] + Attempting to get work packet
[07:10:41] - Will indicate memory of 1023 MB
[07:10:41] - Connecting to assignment server
[07:10:41] Connecting to http://assign.stanford.edu:8080/
[07:10:41] Posted data.
[07:10:41] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:10:41] + News From Folding@Home: Welcome to Folding@Home
[07:10:42] Loaded queue successfully.
[07:10:42] Connecting to http://129.74.85.48:8080/
[07:10:42] Posted data.
[07:10:42] Initial: 0000; - Receiving payload (expected size: 77669)
[07:10:43] - Downloaded at ~75 kB/s
[07:10:43] - Averaged speed for that direction ~107 kB/s
[07:10:43] + Received work.
[07:10:43] Trying to send all finished work units
[07:10:43] + No unsent completed units remaining.
[07:10:43] + Closed connections
[07:10:48]
[07:10:48] + Processing work unit
[07:10:48] Core required: FahCore_b4.exe
[07:10:48] Core found.
[07:10:48] Working on queue slot 07 [December 30 07:10:48 UTC]
[07:10:48] + Working ...
[07:10:48] - Calling '.\FahCore_b4.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:10:51] *********************** Log Started 30/Dec/2009 07:10:51 ***********************
[07:10:51] ************************** ProtoMol Folding@Home Core **************************
[07:10:51]   Version: 21
[07:10:51]      Type: 180
[07:10:51]      Core: ProtoMol
[07:10:51]   Website: http://folding.stanford.edu/
[07:10:51] Copyright: (c) 2009 Stanford University
[07:10:51]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:10:51]      Args: -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 267364
[07:10:51]            -version 623
[07:10:51] ************************************ Build *************************************
[07:10:51]      Date: Dec 24 2009
[07:10:51]      Time: 14:36:31
[07:10:51]  Revision: 1748
[07:10:51]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:10:51]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:10:51]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:10:51]  Platform: Windows XP
[07:10:51]      Bits: 32
[07:10:51] ************************************ System ************************************
[07:10:51]        OS: Microsoft Windows XP Professional
[07:10:51]       CPU: AMD Athlon(tm) XP 2800+
[07:10:51]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:10:51]      CPUs: 1 Logical, 1 Physical
[07:10:51]    Memory: 1023 MB
[07:10:51] ********************************************************************************
[07:10:51] Project: 10001 (Run 971, Clone 5, Gen 8)
[07:10:51] Reading tar file par_all27_prot_lipid.inp
[07:10:51] Reading tar file scpismQuartic.inp
[07:10:51] Reading tar file ww_exteq_nowater1.pdb
[07:10:51] Reading tar file ww_exteq_nowater1.psf
[07:10:51] Reading tar file checkpt
[07:10:51] Reading tar file ww_exteq_nowater1.279.pos
[07:10:51] Reading tar file ww_exteq_nowater1.279.vel
[07:10:51] Reading tar file protomol.conf
[07:10:51] Reading tar file core.xml
[07:10:51] Digital signatures verified
[07:10:52] GUI Server started
[07:10:52] Completed 0 out of 200000 steps (0%)
[07:10:52] WARNING: UnexpectedExitHandler triggered
[07:10:52] WARNING: Unexpected exit from science code
[07:10:52] Saving result file logfile_07.txt
[07:10:52] Saving result file checkpt
[07:10:52] Saving result file log.txt
[07:10:52] Saving result file protomol.conf
[07:10:52] Saving result file ww.dcd
[07:10:52] Saving result file ww_exteq_nowater1.279.pos
[07:10:52] Saving result file ww_exteq_nowater1.279.vel
[07:10:52] Folding@home Core Shutdown: UNKNOWN
[07:10:55] CoreStatus = 7B (123)
[07:10:55] Sending work to server
[07:10:55] Project: 10001 (Run 971, Clone 5, Gen 8)
[07:10:55] - Read packet limit of 540015616... Set to 524286976.
[07:10:55] + Attempting to send results [December 30 07:10:55 UTC]
[07:10:55] - Reading file work/wuresults_07.dat from core
[07:10:55]   (Read 49097 bytes from disk)
[07:10:55] Connecting to http://129.74.85.48:8080/
[07:10:59] Posted data.
