I got asked a question; don't know the answer to this one
noorman
Hardware configuration: Folders: Intel C2D E6550 @ 3.150 GHz + GPU XFX 9800GTX+ @ 765 MHZ w. WinXP-GPU
AMD A2X64 3800+ @ stock + GPU XFX 9800GTX+ @ 775 MHZ w. WinXP-GPU
Main rig: an old Athlon Barton 2500+ @2.25 GHz & 2* 512 MB RAM Apacer, Radeon 9800Pro, WinXP SP3+
Location: Belgium, near the International Sea-Port of Antwerp
Post by noorman »
so, I 'll have to ask it here:
a fellow Folder wanted a list of current projects uniquely for the UNIX client/systems, or a list which shows this information for all client types in which he can find the data he wants ...
A link to such a list/database would be fine !
thanks
- stopped Linux SMP w. HT on i7-860@3.5 GHz
Folded since 10-06-04 till 09-2010
Re: I got asked a question; don't know the answer to this one
I think such a list doesn't exist :(
You can only try to guess by crossing data frome Project Summary and Server Status ...
noorman
Post by noorman »
toTOW wrote:I think such a list doesn't exist :(
Then another question from me: are all SMP projects workable by all SMP type clients ?
The Mac and Linux SMP clients are basically the same. The Windows client is not quite the same, as indicated by no v6 SMP client for Windows. The server stats page has a column for "operating system" If you find the servers associated with SMP projects, most show W L and X (Windows Linux OSX) but not all.
There are also SMP projects restricted by the number of processors your system has. Note the SMP Cores column.
My estimate is that not all SMP projects are universal between the three SMP client types, but some are.
noorman
Post by noorman »
thanks 7im Image
passed that on ..
