Project: 5790 (Run 5, Clone 431, Gen 0)CoreStatus = 75 (117)
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Post by Leoslocks »
Is there a listing for what the Core Status means?
[15:42:27] Project: 5790 (Run 5, Clone 431, Gen 0)
[15:42:27]
[15:42:27] Assembly optimizations on if available.
[15:42:27] Entering M.D.
[15:42:34] Working on Protein
[15:42:36] Client config found, loading data.
[15:42:36] Starting GUI Server
[15:42:36] Successful run
[15:42:36] DynamicWrapper: Finished Work Unit: sleep=10000
[15:42:46] Reserved 0 bytes for xtc file; Cosm status=-2
[15:42:46] Allocated 0 bytes for xtc file
[15:42:46] - Reading up to 0 from "work/wudata_03.xtc": Could not open file
[15:42:46] Error opening or reading xtcfile -- exiting.
[15:42:46] GuardedRun: run failure in DynamicWrapper
[15:42:46] Run: GuardedRun completed.
[15:42:47] y Shutting down core workthread not completede
[15:42:47] - Shutting down core
[15:42:47]
[15:42:47] Folding@home Core Shutdown: FILE_IO_ERROR
[15:42:49] CoreStatus = 75 (117)
[15:42:49] Error opening or reading from a file.
[15:42:49] Deleting current work unit & continuing...
[15:42:54] - Preparing to get new work unit...
[15:42:54] + Attempting to get work packet
[15:42:54] - Connecting to assignment server
[15:42:54] - Successful: assigned to (171.64.65.106).
[15:42:54] + News From Folding@Home: Welcome to Folding@Home
[15:42:54] Loaded queue successfully.
[15:42:55] + Closed connections
[15:43:00]
[15:43:00] + Processing work unit
[15:43:00] Core required: FahCore_11.exe
[15:43:00] Core found.
[15:43:00] Working on queue slot 04 [October 20 15:43:00 UTC]
[15:43:00] + Working ...
[15:43:00]
[15:43:00] *------------------------------*
[15:43:00] Folding@Home GPU Core - Beta
[15:43:00] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:43:00]
[15:43:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:43:00] Build host: amoeba
[15:43:00] Board Type: Nvidia
[15:43:00] Core      :
[15:43:00] Preparing to commence simulation
[15:43:00] - Looking at optimizations...
[15:43:00] - Created dyn
[15:43:00] - Files status OK
[15:43:00] - Expanded 60055 -> 346568 (decompressed 577.0 percent)
[15:43:00] Called DecompressByteArray: compressed_data_size=60055 data_size=346568, decompressed_data_size=346568 diff=0
[15:43:00] - Digital signature verified
[15:43:00]
[15:43:00] Project: 5790 (Run 5, Clone 431, Gen 0)
[15:43:00]
[15:43:00] Assembly optimizations on if available.
[15:43:00] Entering M.D.
[15:43:07] Working on Protein
[15:43:09] Client config found, loading data.
[15:43:09] Starting GUI Server
[15:43:09] Successful run
[15:43:09] DynamicWrapper: Finished Work Unit: sleep=10000
[15:43:19] Reserved 0 bytes for xtc file; Cosm status=-2
[15:43:19] Allocated 0 bytes for xtc file
[15:43:19] - Reading up to 0 from "work/wudata_04.xtc": Could not open file
[15:43:19] Error opening or reading xtcfile -- exiting.
[15:43:19] GuardedRun: run failure in DynamicWrapper
[15:43:19] Run: GuardedRun completed.
[15:43:20] y Shutting down core workthread not completede
[15:43:20] - Shutting down core
[15:43:20]
[15:43:20] Folding@home Core Shutdown: FILE_IO_ERROR
[15:43:22] CoreStatus = 75 (117)
[15:43:22] Error opening or reading from a file.
[15:43:22] Deleting current work unit & continuing...
[15:43:26] - Preparing to get new work unit...
[15:43:26] + Attempting to get work packet
[15:43:26] - Connecting to assignment server
[15:43:27] - Successful: assigned to (171.64.65.106).
[15:43:27] + News From Folding@Home: Welcome to Folding@Home
[15:43:27] Loaded queue successfully.
[15:43:28] + Closed connections
[15:43:33]
[15:43:33] + Processing work unit
[15:43:33] Core required: FahCore_11.exe
[15:43:33] Core found.
[15:43:33] Working on queue slot 05 [October 20 15:43:33 UTC]
[15:43:33] + Working ...
