2669 (Run 9, Clone 86, Gen 83)
Grandpa_01
Post by Grandpa_01 »
I had a WU fail on me today it is the first 1 that has ever failed on that machine. It is running it again and perhaps it will complete it this time. But I was curious at to what would cause the CoreStatus = FF (255) error. I do not recall seeing this error before. The one thing that has changed on this machine is I upgraded from VM 2 to VM 3 today
[21:25:13] Completed 92500 out of 250000 steps  (37%)
[21:31:45] CoreStatus = FF (255)
[21:31:45] Client-core communications error: ERROR 0xff
[21:31:45] Deleting current work unit & continuing...
[21:31:59] - Preparing to get new work unit...
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Re: 2669 (Run 9, Clone 86, Gen 83)
How much memory did you allocate to your VM?
Grandpa_01
I had 1556mb allocated
Phantom
Post by Phantom »
This one failed for me, too, but before even 1% was completed... It was running on Mac Pro with dual C2D processors and 8GB of memory assigned.
(No special action was needed to clear the bad WU -- automatically reassigned a different WU after repeated failure threshold passed.)
