171.67.108.201 assign-gpu.stanford.edu
Galahad
Hardware configuration: Intel Core i7-920 @3350MHz
Foxconn Renaissance
3x2048 Samsung M378B5673FH0-CH9 @9-9-9-19
Gainward GTX470 1280M GDDR5 320B (was 1024MB DDR3 Gigabyte GV-N250OC-1GI)
E-MU 1212M
St-Lab A-400 PCI-E SATA RAID
TP-LINK TG-3468 Gigabit NIC
2xSamsung HD752LJ (RAID0)
HL-DT-ST DVDRAM GSA-H42N ATA
Thermaltake ToughPower 600W <W0103RE>
Windows 7 Ultimate x64
Post by Galahad »
[12:41:04] - Connecting to assignment server
[12:41:04] Connecting to http://assign-GPU.stanford.edu:8080/
[12:41:05] - Couldn't send HTTP request to server
[12:41:05]   (Got status 502)
[12:41:05] + Could not connect to Assignment Server
[12:41:05] Connecting to http://assign-GPU.stanford.edu:80/
[12:41:05] + Could not connect to Assignment Server 2
[12:41:05] + Couldn't get work instructions.
[12:41:05] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
I know the pieces fit
Re: 171.67.108.201 assign-gpu.stanford.edu
502 Bad Gateway ou Proxy Error
P.S : I get an OK from this server ... the problem is on your end or with your ISP ...
chillerworks.com
Post by chillerworks.com »
..and no other work to do.
[20:39:32] - Connecting to assignment server
[20:39:32] Connecting to http://assign-GPU.stanford.edu:8080/
[20:39:34] Posted data.
[20:39:34] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:39:34] + Couldn't get work instructions.
[20:39:34] - Attempt #1  to get work failed, and no other work to do.
[20:39:46] + Attempting to get work packet
[20:39:46] - Will indicate memory of 3899 MB
[20:39:46] - Connecting to assignment server
[20:39:46] Connecting to http://assign-GPU.stanford.edu:8080/
[20:39:48] Posted data.
[20:39:48] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:39:48] + Couldn't get work instructions.
[20:39:48] - Attempt #2  to get work failed, and no other work to do.
[20:40:08] + Attempting to get work packet
[20:40:08] - Will indicate memory of 3899 MB
[20:40:08] - Connecting to assignment server
[20:40:08] Connecting to http://assign-GPU.stanford.edu:8080/
[20:40:10] Posted data.
[20:40:10] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:40:10] + Couldn't get work instructions.
[20:40:10] - Attempt #3  to get work failed, and no other work to do.
[20:40:42] + Attempting to get work packet
[20:40:42] - Will indicate memory of 3899 MB
[20:40:42] - Connecting to assignment server
[20:40:42] Connecting to http://assign-GPU.stanford.edu:8080/
[20:40:46] Posted data.
[20:40:46] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:40:46] + Couldn't get work instructions.
[20:40:46] - Attempt #4  to get work failed, and no other work to do.
[20:41:37] + Attempting to get work packet
[20:41:37] - Will indicate memory of 3899 MB
[20:41:37] - Connecting to assignment server
[20:41:37] Connecting to http://assign-GPU.stanford.edu:8080/
[20:41:39] Posted data.
[20:41:39] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:41:39] + Couldn't get work instructions.
[20:41:39] - Attempt #5  to get work failed, and no other work to do.
[20:43:14] + Attempting to get work packet
[20:43:14] - Will indicate memory of 3899 MB
[20:43:14] - Connecting to assignment server
[20:43:14] Connecting to http://assign-GPU.stanford.edu:8080/
[20:43:32] - Couldn't send HTTP request to server
[20:43:32] + Could not connect to Assignment Server
[20:43:32] Connecting to http://assign-GPU.stanford.edu:80/
[20:43:33] Posted data.
[20:43:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:43:33] + Couldn't get work instructions.
[20:43:33] - Attempt #6  to get work failed, and no other work to do.
[20:46:27] + Attempting to get work packet
[20:46:27] - Will indicate memory of 3899 MB
[20:46:27] - Connecting to assignment server
[20:46:27] Connecting to http://assign-GPU.stanford.edu:8080/
[20:46:30] Posted data.
[20:46:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:46:30] + Couldn't get work instructions.
[20:46:30] - Attempt #7  to get work failed, and no other work to do.
chillerworks.com
Same situation once again. No available WUs from assign-gpu.stanford.edu. Would you fix the problem?
                          http://folding.stanford.edu
Launch directory: Z:\home\mateusz\gpu
Executable: Folding@home-Win32-GPU.exe
Arguments: -forcegpu nvidia_80 -verbosity 9
[18:30:20] - Ask before connecting: No
[18:30:20] - User name: chillerworks.com (Team 276)
[18:30:20] - User ID: 62E6AE0C1522C2
[18:30:20] - Machine ID: 2
[18:30:20]
[18:30:20] Loaded queue successfully.
[18:30:20] - Autosending finished units... [November 18 18:30:20 UTC]
[18:30:20] Trying to send all finished work units
[18:30:20] + No unsent completed units remaining.
[18:30:20] - Autosend completed
[18:30:20] - Preparing to get new work unit...
[18:30:20] + Attempting to get work packet
[18:30:20] - Will indicate memory of 3899 MB
[18:30:20] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 7
[18:30:20] - Connecting to assignment server
[18:30:20] Connecting to http://assign-GPU.stanford.edu:8080/
[18:30:21] Posted data.
[18:30:21] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:30:21] + Couldn't get work instructions.
[18:30:21] - Attempt #1  to get work failed, and no other work to do.
[18:30:27] + Attempting to get work packet
[18:30:27] - Will indicate memory of 3899 MB
[18:30:27] - Connecting to assignment server
[18:30:27] Connecting to http://assign-GPU.stanford.edu:8080/
[18:30:28] Posted data.
[18:30:28] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:30:28] + Couldn't get work instructions.
[18:30:28] - Attempt #2  to get work failed, and no other work to do.
[18:30:42] + Attempting to get work packet
[18:30:42] - Will indicate memory of 3899 MB
[18:30:42] - Connecting to assignment server
[18:30:42] Connecting to http://assign-GPU.stanford.edu:8080/
[18:30:42] Posted data.
[18:30:42] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:30:42] + Couldn't get work instructions.
[18:30:42] - Attempt #3  to get work failed, and no other work to do.
[18:31:16] + Attempting to get work packet
[18:31:16] - Will indicate memory of 3899 MB
[18:31:16] - Connecting to assignment server
[18:31:16] Connecting to http://assign-GPU.stanford.edu:8080/
[18:31:17] Posted data.
[18:31:17] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:31:17] + Couldn't get work instructions.
[18:31:17] - Attempt #4  to get work failed, and no other work to do.
[18:32:08] + Attempting to get work packet
[18:32:08] - Will indicate memory of 3899 MB
[18:32:08] - Connecting to assignment server
[18:32:08] Connecting to http://assign-GPU.stanford.edu:8080/
[18:32:09] Posted data.
[18:32:09] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:32:09] + Couldn't get work instructions.
[18:32:09] - Attempt #5  to get work failed, and no other work to do.
All GPU servers seem to be working fine ... do you have an ATI or a NV GPU ?
chillerworks.com
I have a NV GTX275 working under Wine. Everything was ok until yesterday.
