171.67.108.25
Locked
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
171.67.108.25
Post by SKeptical_Thinker »
Can't upload to this server. Status shows accepting but it is returning a status of 503.
[15:41:02] Completed 99%
[15:42:09] Completed 100%
[15:42:09] Successful run
[15:42:09] DynamicWrapper: Finished Work Unit: sleep=10000
[15:42:19] Reserved 75816 bytes for xtc file; Cosm status=0
[15:42:19] Allocated 75816 bytes for xtc file
[15:42:19] - Reading up to 75816 from "work/wudata_05.xtc": Read 75816
[15:42:19] Read 75816 bytes from xtc file; available packet space=786354648
[15:42:19] xtc file hash check passed.
[15:42:19] Reserved 15168 15168 786354648 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[15:42:19] Allocated 15168 bytes for arc file
[15:42:19] - Reading up to 15168 from "work/wudata_05.trr": Read 15168
[15:42:19] Read 15168 bytes from arc file; available packet space=786339480
[15:42:19] trr file hash check passed.
[15:42:19] Allocated 560 bytes for edr file
[15:42:19] Read bedfile
[15:42:19] edr file hash check passed.
[15:42:19] Allocated 33588 bytes for logfile
[15:42:19] Read logfile
[15:42:19] GuardedRun: success in DynamicWrapper
[15:42:19] GuardedRun: done
[15:42:19] Run: GuardedRun completed.
[15:42:23] + Opened results file
[15:42:23] - Writing 125644 bytes of core data to disk...
[15:42:23] Done: 125132 -> 99453 (compressed to 79.4 percent)
[15:42:23]   ... Done.
[15:42:23] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[15:42:24] Shutting down core
[15:42:24]
[15:42:24] Folding@home Core Shutdown: FINISHED_UNIT
[15:42:27] CoreStatus = 64 (100)
[15:42:27] Unit 5 finished with 86 percent of time to deadline remaining.
[15:42:27] Updated performance fraction: 0.948948
[15:42:27] Sending work to server
[15:42:27] Project: 5771 (Run 3, Clone 96, Gen 959)
[15:42:27] - Read packet limit of 540015616... Set to 524286976.
[15:42:27] + Attempting to send results [December 5 15:42:27 UTC]
[15:42:27] - Reading file work/wuresults_05.dat from core
[15:42:27]   (Read 99965 bytes from disk)
[15:42:27] Connecting to http://171.67.108.11:8080/
[15:42:28] - Couldn't send HTTP request to server
[15:42:28] + Could not connect to Work Server (results)
[15:42:28]     (171.67.108.11:8080)
[15:42:28] + Retrying using alternative port
[15:42:28] Connecting to http://171.67.108.11:80/
[15:42:29] - Couldn't send HTTP request to server
[15:42:29] + Could not connect to Work Server (results)
[15:42:29]     (171.67.108.11:80)
[15:42:29] - Error: Could not transmit unit 05 (completed December 5) to work server.
[15:42:29] - 1 failed uploads of this unit.
[15:42:29]   Keeping unit 05 in queue.
[15:42:29] Trying to send all finished work units
[15:42:29] Project: 5771 (Run 3, Clone 96, Gen 959)
[15:42:29] - Read packet limit of 540015616... Set to 524286976.
[15:42:29] + Attempting to send results [December 5 15:42:29 UTC]
[15:42:29] - Reading file work/wuresults_05.dat from core
[15:42:29]   (Read 99965 bytes from disk)
[15:42:29] Connecting to http://171.67.108.11:8080/
[15:42:30] - Couldn't send HTTP request to server
[15:42:30] + Could not connect to Work Server (results)
[15:42:30]     (171.67.108.11:8080)
[15:42:30] + Retrying using alternative port
[15:42:30] Connecting to http://171.67.108.11:80/
[15:42:32] - Couldn't send HTTP request to server
[15:42:32] + Could not connect to Work Server (results)
[15:42:32]     (171.67.108.11:80)
[15:42:32] - Error: Could not transmit unit 05 (completed December 5) to work server.
[15:42:32] - 2 failed uploads of this unit.
[15:42:32] - Read packet limit of 540015616... Set to 524286976.
[15:42:32] + Attempting to send results [December 5 15:42:32 UTC]
[15:42:32] - Reading file work/wuresults_05.dat from core
[15:42:32]   (Read 99965 bytes from disk)
[15:42:32] Connecting to http://171.67.108.25:8080/
[15:42:32]   (Got status 503)
[15:42:32]     (171.67.108.25:8080)
[15:42:32] + Retrying using alternative port
[15:42:32] Connecting to http://171.67.108.25:80/
[15:42:32]     (171.67.108.25:80)
[15:42:32]   Could not transmit unit 05 to Collection server; keeping in queue.
[15:42:32] + Sent 0 of 1 completed units to the server
[15:42:32] - Preparing to get new work unit...
