Project: 10001 (Run 503, Clone 1, Gen 1) "by another proces"
Tobit
Post by Tobit »
This error code on this one is the same as my last submission. However, this one made it to 100%.. the other one did not.
Edit: looks like this might be just a harmless warning message as the work is completing as expected. However, I am still reporting so that it might be cleaned up in the future. :)
[11:23:47] Core required: FahCore_b4.exe
[11:23:47] Core found.
[11:23:47] Working on queue slot 06 [December 22 11:23:47 UTC]
[11:23:47] + Working ...
[11:23:51] *********************** Log Started 22/Dec/2009 11:23:51 ***********************
[11:23:51] ************************** ProtoMol Folding@Home Core **************************
[11:23:51]   Version: 19
[11:23:51]      Type: 180
[11:23:51]      Core: ProtoMol
[11:23:51]   Website: http://folding.stanford.edu/
[11:23:51] Copyright: (c) 2009 Stanford University
[11:23:51]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[11:23:51]      Args: -dir work/ -suffix 06 -checkpoint 15 -lifeline 5116 -version 623
[11:23:51] ************************************ Build *************************************
[11:23:51]      Date: Dec 16 2009
[11:23:51]      Time: 17:02:04
[11:23:51]  Revision: 1746
[11:23:51]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[11:23:51]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[11:23:51]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[11:23:51]  Platform: Windows XP
[11:23:51]      Bits: 32
[11:23:51] ************************************ System ************************************
[11:23:51]        OS: Microsoft(R) Windows(R) XP Professional x64 Edition
[11:23:51]       CPU: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
[11:23:51]    CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
[11:23:51]      CPUs: 2 Logical, 1 Physical
[11:23:51]    Memory: 4.00 GB
[11:23:51] ********************************************************************************
[11:23:51] Project: 10001 (Run 503, Clone 1, Gen 1)
[11:23:51] Reading tar file par_all27_prot_lipid.inp
[11:23:51] Reading tar file scpismQuartic.inp
[11:23:51] Reading tar file ww_exteq_nowater1.pdb
[11:23:51] Reading tar file ww_exteq_nowater1.psf
[11:23:51] Reading tar file checkpt
[11:23:51] Reading tar file ww_exteq_nowater1.14.pos
[11:23:51] Reading tar file ww_exteq_nowater1.14.vel
[11:23:51] Reading tar file protomol.conf
[11:23:51] Reading tar file core.xml
[11:23:51] Digital signatures verified
[11:23:52] Completed 0 out of 200000 steps (0%)
[11:27:12] Completed 2000 out of 200000 steps (1%)
lines intentionally removed to save space
[16:59:10] Completed 200000 out of 200000 steps (100%)
[16:59:11] Saving result file logfile_06.txt
[16:59:11] Saving result file checkpt
[16:59:11] Saving result file checkpt.crc
[16:59:11] Saving result file log.txt
[16:59:11] Saving result file protomol.conf
[16:59:11] Saving result file ww.dcd
[16:59:11] Saving result file ww_exteq_nowater1.37.pos
[16:59:11] Saving result file ww_exteq_nowater1.37.vel
[16:59:12] WARNING: While cleaning up: @ fah\os\SystemUtilities.cpp:123:<unknown> 0: Failed to remove directory '06': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "06\log.txt"
[16:59:12] Folding@home Core Shutdown: FINISHED_UNIT
[16:59:14] CoreStatus = 64 (100)
[16:59:14] Sending work to server
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: Project: 10001 (Run 503, Clone 1, Gen 1)
Post by MtM »
This is normal for this core, some wu's will not run to 100% but they are still returning valid results ( the trajectory just ends sooner then expected ). toTow will edit his news about this core to include this.
Would be nice to see a Pande Group News post as well, or at least a tweet.
Or should we just set our browsers to redirect http://folding.typepad.com/ to http://en.fah-addict.net/news/news.php instead?
Tobit
Post by Tobit »
Agreed, I'm just concerned about the warning message saying it can't clean up the work directory properly. Hopefully new work downloaded to this slot can overwrite this data and process properly.
MtM
Post by MtM »
That warning has been there with all cores, Joseph has looked at making sure the slots will not be unusable ( tested and confirmed afaik ) so that should not be an issue.
Tobit
Post by Tobit »
MtM wrote:That warning has been there with all cores, Joseph has looked at making sure the slots will not be unusable ( tested and confirmed afaik ) so that should not be an issue.
Odd, I don't see it in any of my other log files prior to these new ProtoMol cores but I will take your word for it. You've been around a lot longer than I. :)
MtM
Post by MtM »
Gpu cores, not cpu cores, so you're right and I'm not. Still, it's both atm a cosmetic issue ( or it should be ).
Time on the forum does not reflect one's knowledge, stay sceptical ;)
I've just noticed this message on my machine too ... I guess we should put it on the to-investigate list :mrgreen:
Amaruk
Post by Amaruk »
toTOW wrote:I've just noticed this message on my machine too ... I guess we should put it on the to-investigate list :mrgreen:
If you check your client's work folder, you will likely find a stray LOCK file. (wudata_XX.lock) The XX will correspond to the queue slot of the ProtoMol WU creating the warning message.
So far every ProtoMol I've folded has left it's LOCK file in the work folder. :?
Yes, more investigation is warranted.
I have not seen any serious errors from this issue, but it may become an issue after you've completed 10 WUs and the queue loops around.
