Project: 2665 (Run 2, Clone 913, Gen 131)
Mactin
Post by Mactin »
Could a MOD please check : Project: 2665 (Run 2, Clone 913, Gen 131).
Eleven other WUs have completed sinse this one, and still it has not been credited.
Log file:
[16:21:17] Working on queue slot 07 [October 15 16:21:17 UTC]
[16:21:17] + Working ...
[16:21:17] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 10 -forceasm -verbose -lifeline 5200 -version 624'
[16:21:17]
[16:21:17] *------------------------------*
[16:21:17] Folding@Home Gromacs SMP Core
[16:21:17] Version 1.74 (March 10, 2007)
[16:21:17]
[16:21:17] Preparing to commence simulation
[16:21:17] - Ensuring status. Please wait.
[16:21:34] - Assembly optimizations manually forced on.
[16:21:34] - Not checking prior termination.
[16:21:49] - Expanded 4828834 -> 24810145 (decompressed 513.7 percent)
[16:21:50] - Starting from initial work packet
[16:21:50]
[16:21:50] Project: 2665 (Run 2, Clone 913, Gen 131)
[16:21:50]
[16:21:52] Assembly optimizations on if available.
[16:21:52] Entering M.D.
[16:22:03] Rejecting checkpoint
[16:22:05] cosylations
[16:22:05] Writing local files
[16:22:06]
[16:22:06] Writing local files
[16:22:17] Extra SSE boost OK.
[16:22:18] Writing local files
[16:22:18] Completed 0 out of 250000 steps  (0 percent)
[16:32:18] Timered checkpoint triggered.
[16:42:19] Timered checkpoint triggered.
[16:47:04] Writing local files
[16:47:04] Completed 2500 out of 250000 steps  (1 percent)
[13:28:09] Completed 247500 out of 250000 steps  (99 percent)
[13:38:09] Timered checkpoint triggered.
[13:48:09] Timered checkpoint triggered.
[13:56:23] Writing local files
[13:56:23] Completed 250000 out of 250000 steps  (100 percent)
[13:56:24] Writing final coordinates.
[13:56:25] Past main M.D. loop
[13:56:26] Will end MPI now
[13:57:26]
[13:57:26] Finished Work Unit:
[13:57:26] - Reading up to 21421872 from "work/wudata_07.arc": Read 21421872
[13:57:26] - Reading up to 594636 from "work/wudata_07.xtc": Read 594636
[13:57:26] goefile size: 0
[13:57:26] logfile size: 221527
[13:57:26] Leaving Run
[13:57:28] - Writing 22244407 bytes of core data to disk...
[13:57:28]   ... Done.
[13:57:28] - Failed to delete work/wudata_07.sas
[13:57:28] - Failed to delete work/wudata_07.goe
[13:57:28] Warning:  check for stray files
[13:57:28] - Shutting down core
[13:59:28]
[13:59:28] Folding@home Core Shutdown: FINISHED_UNIT
[13:59:28]
[13:59:33] CoreStatus = 64 (100)
[13:59:33] Unit 7 finished with 68 percent of time to deadline remaining.
[13:59:33] Updated performance fraction: 0.710521
[13:59:33] Sending work to server
[13:59:33] Project: 2665 (Run 2, Clone 913, Gen 131)
[13:59:33] + Attempting to send results [October 17 13:59:33 UTC]
[13:59:33] - Reading file work/wuresults_07.dat from core
[13:59:33]   (Read 22244407 bytes from disk)
[13:59:33] Connecting to http://171.64.65.64:8080/
[14:03:25] Posted data.
[14:03:25] Initial: 0000; - Uploaded at ~93 kB/s
[14:03:25] - Averaged speed for that direction ~90 kB/s
[14:03:25] + Results successfully sent
[14:03:25] Thank you for your contribution to Folding@Home.
[14:03:25] + Number of Units Completed: 54
[14:03:30] - Warning: Could not delete all work unit files (7): Core returned invalid code
[14:03:30] Trying to send all finished work units
[14:03:30] + No unsent completed units remaining.
[14:03:30] - Preparing to get new work unit...
[14:03:30] Cleaning up work directory
[14:03:30] + Attempting to get work packet
[14:03:30] - Will indicate memory of 1999 MB
[14:03:30] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 7
[14:03:30] - Connecting to assignment server
[14:03:30] Connecting to http://assign.stanford.edu:8080/
[14:03:30] Posted data.
[14:03:30] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[14:03:30] + News From Folding@Home: Welcome to Folding@Home
[14:03:30] Loaded queue successfully.
[14:03:30] Connecting to http://171.64.65.64:8080/
[14:03:35] Posted data.
[14:03:35] Initial: 0000; - Receiving payload (expected size: 4731616)
[14:03:43] - Downloaded at ~577 kB/s
[14:03:43] - Averaged speed for that direction ~499 kB/s
[14:03:43] + Received work.
[14:03:43] Trying to send all finished work units
[14:03:43] + No unsent completed units remaining.
[14:03:43] + Closed connections
[14:03:43]
[14:03:43] + Processing work unit
[14:03:43] Work type a1 not eligible for variable processors
[14:03:43] Core required: FahCore_a1.exe
[14:03:43] Core found.
[14:03:43] Using generic mpiexec calls
[14:03:43] Working on queue slot 08 [October 17 14:03:43 UTC]
[14:03:43] + Working ...
[14:03:43] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 08 -checkpoint 10 -forceasm -verbose -lifeline 5316 -version 624'
[14:03:44]
[14:03:44] *------------------------------*
[14:03:44] Folding@Home Gromacs SMP Core
[14:03:44] Version 1.74 (Mar- Assembly optimizations manually forced on.
[14:04:01] - Not checking prior termination.
[14:04:17] - Expanded 4731104 -> 24426905 (decompressed 516.3 percent)
[14:04:17] - Starting from initial work packet
[14:04:17]
[14:04:17] Project: 2665 (Run 3, Clone 672, Gen 135)
[14:04:17]
[14:04:20] Assembly optimizations on if available.
[14:04:20] Entering M.D.
[14:04:31] Rejecting checkpoint
[14:04:36]
[14:04:36] Writing local files
[14:04:38]
[14:04:38] Writing local files
[14:04:52] Extra SSE boost OK.
[14:04:54] Writing local files
[14:04:54] Completed 0 out of 250000 steps  (0 percent)
Thank you
Re: Project: 2665 (Run 2, Clone 913, Gen 131)
Since last database server update, our database is unavailable ... we can't check for credit/EUE anymore :(
