Project: 4601 (Run 45, Clone 24, Gen 64) instantaneous EUE
[13:04:54] Project: 4601 (Run 45, Clone 24, Gen 64)
[13:04:54]
[13:04:54] Assembly optimizations on if available.
[13:04:54] Entering M.D.
[13:05:00] Going to send back what have done.
[13:05:00] logfile size: 5649
[13:05:00] - Writing 6169 bytes of core data to disk...
[13:05:00]   ... Done.
[13:05:00]
[13:05:00] Folding@home Core Shutdown: EARLY_UNIT_END
[13:05:04] CoreStatus = 72 (114)
Grandpa_01
Re: Project: 4601 (Run 45, Clone 24, Gen 64) instantaneous EUE
Post by Grandpa_01 »
I have had 2 of the 46xx do the same thing.
[05:17:21] Project: 4625 (Run 19, Clone 54, Gen 69)
[05:17:21]
[05:17:21] Assembly optimizations on if available.
[05:17:21] Entering M.D.
[05:17:27] Going to send back what have done.
[05:17:27] logfile size: 5649
[05:17:27] - Writing 6169 bytes of core data to disk...
[05:17:27]   ... Done.
[05:17:27]
[05:17:27] Folding@home Core Shutdown: EARLY_UNIT_END
[05:17:31] CoreStatus = 72 (114)
[05:17:31] Sending work to server
[05:17:31] Project: 4625 (Run 19, Clone 54, Gen 69)
[18:14:57] Project: 4610 (Run 8, Clone 34, Gen 47)
[18:14:57]
[18:14:57] Assembly optimizations on if available.
[18:14:57] Entering M.D.
[18:15:03] Going to send back what have done.
[18:15:03] logfile size: 5649
[18:15:03] - Writing 6169 bytes of core data to disk...
[18:15:03]   ... Done.
[18:15:03]
[18:15:03] Folding@home Core Shutdown: EARLY_UNIT_END
[18:15:07] CoreStatus = 72 (114)
[18:15:07] Sending work to server
[18:15:07] Project: 4610 (Run 8, Clone 34, Gen 47)
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
whynot
Post by whynot »
(just guessing) Is that that infamous "validation"?
[11:14:19] Project: 4613 (Run 30, Clone 16, Gen 30)
[11:14:25] Folding@home Core Shutdown: EARLY_UNIT_END
[11:14:37] Project: 4614 (Run 40, Clone 17, Gen 33)
[11:14:43] Folding@home Core Shutdown: EARLY_UNIT_END
[11:14:56] Project: 4616 (Run 25, Clone 21, Gen 47)
[11:15:02] Folding@home Core Shutdown: EARLY_UNIT_END
[01:47:25] Project: 4600 (Run 14, Clone 0, Gen 63)
[01:47:31] Folding@home Core Shutdown: EARLY_UNIT_END
[04:58:47] Project: 4602 (Run 2, Clone 34, Gen 32)
[04:58:53] Folding@home Core Shutdown: EARLY_UNIT_END
[08:09:31] Project: 4601 (Run 47, Clone 38, Gen 37)
[08:09:37] Folding@home Core Shutdown: EARLY_UNIT_END
[07:28:21] Project: 4616 (Run 8, Clone 29, Gen 36)
[07:28:27] Folding@home Core Shutdown: EARLY_UNIT_END
[16:12:41] Project: 4603 (Run 33, Clone 55, Gen 68)
[16:12:47] Folding@home Core Shutdown: EARLY_UNIT_END
[08:19:07] Project: 4604 (Run 26, Clone 21, Gen 97)
[08:19:13] Folding@home Core Shutdown: EARLY_UNIT_END
[08:19:25] Project: 4605 (Run 42, Clone 22, Gen 25)
[08:19:31] Folding@home Core Shutdown: EARLY_UNIT_END
[08:19:46] Project: 4606 (Run 23, Clone 23, Gen 68)
[08:19:52] Folding@home Core Shutdown: EARLY_UNIT_END
[06:13:26] Project: 4617 (Run 10, Clone 10, Gen 94)
[06:13:32] Folding@home Core Shutdown: EARLY_UNIT_END
[10:06:28] Project: 4601 (Run 11, Clone 29, Gen 56)
[10:06:34] Folding@home Core Shutdown: EARLY_UNIT_END
[03:25:12] Project: 4624 (Run 7, Clone 37, Gen 46)
[03:25:18] Folding@home Core Shutdown: EARLY_UNIT_END
[15:43:41] Project: 4624 (Run 33, Clone 51, Gen 40)
[15:43:47] Folding@home Core Shutdown: EARLY_UNIT_END
[04:12:02] Project: 4626 (Run 20, Clone 6, Gen 46)
[04:12:08] Folding@home Core Shutdown: EARLY_UNIT_END
[04:15:43] Project: 4602 (Run 23, Clone 30, Gen 95)
[04:15:49] Folding@home Core Shutdown: EARLY_UNIT_END
[10:15:40] Project: 4600 (Run 21, Clone 7, Gen 75)
[10:15:46] Folding@home Core Shutdown: EARLY_UNIT_END
[01:31:33] Project: 4615 (Run 1, Clone 31, Gen 51)
[01:31:39] Folding@home Core Shutdown: EARLY_UNIT_END
[01:31:50] Project: 4616 (Run 31, Clone 24, Gen 34)
[01:31:56] Folding@home Core Shutdown: EARLY_UNIT_END
[06:42:00] Project: 4612 (Run 22, Clone 71, Gen 53)
[06:42:06] Folding@home Core Shutdown: EARLY_UNIT_END
As you can see, sometime EUEs come in series.
I'm counting for science.
Points just make me sick.