[15:43:33]
[15:43:33] *------------------------------*
[15:43:33] Folding@Home GPU Core - Beta
[15:43:33] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:43:33]
[15:43:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:43:33] Build host: amoeba
[15:43:33] Board Type: Nvidia
[15:43:33] Core      :
[15:43:33] Preparing to commence simulation
[15:43:33] - Looking at optimizations...
[15:43:33] - Created dyn
[15:43:33] - Files status OK
[15:43:33] - Expanded 60055 -> 346568 (decompressed 577.0 percent)
[15:43:33] Called DecompressByteArray: compressed_data_size=60055 data_size=346568, decompressed_data_size=346568 diff=0
[15:43:33] - Digital signature verified
[15:43:33]
[15:43:33] Project: 5790 (Run 5, Clone 431, Gen 0)
[15:43:33]
[15:43:33] Assembly optimizations on if available.
[15:43:33] Entering M.D.
[15:43:40] Working on Protein
[15:43:42] Client config found, loading data.
[15:43:42] Starting GUI Server
[15:43:42] Successful run
[15:43:42] DynamicWrapper: Finished Work Unit: sleep=10000
[15:43:53] Reserved 0 bytes for xtc file; Cosm status=-2
[15:43:53] Allocated 0 bytes for xtc file
[15:43:53] - Reading up to 0 from "work/wudata_05.xtc": Could not open file
[15:43:53] Error opening or reading xtcfile -- exiting.
[15:43:53] GuardedRun: run failure in DynamicWrapper
[15:43:53] Run: GuardedRun completed.
[15:43:53] y Shutting down core workthread not completede
[15:43:53] - Shutting down core
[15:43:53]
[15:43:53] Folding@home Core Shutdown: FILE_IO_ERROR
[15:43:55] CoreStatus = 75 (117)
[15:43:55] Error opening or reading from a file.
[15:43:55] Deleting current work unit & continuing...
[15:43:59] - Preparing to get new work unit...
[15:43:59] + Attempting to get work packet
[15:43:59] - Connecting to assignment server
[15:44:00] - Successful: assigned to (171.64.65.106).
[15:44:00] + News From Folding@Home: Welcome to Folding@Home
[15:44:00] Loaded queue successfully.
[15:44:01] + Closed connections
[15:44:06]
[15:44:06] + Processing work unit
[15:44:06] Core required: FahCore_11.exe
[15:44:06] Core found.
[15:44:06] Working on queue slot 06 [October 20 15:44:06 UTC]
[15:44:06] + Working ...
[15:44:06]
[15:44:06] *------------------------------*
[15:44:06] Folding@Home GPU Core - Beta
[15:44:06] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:44:06]
[15:44:06] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:44:06] Build host: amoeba
[15:44:06] Board Type: Nvidia
[15:44:06] Core      :
[15:44:06] Preparing to commence simulation
[15:44:06] - Looking at optimizations...
[15:44:06] - Created dyn
[15:44:06] - Files status OK
[15:44:06] - Expanded 60055 -> 346568 (decompressed 577.0 percent)
[15:44:06] Called DecompressByteArray: compressed_data_size=60055 data_size=346568, decompressed_data_size=346568 diff=0
[15:44:06] - Digital signature verified
[15:44:06]
[15:44:06] Project: 5790 (Run 5, Clone 431, Gen 0)
[15:44:06]
[15:44:06] Assembly optimizations on if available.
[15:44:06] Entering M.D.
[15:44:13] Working on Protein
[15:44:15] Client config found, loading data.
[15:44:15] Starting GUI Server
[15:44:15] Successful run
[15:44:15] DynamicWrapper: Finished Work Unit: sleep=10000
[15:44:25] Reserved 0 bytes for xtc file; Cosm status=-2
[15:44:25] Allocated 0 bytes for xtc file
[15:44:25] - Reading up to 0 from "work/wudata_06.xtc": Could not open file
[15:44:25] Error opening or reading xtcfile -- exiting.
[15:44:25] GuardedRun: run failure in DynamicWrapper
[15:44:25] Run: GuardedRun completed.
[15:44:26] y Shutting down core workthread not completede
[15:44:26] - Shutting down core
[15:44:26]
[15:44:26] Folding@home Core Shutdown: FILE_IO_ERROR
[15:44:28] CoreStatus = 75 (117)
[15:44:28] Error opening or reading from a file.
[15:44:28] Deleting current work unit & continuing...
[15:44:32] - Preparing to get new work unit...
[15:44:32] + Attempting to get work packet
[15:44:32] - Connecting to assignment server
[15:44:36] - Successful: assigned to (171.64.65.106).