[15:42:32] + Attempting to get work packet
[15:42:32] - Will indicate memory of 3326 MB
[15:42:32] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[15:42:32] - Connecting to assignment server
[15:42:32] Connecting to http://assign-GPU.stanford.edu:8080/
[15:42:32] Posted data.
[15:42:32] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[15:42:32] + News From Folding@Home: Welcome to Folding@Home
[15:42:32] Loaded queue successfully.
[15:42:32] Connecting to http://171.64.65.106:8080/
[15:42:33] Posted data.
[15:42:33] Initial: 0000; - Receiving payload (expected size: 67952)
[15:42:33] Conversation time very short, giving reduced weight in bandwidth avg
[15:42:33] - Downloaded at ~132 kB/s
[15:42:33] - Averaged speed for that direction ~80 kB/s
[15:42:33] + Received work.
[15:42:34] Trying to send all finished work units
[15:42:34] Project: 5771 (Run 3, Clone 96, Gen 959)
[15:42:34] - Read packet limit of 540015616... Set to 524286976.
[15:42:34] + Attempting to send results [December 5 15:42:34 UTC]
[15:42:34] - Reading file work/wuresults_05.dat from core
[15:42:34]   (Read 99965 bytes from disk)
[15:42:34] Connecting to http://171.67.108.11:8080/
[15:42:35] - Couldn't send HTTP request to server
[15:42:35] + Could not connect to Work Server (results)
[15:42:35]     (171.67.108.11:8080)
[15:42:35] + Retrying using alternative port
[15:42:35] Connecting to http://171.67.108.11:80/
[15:42:36] - Couldn't send HTTP request to server
[15:42:36] + Could not connect to Work Server (results)
[15:42:36]     (171.67.108.11:80)
[15:42:36] - Error: Could not transmit unit 05 (completed December 5) to work server.
[15:42:36] - 3 failed uploads of this unit.
[15:42:36] - Read packet limit of 540015616... Set to 524286976.
[15:42:36] + Attempting to send results [December 5 15:42:36 UTC]
[15:42:36] - Reading file work/wuresults_05.dat from core
[15:42:36]   (Read 99965 bytes from disk)
[15:42:36] Connecting to http://171.67.108.25:8080/
[15:42:36]   (Got status 503)
[15:42:36]     (171.67.108.25:8080)
[15:42:36] + Retrying using alternative port
[15:42:36] Connecting to http://171.67.108.25:80/
[15:42:36]     (171.67.108.25:80)
[15:42:36]   Could not transmit unit 05 to Collection server; keeping in queue.
[15:42:36] + Sent 0 of 1 completed units to the server
[15:42:36] + Closed connections
Pick2
Hardware configuration: Linux & CPUs
Re: 171.67.108.25
Post by Pick2 »
The server for that WU is 171.67.108.11 , which is in "Reject" at the moment. Failing to upload the WU to it's server , it then tries the Collection Server (CS5) , which is 171.67.108.25 ( and fails again)
tonic
Re: 171.67.108.25
Post by tonic »
Was having this trouble as well, but finally got one through.
[18:12:14] + Attempting to send results [December 5 18:12:14 UTC]
[18:12:14] - Reading file work/wuresults_00.dat from core
[18:12:14]   (Read 91110 bytes from disk)
[18:12:14] Connecting to http://171.67.108.11:8080/
[18:12:15] - Couldn't send HTTP request to server
[18:12:15] + Could not connect to Work Server (results)
[18:12:15]     (171.67.108.11:8080)
[18:12:15] + Retrying using alternative port
[18:12:15] Connecting to http://171.67.108.11:80/
[18:12:16] - Couldn't send HTTP request to server
[18:12:16] + Could not connect to Work Server (results)
[18:12:16]     (171.67.108.11:80)
[18:12:16] - Error: Could not transmit unit 00 (completed December 5) to work server.
[18:12:16] - 6 failed uploads of this unit.
[18:12:16] - Read packet limit of 540015616... Set to 524286976.
[18:12:16] + Attempting to send results [December 5 18:12:16 UTC]
[18:12:16] - Reading file work/wuresults_00.dat from core
[18:12:16]   (Read 91110 bytes from disk)
[18:12:16] Connecting to http://171.67.108.25:8080/
[18:12:20] Posted data.
[18:12:20] Initial: 0000; - Uploaded at ~22 kB/s
[18:12:20] - Averaged speed for that direction ~124 kB/s
[18:12:20] + Results successfully sent
[18:12:20] Thank you for your contribution to Folding@Home.
[18:12:20] + Number of Units Completed: 1374
[18:12:20]   Successfully sent unit 00 to Collection server.
[18:12:20] + Sent 1 of 1 completed units to the server
[18:12:20] - Autosend completed
tonic
Re: 171.67.108.25
Post by tonic »
Yeah,looks like it took 6 tries to get it uploaded.
Re: 171.67.108.25
Please use this thread to report problems with 171.67.108.11 : viewtopic.php?f=18&t=11379
Locked