[07:10:59] Initial: 0000; - Uploaded at ~12 kB/s
[07:10:59] - Averaged speed for that direction ~26 kB/s
[07:10:59] + Results successfully sent
[07:10:59] Thank you for your contribution to Folding@Home.
This continued until Project: 10000 (Run 372, Clone 0, Gen 12) was issued.
[07:11:05] - Preparing to get new work unit...
[07:11:05] + Attempting to get work packet
[07:11:05] - Will indicate memory of 1023 MB
[07:11:05] - Connecting to assignment server
[07:11:05] Connecting to http://assign.stanford.edu:8080/
[07:11:05] Posted data.
[07:11:05] Initial: 4A81; - Successful: assigned to (129.74.85.48).
[07:11:05] + News From Folding@Home: Welcome to Folding@Home
[07:11:05] Loaded queue successfully.
[07:11:05] Connecting to http://129.74.85.48:8080/
[07:11:05] Initial: 0000; - Receiving payload (expected size: 64905)
[07:11:06] - Downloaded at ~63 kB/s
[07:11:06] - Averaged speed for that direction ~98 kB/s
[07:11:06] + Received work.
[07:11:06] Trying to send all finished work units
[07:11:06] + No unsent completed units remaining.
[07:11:06] + Closed connections
[07:11:11]
[07:11:11] + Processing work unit
[07:11:11] Core required: FahCore_b4.exe
[07:11:11] Core found.
[07:11:11] Working on queue slot 08 [December 30 07:11:11 UTC]
[07:11:11] + Working ...
[07:11:11] - Calling '.\FahCore_b4.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 267364 -version 623'
[07:11:13] *********************** Log Started 30/Dec/2009 07:11:13 ***********************
[07:11:13] ************************** ProtoMol Folding@Home Core **************************
[07:11:13]   Version: 21
[07:11:13]      Type: 180
[07:11:13]      Core: ProtoMol
[07:11:13]   Website: http://folding.stanford.edu/
[07:11:13] Copyright: (c) 2009 Stanford University
[07:11:13]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:11:13]      Args: -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 267364
[07:11:13]            -version 623
[07:11:13] ************************************ Build *************************************
[07:11:13]      Date: Dec 24 2009
[07:11:13]      Time: 14:36:31
[07:11:13]  Revision: 1748
[07:11:13]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:11:13]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:11:13]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:11:13]  Platform: Windows XP
[07:11:13]      Bits: 32
[07:11:13] ************************************ System ************************************
[07:11:13]        OS: Microsoft Windows XP Professional
[07:11:13]       CPU: AMD Athlon(tm) XP 2800+
[07:11:13]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[07:11:13]      CPUs: 1 Logical, 1 Physical
[07:11:13]    Memory: 1023 MB
[07:11:13] ********************************************************************************
[07:11:13] Project: 10000 (Run 372, Clone 0, Gen 12)
[07:11:13] Reading tar file par_all27_prot_lipid.inp
[07:11:13] Reading tar file scpismQuartic.inp
[07:11:13] Reading tar file ww_exteq_nowater1.pdb
[07:11:14] Reading tar file ww_exteq_nowater1.psf
[07:11:14] Reading tar file checkpt
[07:11:14] Reading tar file ww_exteq_nowater1.629.pos
[07:11:14] Reading tar file ww_exteq_nowater1.629.vel
[07:11:14] Reading tar file protomol.conf
[07:11:14] Reading tar file core.xml
[07:11:14] Digital signatures verified
[07:11:14] GUI Server started
[07:11:14] Completed 0 out of 1000000 steps (0%)
The good news is Project: 10000 (Run 372, Clone 0, Gen 12) is running at @160 PPD.
The bad news is the following WUs were thrashed first:
Project: 10001 (Run 653, Clone 2, Gen 11) 2X
Project: 10001 (Run 655, Clone 3, Gen 2) 4X
2X
That's ten P10001 WUs thrashed in about six minutes, some of them multiple times! And it appears this would have continued as long as P10001s were assigned. :shock:
I have already set the client to quit after completing the current unit as this level of carnage is not acceptable.
Interestingly, according to the Vijay's blog, P10000 uses conventional simulation while P10001 uses NML. It appears my Athlon XP has a strong aversion to NML. :(
http://folding.typepad.com/news/2009/12/release-of-new-protomol-core-b4-wus-.html
I should try to restart my old XP 2200+ to do some testing on this core ...
