--- Opening Log file [October 21 20:35:10 UTC]
http://folding.stanford.edu
Launch directory: C:\fah
Executable: fah
Arguments: -forcegpu ati_r700 -verbosity 9
[20:35:10] - Ask before connecting: No
[20:35:10] - User name: theteofscuba (Team 0)
[20:35:10] - User ID: 13DB32AC79686683
[20:35:10] - Machine ID: 2
[20:35:10]
[20:35:10] Loaded queue successfully.
[20:35:10] Deleting incompletely fetched item (4) from queue position #4
[20:35:10] - Warning: Could not delete all work unit files (4): Core file absent
[20:35:10] - Preparing to get new work unit...
[20:35:10] + Attempting to get work packet
[20:35:10] - Autosending finished units... [October 21 20:35:10 UTC]
[20:35:10] - Will indicate memory of 3325 MB
[20:35:10] Trying to send all finished work units
[20:35:10] - Detect CPU.[20:35:10] Project: 5733 (Run 0, Clone 75, Gen 354)
Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6
[20:35:10] - Connecting to assignment server
[20:35:10] Connecting to http://assign-GPU.stanford.edu:8080/
[20:35:10] + Attempting to send results [October 21 20:35:10 UTC]
[20:35:10] - Reading file work/wuresults_03.dat from core
[20:35:10] (Read 252568 bytes from disk)
[20:35:10] Connecting to http://171.64.65.102:8080/
[20:35:11] Posted data.
[20:35:11] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:35:11] + Couldn't get work instructions.
[20:35:11] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[20:35:11] - Couldn't send HTTP request to server
[20:35:11] + Could not connect to Work Server (results)
[20:35:11] (171.64.65.102:8080)
[20:35:11] + Retrying using alternative port
[20:35:11] Connecting to http://171.64.65.102:80/
[20:35:13] - Couldn't send HTTP request to server
[20:35:13] + Could not connect to Work Server (results)
[20:35:13] (171.64.65.102:80)
[20:35:13] - Error: Could not transmit unit 03 (completed October 21) to work server.
[20:35:13] - 12 failed uploads of this unit.
[20:35:13] + Attempting to send results [October 21 20:35:13 UTC]
[20:35:13] - Reading file work/wuresults_03.dat from core
[20:35:13] (Read 252568 bytes from disk)
[20:35:13] Connecting to http://171.67.108.17:8080/
[20:35:13] (Got status 503)
[20:35:13] (171.67.108.17:8080)
[20:35:13] + Retrying using alternative port
[20:35:13] Connecting to http://171.67.108.17:80/
[20:35:13] (171.67.108.17:80)
[20:35:13] Could not transmit unit 03 to Collection server; keeping in queue.
[20:35:13] + Sent 0 of 1 completed units to the server
[20:35:13] - Autosend completed
[20:35:29] + Attempting to get work packet
[20:35:29] - Will indicate memory of 3325 MB
[20:35:29] - Connecting to assignment server
[20:35:29] Connecting to http://assign-GPU.stanford.edu:8080/
[20:35:29] Posted data.
[20:35:29] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:35:29] + Couldn't get work instructions.
[20:35:29] - Attempt #2 to get work failed, and no other work to do.
[20:35:51] + Attempting to get work packet
[20:35:51] - Will indicate memory of 3325 MB
[20:35:51] - Connecting to assignment server
[20:35:51] Connecting to http://assign-GPU.stanford.edu:8080/
[20:35:51] Posted data.
[20:35:51] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:35:51] + Couldn't get work instructions.
[20:35:51] - Attempt #3 to get work failed, and no other work to do.
[20:36:14] + Attempting to get work packet
[20:36:14] - Will indicate memory of 3325 MB
[20:36:14] - Connecting to assignment server
[20:36:14] Connecting to http://assign-GPU.stanford.edu:8080/
[20:36:14] Posted data.
[20:36:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:36:14] + Couldn't get work instructions.
[20:36:14] - Attempt #4 to get work failed, and no other work to do.
[20:37:07] + Attempting to get work packet
[20:37:07] - Will indicate memory of 3325 MB
[20:37:07] - Connecting to assignment server
[20:37:07] Connecting to http://assign-GPU.stanford.edu:8080/
[20:37:08] Posted data.
[20:37:08] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:37:08] + Couldn't get work instructions.
[20:37:08] - Attempt #5 to get work failed, and no other work to do.
[20:38:42] + Attempting to get work packet
[20:38:42] - Will indicate memory of 3325 MB
[20:38:42] - Connecting to assignment server
[20:38:42] Connecting to http://assign-GPU.stanford.edu:8080/
[20:38:43] Posted data.
[20:38:43] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:38:43] + Couldn't get work instructions.
[20:38:43] - Attempt #6 to get work failed, and no other work to do.
[20:40:54] ***** Got a SIGTERM signal (2)
[20:40:54] Killing all core threads
Folding@Home Client Shutdown.
