Project: 5745 (Run 0, Clone 59, Gen 228)
SidVicious
Post by SidVicious »
Another broken WU, EUE'd five times and issued the dreadful "Pausing 24 hours."
[21:26:37] Project: 5745 (Run 0, Clone 59, Gen 228)
[21:26:37]
[21:26:37] Assembly optimizations on if available.
[21:26:37] Entering M.D.
[21:26:43] Tpr hash work/wudata_00.tpr:  57746033 946412100 2250985240 2869848819 1138190429
[21:26:43] Working on Protein
[21:26:44] Client config found, loading data.
[21:26:44] Starting GUI Server
[21:26:47] mdrun_gpu returned
[21:26:47] Nonzero force sum on GPU
[21:26:47]
[21:26:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:26:49] CoreStatus = 7A (122)
[21:26:49] Sending work to server
[21:26:49] Project: 5745 (Run 0, Clone 59, Gen 228)
[21:26:49] - Read packet limit of 540015616... Set to 524286976.
[21:26:49] - Error: Could not get length of results file work/wuresults_00.dat
[21:26:49] - Error: Could not read unit 00 file. Removing from queue.
[21:26:49] EUE limit exceeded. Pausing 24 hours.
I'm doing science and I'm still folding
I feel FANTASTIC and I'm still folding
While you are dying I'll still be folding
and when you're dead I'll still be folding
STILL FOLDING, still folding
Tynat
Re: Project: 5745 (Run 0, Clone 59, Gen 228)
Post by Tynat »
There were four prior UNSTABLE_MACHINE failures with this WU previous to this one. It's unknown while the job stack is being rebuilt whether restarting the GPU client would result in receiving the same WU.
[16:39:31] + Received work.
[16:39:31] Trying to send all finished work units
[16:39:31] + No unsent completed units remaining.
[16:39:31] + Closed connections
[16:39:36]
[16:39:36] + Processing work unit
[16:39:36] Core required: FahCore_11.exe
[16:39:36] Core found.
[16:39:36] Working on queue slot 01 [July 4 16:39:36 UTC]
[16:39:36] + Working ...
[16:39:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 680 -version 623'
[16:39:37]
[16:39:37] *------------------------------*
[16:39:37] Folding@Home GPU Core - Beta
[16:39:37] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:39:37]
[16:39:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:39:37] Build host: amoeba
[16:39:37] Board Type: AMD
[16:39:37] Core      :
[16:39:37] Preparing to commence simulation
[16:39:37] - Looking at optimizations...
[16:39:37] - Created dyn
[16:39:37] - Files status OK
[16:39:37] - Expanded 68539 -> 357580 (decompressed 521.7 percent)
[16:39:37] Called DecompressByteArray: compressed_data_size=68539 data_size=357580, decompressed_data_size=357580 diff=0
[16:39:37] - Digital signature verified
[16:39:37]
[16:39:37] Project: 5745 (Run 0, Clone 59, Gen 228)
[16:39:37]
[16:39:37] Assembly optimizations on if available.
[16:39:37] Entering M.D.
[16:39:43] Tpr hash work/wudata_01.tpr:  57746033 946412100 2250985240 2869848819 1138190429
[16:39:43] Working on Protein
[16:39:44] Client config found, loading data.
[16:39:44] Starting GUI Server
[16:39:54] mdrun_gpu returned
[16:39:54] Nonzero force sum on GPU
[16:39:54]
[16:39:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:39:57] CoreStatus = 7A (122)
[16:39:57] Sending work to server
[16:39:57] Project: 5745 (Run 0, Clone 59, Gen 228)
[16:39:57] - Read packet limit of 540015616... Set to 524286976.
[16:39:57] - Error: Could not get length of results file work/wuresults_01.dat
[16:39:57] - Error: Could not read unit 01 file. Removing from queue.
[16:39:57] EUE limit exceeded. Pausing 24 hours.
All clients stopped due to Stanford's upcoming September 2011 decision
The WU (P5745,R0,C59,G228) has been reported as a bad WU.
