I got this utility from here but though it works quite well, it doesn't show progress of my current WU, which is using the Gromacs33 core. This is a large unit , so it would be handy to see progress and how other progs affect timings.
Perhaps, as it's a new core[for me anyway], it can't handle the long time scale per step? - I'm not even sure if itactually works' live' - or just finished units.
There's no help file.
FahChart 1.0.1.0 by JWhy
Re: FahChart 1.0.1.0 by JWhy
If it's a p5113, it's missing on the psummary, so the program might not know about this WU ...
- Hardware configuration: Hewlett-Packard 1494 Win10 Build 1836
GeForce [MSI] GTX 950
Runs F@H Ver7.6.21
[As of Jan 2021] - Location: England
Thanks ToW - the unit's :
p1751_ACHE_NAT_300_03-33 for reference.
It's going smoothly (2/3 done)- last time on this core I got an EUE -on windows updating after over a weeks work!
Well ... p1751 is not in psummary ... so you know why it's unknown to 3rd party software.
