Immediate EUEs with P46xx WUs
AgrFan
Post by AgrFan »
I've had these Amber units (46xx WUs) immediately EUE on 5 different clients over the past few weeks.
Project: 4600 (Run 35, Clone 49, Gen 44)
Project: 4625 (Run 37, Clone 64, Gen 60)
Project: 4626 (Run 21, Clone 74, Gen 41)
Project: 4611 (Run 20, Clone 63, Gen 35)
Project: 4602 (Run 11, Clone 58, Gen 42)
Project: 4602 (Run 14, Clone 67, Gen 34)
Project: 4608 (Run 11, Clone 40, Gen 47)
Project: 4607 (Run 1, Clone 87, Gen 36)
Project: 4608 (Run 4, Clone 45, Gen 82)
Project: 4606 (Run 41, Clone 38, Gen 82)
Project: 4624 (Run 17, Clone 88, Gen 45)
Project: 4609 (Run 45, Clone 22, Gen 94)
Project: 4619 (Run 12, Clone 18, Gen 53)
Project: 4624 (Run 21, Clone 34, Gen 71)
Project: 4600 (Run 32, Clone 46, Gen 45)
Project: 4604 (Run 12, Clone 39, Gen 66)
Project: 4607 (Run 14, Clone 29, Gen 84)
Project: 4609 (Run 0, Clone 31, Gen 64)
Project: 4612 (Run 16, Clone 60, Gen 45)
Project: 4625 (Run 26, Clone 71, Gen 53)
Project: 4612 (Run 8, Clone 38, Gen 60)
Project: 4626 (Run 24, Clone 40, Gen 69)
Project: 4600 (Run 44, Clone 7, Gen 87)
Project: 4603 (Run 7, Clone 36, Gen 56)
Project: 4602 (Run 21, Clone 42, Gen 57)
Project: 4602 (Run 27, Clone 56, Gen 58)
Project: 4606 (Run 26, Clone 31, Gen 45)
Project: 4601 (Run 36, Clone 37, Gen 44)
Project: 4624 (Run 44, Clone 37, Gen 67)
Project: 4610 (Run 4, Clone 33, Gen 51)
Project: 4602 (Run 1, Clone 82, Gen 22)
Project: 4601 (Run 10, Clone 46, Gen 42)
Project: 4609 (Run 9, Clone 36, Gen 60)
Project: 4619 (Run 7, Clone 4, Gen 78)
Project: 4620 (Run 5, Clone 35, Gen 84)
Project: 4606 (Run 41, Clone 32, Gen 82)
Project: 4607 (Run 29, Clone 50, Gen 78)
Project: 4608 (Run 24, Clone 39, Gen 65)
Project: 4600 (Run 38, Clone 41, Gen 46)
Project: 4614 (Run 21, Clone 34, Gen 65)
Project: 4619 (Run 19, Clone 2, Gen 56)
Project: 4624 (Run 21, Clone 35, Gen 71)
Project: 4619 (Run 0, Clone 73, Gen 41)
Project: 4619 (Run 11, Clone 21, Gen 76)
Project: 4601 (Run 36, Clone 47, Gen 44)
AgrFan
Re: Immediate EUEs with P46xx WUs
Post by AgrFan »
Here's my hardware specs ...
#1 - Dell Inspiron E530s, Pentium Dual Core E2160, 1GB RAM, Windows Vista Basic, dual CPU clients
#2 - Whitebox, Gigabyte GA-G31M-ES2L mobo, Pentium Dual Core E5200, 2GB RAM, Windows XP Pro SP3, dual CPU clients
#3 - Whitebox, Asus A7S8X-MX mobo, AMD Sempron 2500+, 1 GB RAM, Windows XP Home SP3, single CPU client
Everything is running stock, no OC'ing or tricks whatsoever.
Hmmm. You do complete some of them. Your most recent WUs got full credit.
