5772 (Run 2, Clone 17, Gen 1455)
rhavern
Post by rhavern »
I didn't see this one in the last 6 months of posts. Stable machine, WinXP 32-bit, 191 drivers, CUDA 2.3, latest cores
[04:58:46] Trying to send all finished work units
[04:58:46] + No unsent completed units remaining.
[04:58:46] - Preparing to get new work unit...
[04:58:46] + Attempting to get work packet
[04:58:46] - Will indicate memory of 2046 MB
[04:58:46] - Connecting to assignment server
[04:58:46] Connecting to http://assign-GPU.stanford.edu:8080/
[04:58:47] - Successful: assigned to (171.67.108.11).
[04:58:47] + News From Folding@Home: Welcome to Folding@Home
[04:58:47] Loaded queue successfully.
[04:58:47] Connecting to http://171.67.108.11:8080/
[04:58:48] - Receiving payload (expected size: 45950)
[04:58:49] - Downloaded at ~44 kB/s
[04:58:49] - Averaged speed for that direction ~52 kB/s
[04:58:49] + Received work.
[04:58:49] Trying to send all finished work units
[04:58:49] + No unsent completed units remaining.
[04:58:49] + Closed connections
[04:58:49]
[04:58:49] + Processing work unit
[04:58:49] Core required: FahCore_11.exe
[04:58:49] Core found.
[04:58:49] Working on queue slot 03 [December 7 04:58:49 UTC]
[04:58:49] + Working ...
[04:58:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 15 -service -verbose -lifeline 1476 -version 623'
[04:58:49]
[04:58:49] *------------------------------*
[04:58:49] Folding@Home GPU Core
[04:58:49] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:58:49]
[04:58:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:58:49] Build host: amoeba
[04:58:49] Board Type: Nvidia
[04:58:49] Core      :
[04:58:49] Preparing to commence simulation
[04:58:49] - Looking at optimizations...
[04:58:49] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[04:58:49] - Created dyn
[04:58:49] - Files status OK
[04:58:49] - Expanded 45438 -> 251112 (decompressed 552.6 percent)
[04:58:49] Called DecompressByteArray: compressed_data_size=45438 data_size=251112, decompressed_data_size=251112 diff=0
[04:58:49] - Digital signature verified
[04:58:49]
[04:58:49] Project: 5772 (Run 2, Clone 17, Gen 1455)
[04:58:49]
[04:58:49] Assembly optimizations on if available.
[04:58:49] Entering M.D.
[04:58:55] Tpr hash work/wudata_03.tpr:  2728305584 318264913 2838206071 276967414 357431773
[04:58:55]
[04:58:55] Calling fah_main args: 14 usage=100
[04:58:55]
[04:58:56] Working on Protein
[04:58:57] Client config found, loading data.
[04:58:57] Starting GUI Server
[04:59:53] Completed 1%
[05:00:49] Completed 2%
[05:01:44] Completed 3%
[05:02:40] Completed 4%
[05:03:36] Completed 5%
[05:04:32] Completed 6%
[05:05:28] Completed 7%
[05:06:24] Completed 8%
[05:07:20] Completed 9%
[05:08:16] Completed 10%
[05:09:12] Completed 11%
[05:10:07] Completed 12%
[05:11:03] Completed 13%
[05:11:59] Completed 14%
[05:12:55] Completed 15%
[05:13:51] Completed 16%
[05:14:47] Completed 17%
[05:15:43] Completed 18%
[05:16:39] Completed 19%
[05:17:34] Completed 20%
[05:18:30] Completed 21%
[05:19:26] Completed 22%
[05:20:22] Completed 23%
[05:21:01] Run: exception thrown during GuardedRun
[05:21:01] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[05:21:01] Going to send back what have done -- stepsTotalG=15000000
[05:21:01] Work fraction=0.2370 steps=15000000.
[05:21:05] logfile size=14924 infoLength=14924 edr=0 trr=23
[05:21:05] + Opened results file
[05:21:05] - Writing 15460 bytes of core data to disk...
[05:21:05] Done: 14948 -> 4570 (compressed to 30.5 percent)
[05:21:05]   ... Done.
[05:21:05] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[05:21:05]
[05:21:05] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:21:07] CoreStatus = 7A (122)
[05:21:07] Sending work to server
[05:21:07] Project: 5772 (Run 2, Clone 17, Gen 1455)
[05:21:07] - Read packet limit of 540015616... Set to 524286976.
[05:21:07] + Attempting to send results [December 7 05:21:07 UTC]
[05:21:07]   (Read 5082 bytes from disk)
[05:21:07] Connecting to http://171.67.108.11:8080/
[05:21:09] - Uploaded at ~2 kB/s
[05:21:09] - Averaged speed for that direction ~49 kB/s
[05:21:09] + Results successfully sent
[05:21:09] Thank you for your contribution to Folding@Home.
Folding since 1 WU=1 point
