Project: 10001 (Run 388, Clone 2, Gen 0)
I don't see this WU in the Project summary and FahMon reports it as unknown. It downloaded FahCore_b4.exe, which I didn't have until now. Is there any information about this one?
All clients stopped due to Stanford's upcoming September 2011 decision
Zagen30
Re: Project: 10001 (Run 388, Clone 2, Gen 0)
The project summary page is now split up into general and beta projects, and the default page only shows general projects. You should see three links in the upper-left corner of the screen under the big bold "Currently Running Projects" that change which set you're viewing. The new Protomol-based projects are listed as beta.
FahMon is probably still reading off of the default page, which is why the beta projects can't be found by it.
Ah, I see what you mean about the other page summaries. Thanks. Wow, it's only a 50 pointer.
It's to bad about FahMon, it would appear that it is never going to get updated and not for just the reason expressed in this thread.
If you want to know more about this core and projects, I wrote a little something : The Protomol core unveiled in Advmethods
MtM
You do know fahMON can be set to the other pages manually, and it has always been that way?FahMon is probably still reading off of the default page, which is why the beta projects can't be found by it.
Zagen30
Now that you mention it, I think I have seen that, but I never paid much attention.MtM wrote:You do know fahMON can be set to the other pages manually, and it has always been that way?FahMon is probably still reading off of the default page, which is why the beta projects can't be found by it.
What other pages?MtM wrote:You do know fahMON can be set to the other pages manually, and it has always been that way?FahMon is probably still reading off of the default page, which is why the beta projects can't be found by it.
A small clarification about the comment I made earlier about the WU only being 50 points. I actually prefer these smaller WUs because they make you feel as though you are actually getting something accomplished in a day, rather than having to wait 3 or 4 days for a single result.
Am I the only one that doesn't see the links at the top of the Project Summary page?
They have been removed, beta information are only available to Beta Team members. These links shouldn't have been added, so it's fixed now.
Okay, I thought maybe I had accidentally changed a browser setting or something and that's why I couldn't see them.
Thanks all.
Thanks all.
'p1000?'s aren't betas anymore anyway
I'm counting for science.
Points just make me sick.
codysluder
Right. They appear on the regular psummary, though you have to scroll a long way to find them.whynot wrote:'p1000?'s aren't betas anymore anyway
Both of you must not be using the Project Summary link at the top of the forums. The highest number there is 6316.
I thought this was solved with toTOW's post. Now it's confusing again.
Tynat, there currently is no more ProtoMol work available for the moment. They were listed properly last night so I suspect the server ran out of work early this morning.