[15:44:36] + News From Folding@Home: Welcome to Folding@Home
[15:44:36] Loaded queue successfully.
[15:44:37] + Closed connections
[15:44:42]
[15:44:42] + Processing work unit
[15:44:42] Core required: FahCore_11.exe
[15:44:42] Core found.
[15:44:42] Working on queue slot 07 [October 20 15:44:42 UTC]
[15:44:42] + Working ...
[15:44:42]
[15:44:42] *------------------------------*
[15:44:42] Folding@Home GPU Core - Beta
[15:44:42] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:44:42]
[15:44:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:44:42] Build host: amoeba
[15:44:42] Board Type: Nvidia
[15:44:42] Core      :
[15:44:42] Preparing to commence simulation
[15:44:42] - Looking at optimizations...
[15:44:42] - Created dyn
[15:44:42] - Files status OK
[15:44:42] - Expanded 60055 -> 346568 (decompressed 577.0 percent)
[15:44:42] Called DecompressByteArray: compressed_data_size=60055 data_size=346568, decompressed_data_size=346568 diff=0
[15:44:42] - Digital signature verified
[15:44:42]
[15:44:42] Project: 5790 (Run 5, Clone 431, Gen 0)
[15:44:42]
[15:44:42] Assembly optimizations on if available.
[15:44:42] Entering M.D.
[15:44:49] Working on Protein
[15:44:51] Client config found, loading data.
[15:44:51] Starting GUI Server
[15:44:51] Successful run
[15:44:51] DynamicWrapper: Finished Work Unit: sleep=10000
[15:45:01] Reserved 0 bytes for xtc file; Cosm status=-2
[15:45:01] Allocated 0 bytes for xtc file
[15:45:01] - Reading up to 0 from "work/wudata_07.xtc": Could not open file
[15:45:01] Error opening or reading xtcfile -- exiting.
[15:45:01] GuardedRun: run failure in DynamicWrapper
[15:45:01] Run: GuardedRun completed.
[15:45:02] y Shutting down core workthread not completede
[15:45:02] - Shutting down core
[15:45:02]
[15:45:02] Folding@home Core Shutdown: FILE_IO_ERROR
[15:45:04] CoreStatus = 75 (117)
[15:45:04] Error opening or reading from a file.
[15:45:04] Deleting current work unit & continuing...
Re: Project: 5790 (Run 5, Clone 431, Gen 0)CoreStatus = 75 (117)
http://fahwiki.net/index.php/CoreStatus_codes#75
Typically a problem with access to the work files ...
Leoslocks
Post by Leoslocks »
I tried searching for the Core Status page without out success. Thanks for posting the link, bookmarked for future reference.
Strange error this is. I do not understand this part;
frag85
Post by frag85 »
same here. i keep getting it over and over:
[23:49:46] Project: 5772 (Run 14, Clone 13, Gen 746)
[23:49:46]
[23:49:46] Assembly optimizations on if available.
[23:49:46] Entering M.D.
[23:49:52] mdrun_gpu returned
[23:49:52] Going to send back what have done -- stepsTotalG=0
[23:49:52] Work fraction=0.0000 steps=0.
[23:49:56] logfile size=0 infoLength=0 edr=0 trr=25
[23:49:56] - Writing 637 bytes of core data to disk...
[23:49:56] Done: 125 -> 124 (compressed to 99.2 percent)
[23:49:56]   ... Done.
[23:49:56]
[23:49:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:49:58] CoreStatus = 7A (122)
[23:49:58] Sending work to server
[23:49:58] Project: 5772 (Run 14, Clone 13, Gen 746)
[23:49:58] - Read packet limit of 540015616... Set to 524286976.
[23:51:13] Project: 5772 (Run 14, Clone 125, Gen 1424)
[23:51:13]
[23:51:14] Assembly optimizations on if available.
[23:51:14] Entering M.D.
[23:51:20] mdrun_gpu returned
[23:51:20] Going to send back what have done -- stepsTotalG=0
[23:51:20] Work fraction=0.0000 steps=0.
[23:51:24] logfile size=0 infoLength=0 edr=0 trr=25
[23:51:24] - Writing 637 bytes of core data to disk...
[23:51:24] Done: 125 -> 124 (compressed to 99.2 percent)
[23:51:24]   ... Done.
[23:51:24]
[23:51:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:51:28] CoreStatus = 7A (122)
[23:51:28] Sending work to server
[23:51:28] Project: 5772 (Run 14, Clone 125, Gen 1424)
[23:51:28] - Read packet limit of 540015616... Set to 524286976.