Amaruk
Post by Amaruk »
FWIW, Project: 10000 (Run 372, Clone 0, Gen 12) completed without issue.
autogrog
Post by autogrog »
My dual MP2800 Windows Professional 2000 SP4 1Gb RAM no OC,is failing on the b4 core as well after processing in excess of 1200 non-b4 WU's:
# Windows Console Edition #####################################################
                       Folding@Home Client Version 5.04beta
Launch directory: D:\Folding At Home\cpu2
Executable: D:\Folding At Home\cpu2\FAH504-Console.exe
Arguments: -service -local -advmethods -forceasm
[19:34:11] - Ask before connecting: No
[19:34:11] - User name: AutoGrog
[19:34:12] - User ID: 103A1D6***
[19:34:12] - Machine ID: 2
[19:34:12]
[19:34:12] Loaded queue successfully.
[19:34:12] + Benchmarking ...
[19:34:15] - Preparing to get new work unit...
[19:34:15] + Attempting to get work packet
[19:34:15] - Connecting to assignment server
[19:34:17] - Successful: assigned to (129.74.85.48).
[19:34:17] + News From Folding@Home: Welcome to Folding@Home
[19:34:17] Loaded queue successfully.
[19:34:25] + Closed connections
[19:34:25]
[19:34:25] + Processing work unit
[19:34:25] Core required: FahCore_b4.exe
[19:34:25] Core found.
[19:34:25] Working on Unit 01 [March 29 19:34:25]
[19:34:25] + Working ...
[19:34:50] *********************** Log Started 29/Mar/2010 19:34:49 ***********************
[19:34:50] ************************** ProtoMol Folding@Home Core **************************
[19:34:50]   Version: 22
[19:34:50]      Type: 180
[19:34:50]      Core: ProtoMol
[19:34:50]   Website: http://folding.stanford.edu/
[19:34:50] Copyright: (c) 2009 Stanford University
[19:34:50]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[19:34:50]      Args: -dir work/ -suffix 01 -checkpoint 30 -service -forceasm -lifeline 588
[19:34:50]            -version 504
[19:34:50]
[19:34:50] ************************************ Build *************************************
[19:34:50]      Date: Jan 21 2010
[19:34:50]      Time: 19:16:23
[19:34:50]  Revision: 1756
[19:34:50]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[19:34:50]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[19:34:50]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[19:34:50]  Platform: Windows XP
[19:34:50]      Bits: 32
[19:34:50]      Mode: Release
[19:34:50] ************************************ System ************************************
[19:34:50]        OS: Microsoft Windows 2000 Service Pack 4
[19:34:50]       CPU: AMD Athlon(tm) MP 2800+
[19:34:50]    CPU ID: AuthenticAMD Family 6 Model 10 Stepping 0
[19:34:50]      CPUs: 1 Logical, 1 Physical
[19:34:50]    Memory: 1023 MB
[19:34:50]   Threads: Windows
[19:34:50] ********************************************************************************
[19:34:50] Project: 10006 (Run 822, Clone 5, Gen 0)
[19:34:51] Reading tar file par_all27_prot_lipid.inp
[19:34:51] Reading tar file scpismQuartic.inp
[19:34:51] Reading tar file ww_exteq_nowater1.pdb
[19:34:51] Reading tar file ww_exteq_nowater1.psf
[19:34:51] Reading tar file protomol.conf
[19:34:51] Reading tar file core.xml
[19:34:51] Digital signatures verified
[19:35:01] ERROR: Exception in thread 1: @ fah\net\Socket.cpp:139:<unknown> 0: Could not bind socket to 127.0.0.1: No error
[19:35:01] Completed 0 out of 500000 steps (0)
[19:35:02] WARNING: Caught signal SIGILL(4) on PID 1140
[19:35:02] WARNING: Unexpected exit from science code
[19:35:02] Saving result file logfile_01.txt
[19:35:02] Saving result file log.txt
[19:35:02] Saving result file protomol.conf
[19:35:02] Saving result file ww.dcd
[19:35:02] Folding@home Core Shutdown: BAD_WORK_UNIT
[19:35:06] CoreStatus = 72 (114)
[19:35:06] Sending work to server
This will repeat until a non-b4 WU is downloaded. All the usual delete / restart attempts have proved futile. Will now drop the -advmethods as a last gasp solution.
