4602 Run3 Clone 85 Gen 16 Client-core Communication Error
CoMePrAdZ
Hardware configuration: Pentium 4 524
Celeron @2.2ghz w/ 512 MB, folding for team 130783
Distributed Clusters over My School :D
Post by CoMePrAdZ »
OMG, 3 times error
--- Opening Log file [November 28 06:05:36 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home\Folding@Home Consoles\Folding@Home Console #01
Executable: Folding@home-Win32-x86.exe
Arguments: -local -verbosity 9 -forceasm
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[06:05:36] - Ask before connecting: Yes
[06:05:36] - User name: CoMePrAdZ (Team 130783)
[06:05:36] - User ID: 3200B16915E51508
[06:05:36] - Machine ID: 3
[06:05:36]
[06:05:36] Loaded queue successfully.
[06:05:36]
[06:05:36] + Processing work unit
[06:05:36] Core required: FahCore_82.exe
[06:05:36] Core found.
[06:05:36] - Autosending finished units... [November 28 06:05:36 UTC]
[06:05:36] Trying to send all finished work units
[06:05:36] Project: 4603 (Run 2, Clone 108, Gen 16)
[06:05:36] + Attempting to send results [November 28 06:05:36 UTC]
[06:05:36] - Reading file work/wuresults_03.dat from core
[06:05:36] Working on queue slot 04 [November 28 06:05:36 UTC]
[06:05:36] + Working ...
[06:05:36] - Calling '.\FahCore_82.exe -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline 3944 -version 623'
[06:05:36]   (Read 386867 bytes from disk)
[06:05:36] - Presenting message box asking to network.
[06:05:36]
[06:05:36] *------------------------------*
[06:05:36] Folding@Home PMD Core
[06:05:36] Version 1.03 (September 7, 2005)
[06:05:36]
[06:05:36] Preparing to commence simulation
[06:05:36] - Assembly optimizations manually forced on.
[06:05:36] - Not checking prior termination.
[06:05:37] - Expanded 12264 -> 76966 (decompressed 627.5 percent)
[06:05:37]
[06:05:37] Project: 4602 (Run 3, Clone 85, Gen 16)
[06:05:37]
[06:05:37] Assembly optimizations on if available.
[06:05:37] Entering M.D.
[06:05:38] Connecting to http://169.230.26.30:8080/
[06:05:49]
[06:05:49] Folding@home Core Shutdown: UNKNOWN_ERROR
[06:05:52] CoreStatus = 76 (118)
[06:05:52] Client-core communications error: ERROR 0x76
[06:05:52] This is a sign of more serious problems, shutting down.
--- Opening Log file [November 28 06:06:24 UTC]
Warning:
 use of the flag.
[06:06:24] - Ask before connecting: Yes
[06:06:24] - User name: CoMePrAdZ (Team 130783)
[06:06:24] - User ID: 3200B16915E51508
[06:06:24] - Machine ID: 3
[06:06:24]
[06:06:24] Loaded queue successfully.
[06:06:24]
[06:06:24] + Processing work unit
[06:06:24] Core required: FahCore_82.exe
[06:06:24] Core found.
[06:06:24] - Autosending finished units... [November 28 06:06:24 UTC]
[06:06:24] Working on queue slot 04 [November 28 06:06:24 UTC]
[06:06:24] + Working ...
[06:06:24] - Calling '.\FahCore_82.exe -dir work/ -suffix 04 -checkpoint 15 -forceasm -verbose -lifeline 3740 -version 623'
[06:06:24] Trying to send all finished work units
[06:06:24] Project: 4603 (Run 2, Clone 108, Gen 16)
[06:06:24] + Attempting to send results [November 28 06:06:24 UTC]
[06:06:24] - Reading file work/wuresults_03.dat from core
[06:06:24]   (Read 386867 bytes from disk)
[06:06:24] - Presenting message box asking to network.
[06:06:24]
[06:06:24] *------------------------------*
[06:06:24] Folding@Home PMD Core
[06:06:24] Version 1.03 (September 7, 2005)
[06:06:24]
[06:06:24] Preparing to commence simulation
[06:06:24] - Assembly optimizations manually forced on.
[06:06:24] - Not checking prior termination.
[06:06:24] - Expanded 12264 -> 76966 (decompressed 627.5 percent)
[06:06:24]
[06:06:24] Project: 4602 (Run 3, Clone 85, Gen 16)
[06:06:24]
[06:06:24] Assembly optimizations on if available.
[06:06:24] Entering M.D.
[06:06:25] Connecting to http://169.230.26.30:8080/
[06:06:36]
[06:06:36] Folding@home Core Shutdown: UNKNOWN_ERROR
[06:06:40] CoreStatus = 76 (118)
[06:06:40] Client-core communications error: ERROR 0x76
[06:06:40] This is a sign of more serious problems, shutting down.
"... Folding for everything ..."
Team 130783
Re: 4602 Run3 Clone 85 Gen 16 Client-core Communication Error
I don't remember seeing this core status before ... :?
Does it help if you delete the WU ?
CoMePrAdZ
Post by CoMePrAdZ »
Yes. I've did it as your suggestion. Thanks for your help. :-)
Team 130783