[23:51:28] + Attempting to send results [November 21 23:51:28 UTC]
[23:51:28] + Results successfully sent
[23:51:28] Thank you for your contribution to Folding@Home.
[23:51:33] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
[23:54:50] Project: 5772 (Run 14, Clone 88, Gen 577)
[23:54:50]
[23:54:50] Assembly optimizations on if available.
[23:54:50] Entering M.D.
[23:54:56] mdrun_gpu returned
[23:54:56] Going to send back what have done -- stepsTotalG=0
[23:54:56] Work fraction=0.0000 steps=0.
[23:55:00] logfile size=0 infoLength=0 edr=0 trr=25
[23:55:00] - Writing 637 bytes of core data to disk...
[23:55:00] Done: 125 -> 124 (compressed to 99.2 percent)
[23:55:00]   ... Done.
[23:55:00]
[23:55:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:55:02] CoreStatus = 7A (122)
[23:55:02] Sending work to server
[23:55:02] Project: 5772 (Run 14, Clone 88, Gen 577)
[23:55:02] - Read packet limit of 540015616... Set to 524286976.
[23:55:02] + Attempting to send results [November 21 23:55:02 UTC]
[23:55:04] + Results successfully sent
[23:55:04] Thank you for your contribution to Folding@Home.
[23:59:01] Project: 5772 (Run 5, Clone 180, Gen 695)
[23:59:01]
[23:59:01] Assembly optimizations on if available.
[23:59:01] Entering M.D.
[23:59:07] mdrun_gpu returned
[23:59:07] Going to send back what have done -- stepsTotalG=0
[23:59:07] Work fraction=0.0000 steps=0.
[23:59:11] logfile size=0 infoLength=0 edr=0 trr=25
[23:59:11] - Writing 637 bytes of core data to disk...
[23:59:11] Done: 125 -> 123 (compressed to 98.4 percent)
[23:59:11]   ... Done.
[23:59:11]
[23:59:11] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:59:15] CoreStatus = 7A (122)
[23:59:15] Sending work to server
[23:59:15] Project: 5772 (Run 5, Clone 180, Gen 695)
[23:59:15] - Read packet limit of 540015616... Set to 524286976.
[23:59:15] + Attempting to send results [November 21 23:59:15 UTC]
[23:59:15] + Results successfully sent
[23:59:15] Thank you for your contribution to Folding@Home.
EDIT: was looking through the FAHlog-Prev.txt and found that it has completed a 5772:
[13:43:48] Project: 5772 (Run 7, Clone 312, Gen 446)
[13:43:48]
[13:43:48] Assembly optimizations on if available.
[13:43:48] Entering M.D.
[13:43:55] Working on Protein
[13:43:56] Client config found, loading data.
[13:43:56] Starting GUI Server
[13:44:34] Completed 1%
[13:45:20] Completed 2%
[13:46:06] Completed 3%
[13:46:54] Completed 4%
[13:47:41] Completed 5%
[13:48:30] Completed 6%
[13:49:19] Completed 7%
[13:50:06] Completed 8%
[13:50:53] Completed 9%
[13:51:35] Completed 10%
[13:52:20] Completed 11%
[13:53:07] Completed 12%
[13:53:55] Completed 13%
[13:54:41] Completed 14%
[13:55:29] Completed 15%
[13:56:16] Completed 16%
[13:57:04] Completed 17%
[13:57:51] Completed 18%
[13:58:36] Completed 19%
[13:59:19] Completed 20%
[14:00:01] Completed 21%
[14:00:47] Completed 22%
[14:01:34] Completed 23%
[14:02:22] Completed 24%
[14:03:10] Completed 25%
[14:03:59] Completed 26%
[14:04:47] Completed 27%
[14:05:35] Completed 28%
[14:06:21] Completed 29%
[14:07:09] Completed 30%
[14:07:57] Completed 31%
[14:08:44] Completed 32%
[14:09:31] Completed 33%
[14:10:20] Completed 34%
[14:11:07] Completed 35%
[14:11:52] Completed 36%
[14:12:39] Completed 37%
[14:13:26] Completed 38%
[14:14:06] Completed 39%
[14:14:49] Completed 40%
[14:15:33] Completed 41%
[14:16:17] Completed 42%
[14:17:08] Completed 43%
[14:17:51] Completed 44%
[14:18:28] Completed 45%
[14:19:09] Completed 46%
[14:19:55] Completed 47%
[14:20:41] Completed 48%
[14:21:28] Completed 49%
[14:22:18] Completed 50%
[14:23:05] Completed 51%
[14:23:47] Completed 52%
[14:24:38] Completed 53%
[14:25:35] Completed 54%
[14:26:14] Completed 55%
[14:26:55] Completed 56%
[14:27:37] Completed 57%
[14:28:18] Completed 58%
[14:29:01] Completed 59%
[14:29:42] Completed 60%
[14:30:25] Completed 61%
[14:31:07] Completed 62%
[14:31:49] Completed 63%
[14:32:33] Completed 64%
[14:33:15] Completed 65%
[14:33:59] Completed 66%
[14:34:42] Completed 67%
[14:35:25] Completed 68%
[14:36:10] Completed 69%
[14:36:49] Completed 70%
[14:37:29] Completed 71%
[14:38:10] Completed 72%
[14:38:23] + Paused
[14:50:25] + Working ...