119.3 2009-12-12 12:06:45 4619 8 62 83
119.3 2009-12-12 12:06:45 4615 13 128 14
47.0 2009-12-12 16:04:32 4602 10 81 36
119.3 2009-12-12 16:04:32 4619 17 77 40
Any idea what's different about them?
AgrFan
Post by AgrFan »
I've completed hundreds of Amber units on these machines over the past few weeks.
Has anyone returned these failed units successfully?
If so, I'll chalk it up to a hardware or network glitch.
If not, these units are faulty and need to be stopped.
vvoelz
Pande Group Member
Post by vvoelz »
AgrFan --
I'll look into it. Usually our servers stop work on unstable WUs, but perhaps something is going wrong. I'll check it out as soon as I can. --Vince
whynot
Post by whynot »
AgrFan wrote: Project: 4608 (Run 24, Clone 39, Gen 65)
That's mine! That's mine!
[02:34:22] - Preparing to get new work unit...
[02:34:22] + Attempting to get work packet
[02:34:22] - Connecting to assignment server
[02:34:22] Connecting to http://assign.stanford.edu:8080/
[02:34:24] Posted data.
[02:34:24] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[02:34:24] + News From Folding@Home: Welcome to Folding@Home
[02:34:24] Loaded queue successfully.
[02:34:24] Connecting to http://169.230.26.30:8080/
[02:34:25] Posted data.
[02:34:25] Initial: 0000; - Receiving payload (expected size: 18986)
[02:34:26] - Downloaded at ~18 kB/s
[02:34:26] - Averaged speed for that direction ~18 kB/s
[02:34:26] + Received work.
[02:34:26] Trying to send all finished work units
[02:34:26] + No unsent completed units remaining.
[02:34:26] + Closed connections
[02:34:31]
[02:34:31] + Processing work unit
[02:34:31] Core required: FahCore_82.exe
[02:34:31] Core found.
[02:34:31] Working on Unit 09 [December 12 02:34:31]
[02:34:31] + Working ...
[02:34:31] - Calling './FahCore_82.exe -dir work/ -suffix 09 -checkpoint 15 -verbose -lifeline 2794 -version 602'
[02:34:31]
[02:34:31] *------------------------------*
[02:34:31] Folding@Home PMD Core
[02:34:31] Version 1.03 (September 7, 2005)
[02:34:31]
[02:34:31] Preparing to commence simulation
[02:34:31] - Looking at optimizations...
[02:34:31] - Created dyn
[02:34:31] - Files status OK
[02:34:31] - Expanded 18474 -> 121383 (decompressed 657.0 percent)
[02:34:31]
[02:34:31] Project: 4608 (Run 24, Clone 39, Gen 65)
[02:34:31]
[02:34:31] Assembly optimizations on if available.
[02:34:31] Entering M.D.
[02:34:37] Going to send back what have done.
[02:34:37] logfile size: 5649
[02:34:37] - Writing 6169 bytes of core data to disk...
[02:34:37]   ... Done.
[02:34:37]
[02:34:37] Folding@home Core Shutdown: EARLY_UNIT_END
[02:34:38] CoreStatus = 72 (114)
[02:34:38] Sending work to server
[02:34:38] - Read packet limit of 540015616... Set to 524286976.
[02:34:38] + Attempting to send results
[02:34:38] - Reading file work/wuresults_09.dat from core
[02:34:38]   (Read 6169 bytes from disk)
[02:34:38] Connecting to http://169.230.26.30:8080/
[02:34:39] Posted data.
[02:34:39] Initial: 0000; - Uploaded at ~7 kB/s
[02:34:39] - Averaged speed for that direction ~11 kB/s
[02:34:39] + Results successfully sent
[02:34:39] Thank you for your contribution to Folding@Home.
BTW, this '4608 (Run 24, Clone 39, Gen 65)' was second among three in that run of EUEs.
I'm counting for science.
Points just make me sick.