[14:50:25] Suspending work thread...
[14:50:25] Resuming work thread...
[14:50:53] Completed 73%
[14:51:37] Completed 74%
[14:52:21] Completed 75%
[14:53:06] Completed 76%
[14:53:50] Completed 77%
[14:54:32] Completed 78%
[14:55:14] Completed 79%
[14:55:57] Completed 80%
[14:56:41] Completed 81%
[14:57:24] Completed 82%
[14:58:06] Completed 83%
[14:58:46] Completed 84%
[14:59:29] Completed 85%
[15:00:12] Completed 86%
[15:00:54] Completed 87%
[15:01:36] Completed 88%
[15:02:19] Completed 89%
[15:03:01] Completed 90%
[15:03:04] + Paused
[15:17:36] + Working ...
[15:17:36] Suspending work thread...
[15:17:36] Timer requesting checkpoint
[15:17:36] Resuming work thread...
[15:18:08] Completed 91%
[15:18:43] Completed 92%
[15:19:17] Completed 93%
[15:19:52] Completed 94%
[15:20:26] Completed 95%
[15:21:02] Completed 96%
[15:21:37] Completed 97%
[15:22:11] Completed 98%
[15:22:44] Completed 99%
[15:23:17] Completed 100%
[15:23:17] Successful run
[15:23:17] DynamicWrapper: Finished Work Unit: sleep=10000
[15:23:27] Reserved 76140 bytes for xtc file; Cosm status=0
[15:23:27] Allocated 76140 bytes for xtc file
[15:23:27] - Reading up to 76140 from "work/wudata_09.xtc": Read 76140
[15:23:27] Read 76140 bytes from xtc file; available packet space=786354324
[15:23:27] xtc file hash check passed.
[15:23:27] Reserved 15168 15168 786354324 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[15:23:27] Allocated 15168 bytes for arc file
[15:23:27] - Reading up to 15168 from "work/wudata_09.trr": Read 15168
[15:23:27] Read 15168 bytes from arc file; available packet space=786339156
[15:23:27] trr file hash check passed.
[15:23:27] Allocated 560 bytes for edr file
[15:23:27] Read bedfile
[15:23:27] edr file hash check passed.
[15:23:27] Allocated 0 bytes for logfile
[15:23:27] Could not open/read logfile=<work/wudata_09.log>; Cosm status=-1
[15:23:27] GuardedRun: success in DynamicWrapper
[15:23:27] GuardedRun: done
[15:23:27] Run: GuardedRun completed.
[15:23:32] - Writing 92380 bytes of core data to disk...
[15:23:32] Done: 91868 -> 90569 (compressed to 98.5 percent)
[15:23:32]   ... Done.
[15:23:32] - Shutting down core
[15:23:32]
[15:23:32] Folding@home Core Shutdown: FINISHED_UNIT
[15:23:35] CoreStatus = 64 (100)
[15:23:35] Sending work to server
[15:23:35] Project: 5772 (Run 7, Clone 312, Gen 446)
[15:23:35] - Read packet limit of 540015616... Set to 524286976.
[15:23:35] + Attempting to send results [November 20 15:23:35 UTC]
[15:23:36] + Results successfully sent
[15:23:36] Thank you for your contribution to Folding@Home.
[15:23:36] + Number of Units Completed: 151
frag85 wrote:same here. i keep getting it over and over:
No, that's not the same WU over and over. That is four different WUs, none of which are the Project: 5790 (Run 5, Clone 431, Gen 0) which is mentioned in the title of this topic. Check your hardware carefully because it appears to be truly unstable.
